Old 28th December 2006, 13:35   #601  |  Link
buzzqw
HDConvertToX author
update www.64k.it/andres/data/a/AutoMKV064.exe
Changelog
ADDED: Save default now save name of final muxed file
ADDED: in command line input is now possibility to specify audio external (woking with m2v or d2v files)
es: AutoMKV.exe automkv.ini "c:\temp\_aaa.d2v" "c:\temp\_aaa.ac3" 0 0 0 start wait
ADDED: Totally reworked queued sections, now is similar to VirtualDub queue. For every work queued AutoMKV will produce an queueXXX.ini file, where XXX is the number of job
When user click start queue all queued job (not necessary all queueXXX.ini files) will be processed, and the corrisponding queueXXX.ini file deleted.
When AutoMKV start it will check for those queueXXX.ini files and if found will ask to process. In this way we have a permanently queue !
Those change are early beta (i am at home with the flu...) , i have done much test but never as yours
I want also all for the big support with all those not so stable build !
BHH
AutoMen: The Mencoder GUI
AutoWebM: supporting WebM/VP8
buzzqw is offline
Old 28th December 2006, 16:37   #602  |  Link
weaver4
buzzqw: What is the link to make a donation; I couldn't seem to find it.
weaver4 is offline
Old 28th December 2006, 17:02   #603  |  Link
fogbav
Integrated into Automkv - Main View - Button with "empty" text ( 8) ) left side from the about button ....
Opens up a new browser window ...
fogbav is offline
Old 28th December 2006, 17:02   #604  |  Link
SeeMoreDigital
Life's clearer in 4K UHD
SeeMoreDigital's Avatar
Where is it... Where is it?
SeeMoreDigital is online now
Old 28th December 2006, 17:15   #605  |  Link
weaver4
Oh...Thanks; don't I feel silly. I thought I had seen the link in this thread, so I looked for 20 minutes.
weaver4 is offline
Old 28th December 2006, 17:33   #606  |  Link
buzzqw
HDConvertToX author
for anyone that problem with donate button here is the LINK
i will add it to first topic
thanks!
BHH
buzzqw is offline
Old 28th December 2006, 23:33   #607  |  Link
killerhex
is mkv input allowed
killerhex is offline
Old 29th December 2006, 02:29   #608  |  Link
weaver4
I am still having problems with audio sync using constant quality xvid. I have run this movie through avi.net, autogk, dr divx, and MeGui and they all have the audio in sync. But in automkv the movie is out of sync by 90 seconds (audio is late by 90 seconds).
Here are the files.
Log file.
16:43:56 0.64 - - - - - - - - - - - - - START JOBS - - - - - - - - - - - - - -
16:43:56 Selected Input file: E:\Movies\Rips\MUMMY169\VTS_01_0.IFO
16:43:56 Selected Output dir: E:\Movies\temp\
16:43:56 Selected Container type: AVI
16:43:56 Selected Encoder: XviD
16:43:56 Selected Size: 1 CD
16:43:56 Selected Slice: 1
16:43:56 Selected Profile: XviD_CQ30.xml
16:43:56 Selected Width: 640
16:43:56 Selected Resizer: SimpleResize (neutral soft)
16:43:56 Selected Filters: RemoveGrain(mode=2)
16:43:56 Selected Deinterlacer: AUTO
16:43:56 NeroAACEnc.exe not present
16:43:56 Enabled CRF/CQ autoresize with value 3
16:43:56 Using Matrix: Sharktooth's EQM v3LR.cqm
16:43:56 Track Language 1: English (AC3 6ch, 0xBD 0x80) [0]
16:43:56 Audio Codec 1: Lame
16:43:56 Audio Quality 1: 6
16:43:56 Selected Unlimited media size
16:43:56 Starting Indexing
16:43:56 Dgindex CMD: C:\Downloads\AutoMKV\AutoMKV063\exe\dgindex\dgindex.exe -FO=0 -OM=1 -TN=1 -YR=2 -AIF=[E:\Movies\Rips\MUMMY169\VTS_01_1.vob] -OF=[E:\Movies\temp\movie] -exit -minimize
16:46:30 Finished indexing
16:46:30 Starting fixing audio delay on track number 1
16:46:30 DelayCut CMD: C:\Downloads\AutoMKV\AutoMKV063\exe\dgindex\Delaycut.exe -auto -out "E:\Movies\temp\fixed1.ac3" "E:\Movies\temp\movie T01 3_2ch 448Kbps DELAY 6ms.ac3"
16:47:07 Original 1' Audio Size: 419553792 bytes
16:47:08 Finished fixing audio delay
16:47:08 Encoding E:\Movies\temp\fixed1.ac3 To Mp3 with 6 quality
17:12:36 Encoded 1' Audio Track: 92157580 bytes
17:12:37 ForcedFilm applied: 99.900002% FILM found
17:12:44 Number of Frames: 179630
17:12:44 Framerate: 23.976025
17:12:44 Movie lenght in Seconds: 7493
17:12:44 Movie Width: 720
17:12:44 Movie Height: 480
17:12:44 CQ encoding XviD: C:\Downloads\AutoMKV\AutoMKV063\exe\encoder\xvid_encraw.exe -cq 3 -progress -threads 1 -max_bframes 2 -imax 31 -quality 6 -vhqmode 1 -qtype 0 -pmax 31 -bmax 31 -bquant_ratio 162 -bquant_offset 0 -nopacked -nochromame -noclosed_gop -bvhq -qmatrix "C:\Downloads\AutoMKV\AutoMKV063\profiles\XviD-profiles\matrix\Sharktooth's EQM v3LR.cqm" -i "E:\Movies\temp\movie.avs" -type 2 -avi "E:\Movies\temp\movie.avi"
19:32:17 Accepted values are between 697303040 and 741343232 bytes (movie+audio)
19:32:17 Got a file of size: 826162688 bytes + audio size 92157580 bytes (918320256)
19:32:17 Only Movie Size: 826162688 bytes
19:33:32 Final Muxed size: 922267154 bytes
19:33:32 Encoding finished: 02:49:36 elapsed time
19:33:32 -----------------------------------------------------------------------
19:33:32 Muxing Script
19:33:32 C:\Downloads\AutoMKV\AutoMKV063\exe\matroska\AVIMux_GUI.exe E:\Movies\temp\muxavi
19:33:32
19:33:32 CLEAR
19:33:32 LOAD E:\Movies\temp\movie.avi
19:33:32 LOAD E:\Movies\temp\audio.mp3
19:33:32 SELECT FILE 1
19:33:32 ADD VIDEOSOURCE
19:33:32 SET INPUT OPTIONS
19:33:32 SET OPTION MP3 VERIFY CBR NEVER
19:33:32 SET OPTION MP3 VERIFY RESDLG OFF
19:33:32 SET OUTPUT OPTIONS
19:33:32 WITH SET OPTION
19:33:32 OPENDML 0
19:33:32 RECLISTS 0
19:33:32 AUDIO INTERLEAVE 3 FR
19:33:32 AVI ADDJUNKBEFOREHEADERS 0
19:33:32 PRELOAD 200
19:33:32 WITH AUDIO
19:33:32 NAME 1 english
19:33:32 END WITH
19:33:32 OVERWRITEDLG 0
19:33:32 CLOSEAPP 1
19:33:32 DONEDLG 0
19:33:32 ALL AUDIO 1
19:33:32 LEGACY 0
19:33:32 RECLISTS 1
19:33:32 NUMBERING OFF
19:33:32 MAXFILESIZE OFF
19:33:32 END WITH
19:33:32 START E:\Movies\temp\movie_full.avi
19:33:32 Script AutoCrop.log
19:33:32
19:33:32 Crop(10,54,704,368)
19:33:32 Script Resmovie.avs
19:33:32
19:33:32 Script movie.avs
19:33:32
19:33:32 LoadPlugin("C:\Downloads\AutoMKV\AutoMKV063\exe\filter\autocrop.dll")
19:33:32 LoadPlugin("C:\Downloads\AutoMKV\AutoMKV063\exe\filter\blockbuster.dll")
19:33:32 LoadPlugin("C:\Downloads\AutoMKV\AutoMKV063\exe\filter\cnr2.dll")
19:33:32 LoadPlugin("C:\Downloads\AutoMKV\AutoMKV063\exe\filter\ColorMatrix.dll")
19:33:32 LoadPlugin("C:\Downloads\AutoMKV\AutoMKV063\exe\filter\Convolution3D.dll")
19:33:32 LoadPlugin("C:\Downloads\AutoMKV\AutoMKV063\exe\filter\corrector.dll")
19:33:32 LoadPlugin("C:\Downloads\AutoMKV\AutoMKV063\exe\filter\DctFilter.dll")
19:33:32 LoadPlugin("C:\Downloads\AutoMKV\AutoMKV063\exe\filter\Decomb.dll")
19:33:32 LoadPlugin("C:\Downloads\AutoMKV\AutoMKV063\exe\filter\Deen.dll")
19:33:32 LoadPlugin("C:\Downloads\AutoMKV\AutoMKV063\exe\filter\degrainmedian.dll")
19:33:32 LoadPlugin("C:\Downloads\AutoMKV\AutoMKV063\exe\filter\DGDecode.dll")
19:33:32 LoadPlugin("C:\Downloads\AutoMKV\AutoMKV063\exe\filter\EEDI2.dll")
19:33:32 LoadPlugin("C:\Downloads\AutoMKV\AutoMKV063\exe\filter\fft3dfilter.dll")
19:33:32 LoadPlugin("C:\Downloads\AutoMKV\AutoMKV063\exe\filter\FluxSmooth.dll")
19:33:32 LoadPlugin("C:\Downloads\AutoMKV\AutoMKV063\exe\filter\frfun7.dll")
19:33:32 LoadPlugin("C:\Downloads\AutoMKV\AutoMKV063\exe\filter\hqdn3d.dll")
19:33:32 LoadPlugin("C:\Downloads\AutoMKV\AutoMKV063\exe\filter\LeakKernelDeint.dll")
19:33:32 LoadPlugin("C:\Downloads\AutoMKV\AutoMKV063\exe\filter\MaskTools.dll")
19:33:32 LoadPlugin("C:\Downloads\AutoMKV\AutoMKV063\exe\filter\medianblur.dll")
19:33:32 LoadPlugin("C:\Downloads\AutoMKV\AutoMKV063\exe\filter\MipSmooth.dll")
19:33:32 LoadPlugin("C:\Downloads\AutoMKV\AutoMKV063\exe\filter\mt_masktools.dll")
19:33:32 LoadPlugin("C:\Downloads\AutoMKV\AutoMKV063\exe\filter\mvtools.dll")
19:33:32 LoadPlugin("C:\Downloads\AutoMKV\AutoMKV063\exe\filter\NicAudio.dll")
19:33:32 LoadPlugin("C:\Downloads\AutoMKV\AutoMKV063\exe\filter\RemoveGrain.dll")
19:33:32 LoadPlugin("C:\Downloads\AutoMKV\AutoMKV063\exe\filter\Repair.dll")
19:33:32 LoadPlugin("C:\Downloads\AutoMKV\AutoMKV063\exe\filter\SangNom.dll")
19:33:32 LoadPlugin("C:\Downloads\AutoMKV\AutoMKV063\exe\filter\SimpleResize.dll")
19:33:32 LoadPlugin("C:\Downloads\AutoMKV\AutoMKV063\exe\filter\TBilateral.dll")
19:33:32 LoadPlugin("C:\Downloads\AutoMKV\AutoMKV063\exe\filter\TDeint.dll")
19:33:32 LoadPlugin("C:\Downloads\AutoMKV\AutoMKV063\exe\filter\TIVTC.dll")
19:33:32 LoadPlugin("C:\Downloads\AutoMKV\AutoMKV063\exe\filter\TomsMoComp.dll")
19:33:32 LoadPlugin("C:\Downloads\AutoMKV\AutoMKV063\exe\filter\TTempSmooth.dll")
19:33:32 LoadPlugin("C:\Downloads\AutoMKV\AutoMKV063\exe\filter\UnDot.dll")
19:33:32 LoadPlugin("C:\Downloads\AutoMKV\AutoMKV063\exe\filter\UnFilter.dll")
19:33:32 LoadPlugin("C:\Downloads\AutoMKV\AutoMKV063\exe\filter\VSFilter.dll")
19:33:32 #loadpluginstart
19:33:32
19:33:32 #test1
19:33:32
19:33:32 Import("C:\Downloads\AutoMKV\AutoMKV063\exe\filter\MCBob_v03c.avsi")
19:33:32 Import("C:\Downloads\AutoMKV\AutoMKV063\exe\filter\mvbob.avsi")
19:33:32 Import("C:\Downloads\AutoMKV\AutoMKV063\exe\filter\QMF.avsi")
19:33:32 Import("C:\Downloads\AutoMKV\AutoMKV063\exe\filter\seesaw.avsi")
19:33:32 Import("C:\Downloads\AutoMKV\AutoMKV063\exe\filter\spresso.avsi")
19:33:32 #importstart
19:33:32
19:33:32 #test2
19:33:32
19:33:32 movie = mpeg2source("E:\Movies\temp\movie.d2v")
19:33:32 function getOrder(clip c) {
19:33:32 order = GetParity(c) ? 1 : 0
19:33:32 Return order }
19:33:32 #filter1start
19:33:32
19:33:32 #test3
19:33:32
19:33:32 #cropstart
19:33:32
19:33:32 cropclip = autocrop(movie,mode=0,wmultof=4,hmultof=4,samples=40,aspect=0,threshold=34,samplestartframe=0)
19:33:32 fixed_aspect = 1.185185
19:33:32 c_width = width(cropclip)
19:33:32 c_height = Round(height(cropclip) / fixed_aspect)
19:33:32 input_par = float(float(c_width)/float(c_height))
19:33:32 input_par = input_par > 1.4 ? input_par : (4.0/3.0)
19:33:32 out_width = 640
19:33:32 out_height = Round(float(out_width) / input_par)
19:33:32 hmod = out_height - (floor(out_height / 16 ) * 16)
19:33:32 out_height = (hmod > 4) ? (out_height + (16 - hmod)) : (out_height - hmod)
19:33:32 new_aspect = (float(out_width) / float(out_height)) / fixed_aspect
19:33:32 autocrop(movie,mode=0,wmultof=4,hmultof=4,samples=40,aspect=new_aspect,threshold=34,samplestartframe=0)
19:33:32
19:33:32 #resizestart
19:33:32
19:33:32 #test4
19:33:32
19:33:32 SimpleResize(out_width,out_height)
19:33:32 #filter2start
19:33:32
19:33:32 #test5
19:33:32
19:33:32 RemoveGrain(mode=2)
19:33:32 Script mkvmaudio.avs
19:33:32
19:33:32 NicAC3Source("E:\Movies\temp\fixed1.ac3")
19:33:32 EnsureVBRMP3Sync()
19:33:32 ConvertAudioTo16bit()
19:33:32 #Applyed STEREO downmixing routines
19:33:32 function stereo(clip a)
19:33:32 {
19:33:32 fl = GetChannel(a, 1)
19:33:32 fr = GetChannel(a, 2)
19:33:32 c = GetChannel(a, 3)
19:33:32 lfe = GetChannel(a, 4)
19:33:32 sl = GetChannel(a, 5)
19:33:32 sr = GetChannel(a, 6)
19:33:32 l_sl = MixAudio(fl, sl, 0.2929, 0.2929)
19:33:32 c_lfe = MixAudio(lfe, c, 0.2071, 0.2071)
19:33:32 r_sr = MixAudio(fr, sr, 0.2929, 0.2929)
19:33:32 l = MixAudio(l_sl, c_lfe, 1.0, 1.0)
19:33:32 r = MixAudio(r_sr, c_lfe, 1.0, 1.0)
19:33:32 Return MergeChannels(l, r).Normalize()
19:33:32 }
19:33:32 #
19:33:32 function original(clip a)
19:33:32 {
19:33:32 Normalize(a)
19:33:32 Return last
19:33:32 }
19:33:32 6==Audiochannels() ? stereo() : original()
19:33:32 Script mkvmaudio.bat
19:33:32
19:33:32 "C:\Downloads\AutoMKV\AutoMKV063\exe\besweet\bepipe.exe" --script "Import(^E:\Movies\temp\mkvmaudio.avs^)" | "C:\Downloads\AutoMKV\AutoMKV063\exe\besweet\lame.exe" -v --vbr-new -h -S -V 6 - "E:\Movies\temp\audio.mp3"
19:33:32 Script mkvmaudio2.avs
19:33:32
19:33:32 Script mkvmaudio2.bat
19:33:32
19:33:32
19:33:32 - - - - - - - - - - - - FINISHED JOBS - - - - - - - - - - - - - - - - -
Profile.
<?xml version="1.0" ?>
- <VideoProfile xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:xsd="http://www.w3.org/2001/XMLSchema">
<Name>cq</Name>
- <Settings xsi:type="xvidSettings">
<EncodingMode>1</EncodingMode>
<BitrateQuantizer>3</BitrateQuantizer>
<KeyframeInterval>300</KeyframeInterval>
<NbBframes>2</NbBframes>
<MinQuantizer>2</MinQuantizer>
<MaxQuantizer>31</MaxQuantizer>
<Turbo>false</Turbo>
<V4MV>false</V4MV>
<QPel>false</QPel>
<Trellis>true</Trellis>
<CreditsQuantizer>12</CreditsQuantizer>
- <FourCCs>
<string>XVID</string>
<string>DIVX</string>
<string>DX50</string>
<string>MP4V</string>
</FourCCs>
<Logfile>.stats</Logfile>
<CustomEncoderOptions />
<FourCC>0</FourCC>
<Zones />
<MaxNumberOfPasses>2</MaxNumberOfPasses>
<NbThreads>1</NbThreads>
<MotionSearchPrecision>6</MotionSearchPrecision>
<VHQMode>1</VHQMode>
<QuantType>0</QuantType>
<MinPQuant>2</MinPQuant>
<MaxPQuant>31</MaxPQuant>
<MinBQuant>2</MinBQuant>
<MaxBQuant>31</MaxBQuant>
<BQuantRatio>162</BQuantRatio>
<BQuantOffset>0</BQuantOffset>
<KeyFrameBoost>10</KeyFrameBoost>
<KeyframeThreshold>1</KeyframeThreshold>
<KeyframeReduction>20</KeyframeReduction>
<OverflowControlStrength>5</OverflowControlStrength>
<MaxOverflowImprovement>5</MaxOverflowImprovement>
<MaxOverflowDegradation>5</MaxOverflowDegradation>
<HighBitrateDegradation>0</HighBitrateDegradation>
<LowBitrateImprovement>0</LowBitrateImprovement>
<ReactionDelayFactor>16</ReactionDelayFactor>
<AveragingPeriod>100</AveragingPeriod>
<FrameDropRatio>0</FrameDropRatio>
<RateControlBuffer>0</RateControlBuffer>
<VbvPeakRate>0</VbvPeakRate>
<VbvMaxRate>0</VbvMaxRate>
<VbvBuffer>0</VbvBuffer>
<PackedBitstream>false</PackedBitstream>
<GMC>false</GMC>
<ChromaMotion>true</ChromaMotion>
<ClosedGOP>true</ClosedGOP>
<VHQForBframes>true</VHQForBframes>
<AdaptiveQuant>true</AdaptiveQuant>
<Greyscale>false</Greyscale>
<Interlaced>false</Interlaced>
<BottomFieldFirst>true</BottomFieldFirst>
<LumiMasking>false</LumiMasking>
<BframeThreshold>0</BframeThreshold>
<CustomQuantizerMatrix>extra\Sharktooth's EQM v3LR.cqm</CustomQuantizerMatrix>
</Settings>
</VideoProfile>
The Mux File
CLEAR
SELECT FILE 1
ADD VIDEOSOURCE
SET INPUT OPTIONS
SET OUTPUT OPTIONS
WITH SET OPTION
OPENDML 0
RECLISTS 0
PRELOAD 200
WITH AUDIO
NAME 1 english
END WITH
OVERWRITEDLG 0
CLOSEAPP 1
DONEDLG 0
ALL AUDIO 1
LEGACY 0
RECLISTS 1
NUMBERING OFF
MAXFILESIZE OFF
END WITH
weaver4 is offline
Old 29th December 2006, 02:56   #609  |  Link
weaver4
After looking at this some more it appears that audio gets out of sync further as the movie proceeds.
I played both the autogk and automkv version in MPC and here are the properties.
------ AutoGK
Video: XVID 640x288 23.98fps [Stream 00]
Audio: MPEG Audio Layer 3 48000Hz stereo 160Kbps [Stream 01]
------ AutoMKS
Video: XVID 640x288 25.00fps [Stream 00]
Audio: MPEG Audio Layer 3 44100Hz stereo 97Kbps [01) english]
weaver4 is offline
Old 29th December 2006, 10:42   #610  |  Link
SeeMoreDigital
------ AutoGK
------ AutoMKS
First.... Can you confirm whether your MPEG-2 source is PAL or NTSC?
Old 29th December 2006, 10:49   #611  |  Link
buzzqw
HDConvertToX author
My Kudos to Weaver4 !
YOU have resolved !!!
the source if fully FILM so automkv (as autogk) will ForceFilm in dgindex !
BUT xvid_encraw isn't able to recognize the framerate ! and so put 25 fps as default value
www.64k.it/andres/data/a/AutoMKV064a.exe
ADDED: -framerate to xvid_encraw command line
FIXED: lot's of bugs in queue mode
FIXED: is now possible to delete single job
for your patience (and Contribute!)
BHH
buzzqw is offline
Old 29th December 2006, 13:52   #612  |  Link
dssgorila
I used to the psp profile to create a encode a video for my psp. but when I copied to the psp and tried to play the file i get Unsupported Data. the only thing i can think of is the file has a res of 704x304 not sure if the psp can play that res. I thought choosing the psp template would configure the video for psp spec. Am i missing something?
dssgorila is offline
Old 29th December 2006, 13:55   #613  |  Link
fogbav
Hi Buzzqw,
think a path error is back again ... i am encoding a m2v in path
d:\ace4.0\tmp\film.m2v
but xvid_encraw has following params :
D:\ACE4.0\temp>"D:\ACE4.0\exe\encoder\xvid_encraw.exe" -pass1 -progress -bitrate
1514 -turbo -threads 1 -max_bframes 2 -imax 16 -qpel -quality 6 -vhqmode 3 -pma
x 16 -bmax 16 -framerate 25.000000 -bquant_ratio 162 -chigh 20 -clow 7 -nopacked
-nochromame -noclosed_gop -bvhq -qmatrix "D:\ACE4.0\profiles\XviD-profiles\matrix\Sharktooth's EQM v3LR.cqm" -i "D:\ACE4.0\temp\movie.avs" -type 2 -avi "D:\ACE4.0\temp\movie_firstpass.avi"
so the temp path is one directory above the real path ... is this a new planed change ?
muxxing to final mp4 container is also wrong :
"D:\ACE4.0\exe\matroska\mp4box.exe" -add "D:\ACE4.0\temp\movie.avi"ar=2.392523 -chap "D:\ACE4.0\exe\chapters.txt" -fps 25.000000 "D:\ACE4.0\temp\movie.mp4"
it should go into d:\ace4.0\tmp\movie.mp4 ....
so final movie.mp4 ends up in
d:\ace4.0\temp\movie.mp4
and not in
fogbav is offline
Old 29th December 2006, 14:27   #614  |  Link
buzzqw
HDConvertToX author
could please post the first 10 lines of log ?
and the first lines of automkv.ini ?
i tryed from command line (m2v, no audio, xvid into mp4) and no got error
this is my log (as example)
14:22:20 0.64a  - - - - - - - - - - - - - START JOBS - - - - - - - - - - - - - -
14:22:20 Selected Input file:     c:\Programmi\PureBasic4\AutoMKV\test\Sample_1.demuxed.m2v
14:22:20 Selected Output dir:     C:\Programmi\PureBasic4\AutoMKV\test\temp\
and this is the mux line
14:22:29 C:\Programmi\PureBasic4\AutoMKV\exe\matroska\mp4box.exe -add "C:\Programmi\PureBasic4\AutoMKV\test\temp\movie.avi":par=1.367521  -chap "C:\Programmi\PureBasic4\AutoMKV\exe\chapters.txt"   -fps 29.970030 "C:\Programmi\PureBasic4\AutoMKV\test\temp\movie.mp4"
and this is part of automkv.ini
; AutoMKV default parameters
; If AutoMKV.ini is present then specified parameters will be loaded
[AutoMKV]
Input Folder = C:\Programmi\PureBasic4\AutoMKV\test\
Output Folder = C:\Programmi\PureBasic4\AutoMKV\test\
Container = MP4
EDIT: and this is the command line used
C:\Programmi\PureBasic4\AutoMKV>AutoMKV064a.exe automkv.ini c:\Programmi\PureBasic4\AutoMKV\test\Sample_1.demuxed.m2v" 0 0 0 0 start wait
thanks
BHH
buzzqw is offline
Old 29th December 2006, 14:43   #615  |  Link
fogbav
Sorry BuzzQW ... my first wrong bug ...8)
Movie.mp4 is created in d:\ace4.0 dir ...
only thing changed from last version is that the temp directory is now created on another place ...
and ...
i have to select in automkv.ini the destination folder ...
so i change my script ...
Sorry again ...
fogbav is offline
Old 29th December 2006, 15:15   #616  |  Link
buzzqw
HDConvertToX author
@fogbav
try this build www.64k.it/andres/data/a/AutoMKV064b.exe
if dest folder is specified then is used, if not will be muxed where is the input file (and the work is done is inputfile\temp folder)
BHH
buzzqw is offline
Old 29th December 2006, 15:23   #617  |  Link
fogbav
Yeah ... thats the one i need ...8)
Thhaanks ... greater for scripting purposes ...8)
Edit : Works perfect again ... thanks !
fogbav is offline
Old 30th December 2006, 00:52   #618  |  Link
weaver4
BHH
I just checked this version....and the audio is in sync!!!! Great JOB!
weaver4 is offline
Old 30th December 2006, 16:16   #619  |  Link
weaver4
If you add CQ encoding (either XviD or x264) to the queue and then press the start queue button the dialog box for "go unlimited" comes up twice before each job. This is really annoying because before each job it stops while it waits for me to answer this dialog.
Also, I know this was mentioned a few months ago but AutoMKV application still disappears when you are running a queue. This makes it very difficult to see the log.
weaver4 is offline
Old 30th December 2006, 18:04   #620  |  Link
buzzqw
HDConvertToX author
www.64k.it/andres/data/a/AutoMKV064c.exe
FIXED: when adding files to queue now is saved "Hit Media Size/Go Unlimited" (thanks to weaver4)
About: window... i am working on it
BHH
buzzqw is offline
