12th March 2016, 01:56 | #36823 | Link | |
12th March 2016, 02:18 | #36826 | Link |
I had to increase my CPU and GPU queue depths from 4 (my old setting, the minimum allowed) to 8 and activate the "alternative glitch handling" in order to get smooth 3D playback (otherwise, it stuttered like hell with my i5-2500K + 290X + Win10 system).
But now, it works unsurprisingly well (MPC-HC + madVR changed to 3D a lot faster and smoother than PowerDVD [which ends up in 3D with a 50-50 chance after vibrating the screen for several seconds]). Thank you for this! (Even if 3D is going out of the TV business, I didn't care to watch any 3D content since late 2012, so I have some movies to attend to for this special occasion ). Separate 3DLUTs would be welcomed though (2D/3D) because my plasma TV behaves extremely differently in 3D mode (but considering how scarce the 3D materials are, it's not that painful to change this manually). |
12th March 2016, 02:19 | #36827 | Link |
I don't think so.
If you use the old params, you get rid of all aliasing. No need of specific code to get rid of it. What could upgrade sxbr would be a way to squeeze edge gradients. I've read some papers about it: Source 1, Source 2, Source 3, Source 4, but don't know how to implement a fast way to do it. |
12th March 2016, 05:59 | #36828 | Link | |
madshi, NNEDI3 quadrupling is broken with 720 res content. Regarding max line thinning, since all upscaling refinement options max at 4 I assume you'll just change the degree of strength per point rather than changing the max value like I suggested. I think you could increase it per point by 25-50%, users would need to update their settings.. but it keeps it all in line then. Last edited by ryrynz; 12th March 2016 at 11:16. |
12th March 2016, 12:17 | #36829 | Link |
Subtitles position
Hi everyone,
When using MadVR with XySubFilter to display subtitles outside of the video area with the option "move subtitles to bottom of the screen/window" of the "zoom control" menu, when an italic subtitle appears (<i> tag), the italic subtitle and all the following subtitles are displayed into active video area. Can this bug be fixed by madVR ? Example with a normal subtitle : Here comes the italic subtitle : All the following subtitles are placed like this : Last edited by Neo-XP; 12th March 2016 at 12:33. Reason: Precision |
12th March 2016, 13:16 | #36832 | Link |
Doubling 720 to 1080p already super samples, I doubt there is much of an improvement to be seen further, not to mention that doubling 1440p once more would be extremely expensive.
12th March 2016, 13:23 | #36834 | Link | |
I would like to know what alternative glitch hadling does, I have it unckecked. If you have any questions please feel free to ask me. |
12th March 2016, 14:29 | #36837 | Link | |
12th March 2016, 15:57 | #36838 | Link |
madshi, continuing the discussion from AVS, may I suggest some idea about HDR to SDR conversion;
If reference white is still 100 nit then everything below it should look the same for HDR and SDR. If you will, you can try to tweak your algorithm so that 90 nit and below remains the same (unchanges) and the last 10 nit will compress all the data from the HDR video. The ratio can be changed for example 70 and 30, but the point is that the lower part should remain unchanged, or mostly unchanged. Your algo as you mentioned also fixes the colors as it compresses HDR to SDR but I don't know how it will work out with the way I suggested, if at all, thugh it may not matter that much because only the last 10 or 30 nit will have to remap. From what I see now with the current algorithm even the darkest parts like night sky form Life of Pi HDR demo changes. The night sky in this demo only look black as they should when I select 1,300 nits for my display which matches the mastering display from the metadata.
System: i7 3770K, GTX660, Win7 64bit, Panasonic ST60, Dell U2410. Last edited by James Freeman; 12th March 2016 at 16:18. |
12th March 2016, 16:27 | #36839 | Link |
If you could post the subtitle file, and the settings.bin from the madVR folder to some web upload service (I use wikisend as it's fast and free of dangerous and intrusive ads, but anything else can be used instead), and also take screenshots with the madVR OSD active (Ctrl + J) so that your scaling settings are visible, that will likely help. |
