Old 17th March 2011, 21:54   #11021  |  Link
Vilous
Originally Posted by Snowknight26 View Post
Out of space on your G drive? Tried changing output formats? What about input formats?
First, I appreciate all efforts here.
That said, as I mentioned above, G has tons of room (over 2.5 TB free)
I can't really change the input format, the input format is the movie.
I can try to adjust the output format, and report back what happens. I'm not sure how it will help me if that works though.
-Vilous
Vilous is offline
Old 17th March 2011, 22:11   #11022  |  Link
Snowknight26
Try a different one if you can.
Try to do each extraction separately to see if a certain one stalls eac3to's progress.
Is the drive you're outputting to a RAID? It could be Haali Media Splitter's gdsmux not liking the drive. I've had an issue where eac3to couldn't write more than ~2MB an MKV on one of my RAIDs. The only solution was to switch RAID controllers/recreate the array. Never figured out exactly what caused it but it might be worthwhile to investigate.
Snowknight26 is offline
Old 18th March 2011, 01:04   #11023  |  Link
Vilous
The drive is not RAID. So that's not the issue.
I'm running some additional tests, the hangs appears to be in the creation of the mkv file. It does not hang when just creating the .w64 file.
So I ran -test and noticed that, despite Haali being installed and recognized, it says MkvToolnix is not installed.
I never installed that tool in the past, is it actually needed?
Vilous is offline
Old 18th March 2011, 01:19   #11024  |  Link
Snowknight26
No, it's not used for MKV muxing.
Try remuxing the file with gdsmux (in your Haali Media Splitter directory). Chances are it won't work either, in which case it's not an eac3to issue.
Old 18th March 2011, 01:42   #11025  |  Link
Vilous
You are correct. It did not. It got hung up in a very similiar manner.
Any suggestions as to a good forum to seek support for this issue?
Thanks,
-Vilous
Vilous is offline
Old 18th March 2011, 20:52   #11026  |  Link
Snowknight26
This one, but it's hopeless. I don't think Haali reads the forums anymore so don't expect it to ever be fixed. The only alternate is to output to a different drive.
Old 19th March 2011, 01:55   #11027  |  Link
Qriist
Thank you for this tool. It is very useful.
I request a couple features, however.
1: A command parameter to demux a given file without demuxing the video. "-demux novideo"
2: The ability to output a plain-text list of all produced files from demux or mkv conversion. "-makelist"
Example list inside Movie1.txt:
video > c:\folder\movie1 - 2 - VC-1, 1080p24.vc1
audio > c:\folder\movie1 - 3 - DTS Master Audio, English, 5.1 channels, 24 bits, 48kHz.dtsma
subtitle > c:\folder\movie1 - 4 - Subtitle (PGS), English.sup
subtitle > c:\folder\movie1 - 5 - Subtitle (PGS), Spanish.sup
subtitle > c:\folder\movie1 - 6 - Subtitle (PGS), French.sup
Please and thank you.
Please keep up the good work.
Qriist is offline
Old 21st March 2011, 00:27   #11028  |  Link
Sparktank
47.952fps@71.928Hz
Sparktank's Avatar
I have been using this tool for awhile. I really like it.
And I try to prowl around this thread for information.
I find enough to get done what I want to do.
I even use the Google search function to try narrow my search.
But some things are just difficult to solve.
For instance...
When I use the -demux command, it doesn't demux to same folder as the source (most cases ".m2ts" files).
Instead it demuxes files to my Documents...
WinXP
"C:\Documents and Settings\(username)\files.*"
Vista
"C:\Users\(username)\files.*"
I have to copy the files to the desired folder.
And when I do use the command to demux to a different folder, it saves the files in the desired folder and the Documents folder, too.
Is this normal behavior? (in both cases)
Edit:
Scenario one: Demuxing without setting parameter for new folder
eac3to v3.24
command line: "D:\Apps\eac3to\eac3to.exe" "E:\Work\Bram Stoker's Dracula (Trailer)\MainMovie\DRACULA_TRAILER\BDMV\STREAM\00112.m2ts" -demux
M2TS, 1 video track, 1 audio track, 0:01:28, 24p /1.001
1: MPEG2, 1080p24 /1.001 (16:9)
2: AC3 Surround, English, 2.0 channels, 192kbps, 48kHz, dialnorm: -29dB
[v01] Extracting video track number 1...
[a02] Extracting audio track number 2...
[a02] Removing AC3 dialog normalization...
[v01] Creating file "00112 - 1 - MPEG2, 1080p24.m2v"...
[a02] Creating file "00112 - 2 - AC3 Surround, English, 2.0 channels, 192kbps, 48kHz.ac3"...
Video track 1 contains 2119 frames.
eac3to processing took 12 seconds.
Done.
Saved demuxed files to Documents and not the original folder of the .m2ts file.
Log file is present in documents with demuxed files (named after the .m2ts file) & the eac3to folder as well (simply named "log.txt")
Scenario two: Demuxing to a new folder
eac3to v3.24
command line: "D:\Apps\eac3to\eac3to.exe" "E:\Work\Bram Stoker's Dracula (Trailer)\MainMovie\DRACULA_TRAILER\BDMV\STREAM\00112.m2ts" "E:\Work\Bram Stoker's Dracula (Trailer)(eac3to demuxed)\.*" -demux
[v01] Creating file "E:\Work\Bram Stoker's Dracula (Trailer)(eac3to demuxed)\ - 1 - MPEG2, 1080p24.m2v"...
[a02] Creating file "E:\Work\Bram Stoker's Dracula (Trailer)(eac3to demuxed)\ - 2 - AC3 Surround, English, 2.0 channels, 192kbps, 48kHz.ac3"...
eac3to processing took 21 seconds.
Done.
Saved demuxed files to Documents & the designated folder.
Log files present in the designated folder & the eac3to folder but not the Documents folder.
Sparktank is offline
Old 21st March 2011, 01:53   #11029  |  Link
Midzuki
Unavailable
Midzuki's Avatar
@ Sparktank:
eac3to is a command-line application, so, by default, it outputs its results to the current working directory — which, by default, is the <opinion>stupid</opinion> user's homepath. The "best" policy is 1) include eac3to's directory in the PATH environment-variable, and 2) open the command-prompt directly in the target-folder (easy with Vista and Seven, requires registry-editing in XP).
Midzuki is offline
Old 21st March 2011, 02:06   #11030  |  Link
Sparktank
47.952fps@71.928Hz
Sparktank's Avatar
thanks for the info.
I just extracted eac3to a working folder when i first downloaded it.
I'll have a look into these options.
Old 26th March 2011, 10:38   #11031  |  Link
Joniii
Is this something to worry about and why these errors occur exactly (main movie in this Blu-ray is splitted on several m2ts files on the disc)?
[v02] Extracting video track number 2...
[a04] Extracting audio track number 4...
[a04] Creating file "d:\gl.dts"...
[v02] Creating file "d:\gl.h264"...
[a04] Audio overlaps for 9ms at playtime 0:17:14.  <WARNING>
[a04] Audio overlaps for 5ms at playtime 0:18:58.  <WARNING>
[a04] Audio overlaps for 8ms at playtime 0:32:51.  <WARNING>
[a04] Audio overlaps for 6ms at playtime 0:54:09.  <WARNING>
[a04] Audio overlaps for 5ms at playtime 0:58:03.  <WARNING>
[a04] Audio overlaps for 7ms at playtime 1:11:07.  <WARNING>
[a04] Audio overlaps for 5ms at playtime 1:26:02.  <WARNING>
[a04] Audio overlaps for 6ms at playtime 1:44:18.  <WARNING>
[a04] Audio overlaps for 12ms at playtime 1:52:11.  <WARNING>
[a04] Audio overlaps for 6ms at playtime 2:04:42.  <WARNING>
[a04] Audio overlaps for 7ms at playtime 2:10:04.  <WARNING>
[a04] Audio overlaps for 11ms at playtime 2:15:25.  <WARNING>
[a04] Audio overlaps for 8ms at playtime 2:24:38.  <WARNING>
[a04] Audio overlaps for 8ms at playtime 2:25:29.  <WARNING>
[a04] Audio overlaps for 8ms at playtime 2:31:13.  <WARNING>
[a04] Audio overlaps for 8ms at playtime 2:34:06.  <WARNING>
[a04] Audio overlaps for 7ms at playtime 2:43:40.  <WARNING>
[a04] Starting 2nd pass...
[a04] Realizing DTS gaps...
Video track 2 contains 245919 frames.
eac3to processing took 13 minutes, 11 seconds.
Done.
Windows 10 Pro 2004 with Media Center, 2 x DVB-C with cable cards
MPC-HC (madVR, LAV Filters, XySubFilter)
Sony Bravia 85X950H/85XH95
Yamaha RX-V685
Yamaha Piano Black NS-777/555/C444/YST-SW315
Joniii is offline
Old 26th March 2011, 19:38   #11032  |  Link
krosswindz
I have question on the following two options of eac3to. Can one use these options to convert audio length to match the fps of the video. Basically if I have a audio from a NTSC DVD (23.976fps) then I can use the -changeTo24.000 option to convert it so that I can use it with video from a Blu-ray (24fps).
-23.976/...        define source fps to be "23.976", "24.000", "25.000", ...
-changeTo24.000    change source fps to "23.976", "24.000", "25.000", ...
krosswindz is offline
Old 27th March 2011, 00:01   #11033  |  Link
henryho_hk
Doesn't Blu-ray's "24" also mean 23.976fps?
henryho_hk is offline
Old 27th March 2011, 00:57   #11034  |  Link
tebasuna51
tebasuna51's Avatar
Yes.
No.
tebasuna51 is offline
Old 27th March 2011, 02:52   #11035  |  Link
sneaker_ger
Well, most of the time "1080p24" actually means 24/1.001 fps in the Blu-Ray world, but tebasuna51 is correct in that Blu-Ray supports both 24/1.000 and 24/1.001 fps.
sneaker_ger is offline
Old 27th March 2011, 04:09   #11036  |  Link
krosswindz
Yes.
I used the following command line to do the conversion, I find that the runtime of the audio is still the same as the original. Am I doing something wrong or will the audio and video be in sync. The video runtime for the DVD and Blu-ray source are different.
\path\to\eac3to.exe src.ac3 dest.ac3 -448 -23.976 -changeTo24.000 +1000ms -log=log.txt
Old 27th March 2011, 08:59   #11037  |  Link
Sharc
Try
\path\to\eac3to.exe src.ac3 dest.ac3 -448 -24.000 +1000ms -log=log.txt
Sharc is offline
Old 27th March 2011, 12:21   #11038  |  Link
tebasuna51
tebasuna51's Avatar
I used the following command line to do the conversion:
Only if the runtime is 0:16:41.000
We can't know. Put exact runtime or number of frames.
Try
Here the parameter -24.000 does nothing.
Old 27th March 2011, 17:47   #11039  |  Link
krosswindz
dvd video (23.976fps) runtime is: 10619286 ms
blu-ray video (24fps) runtime is: 10631458 ms
When I used the converted audio while muxing if I add suitable delay it starts of in sync and loses sync progressively.
Old 27th March 2011, 18:09   #11040  |  Link
jj666
You can't normally just take a DVD track and expect it to fit with BD (slowed down or not) - Audition or similar is needed to do a waveform comparison to check for initial delay and any necessary cuts/inserts.
Cheers,
-jj-
jj666 is offline
eac3to
