10th April 2008, 14:48 | #4241 | Link |
I have done this as well converting it to dts in 1 step and get the same results. It took 1 sec because its a small test file i use from ghost rider and as far as the .wav with no name that doesnt really matter at this piont its a test and no more.
10th April 2008, 15:16 | #4242 | Link | |
One good one though is Mission Impossible iii, where the first is @00:44:02. The Simpson's movie is great - it has just has two subtitles (forced), for some tweating birds - "We're going to need more birds." and for "Santa's Little Helper" - , "I did things no dog should do". The first is @00:47:18 . That is Blu-ray so doesn't really count, but you can see that it is inevitable this will (and does) happen. We need a way of trapping it. For DVDs I check with PgcEdit to see if there is a forced stream and if so make sure I rip it, and force it. It should be possible to interrogate HD-DVD in the same way. Isn't it?! Last edited by Jong; 10th April 2008 at 15:54. |
10th April 2008, 15:24 | #4243 | Link | ||
@Madshi, Thanks very much for your replies.
Yep, but my problem is that if I use "eac3to f:\ 1)" to simply get a stream listing I am not specifying a destination directory! Could we add it like "eac3to f:\ 1) c:\destination\log.txt" or even just "eac3to f:\ 1) c:\destination" Last edited by Jong; 10th April 2008 at 15:47. |
10th April 2008, 17:33 | #4244 | Link | |
If you chose the LPCM track, then the most overlap you will get between segments is 5 ms. So, in the case of rat, there are 8 or so (I can't remember exactly), which means you will get, at most, 40 milliseconds of audio desynchronization. And most people will not notice that. But if you listen to the AC3 track (up to 32 ms overlap is possible), I bet you will get a desync of 100-200 ms by the end of the movie, and you WILL notice that. |
10th April 2008, 20:09 | #4246 | Link |
You can also try xport to demux the pcm audio and then eac3to to encode to dts. Xport worked for many people before.
You didn't tell (or at least i can't find) what happened with the pcm to wav convertion. Does the wav sound ok? |
10th April 2008, 20:15 | #4247 | Link | |
No even the demuxed mono wav files sound bad and i tried xport like you said but it didnt work, it was saying error or bad frame something like that all the way through it. I really want to be able to do this i have many movies with pcm and this is the only one i have tried to convert a pcm track, i did the truehd from this movie with no problems at all sounds great but have many movies that have just pcm and would like to convert them. Although no i did not try to demux the pcm from the movie file it self with xport maybe ill try that instead. I demuxed the pcm with tsremux i thought that was the same. Last edited by DoomBot; 10th April 2008 at 20:18. |
10th April 2008, 20:28 | #4248 | Link | ||
The best way is to not use TsRemuxer for PCM demuxing because TsRemux is known to make problems with PCM tracks. Use xport or eac3to for demuxing. If you use eac3to, you can even demux and save to WAVs in one step. |
10th April 2008, 20:41 | #4249 | Link |
I would not describe it as urgent by any means at all, but have a look at my guide. I want to get a stream list before doing any demuxing. It is simply inelegant to have to dig this one log file out of the eac3to program folder when all other working files are somewhere else.
Logically it would make sense to be able to type "eac3to f:\ 1) c:\destination\log.txt" and have it stick the list where the others are. By the way, it might also be good if it included the title number in the name automatically e.g. "log(1).txt" so working on a second ot third title does not overwrite the stream list. But, I do agree this is all third or fourth order stuff! |
10th April 2008, 23:43 | #4251 | Link |
Just FYI, you can use Goldwave to play raw LPCM files if there are only two channels. In xport, there's an option to output only two channels for this.
xport -h2 00052.m2ts 1 1 1 Then in Goldwave, when you open bits0001.mpa, chose file type: raw, attributes: PCM signed 16 or 24 bit, big endian, stereo and rate: 48000 in the File Format dialog box. Ron
HD MPEG-2 Test Patterns http://www.w6rz.net |
11th April 2008, 11:20 | #4253 | Link |
Concerning lpcm:
I have had problems demuxing that with both tsremux and tsmuxer, the results were not accepted by eac3to. Now that eac3to allows demuxing of m(2)ts, this might no longer be a problem. If, for some reason, eac3to should fail demuxing, you can try the following: Remux your files to m2ts using tsmuxer or tsremux and then use xport to demux audio or video. The resulting files should be accepted by eac3to. This has saved my day quite a few times for several audio and video formats. |
11th April 2008, 22:08 | #4257 | Link |
another little request, would it be possible to demux the truehd track (or both tracks) from an already demuxed blu-ray truehd/ac3 track, which has been created with xport? so basically a function which seperates both tracks in order to get rid of the interconnected .ac3. or can this demuxing only be done from the .evo or .m2ts source?
edit: while -demux doesnt work, i see that just specifying the truehd track as input and output seem to do this job already, am I right or would that output be somehow different if demuxing would be done from the source? Last edited by Thunderbolt8; 11th April 2008 at 22:11. |
11th April 2008, 23:23 | #4258 | Link | |
xport -h filename.m2ts 1 1 1 The -h is critical for .m2ts files. Otherwise, you get a zillion errors. A couple of tricks: 1) Put xport.exe in c:\windows. That will make it work in any directory. 2) If you're not getting the audio track that you want, you can abort xport (or any command line program) with Ctrl-c. You don't have to wait for it to finish. Ron
12th April 2008, 05:15 | #4259 | Link | |
Thank you for the reply. I converted TrueHD -> AC-3 like you suggested. The channel mapping was correct through mplayer (ubuntu - primary os). I then moved on and booted into Vista and tried another movie (300) with TrueHD converted to FLAC. This time using MPC HC with the madFLAC filter. The channel mapping was correct! Tried the same file in VLC (windows) and the channel mapping was wrong just like the ubuntu mplayer. I believe mplayer and VLC use the same ffmpeg for decoding. Is this the problem? Are there different flac decoding filters out there? I figured out that mplayer has the channels correct when I use eac3to with "-0,1,4,5,2,3". I had to do this with both 300 and Constantine. Something is not right here... What do you recommend I do next? Thanks, PBjr. UPDATE: I think I figured it out. It's with mplayer. Found this in the documentation. 3.6.2.1. General information Unfortunately, there is no standard for how channels are ordered. The orders listed below are those of AC-3 and are fairly typical; try them and see if your source matches. Channels are numbered starting with 0. surround 5.1 0. left front 1. right front 2. left rear 3. right rear 4. center front 5. subwoofer Last edited by pbjr; 13th April 2008 at 01:31. |
12th April 2008, 06:14 | #4260 | Link |
First post here. I'm a bit confused (or possibly running into issues) trying to take TrueHD and convert it to DTS. The process runs fine in eac3to and then I use mkvmerge to take and patch video and audio files together again.
Problem is when I go to run the mka file in MPC it doesn't work. I can run .evo's fine, but anything converted just hangs. Any ideas to why this is? I'm new to all of this and most of the information is very helpful. Thanks! |
eac3to |
