Old 28th April 2020, 08:31   #1441  |  Link
MeteorRain
結城有紀
I'm on B450 + Ryzen 3600 + GTX 1650S and I feel like it's pretty future proof.
Projects
x265 - Yuuki-Asuna-mod Download / GitHub
TS - ADTS AAC Splitter | LATM AAC Splitter | BS4K-ASS
Neo AviSynth+ filters - F3KDB | FFT3D | DFTTest | MiniDeen | Temporal Median
MeteorRain is offline   Reply With Quote
Old 28th April 2020, 08:49   #1442  |  Link
tormento
Acid fr0g
tormento's Avatar
Originally Posted by Boulder View Post
AVX2 performance was increased substantially compared to the first-gen Ryzens.
Zen 2 is a terrific architecture but about AVX2, that is sort of “emulated”. There are many articles about this topic, look at them if interested.
@turment on Telegram
Old 28th April 2020, 09:07   #1443  |  Link
Boulder
Pig on the wing
Boulder's Avatar
I'm not sure I follow you. The first-gen Zen did some tricks which is why it was quite poor in AVX2. The current gen has full AVX2 support.
https://forum.doom9.org/showthread.php?t=174393&page=2 shows nicely how big the difference is. A 32-thread 1950X scored 4.26 for AVX2 and a stock 3900X (24 threads) got 5.51.
Old 28th April 2020, 09:33   #1444  |  Link
MeteorRain
結城有紀
Zen2 has full AVX2 capability. Not sure where you got that "emulated" idea.
Projects
Old 28th April 2020, 10:06   #1445  |  Link
tormento
Acid fr0g
tormento's Avatar
Unfortunately I can't find the page anymore, I can summarize only.
By SIMDjson benchmark, it was shown that Intel has more AVX2 IPC than Zen2.
Apart from that, the higher core count could nullify that penalty.
Zen3 should come across that and introduce AVX512 too.
Old 28th April 2020, 10:33   #1446  |  Link
MeteorRain
結城有紀
I found that benchmark. It was concluded that AMD has a poor IPC performance on AVX2. That is kinda expected, and actually many factors matters including that SIMDjson was optimized against Intel processors.
CPU pipelines, instruction order, cache size, even picking one instruction over another, can make a lot difference.
Projects
Old 28th April 2020, 10:42   #1447  |  Link
tormento
Acid fr0g
tormento's Avatar
Wasn't compiled using neutral flags?
Old 28th April 2020, 10:44   #1448  |  Link
Groucho2004
Conversation is getting a bit off-topic...
Groucho's Avisynth Stuff
Old 28th April 2020, 23:14   #1449  |  Link
MeteorRain
結城有紀
A highly optimized library wouldn't use a neutral flag. Also there's no neutral flag. If you have Intel CPU then all you can do is make sure your program runs fastest on that Intel CPU. If later AMD CPU appears and has different characteristics, likely some of the previous optimization won't make it as fast as on Intel CPU.
One example would be Intel has avx down clocking. So to reduce the chance of that you can carefully reduce the amount of heavy avx computing, and let CPU stay on light load frequency (higher frequency). But AMD doesn't have avx down clocking so the best thing to do is give it all the heavy lifting as much as possible.
Intel compiler for example when compiling avx 512, will take the down clocking in to account, and emit code that is not too hard for the CPU, so it won't run too fast to run slow (lol) but if AMD comes with 512 some day and it does not clock down, then when it runs the same binary it would not use its 100% potential.
Projects
Old 29th April 2020, 00:00   #1450  |  Link
tormento
Acid fr0g
tormento's Avatar
AFAIK it's a bios option, not mandatory.
Old 27th May 2020, 12:58   #1451  |  Link
hintlou
After I updated some filters (yadifmod2-0.2.4,SangNom2-0.5.0,DCTFilter-0.5.1,vsMSharpen-2.0.0,MatchHistogram-2.1.0,TMM2-0.1.4,CombMask-2.0.0 and MPEG2DecPlus-0.1.2),my QTGMC 3.364 got error and warned me that "KNLMeans.dll cannot be used as a plugin for Avisynth".
I don't know which filter caused it.
hintlou is offline   Reply With Quote
Old 27th May 2020, 16:12   #1452  |  Link
pinterf
KNLMeansCL needs to be rebuilt for AviSynth+ 3.6
https://forum.doom9.org/showthread.p...98#post1909698
Until it is done officially, you can download it from my repository
pinterf is offline   Reply With Quote
Old 27th May 2020, 16:42   #1453  |  Link
hintlou
Thanks pinterf!I updated to your KNLMeansCL.
But it also made error:
Script error:expected ')'
((null),line 1,column 4)
(AviSynth+/plugins64+/srestore v2.796.avsi,line 79)
(QTGMC 3.364.avsi,line 186)
(my.avs line 25:QTGMC(preset="Very Slow", InputType=0,sourceMatch=3).SelectEven())
Old 27th May 2020, 19:24   #1454  |  Link
real.finder
update your scripts, especially SMDegrain and Zs_RF_Shared.avsi
See My Avisynth Stuff
Old 28th May 2020, 10:25   #1455  |  Link
hintlou
Thanks!After I updated the Zs_RF_Shared.avsi,problem were solved.
Old 11th June 2020, 20:03   #1456  |  Link
Selur
Selur's Avatar
KNLMeansCL is still crashing for me with:
Avisynth error :  KNLMeansCL: fatal error!  (oclUtilsGetPlaformDeviceIDs: OCL_UTILS_UNKNOWN_ERROR) (E:\Temp\tempPreviewAvisynthFile08_26_19_695.avs, line 11) Couldn't import -1 (1)
also tried the testbuild from pinterf but it doesn't change anything.
Since it there hasn't been a driver version since February that works for me with KNLMeansCL anyone has an idea how to get it working again?
(Problem is only with 32bit Avisynth, works fine in 64bit Vapoursynth)
=> found the problem here, I had an abandoned old OpenCL.dll in the same folder as KNLMeansCL which caused the problem, after removing the OpenCL.dll it's working again
Notice: Since email notifications do not work here any more, it might take me quite some time to notice a reply to a thread,..
