Old 13th May 2020, 14:11   #81  |  Link
MeteorRain
結城有紀
There was already C++AMP. I used that a few years ago but it's still not popular till today.
Projects
x265 - Yuuki-Asuna-mod Download / GitHub
TS - ADTS AAC Splitter | LATM AAC Splitter | BS4K-ASS
Neo AviSynth+ filters - F3KDB | FFT3D | DFTTest | MiniDeen | Temporal Median
MeteorRain is offline   Reply With Quote
Old 13th May 2020, 15:00   #82  |  Link
pinterf
Originally Posted by kedautinh12 View Post
I find out a fork from maki's MPEG2DecPlus 0.1.1 on github, is it added v8 interface or not??
https://github.com/299792458m/DGIndex_mod
Note that v8 update will only be necessary if plugin is using the non-finalized IScriptEnvironment2 Avisynth+ interface calls.
Plugins which were not relying on IScriptEnvironment2 will be working fine.
pinterf is offline   Reply With Quote
Old 13th May 2020, 16:46   #83  |  Link
jpsdr
Originally Posted by FranceBB View Post
And... sure, you could have just been sitting on the couch watching TV all day like many people are doing during this pandemic...
Yes i did... A lot of animes, some old 80's SF/Heroic Fantasy cheaped movies, and also reading manga and comics...
My github.
Old 13th May 2020, 17:23   #84  |  Link
pinterf
My today's recommendation: The Plague by Albert Camus. I've read it in last November, pandemic started in December.
Old 13th May 2020, 18:48   #85  |  Link
Dont blame your self P, you can in no way be held responsible for this bloody lockdown, coincidence only, really.
EDIT: to below.
David Attenborough, yep, on much safer ground there
Old 13th May 2020, 19:44   #86  |  Link
pinterf
Yep, though my currently finished book is neutral, I hope (Zoo Quest by David Attenborough)
Old 14th May 2020, 02:54   #87  |  Link
Reel.Deel
Originally Posted by pinterf View Post
I wonder if they are simply recompiled or adaptively using the frame-property preserving NewVideoFrameP as well. So are they are good only for the new v8 or can work with any former avs versions?
Yes, git is a must have. On one hand now we have to download them and make manual source-code comparison to see what has been changed.
When they are getting new features (such as 10+ bits) in the future the sources have to be put back to git. And because of the credits and source history they have to be forked from the original repository and the new developer must either forget or reinvent these "offline" changes.
I'd encourage everyone to use github in order not to break development history.
Fork, modify, commit, document, release.
Ask, and you shall receive: https://github.com/Asd-g?tab=repositories
asd created a GitHub account, the modified plugins from chickuzen are there. by looking at the commits I don't think they are just recompiled, then again I am no programmer .
asd: if you are reading this, I just want to say thank you for all of the plugins you've uploaded on the wiki. Please check the wiki talk page in the coming days, I have a question for you. Thanks again
Old 14th May 2020, 07:14   #88  |  Link
pinterf
Great, thank you, Asd-g, you spent quite a few hours with the updates.
Old 14th May 2020, 07:20   #89  |  Link
kedautinh12
Asd-g, if you are reading this post, can port back there plugins from vapoursynth
https://forum.doom9.org/showpost.php...&postcount=841
Old 14th May 2020, 09:44   #90  |  Link
tormento
Acid fr0g
tormento's Avatar
This for sure is, looking at sources.
@turment on Telegram
Old 14th May 2020, 10:18   #91  |  Link
videoh
Useful n00b
What is this "v8 interface" you are talking about?
Old 14th May 2020, 10:37   #92  |  Link
pinterf
It's still in a development branch called neo.
IScriptEnvironment has been extended with some new functions which broke those plugins which were using avs+ specific IScriptEnvironment2. So such plugins have to be rebuilt with adaptively using new IScriptEnvironment functions.
The biggest change is the frame property support.
Just like in VS.
It is only the framework. Interface support and fp passing throughout all internal Avisynth+ plugins.
Ideally every filter in the filter chain has to able to pass frame properties on. Such plugins should use a V8 interface NewVideoFrameP instead of NewVideoFrame. But only if V8 host is detected.
Like this:
Technique is very simple.
Read about the changes:
https://github.com/AviSynth/AviSynth...me_history.txt
Grab new Avisynth headers (at the moment from here):
https://github.com/AviSynth/AviSynthPlus/tree/neo
Check V8 availability on create:
https://github.com/pinterf/TIVTC/blo...rlace.cpp#L261
Use the new feature adaptively
https://github.com/pinterf/TIVTC/blo...lanar.cpp#L169
Or when you have a source filter you can add frame properties just like in VapourSynth.
Obviously it is just a framework it will require many more steps later to use this feature properly and along with specific convertions and rules.
Old 14th May 2020, 10:43   #93  |  Link
Myrsloik
Professional Code Monkey
Myrsloik's Avatar
Interesting and familiar looking stuff. What happens with plugins that don't pass along properties? They all just disappear or you use some simple rule to try to pass them along anyway?
Myrsloik is offline   Reply With Quote
Old 14th May 2020, 10:44   #94  |  Link
kedautinh12
I already seen it, thanks
Old 14th May 2020, 11:15   #95  |  Link
videoh
Useful n00b
Thank you for the explanation. I suppose then it's not something to worry about quite yet as a filter author.
Old 14th May 2020, 11:18   #96  |  Link
pinterf
Familiar, yes. Thank you in advance, I've never thought that the concept would work in any Avisynth without breaking everything.
Plugins which do not pass properties will unfortunately break the chain.
Old 14th May 2020, 11:53   #97  |  Link
videoh
Useful n00b
Is there any documentation of the properties and how to use them? Couldn't make much sense out of it from looking at avisynth.h. Thank you.
Old 14th May 2020, 13:44   #98  |  Link
tormento
Acid fr0g
tormento's Avatar
How I wish everybody put dll version too in the compiled build.
Old 14th May 2020, 13:55   #99  |  Link
Myrsloik
Myrsloik's Avatar
You can't do something like my avisynth compatibility layer? Copy the properties from the input frame in secret?
(of course this in some cases need plugin parameter parsing and a deep knowledge of framerate modifications for plugins that do such things)
Old 14th May 2020, 14:18   #100  |  Link
pinterf
At the moment I cannot imagine how could I do that in a consistent way with parameter parsing.
Anyway when things are settling down I'd like to reproduce an issue with VapourSynth with which I had troubles and had to fix.
But probably you can answer it right now.
I added property "X" to a frame.
Then later (in another "ScriptClip") I added property "X" index #1 (2nd array element).
This array addition was not thread safe, second addition appeared multiple times in propShow when used in an MT environment. So the container was not detached in this case.
The fix was in this commit
https://github.com/AviSynth/AviSynth...48e05c60117290
Probably this one has no proper use case but I encountered the issue during my mt stress tests.
