25th December 2018, 23:09 | #41 | Link |
A link to your checkmate plugin would be nice, so we can test it too.
25th December 2018, 23:09 | #42 | Link | |
I just dumped checkmate.dll into my plugin folder. No error received at startup. Maybe an old AvsPmod filter database (filterdb.dat) or self created parameters in the function definitions (see picture) Time to unpack the new version completely in a directory and then start it.
Live and let live |
26th December 2018, 09:07 | #43 | Link | |
Imagine, now if I'd fork the original AvsPMod, and copy in your current source and commit it back, it will appear on github under my name, because you made those modifications "offline". Using github not only keeps the who-made-and-what history of the source in order (through the properly arranged and documented commits) but makes the teamwork possible. It can also be used to host the assembled releases - and github is even automatically snapshotting the actual source code. |
26th December 2018, 17:50 | #44 | Link | |
Live and let live |
30th December 2018, 20:23 | #45 | Link |
Thanks, I'm halfway on porting to interface version V6 (which includes Avs+ new functions).
Big success though, because x64 now works, and I think it's even a bit ahead of the x86 version. Please check it, you have a broader view on the whole AvsPMod project. One have to know that in this branch avxsynth (a former avisynth variant for linux) will probably not supported. Neither will this branch support Avisynth versions with interface version less than 6, practically AvsPMod needs classic Avisynth 2.6 or Avisynth+. But I think this is not a huge problem nowadays. Things to solve on my part: look into the x86 part, which is not moved to interface V6. As we don't want to support Avs+ exclusively. So I have to solve that those functions which do no exist on classic Avisynth, those functions should silently fallback to a compatible call. E.g. "is_yuv444" would not crash on classic avisynth, but fall back to the existing "is_yv24". I think if that works, the core functions can be updated with the high bit depth stuff. I was also experimenting with trying to use a bit newer environment (use Python 3.7 instead of 2.7, wxWidget 4.x instead of 2.8/3.0.2). I have not succeeded, the exe compiler (py2exe) should be changed because its development has been stopped and it does not support Python 3.7. |
31st December 2018, 16:56 | #46 | Link |
@gispos: Update: probably finished with the x86 part, Avisynth+ specific functions can be used freely. I'm using a similar automatic fallback mechanism as I used in the C++ avisynth interface.
For example avs_is_444 will call avs_is_yv24 instead, avs_bits_per_component will always return 8 for classic Avisynth. So the non-existant Avisynth+ extensions are simulated, they won't crash on classic Avisynth. is_444, is_422, is_420, is_y, bits_per_component, num_components, component_size, is_planar_rgb, is_planar_rgba, is_yuva, is_rgb48, is_rgb64 Status of the x64 part: the code is working, but the Avisynth+ specific things I just made now for x86 are missing there, I hope it can be done during the next some days. Yet I won't start a pull request on git immediately, just after you say it's really usable Happy New Year! |
2nd January 2019, 13:37 | #48 | Link |
test-test-test
Warning: not a release (I will have no releases, just did the background C interface things and nothing more, and leave the project back for gispos master). Just please try it to see that they work for you (=no freeze) to sort out obvious bugs when calling the new interface functions. Error messages shown are welcomed - or not In theory x86 should work for both Avs+ and classic Avisynth 2.6.0.5 x64 should work for Avisynth+ x86: https://drive.google.com/file/d/17n2...ew?usp=sharing x64: https://drive.google.com/file/d/1cqP...ew?usp=sharing |
2nd January 2019, 22:51 | #49 | Link | ||
I follow your changes already a few days, but I was not at home, sorry for the late reply. Very nice, and also the comments are very helpful. I'm about to apply your changes to my next version, and have also successfully created an x32 version. This version contains all your recent changes, but must first take a look at everything. And for Information: I do not want to hinder the project, so I do not mind if you create your own releases. It's finally 'open source' I found a small mistake in avsp.py line #15487 Code:
if debug_stats: print ('speed_factor: {0}, required_interval: {1} '\ 'interval: {2} interval_factor: {3}'.format( self.play_speed_factor, interval0, interval, factor)) self.increment = 0 self.previous_time = self.play_initial_time self.play_timer_id = self.timeSetEvent(interval, self.play_timer_resolution, self.callback_c, factor, periodic) Correctly: if debug_stats: print ('speed_factor: {0}, required_interval: {1} '\ 'interval: {2} interval_factor: {3}'.format( self.play_speed_factor, interval0, interval, factor)) self.increment = 0 self.previous_time = self.play_initial_time self.play_timer_id = self.timeSetEvent(interval, self.play_timer_resolution, self.callback_c, factor, periodic) and a happy new year to all Edit: Yes I just created an x64 version. Had previously tried with all sorts of avisynth.h versions ... with your modifications, it finally works. Thanks! I changed it back to the old code Quote:
Live and let live Last edited by gispos; 3rd January 2019 at 03:25. Reason: Edit |
3rd January 2019, 09:04 | #50 | Link | ||
4th January 2019, 20:54 | #51 | Link | |
Using higher* wxWidget version than the default one breaks the field where you manually enter the frame number (bottom left) - if you enter once a frame number, there is no problem, but the next time you try, it's already broken. * - If I remember correctly > 2.9 breaks it. Thanks for your and @gispos work. Is it possible a option Video - YUV -> RGB to remember what I set? I set BT.709 and after a restart the option is Resolution-based again. |
6th January 2019, 05:07 | #54 | Link | |
Yes I am back on wx version 2.8, with the version 3 there were only problems. For further tests, I have no time at the moment. New version is uploaded. See first post.
Live and let live |
6th January 2019, 05:16 | #55 | Link |
Gispos,
I dont like AvsPMod (Never have) but its lovely to see someone taking over from vdcrim, its a very brave effort on your behalf. (I dont like the way it modifies my scripts, and I have to keep changing them back again). Also, with a bit of the monster that is Pinterf, assisiting you, I'm sure that it will be well good Again, thanks for expending your time. EDIT: Would it be a big task to mod to v3,0 Python (from v2.7 or whatever), would probably be a big advantage (with others to maybe assist), if not using the older 2.7 snakey stuff.
I sometimes post sober. StainlessS@MediaFire ::: AND/OR ::: StainlessS@SendSpace "Some infinities are bigger than other infinities", but how many of them are infinitely bigger ??? Last edited by StainlessS; 6th January 2019 at 05:22. |
6th January 2019, 05:52 | #56 | Link | |
The scripts are not changed by AvsP. Or did not I understand you correctly? Higher python version: I've already written that AvsP was the first program I touched with python. I do not know how it is on newer versions, but Python is a pain for me. I do not want to continue here, but it is and remains a script language for which there is no reasonable IDE. At least I do not know any, I use PyScripter for Python and the syntax check is for the ass. Well, first of all, I'm not really good with python, and I do not like it either. Have already thought about a separate project with Delphi ... but that is probably a lot of work ... I think that's too much for me. At least for the moment. Greetings
Live and let live |
6th January 2019, 06:03 | #57 | Link |
Well from Python 2.7 to Python 3.0, I believe the main diff is the print statement[becomes a function in v3.0], not really too big a difference (see x in y minutes web page for differences)
x in y minutes:- https://learnxinyminutes.com/ I have eg a script that calls a file selector to get a filename from user, On return AvsPMod actually changes my script and embeds to chosen filename in script, making the purpose of the script, useless (Ie file sector no longer works proper). I have no idea whatever how AvsPMod does what it does (to screw up my scripts). I just know that it does. Most people love AvsPMod, but if you are a script developer, and have to un-fuck what the AVSPMod thing does EVERY TIME, then its a bit not nice. EDIT: I think this is one of the ones that causes probs (from RT_Stats), [EDIT: It actually modifes the source script, go figure] Code:
avi = RT_FSelOpen("Please select an AVI file",Filt="*.AVI|*.AVI") Assert(avi.IsString,"RT_FSelOpen: Error="+String(avi)) AVISource(AVI) txt = RT_FSelOpen("And now select a Text file",Filt="*.txt|*.txt") Assert(txt.IsString,"RT_FSelOpen: Error="+String(txt)) Txt=RT_ReadTxtFromFile(txt) Lines=RT_TxtQueryLines(Txt) # config DELAY=100 ALIGN=1 # As Numeric KeyPad SCROLL=0 # 0 = Upwards : 1 = Downwards : 2 = Right to Left : 3 = Left to right : 4 = Karaoke # ORG=Last Last=(SCROLL==4)? ORG.Blankclip(height=80) : Last CMD_0 = """RT_Subtitle("%s",Txt,align=ALIGN,y=height+DELAY-current_frame,expx=true,expy=true)""" CMD_1 = """RT_Subtitle("%s",Txt,align=ALIGN,y=-(Lines*20+DELAY) + current_frame,expx=true,expy=true)""" CMD_2 = """RT_Subtitle("%s",Txt,align=ALIGN,x=width+DELAY-current_frame,expx=true,vcent=true)""" CMD_3 = """RT_Subtitle("%s",Txt,align=ALIGN,x=-(width+DELAY)+current_frame,expx=true,vcent=true)""" CMD_4 = """RT_Subtitle("%s",Txt,align=ALIGN,y=height+DELAY-current_frame,expx=true,expy=true)""" CMD_5 = """RT_Subtitle("BAD SCROLL COMMAND (0->4)")""" CMD = (SCROLL<0 || SCROLL>4) ? CMD_5 : Select(Scroll,CMD_0,CMD_1,CMD_2,CMD_3,CMD_4) ScriptClip(CMD) Return (SCROLL==4)? StackVertical(ORG,Last) : Last
I sometimes post sober. StainlessS@MediaFire ::: AND/OR ::: StainlessS@SendSpace "Some infinities are bigger than other infinities", but how many of them are infinitely bigger ??? Last edited by StainlessS; 27th February 2020 at 03:19. |
6th January 2019, 06:52 | #58 | Link |
@StainlessS, if I copy your example then should it work? Will try it with AvsP.
Test: I completely forgot. This is my preliminary 'Dark Color Style' for the editor. Move the file to the program folder of AvsP and load it in the Options menu (Load font and color backup'. Can anyone even make the fine tuning.
Live and let live Last edited by gispos; 6th January 2019 at 07:28. |
6th January 2019, 18:01 | #59 | Link | |
With higher wx version that problem is gone but there is another. |
6th January 2019, 18:43 | #60 | Link |
Request: would it be possible to improve the %RGB %YUV values for pixel sampler (mouse pointer) for additional pixel formats RGB=(R,G,B) , YUV=(Y,U,V)
The video status message bar correctly displays additional pixel formats (eg. YUV422P10, etc...), it would be a nice addition to display those values correctly (currently 8bit 0-255 only) |
