Old 1st June 2019, 23:31   #521  |  Link
stax76
@Natty
Yes it was 32bit, I've deleted it, needi3 loads from plugins_JPSDR.dll.
stax76 is online now   Reply With Quote
Old 2nd June 2019, 22:02   #522  |  Link
Taurus
Taurus's Avatar
In case sombody is looking for a 64bit nnedi3....
jpsdr released a new package just the other day.
Look here:
https://forum.doom9.org/showthread.p...64#post1662264
Taurus is offline   Reply With Quote
Old 7th June 2019, 21:22   #523  |  Link
vanden
I'm trying to encode a movie in x265 HDR.
I can do it with ffms2 (Rename) :
LoadPlugin("C:\StaxRip-x64-2.0.2.2-test\Apps\Plugins\avs\ffms2\ffms2.dll")
FFVideoSource("C:\NEW\Billy.Lynns.Long.Halftime.Walk.2016.hevc", colorspace = "YV12", \
cachefile = "C:\NEW\Billy.Lynns.Long.Halftime.Walk.2016_temp\Billy.Lynns.Long.Halftime.Walk.2016.ffindex")
By :
FFVideoSource("C:\NEW\Billy.Lynns.Long.Halftime.Walk.2016.hevc", cachefile = "C:\NEW\Billy.Lynns.Long.Halftime.Walk.2016_temp\Billy.Lynns.Long.Halftime.Walk.2016.ffindex")
10bit encoding.
On the other hand in LWLibavVideoSource I have this :
LoadPlugin ( "C: \ StaxRip-x64-2.0.2.2-test \ apps \ Plugins \ avs \ L-SMASH-Works \ LSMASHSource.dll")
LWLibavVideoSource ("C: \ NEW \ Billy.Lynns.Long.Halftime.Walk.2016.hevc", format = "YUV420P8")
What can I do to encode it in 10bit ?
avs2pipemod[info]: writing 405600 frames of 60000/1001 fps, 3840x2160,
sar 0:0, YUV-420-planar-8bit progressive video.
y4m [info]: 3840x2160 fps 60000/1001 i420p8 unknown frame count
raw [info]: output file: NUL
x265 [info]: HEVC encoder version 3.0+2-b4b1d84566d7
x265 [info]: build info [Windows][GCC 9.1.1][64 bit] 10bit
update: x265, wolfberry build with avs input support,
in the x265 options: Other> Piping Tool> None
I put Nome here I guess ?
I have an error message :
and also that :
lavf [info]:
Format : avisynth
Codec : rawvideo ( raw video )
PixFmt : yuv420p
Framerate : 60000/1001
Timebase : 1001/60000
Duration : 1:52:46
lavf [info]: 3840x2160 fps 60000/1001 i420p8 frames 0 - 405599 of 405600
And last question, to make downscaling video (1920x1080) what is the best Resize ?
vanden is offline   Reply With Quote
Old 7th June 2019, 22:02   #524  |  Link
Natty
Noob
use avs2pipemod as piping tool
in ffms remove colorspace = "YV12" to let it decide source bitdepth automatically
same lmash or any other, remove format = "YUV420P8"
try lanczos4 (sharp) or blackman (Well balanced)
nothing is best
Natty is offline   Reply With Quote
Old 7th June 2019, 22:32   #525  |  Link
stax76
@vanden
l-smash outputs a double width format that was designed before avisynth had native high bit depth support, you can revert it like this:
LWLibavVideoSource("%source_file%")
ConvertFromDoubleWidth(bits=10)
With wolfberry's x265 built you don't need a piping tool.
Unfortunately I cannot reproduce the exception.
Old 8th June 2019, 17:10   #526  |  Link
vanden
1a. x265, wolfberry build with avs input support,
I can do it with ffms2 whit Rename :
10bit encoding :
1b. In the x265 options: Other> Piping Tool> Automatic, I can do it with ffms2 whit Rename :
10bit encoding :
2a. x265, wolfberry build with avs input support,
I can do it with LWLibavVideoSource whit Rename (the rename is very difficult to do, StaxRip renames it several times) :
LoadPlugin("C:\StaxRip-x64-2.0.2.2-test\Apps\Plugins\avs\L-SMASH-Works\LSMASHSource.dll")
LWLibavVideoSource("C:\Billy\Billy.Lynns.Long.Halftime.Walk.hevc")
10bit encoding :
2b. In the x265 options: Other> Piping Tool> Automatic, I can do it with LWLibavVideoSource whit Rename (the rename is very difficult to do, StaxRip renames it several times) :
10bit encoding :
What is the best method ?
the x265 options: Other> Piping Tool> None + LWLibavVideoSource ?
Old 8th June 2019, 18:56   #527  |  Link
stax76
@vanden
2.0.2.3 fixes the exception.
What is the best method?
Post a full log file on pastebin.com and with a little luck some people will take a look and tell you if something is wrong or can be improved.
Old 9th June 2019, 12:50   #528  |  Link
vanden
Thanks, 2.0.2.3 fixes the exception.
Old 10th June 2019, 12:25   #529  |  Link
Vulpix
I've not really had much success with Staxrip 2.0. I tried the latest (2.0.0.25 ?) by getting the latest compiled full release, and dropping the pipeline build into it, but both the original as well as the final version crash for me.
Demux is fine, indexing is fine but then the staxrip window disappears and I can only see it as a process. I can see it goes through the entirety of the source file once, then goes through some of its parts once and then it crashes (with a windows crash message rather than a staxrip one).
Staxrip 1.x works fine but the gui is missing some switches.
The source is an UHD mkv file.
Vulpix is offline   Reply With Quote
Old 10th June 2019, 12:59   #530  |  Link
stax76
@Vulpix
The latest test build is 2.0.2.3.
https://staxrip.readthedocs.io/intro.html#download
Old 10th June 2019, 21:51   #531  |  Link
Revan654
Revan654's Avatar
You can add new Menu items to StaxRip if you wish, Buttons can't be added by the user.
It's likely ffmpeg being the root problem(Shocking ). ffmpeg doesn't get along with many audio types. It's more noticeable with HLG content.
Revan654 is offline   Reply With Quote
Old 12th June 2019, 12:44   #532  |  Link
Forteen88
Herr
Why isn't TemporalDegrain2 integrated into StaxRip? Isn't it the most used and recommended degrainer?
EDIT: Thanks stax76!
Forteen88 is offline   Reply With Quote
Old 12th June 2019, 15:26   #533  |  Link
stax76
I hope it can be included in the next build.
https://github.com/staxrip/staxrip/issues/7
Meanwhile, it can be integrated manually:
https://github.com/staxrip/staxrip/i...ment-501064185
Old 12th June 2019, 19:55   #534  |  Link
jlw_4049
Latest (stable)build has been super stable/quick for me so far.
jlw_4049 is offline   Reply With Quote
Old 12th June 2019, 20:27   #535  |  Link
stax76
Thanks for the positive feedback!
Old 13th June 2019, 00:27   #536  |  Link
jlw_4049
No problem. This is the only GUI that properly does HDR encoding. Awesome program!
Question. How do I select the subtitles (specifically to not burn in forced subs by default) when encoding? I like to do all my muxing with mkvtoolnix.
Or for instance if I wanted English and Spanish subs from the source file, where would I choose that? I can't seem to find it. Unless I choose when I'm demuxing the source?
Thanks for the responses.
EDIT: I'm about 90% sure I got it figured out mostly. Will post back when I get the chance. Looks like you select what ever subs you want to be encoded in when the demux menu pops up.
I however still can't find the option to disable automatic burn in?
Old 16th June 2019, 15:20   #537  |  Link
Vulpix
@Vulpix
Oh, that explains a few things. I was getting it from here: https://github.com/Revan654/staxrip !
I've tried this 2.0.2.3 version and everything works again, yaay
Old 16th June 2019, 16:13   #538  |  Link
NikosD
FYI
QSVEnc v3.21
NVEnc v4.42
For your next build.
Win 10 x64 (17763.475) - Core i3-4170 - nVidia 1660 (430.39)
HEVC decoding benchmarks
H.264 DXVA Benchmarks for all
Old 16th June 2019, 16:49   #539  |  Link
stax76
Originally Posted by NikosD View Post
FYI
QSVEnc v3.21
NVEnc v4.42
Are these available as binary or only as source code? I'm too stupid to compile C++ code.
Old 16th June 2019, 17:11   #540  |  Link
Zetti
NVEnc v4.42: https://github.com/rigaya/NVEnc/releases
QSVEnc v3.21: https://github.com/rigaya/QSVEnc/releases
Zetti is online now   Reply With Quote
aac, hdr, hevc, staxrip, x265
