27th August 2019, 06:25 | #6581 | Link |
Its my understanding that by loading YouTube page, you also load an embedded YouTube Player on your PC in the open browser tab. When you click Play, that player requests remote Google Server to send stream to your IP address. This stream is pushed by the browser and OS media code through sequence of filters, and then resulting frame sequence is shown by video adapter on your monitor.
I don't see much difference between embedded Google Player and MPC-BE in that regard, except the player relies on browser media code, and better integrated with Google server via specially developed rich API. If a stream server supports rewind feature, it can serve key frames sequentially while dragging mouse along player seek bar. So complexity is rather in your mind than in basic feature implementation. And the devs said above it was implemented for streams long ago, if you can read. Now someone will say this discussion is boring for him. So should we ignore other posters questions and remarks? I don't mind if the forum rules encourage this. Last edited by zamar92; 27th August 2019 at 06:42. |
27th August 2019, 07:15 | #6582 | Link |
Aleksoid1978,
Just to let you know that the stutter video/audio playback appeared again, with the latest MPC Audio renderer and MPC Video renderer. Unfortunately when I was trying to make a video with it, I switched audio to the speaker from the usb-audio device, the stutter playback gone. Also tried switching back to usb-audio device, playback maintained normal. |
27th August 2019, 07:26 | #6583 | Link |
zamar92
You don't understand - ALL PC Player/Downloader parse youtube page and and get direct links for video/audio streams. No any API or something else for working with Youtube No any change for request preview like in browser. Calm down already.
AMD Ryzen 5 3600 /GIGABYTE B450 Gaming X /Patriot 32Gb@3200 /Kingston 500Gb M.2 /RTX 4060 /Samsung U28R550UQI /OLED Philips 55OLED707 /Yamaha RX-V471 + NS-555 + NS-C444 + NS-333 + YST-SW215 |
27th August 2019, 15:38 | #6584 | Link | |
Answering you comment, YouTube offers rich API for 3rd party apps. Its up to app developers whether to use it or not. When YouTube video is playing in MPC-BE from the derived direct link, Google server responds to the player rewind requests, so its not one way street, there is communication btw your player and Google server. Last edited by zamar92; 28th August 2019 at 05:17. |
27th August 2019, 16:05 | #6585 | Link |
27th August 2019, 16:26 | #6586 | Link |
Update for Turkish translation.
https://www.sendspace.com/file/4kcqsl Is it possible to add a shortcut key command to open the URL without confirming it from the clipboard? Like other commands that are shortcut keys but not in the menu: Center level, volume gain, color controls... |
27th August 2019, 22:03 | #6588 | Link |
Thanks for the link and your research. I'm not an experienced media coder. Your example is interesting, in particular in using multithreading to generate thumbnails. However, its not exactly suitable, since it requires prior media file download, and also stores generated thumbnails in the movie folder rather than generate them dynamically and keep in RAM, which is more desirable since accurate search within a single movie is infrequent and shouldn't require files cleanup.
28th August 2019, 02:16 | #6589 | Link | |
Also look at adding External Application Button in a browser. It adds "Open with" option to RMC, so one can add MPC-BE as EXE, and directly open links in it. Last edited by zamar92; 28th August 2019 at 02:24. |
28th August 2019, 04:26 | #6590 | Link |
If it doesn't work sometimes - check what in clipboard(Ctrl+V in notepad). If in clipboard normal URL - write it for me, i check what's wrong.
28th August 2019, 15:08 | #6591 | Link | |
I find the URL addresses and copy them to the clipboard and open them with MPC-BE. I wanted to learn how the URL opening process could be faster for MPC-BE. @Aleksoid1978 Is it possible to make these additions or /playfromclipboard command line switch? Or what can be done? |
29th August 2019, 01:53 | #6592 | Link |
Add in r4698, using "/clipboard" - opened url/path(support multiple lines) from clipboard.
29th August 2019, 11:13 | #6593 | Link | |
Can you add a command-line switch that will turn on mute or unmute when MPC-BE is turned on? Like /mute, /unmute, /vol 100 /vol 50, /vol 0. I use MPC-BE in my presentations. I created shortcuts with different playlists using command line switches. But some of them need to be muted or unmuted. I have to turn the sound off and on every time. |
30th August 2019, 04:57 | #6595 | Link |
updated german translation based on r4701
30th August 2019, 06:47 | #6596 | Link | |
Do you try different Device Buffer ?? P.S. test build with internal buffer 200ms - https://yadi.sk/d/-XwHlHmoHt-wKw
AMD Ryzen 5 3600 /GIGABYTE B450 Gaming X /Patriot 32Gb@3200 /Kingston 500Gb M.2 /RTX 4060 /Samsung U28R550UQI /OLED Philips 55OLED707 /Yamaha RX-V471 + NS-555 + NS-C444 + NS-333 + YST-SW215 Last edited by Aleksoid1978; 30th August 2019 at 07:14. |
30th August 2019, 11:44 | #6597 | Link |
updated german translation based on r4703
30th August 2019, 13:10 | #6598 | Link |
Updated Turkish translation. r4702
30th August 2019, 20:39 | #6599 | Link | |
However, the test build works perfect to me. |
