24th August 2017, 03:35 | #4542 | Link |
Yes - it's correct.
AMD Ryzen 5 3600 /GIGABYTE B450 Gaming X /Patriot 32Gb@3200 /Kingston 500Gb M.2 /RTX 4060 /Samsung U28R550UQI /OLED Philips 55OLED707 /Yamaha RX-V471 + NS-555 + NS-C444 + NS-333 + YST-SW215 |
24th August 2017, 19:18 | #4543 | Link | |
Please do not forget me:
24th August 2017, 19:40 | #4544 | Link | ||
Аbout the same thing in MPC-HC. Quote:
2. It is left in reserve.
MPC-BE 1.7.0 and Nightly builds | VideoRenderer | ImageSource | ScriptSource | BassAudioSource |
24th August 2017, 22:53 | #4545 | Link |
Update for translation files of Chinese Traditional/simplfied and Dutch based on rev 2847
https://www.sendspace.com/file/ypbom7 |
25th August 2017, 08:43 | #4546 | Link |
Thanks v0lt, I'll also test this tomorrow. Actually I was the one who asked for the new features, and you were so kind to implement it. Thanks again!
Ryzen 5 2600,Asus Prime b450-Plus,16GB,MSI GTX 1060 Gaming X 6GB(v398.18),Win10 LTSC 1809,MPC-BEx64+LAV+MadVR,Yamaha RX-A870,LG OLED77G2(2160p@23/24/25/29/30/50/59/60Hz) | madvr config |
25th August 2017, 15:56 | #4547 | Link |
I use automatic refresh rate change of MPC-BE and it works like a charm, but when using delay timer, it delays playback (screen stays black) and then playback starts.
I checked MPC-HC and it also starts playback but the first frame is already rendered and paused till the delay timer runs down and then playback starts with audio. I beg to change it in MPC-BE the way MPC-HC does it. The reason is, that the MPC-HC method doesn't create dropped frames at the start (Video but also Audio). If you need someone to test, let me know. To test this feature you need several different videofiles, some with black first frames, some without black ones at the beginning and some with audio starting at the very beginning. |
26th August 2017, 11:51 | #4548 | Link |
Unfortunately, this change (using 1.5.1.2859.x64) completely broke what Aleksiod did previously. Back to latest beta 1.5.1.2755.
Ryzen 5 2600,Asus Prime b450-Plus,16GB,MSI GTX 1060 Gaming X 6GB(v398.18),Win10 LTSC 1809,MPC-BEx64+LAV+MadVR,Yamaha RX-A870,LG OLED77G2(2160p@23/24/25/29/30/50/59/60Hz) | madvr config Last edited by chros; 26th August 2017 at 11:54. |
26th August 2017, 12:42 | #4549 | Link |
Check settings MPC Audio Renderer.
26th August 2017, 14:59 | #4550 | Link |
Hmm. Where do I find the latest build? Looking at Yandex, the latest version I can see there is 2838 and on SourceForge, it is even older. Sorry if this is a noob question.
Edit: Ahh. Found link in v0lt's tagline that contained the new builds. Thanks. I will test it now. Perpahs I would be a good idea to update the OP with this link, so you can avoid more noob questions like that in the future. Last edited by fluffy01; 26th August 2017 at 15:02. |
26th August 2017, 15:11 | #4551 | Link |
I just tested now, and the new version is actually much worse, because it seems to have problems regaining the exclusive lock after you start playing again, causing the entire player to lock up. And yes, I did activate the feature in the options.
26th August 2017, 15:43 | #4552 | Link |
My english is bad - i don't understand you Maybe you record video from desktop and i try understand.
26th August 2017, 15:54 | #4553 | Link |
I don't know how to record a video from desktop, but instead I will try to describe the problem a little better.
I looked through the commits on sourceforge, and ran them through Google translate. And as far as I could figure out, the commit you made, was about releasing the exclusive lock on the audio system, when pausing the video. So I downloaded the latest build (2859), and enabled the option for this in the settings, and then I played a video and paused it and then unpaused it again, and it completely locked up the player, so I had to kill it from the Process Manager. I hope you understand this, and if not, then maybe Google Translate can help understand it a little better? |
26th August 2017, 18:50 | #4554 | Link | |
Oh, "Release device when idle", nice, thanks!
Interesting, it works like a charm here with r2859 and quickly trying all the previously mentioned tests (see my signature for my setup).
27th August 2017, 18:41 | #4556 | Link |
@beter
Yes. Aleksoid1978 changed it in r2846.
MPC-BE 1.7.0 and Nightly builds | VideoRenderer | ImageSource | ScriptSource | BassAudioSource Last edited by v0lt; 28th August 2017 at 04:16. |
27th August 2017, 20:07 | #4557 | Link |
updated german translation based on r2861.
28th August 2017, 18:40 | #4558 | Link |
Just switched from HC. Having an issue with subtitles not showing. I played a video and subtitles automatically started playing, so I pressed W to turn them off. Now I can't get subtitles to show at all. Does anyone have any idea? Using LAV filters/MadVR. |
28th August 2017, 19:33 | #4559 | Link |
@iSeries
I do not confirm. Update the player and filters.
