31st July 2008, 13:12 | #521 | Link |
Mr. Sandman
there is a "search this thread" function
22nd February 2009, 22:32 | #522 | Link |
I'm trying to compile my own first x264 build using the guide from #166 (hpn) http://forum.doom9.org/showthread.ph...782#post723782
Step 18 runs into errors, no matter what versions of tools I use. I copied config.h from the gpac source folder to include/gpac/internal/config.h to work around the first one, but still, end up with this: http://img6.imageshack.us/img6/2547/70594335.png Last edited by K0zi; 22nd February 2009 at 22:35. |
22nd April 2009, 14:14 | #524 | Link | |||
Swallowed in the Sea
Ubuntu sucks ??
seems like compilation fails on Ubuntu 9.04 using the main branch...
22nd April 2009, 14:50 | #527 | Link |
HOWTO: Install and use the latest FFmpeg and x264
The instructions on the page are for Ubuntu Jaunty Jackalope 9.04 http://ubuntuforums.org/showthread.php?t=786095
Henrikx |
27th April 2009, 14:27 | #529 | Link |
Software Developer
I tried to compile x264 with MinGW 4.4.0, but configure fails:
./configure: line 320: die: command not found Platform: X86 System: MINGW asm: yes avis input: no mp4 output: no pthread: no debug: no gprof: no PIC: no shared: yes visualize: no You can run 'make' or 'make fprofiled' now. Code:
$CC $CFLAGS conftest.c -c -o conftest.o 2>$DEVNULL || die "endian test failed" I used an "unofficial" MinGW build that I found here: http://www.equation.com/servlet/equa...d?call=fortran
Go to https://standforukraine.com/ to find legitimate Ukrainian Charities 🇺🇦✊ Last edited by LoRd_MuldeR; 27th April 2009 at 14:29. |
27th April 2009, 17:32 | #531 | Link | |
Software Developer
If you get your hands on a working MinGW 4.4.x binary, please let me know
Go to https://standforukraine.com/ to find legitimate Ukrainian Charities 🇺🇦✊ Last edited by LoRd_MuldeR; 27th April 2009 at 18:22. |
27th April 2009, 21:26 | #533 | Link |
Software Developer
Yeah, it says that the application caused the runtime to terminate in an "unusual" way.
30th April 2009, 05:39 | #534 | Link | |
Compiling Encoder
on a note on this, due to how x264's configure writes values to TMP (in as_check() and cc_check()) this was crashing my gcc build as this does overwrite the temporary folder location (strangely is only affecting my gcc 4.4.0 x86/x64 builds) as they were then trying to write to a nonexistent folder. changing TMP to say TMPVAL and it works like a charm. you should try this on the build you have, chances are it is the culprit on your side as well. Last edited by kemuri-_9; 30th April 2009 at 05:42. |
1st May 2009, 22:08 | #535 | Link | |
Software Developer
That solved the problem for me too, although I don't understand why renaming a variable in the bash script did fix the crash in GCC In case anybody is interested, my patch is here: http://mplayer.somestuff.org/misc/li...cc440-fix.diff Also I noticed that TDM finally has a MinGW 4.4.0 binary too: http://www.tdragon.net/recentgcc/ BTW: GCC 4.4.0 is flooding the console with even more strange warning when compiling x264 than GCC 4.3.3 did
Go to https://standforukraine.com/ to find legitimate Ukrainian Charities 🇺🇦✊ Last edited by LoRd_MuldeR; 1st May 2009 at 22:39. |
2nd May 2009, 00:49 | #536 | Link | |
Compiling Encoder
x264's configure currently overwrites the location with the *_check() functions saving to the TMP variable. so basically trying to save temporary files to a place that doesn't exist is naturally going to cause some failures. I mentioned this in the dev channel, so it should probably get fixed along side with whatever the next commit will be. i also noticed that gcc 4.4.0 was extremely angry at x264 with its mountain of "dereferencing pointer {} will break strict-aliasing rules" warnings. |
