Old 26th November 2017, 15:20   #26741  |  Link
jdobbs
Originally Posted by Monty11 View Post
Thanks, jdobbs. How do I find the audio delay reported by MEDIAINFO, please? It is not listed in the standard MEDIAINFO text report.
From the command prompt, first set yourself to the folder holding the mkv, then type in:
path\to\bd_rebuilder\tools\mediainfo.exe mkvfilename.mkv
Replace "path\to" and "mkvfilename" with your path/name. If it's not listed, I have to would assume MEDIAINFO didn't report a difference. I believe it is called "Delay relative to video". If it isn't there, BD-RB has no other method by which it adjusts the audio stream, unless your settings are telling it to change the frame rate. Outside of that possibility, I'd have to assume the source is corrupt.
Website: www.jdobbs.net
Old 26th November 2017, 17:53   #26742  |  Link
RoyGBiv-inRI
When BD-RB imports an MKV, it uses the aspect ratio reported by MEDIAINFO. That ratio is taken from the stream -- so I don't see how the import could be the cause.
I understand and appreciate that, but how do they magically return to 16:9 AR when BD Rebuilder re encodes them?
SMK
RoyGBiv-inRI is offline   Reply With Quote
Old 26th November 2017, 18:01   #26743  |  Link
RoyGBiv-inRI
Also, I just downloaded a version of MediaINFO to use in Windows. When I load the original file, it tells me the file is 720*480 (16:9). When I load a file from the "imports" folder in BD, it says it is 720*480 (4:3).
I don't know what is responsible for this change.
SMK
Old 27th November 2017, 05:02   #26744  |  Link
AmigaFuture
AmigaFuture's Avatar
@ Lathe
Though my logic eludes you at times... How has the changing of encoding quality gone for Series BDs? Or have you checked, yet?
Life is not a journey to the grave; but rather to skid out broadside, thoroughly used, torn and warn and loudly proclaim; WOW; What a ride!!! Soon, I'm going to do it AGAiN in different skin!!
AmigaFuture is offline   Reply With Quote
Old 27th November 2017, 05:19   #26745  |  Link
Lathe
Lathe's Avatar
Originally Posted by AmigaFuture View Post
@ Lathe
Though my logic alludes you at times... How has the changing of encoding quality gone for Series BDs? Or have you checked, yet?
Did I ever actually say that you had any logic...?
Hey, thanks for asking. Yeah, it all turned out really well. Most episodes encoded around a CRF of about 18 or so, with a few lower and a couple higher. Looked really good though!
Oh, in the spirit of our Dear Mr. Video, I think that's 'eludes'...
Lathe is offline   Reply With Quote
Old 27th November 2017, 05:39   #26746  |  Link
AmigaFuture
JDobbs and I are in the same boat, we both finger blundered some recently. But you only caught mine, neener, neener!! N'Yuk, N'Yuk!
Since it all turned out well did it all turn it in before you got to it? Hmm..
Old 27th November 2017, 06:33   #26747  |  Link
Lathe
Lathe's Avatar
Old 27th November 2017, 16:05   #26748  |  Link
Sharc
@jdobbs
Just curious: Will this --sar bug possibly be fixed in the next release? It's still there in the current release, it seems ...
Any thoughts?
Old 27th November 2017, 16:15   #26749  |  Link
MrVideo
MrVideo's Avatar
You beat me to it!
Old 27th November 2017, 20:02   #26750  |  Link
varekai
varekai's Avatar
Well, you're awkward, probably should be bulletproof, and most definitely should be tested (for numerous things...) but, hey, we all still love ya!
We loves you too!
varekai is offline   Reply With Quote
Old 27th November 2017, 21:34   #26751  |  Link
Lathe
Lathe's Avatar
Originally Posted by MrVideo View Post
You beat me to it!
Heh heh heh...
Old 27th November 2017, 21:40   #26752  |  Link
Lathe
Lathe's Avatar
Originally Posted by varekai View Post
We loves you too!
Oh brother...
Old 28th November 2017, 00:18   #26753  |  Link
gonca
Hey Lathe
Found the your picture from last week
gonca is offline   Reply With Quote
Old 28th November 2017, 00:40   #26754  |  Link
gonca
varekai
We loves you too!
No we don't
@Lathe
Before you remark
See post above
Old 28th November 2017, 03:23   #26755  |  Link
Lathe
Lathe's Avatar
Originally Posted by gonca View Post
Hey Lathe
Don't these guys have jobs, or a life, or something...
Old 28th November 2017, 07:29   #26756  |  Link
AmigaFuture
@ Lathe
Some go hunting around the Internet for Kiddie pictures. *Yikes, haha* What do you think?
@ JD
Anyway...
Okay, I'm request some help. How do I get a .wav files to be accepted in place of .dts for multiplexing? Seems I'm missing something. Replace an AC3 with AC3, not a problem. I'm (damn it, that kid in the picture keeps looking at me...I'm really becoming bothered...haha) using .wav made by DVDFab that has you-know-what removed. Challenge is, it's only working in Move Only copies (as they call it). So the BD structure is Movie only. Doesn't work with my BD in Full Backup...yet.
For now, I'm fine with a DTS--ish WAV file without you-know-what. Renaming the .wav to .dts doesn't do it. tsMuxR hangs..and such. Makes sense. I've edited the MUX_00xxx.meta files but those are overwritten each time you want to resume -- so no go. I've modified the AUD_00xxx_xxxx.AVS, but that doesn't get the result (so far). I've replaced the M2TS files, but that just gets a realllllllly slow process that seems to hang.
JD, help?
Old 28th November 2017, 10:01   #26757  |  Link
varekai
varekai's Avatar
varekai
No we don't...
Yes WE do!
Old 28th November 2017, 19:27   #26758  |  Link
MrVideo
MrVideo's Avatar
English not your first language?
Old 28th November 2017, 19:38   #26759  |  Link
MrVideo
MrVideo's Avatar
How do I get a .wav files to be accepted in place of .dts for multiplexing? Seems I'm missing something. Replace an AC3 with AC3, not a problem. I'm using .wav made by DVDFab that has you-know-what removed. Challenge is, it's only working in Move[sic] Only copies (as they call it). So the BD structure is Movie only. Doesn't work with my BD in Full Backup...yet.
I have no idea what you mean by "you-know-what removed." That said, WAV audio files are not Blu-ray compliant. If you are trying to actually get a LPCM audio stream, I have to ask... why? LPCM files are huge. They eat up lots of space. What is wrong with keeping the original DTS audio stream?
Old 28th November 2017, 19:57   #26760  |  Link
AmigaFuture
I was having fun about Cinavia. Check here. The copy replaces DTS-HD with a WAV equivalent without the watermark.
I haven't used and forgot about KEEP_HD_LPCM=n. Checking that now...
