19th June 2019, 16:11 | #241 | Link |
This can easily be done in a text editor ("filterdb.dat", search for smdegrain and change "int "prefilter"=0 (0 / 1 / 2 / 3)," to "int "prefilter"=0 (0 / 1 / 2 / 3 / 4),".
Groucho's Avisynth Stuff |
25th June 2019, 22:41 | #243 | Link |
Noob
thanks for your collection i have been playing with it recently and have some questions
https://pastebin.com/CcMxX3xG - your FineDehalo. is it optimized for 16bit? because when i run ConvertBits(16).FineDehalo() it runs atleast 50% slower is it normal? same for your other filters. results are impressive when using whole script in native HBD but its so slow that its not usable. will u update f3kdb for native high bit depth? and i need your help in selective debanding. for example. i use this for full clip. f3kdb(range=30, y=50, Cb=50, Cr=50, grainY=50, grainC=50, keep_tv_range=true) but i want to put more grain in some complex large flat and dark scenes only. how can i do that? hoping for faster HBD filters in future. thanks for all your collection. i use most of them. Last edited by Natty; 25th June 2019 at 22:53. |
26th June 2019, 00:05 | #244 | Link | ||
f3kdb is not a script so I can't, you should ask someone else for it but anyway you can use Double-Width hack for it Quote:
See My Avisynth Stuff |
26th June 2019, 00:24 | #245 | Link | |
Click also on the discussion link.
1st July 2019, 10:00 | #247 | Link |
Noob
2nd July 2019, 07:52 | #248 | Link | |
17th July 2019, 22:08 | #250 | Link |
work fine here, what is your full script?
20th July 2019, 18:33 | #251 | Link |
scripts state for float (32bit) chroma for now:-
aside from smaskmerge, in SMDegrain, Dither_Luma_Rebuild and SMDegrain_prefilters mode 3 both will give wrong output in chroma but since mode 3 use Dfttest not work with float (32bit) yet this is not a big problem, Dither_Luma_Rebuild can be used in many scripts so it's problem for now, avoid use float (32bit) with it if you processes chroma qtgmc in other hand has no problem but since there are a bug will see the other scripts soon and then report back edit: the same bug in qtgmc float (32bit) can be in other scripts
See My Avisynth Stuff Last edited by real.finder; 21st July 2019 at 04:24. |
21st July 2019, 03:42 | #252 | Link |
updates for FineDehalo, BalanceBorders, LSFmod, FastLineDarkenMOD, Masked_DHA, BlindDeHalo3 and DeHalo_alpha
all update are some changes in LUT things, mainly for speed up float (32bit)
See My Avisynth Stuff Last edited by real.finder; 21st July 2019 at 03:56. |
21st July 2019, 07:08 | #253 | Link |
I need to double post as the character limit is preventing me to place the script within one post.
Thanks for the updates. I am having issues with DebilinearM still. I'm guessing it maybe due to not being able to get the latest ResizeX_v1.0.1 mod 9 as it's still pending for approval so I only got mod 7. Would it be possible to provide a pastebin? I'm receiving the following in avspmod: ResizeX does not have a named argument "dither_mode" (C: path\plugins64+\DebilinearM_v1.3.1_mod1.25.avsi, line 78) (New File, line 95). Another subject. As mentioned on the ResampleMT thread, https://forum.doom9.org/showthread.p...89#post1879189 I came about this script just a few days ago but it's been available since 2016. Haven't seen it on any Doom9 thread for Avisynt just VaporSynth. It uses DebilinearM and Debilinear.dll for both versions of AviSynth x86 not sure for 64 bit. This script, Gradfun3mod (https://forum.doom9.org/showthread.p...65#post1879765) I've been implementing it like so: Code:
dither_convert_8_to_16() ly = GradFun3mod(thr=0.35, smode=2,thr_det=2,elast=4,mode=6, yuv444=true, resizer="DebilinearM", lsb_in=true, lsb=true) lc = nnedi3_resize16(1280*2, 720*2,lsb_in=true,lsb=true,kernel_d="Spline64",kernel_u="Spline64",src_top=0.0,src_left=0.50) # lu = lc.UtoY() lv = lc.VtoY() YtoUV(lu,lv,ly) Dither_out() I'm not asking for anything but this if you may be interested in modifying this to work with your updated DebilinearM script using the ResampleMT plugin for Avisynth+. Also, about this n16 matter. Is there a documentation about this? I like to know more as if I understood correctly this n16 is true 16 bit and not the somewhat fake 16 bit of lsb and how would I turn it off going 8 bit. Is there an new method of going: dither_convert_8_to_16() DitherPost(mode=6) & to end Dither_out() Thanks for your time. Last edited by dREV; 21st July 2019 at 07:40. Reason: forgot n16 stuff |
21st July 2019, 07:09 | #254 | Link |
The script is called Gradfun3mod. https://pastebin.com/0mkhsimh Code:
################################################################################################################## # # High bitdepth tools for Avisynth - GradFun3mod r6 # based on Dither v1.27.1 # Author: Firesledge, slightly modified by Gebbi # # What? # - This is a slightly modified version of the original GradFun3. # - It combines the usual color banding removal stuff with resizers during the process # for sexier results (less detail loss, especially for downscales of cartoons). # - This is a starter script, not everything is covered through parameters. Modify it to your needs. # # Requirements (in addition to the Dither requirements): # - AviSynth 2.6.x # - Debilinear, Debicubic, DebilinearM # - NNEDI3 + nnedi3_resize16 # # Changes from the original GradFun3: # - yuv444 = true # (4:2:0 -> 4:4:4 colorspace conversion, needs 1920x1080 input) # - resizer = [ "none", "Debilinear", "DebilinearM", "Debicubic", "DebicubicM", "Spline16", # "Spline36", "Spline64", "lineart_rpow2", "lineart_rpow2_bicubic" ] # (use it only for downscales) # NOTE: As of r2 Debicubic doesn't have 16-bit precision, so a Y (luma) plane fix by torch is used here, # more info: https://mechaweaponsvidya.wordpress.com/2015/07/07/a-precise-debicubic/ # Without yuv444=true Dither_resize16 is used with an inverse bicubic kernel. # - w = 1280, h = 720 # (output width & height for the resizers; or production resolution for resizer="lineart_rpow2") # - smode = 4 # (the old GradFun3mod behaviour for legacy reasons; based on smode = 1 (dfttest); # not useful anymore in most cases, use smode = 2 instead (less detail loss)) # - deb = true # (legacy parameter; same as resizer = "DebilinearM") # # Usage examples: # - Source is bilinear 720p->1080p upscale (BD) with 1080p credits overlayed, # revert the upscale without fucking up the credits: # lwlibavvideosource("lol.m2ts") # GradFun3mod(smode=1, yuv444=true, resizer="DebilinearM") # # - You just want to get rid off the banding without changing the resolution: # GradFun3(smode=2) # # - Source is 1080p production (BD), downscale to 720p: # GradFun3mod(smode=2, yuv444=true, resizer="Spline36") # # - Source is a HDTV transportstream (or CR or whatever), downscale to 720p: # GradFun3mod(smode=2, resizer="Spline36") # # - Source is anime, 720p->1080p upscale, keep the resolution # but with smoother lineart instead of bilinear upscaled shit: # GradFun3mod(smode=2, resizer="lineart_rpow2") # This won't actually resize the video but instead mask the lineart and re-upscale it using # nnedi3_rpow2 which often results in much better looking lineart (script mostly by Daiz). # # Note: Those examples don't include parameters like thr, radius, elast, mode, ampo, ampn, staticnoise. # You probably don't want to use the default values. # For 16-bit output use: # GradFun3mod(lsb=true).Dither_out() # # What's the production resolution of my korean cartoon? # - Use your eyes combined with Debilinear(1280,720) - if it looks like oversharped shit, # it was probably produced in a higher resolution. # - Use Debilinear(1280,720).BilinearResize(1920,1080) for detail loss search. # - Alternatively you can lookup the (estimated) production resolution at # http://anibin.blogspot.com (but don't blindly trust those results) # # This program is free software. It comes without any warranty, to # the extent permitted by applicable law. You can redistribute it # and/or modify it under the terms of the Do What The Fuck You Want # To Public License, Version 2, as published by Sam Hocevar. See # http://sam.zoy.org/wtfpl/COPYING for more details. # ################################################################################################################## Function GradFun3mod (clip src, float "thr", int "radius", float "elast", \ int "mask", int "mode", float "ampo", float "ampn", int "pat", \ bool "dyn", float "dthr", int "smode", float "wmin", float "thr_det", \ float "thr_edg", int "debug", int "subspl", bool "lsb", bool "lsb_in", \ bool "staticnoise", float "thrc", int "radiusc", float "elastc", \ int "y", int "u", int "v", clip "ref", bool "slice", bool "yuv444", int "w", int "h", string "resizer", bool "deb") { thr = Default (thr, 0.35) thrc = Default (thrc, thr) radius = Default (radius, 12) radiusc = Default (radiusc, radius) elast = Default (elast, 3.0) elastc = Default (elastc, elast) mask = Default (mask, 2) smode = Default (smode, 2) wmin = Default (wmin, 1.0) thr_det = Default (thr_det, 2 + Round (Dither_max (thr - 0.35, 0) / 0.3)) debug = Default (debug, 0) subspl = Default (subspl, 0) lsb = Default (lsb, false) lsb_in = Default (lsb_in, false) ref = Default (ref, src) yuv444 = Default (yuv444, false) w = Default (w, 1280) h = Default (h, 720) resizer = Default (resizer, "none") deb = Default (deb, false) # Do lineart smoothing first for sharper results ow = src.Width() oh = src.Height() src = (resizer == "lineart_rpow2") ? lineart_rpow2(src, w, h, ow, oh, false) \ : (resizer == "lineart_rpow2_bicubic") ? lineart_rpow2(src, w, h, ow, oh, true) \ : src # Input range check. The other parameters are checked by the plugins. Assert (radius > 0, "GradFun3: "+chr(34)+"radius" +chr(34)+" must be strictly positive.") Assert (radiusc > 0, "GradFun3: "+chr(34)+"radiusc"+chr(34)+" must be strictly positive.") Assert (thr > 0, "GradFun3: "+chr(34)+"thr" +chr(34)+" must be strictly positive.") Assert (thrc > 0, "GradFun3: "+chr(34)+"thrc" +chr(34)+" must be strictly positive.") Assert (thr_det > 0, "GradFun3: "+chr(34)+"thr_det"+chr(34)+" must be strictly positive.") Assert (elast >= 1, "GradFun3: "+chr(34)+"elast" +chr(34)+" must be greater or equal to 1.") Assert (elastc >= 1, "GradFun3: "+chr(34)+"elastc" +chr(34)+" must be greater or equal to 1.") (yuv444 && resizer != "lineart_rpow2" && resizer != "lineart_rpow2_bicubic") ? Assert (w == 1280, "GradFun3mod: Output resolution must be 1280x720 when using 4:4:4 colorspace.") : true (yuv444 && resizer != "lineart_rpow2" && resizer != "lineart_rpow2_bicubic") ? Assert (h == 720, "GradFun3mod: Output resolution must be 1280x720 when using 4:4:4 colorspace.") : true src_8 = (lsb_in) ? src.DitherPost (mode=-1) : src src_16 = (lsb_in) ? src : src.Dither_convert_8_to_16 () ref_16 = (lsb_in) ? ref : ref.Dither_convert_8_to_16 () yv411_flag = src.Dither_isyv411 () # Main debanding yp = (! Defined (y) || (y == 3)) ? 3 : 1 up = (! Defined (u) || (u == 3)) ? 3 : 1 vp = (! Defined (v) || (v == 3)) ? 3 : 1 chroma_flag = ( (thrc != thr || radiusc != radius || elastc != elast) \ && yp == 3 && (up == 3 || vp == 3)) up2 = (chroma_flag) ? 1 : up vp2 = (chroma_flag) ? 1 : vp src_16 flt_y = Dither_gf3_smooth_mod (last, src_8, ref_16, smode, radius, thr, elast, lsb_in, wmin, subspl, yp, up2, vp2) flt_c = (chroma_flag) ? Dither_gf3_smooth_mod (last, src_8, ref_16, smode, radiusc, thrc, elastc, lsb_in, wmin, subspl, 1, up, vp) : flt_y flt = (chroma_flag) ? flt_y.MergeChroma (flt_c) : flt_y # Edge/detail mask td_lo = Dither_max (thr_det * 0.75, 1) td_hi = Dither_max (thr_det, 1) mexpr = Dither_make_expr_gate (td_lo, td_hi) dmask = (mask > 0 && yv411_flag) ? src_8.ConvertToY8 () : src_8 dmask = (mask > 0) ? dmask.Dither_build_gf3_range_mask (mask) : dmask dmask = (mask > 0) ? dmask.mt_lut (expr=mexpr) : dmask dmask = (mask > 0) ? dmask.Dither_removegrain_emul (22, -1) : dmask dmask = (mask > 1) ? dmask.Dither_removegrain_emul (11, -1) : dmask dmask = (mask > 2) ? dmask.Dither_removegrain_emul (20, -1) : dmask dmask = (mask > 0 && yv411_flag) ? dmask.ConvertToYV411 () : dmask res_16 = (mask > 0) ? Dither_merge16_8 (flt, src_16, dmask, luma=true, y=yp, u=up, v=vp) : flt # Resizing / colorspace conversion (GradFun3mod) resizer = (deb) ? "DebilinearM" : resizer resizer = (yuv444 && resizer == "none") ? "Spline36" : resizer rkernel = (resizer == "Debilinear" && yuv444) ? res_16.DebilinearY(w,h,lsb_inout=true) \ : (resizer == "Debilinear") ? res_16.Debilinear(w,h,lsb_inout=true) \ : (resizer == "DebilinearM" && yuv444) ? res_16.DebilinearM(w,h,lsb_inout=true,chroma=false) \ : (resizer == "DebilinearM") ? res_16.DebilinearM(w,h,lsb_inout=true) \ : (resizer == "Debicubic" && yuv444) ? res_16.debicubicy_precise(w,h) \ : (resizer == "Debicubic") ? res_16.Dither_resize16(w,h,kernel="bicubic",invksh=true,fh=1.3,fv=1.3,invkstaps=7) \ : (resizer == "DebicubicM" && yuv444) ? res_16.DebicubicM_precise16(w,h,chroma=false) \ : (resizer == "DebicubicM") ? res_16.DebicubicM_precise16(w,h) \ : (resizer == "Spline16" && yuv444) ? res_16.Dither_resize16(w,h,kernel="spline16",fh=1.2,fv=1.2).ConvertToY8() \ : (resizer == "Spline16") ? res_16.Dither_resize16(w,h,kernel="spline16",fh=1.2,fv=1.2) \ : (resizer == "Spline36" && yuv444) ? res_16.Dither_resize16(w,h,kernel="spline36",fh=1.2,fv=1.2).ConvertToY8() \ : (resizer == "Spline36") ? res_16.Dither_resize16(w,h,kernel="spline36",fh=1.2,fv=1.2) \ : (resizer == "Spline64" && yuv444) ? res_16.Dither_resize16(w,h,kernel="spline64",fh=1.2,fv=1.2).ConvertToY8() \ : (resizer == "Spline64") ? res_16.Dither_resize16(w,h,kernel="spline64",fh=1.2,fv=1.2) \ : ((resizer == "lineart_rpow2" || resizer == "lineart_rpow2_bicubic") && yuv444) ? res_16.Dither_resize16(1280,720,kernel="spline36",fh=1.2,fv=1.2).ConvertToY8() \ : (resizer == "lineart_rpow2" || resizer == "lineart_rpow2_bicubic") ? res_16 \ : (resizer == "none") ? res_16 \ : Assert (false, "GradFun3mod: wrong resizer value.") ly = rkernel lu = res_16.utoy8().Dither_resize16(1280, 720, src_left=0.25, kernel="blackman") lv = res_16.vtoy8().Dither_resize16(1280, 720, src_left=0.25, kernel="blackman") (yuv444) ? ytouv(lu,lv,ly) : rkernel # Dithering result = (lsb) ? last : last.DitherPost ( \ mode=mode, ampo=ampo, ampn=ampn, pat=pat, dyn=dyn, \ prot=false, thr=dthr, staticnoise=staticnoise, \ y=yp, u=up, v=vp, slice=slice \ ) result = (lsb) \ ? Dither_switch_planes16 (src_16, result, y=y, u=u, v=v) \ : Dither_switch_planes8 (src_8, result, y=y, u=u, v=v) (debug == 1 ) ? dmask.GreyScale () : result (debug == 1 && lsb) ? Dither_convert_8_to_16 () : last } Function Dither_gf3_smooth_mod (clip src_16, clip src_8, clip ref_16, int smode, int radius, float thr, float elast, bool lsb_in, float wmin, int subspl, int yp, int up, int vp) { src_16 (smode == 0) ? Dither_gf3_smoothgrad_multistage (ref_16, radius, thr, elast, yp, up, vp) \ : (smode == 1) ? Dither_gf3_dfttest (src_8, ref_16, radius, thr, elast, lsb_in, yp, up, vp) \ : (smode == 2) ? Dither_gf3_bilateral_multistage (ref_16, radius, thr, elast, wmin, subspl, yp, up, vp) \ : (smode == 3) ? Dither_gf3_smoothgrad_multistage_3 (radius, thr, elast, yp, up, vp) \ : (smode == 4) ? Dither_gf3_dfttest_mod (src_8, ref_16, radius, thr, elast, lsb_in, yp, up, vp) \ : Assert (false, "GradFun3mod: wrong smode value.") } # Valid values for y, u and v: 1 and 3 Function Dither_gf3_dfttest_mod (clip src, clip src_8, clip ref, \ int radius, float thr, float elast, bool lsb_in, \ int y, int u, int v) { Assert (radius <= 128, "GradFun3: max "+chr(34)+"radius" +chr(34)+" value is 128 when smode = 1.") hrad = Dither_max (radius * 3 / 4, 1) (lsb_in) ? src : src_8 dfttest ( \ sigma=thr*12, tbsize=1, \ sbsize=hrad*4, sosize=hrad*3, \ lsb=true, lsb_in=lsb_in, \ Y=(y==3), U=(u==3), V=(v==3) \ ) Dither_limit_dif16 (last, ref, thr=thr, elast=elast, y=y, u=u, v=v) } Function lineart_rpow2 (clip src, int w, int h, int ow, int oh, bool bicubic) { w = default(w, 1280) h = default(h, 720) ow = default(ow, 1920) oh = default(oh, 1080) bicubic = default(bicubic, false) orig = src (bicubic) ? DebicubicM(src, w, h) : DebilinearM(src, w, h) nnedi3_rpow2(2, cshift="Spline36Resize", fwidth=ow, fheight=oh) edges = last.mt_edge("prewitt", 4, 24, 4, 24, chroma="true").removegrain(20, 1) sharp = last mt_merge(orig, sharp, edges) } Function debicubicy_precise(clip src, int dst_width, int dst_height, float "src_left", float "src_top", float "src_width", float "src_height") { # script by torch sw = src.width() sh = src.height()/2 src_left = default(src_left, 0.0) src_top = default(src_top, 0.0) src_width = default(src_width, sw) src_height = default(src_height, sh) inv_left = -src_left * dst_width/src_width inv_top = -src_top * dst_height/src_height inv_width = (sw-src_left) * dst_width/src_width inv_height = (sh-src_top) * dst_height/src_height seed = debicubicy(src, dst_width, dst_height, src_left, src_top, src_width+src_left, src_height+src_top, lsb_inout=true) up = seed.dither_resize16(sw, sh, inv_left, inv_top, inv_width, inv_height, kernel="bicubic", fh=-1.0, fv=-1.0) diff = dither_sub16(src, up, dif=true).dither_lut16("x 32768 - 99 * 32768 +") down = diff.debicubicy(dst_width, dst_height, src_left, src_top, src_width+src_left, src_height+src_top, lsb_inout=true) down = down.dither_lut16("x 32768 - 99 / 32768 + round") return seed.dither_add16(down, dif=true) } Function DebicubicM_precise16(clip input, int target_width, int target_height, bool "chroma") { # based on DebilinearM v1.3.1 Assert(target_width > 0, "GradFun3mod: target width must be greater than 0") Assert(target_height > 0, "GradFun3mod: target height must be greater than 0") thr = 10 expand = 1 inflate = 2 kernel = "Spline36" chroma = Default(chroma, true) w = input.Width() h = input.Height()/2 uvint = chroma ? 3 : 1 # Resizing input_8bit = input.DitherPost(mode=-1) dbi = chroma ? input.Dither_resize16(target_width,target_height,kernel="bicubic",invksh=true,fh=1.3,fv=1.3,invkstaps=7) \ : input.debicubicy_precise(target_width,target_height) dbi_8bit = chroma ? input_8bit.Debicubic(target_width,target_height) \ : input_8bit.DebicubicY(target_width,target_height) dbi2 = dbi_8bit.ResizeX(w,h, kernel="Bicubic", chroma=chroma) rs = input.ResizeX(target_width,target_height, kernel=kernel, chroma=chroma, lsb_in=true, lsb=true) # Masking diffmask = mt_lutxy(input_8bit,dbi2, "x y - abs", U=uvint, V=uvint).mt_binarize(threshold=thr, U=uvint, V=uvint) diffmask = diffmask.ResizeX(target_width,target_height, kernel="Bilinear", chroma=chroma) \ .mt_binarize(threshold=3, U=uvint, V=uvint) \ .DebilinearM_expand(expand=expand, U=uvint, V=uvint) \ .DebilinearM_inflate(inflate=inflate, U=uvint, V=uvint) merged = Dither_merge16_8(dbi,rs,diffmask, u=uvint, v=uvint) return merged } |
21st July 2019, 07:34 | #255 | Link | |
about n16 yes it's like lsb but true 16bit, we did talk about that here in the past (and even in other Threads like https://forum.doom9.org/showthread.p...47#post1875147) will see the other things you asked for later (maybe in few Hours or some days) and since you bring deband filter, can you or other members provides some video samples (I remember there also some code in avs to generate moving banding in some post here in doom9 few years ago)
See My Avisynth Stuff Last edited by real.finder; 21st July 2019 at 08:06. |
21st July 2019, 16:19 | #257 | Link |
in very few scripts
21st July 2019, 16:25 | #258 | Link |
Very sneaky Real.Finder, that squiggle in your last [EDIT: but one] post had me investigating how you did it, (to save anybody else the trouble of finding out, its repeated below [png]).
I sometimes post sober. StainlessS@MediaFire ::: AND/OR ::: StainlessS@SendSpace "Some infinities are bigger than other infinities", but how many of them are infinitely bigger ??? Last edited by StainlessS; 21st July 2019 at 16:28. |
21st July 2019, 17:42 | #259 | Link | |
What is the cause of "Moving Banding", just moving images ? EDIT: This works but need low OUTLEVELS for real obvious banding Code:
Function BandingGenny(clip c,int "nLevels",Bool "PcLevels") { # https://forum.doom9.org/showthread.php?p=1879799#post1879799 c nLevels = Default(NLevels,36) PcLevels = Default(PcLevels,False) Foot = (PcLevels) ? 0 : 16 Head = (PcLevels) ? 255 : 235 Levels(Foot , 1.0, Head, Head-nLevels+1, Head,coring=false) # Squish range to nLevels number of levels Levels(Head-nLevels+1, 1.0, Head, Foot , Head,coring=false) # UnSquish range, still nLevels number of levels return Last } AviSource("D:\AutoLevels\OZ.avi") ConvertToYV12 ORG=Last ### CONFIG ### PCLEVELS = False OUTLEVELS = 36 SHOW = false ########## BandingGenny(OutLevels,PcLevels) (Show) ? Subtract(ORG) : Last return last
I sometimes post sober. StainlessS@MediaFire ::: AND/OR ::: StainlessS@SendSpace "Some infinities are bigger than other infinities", but how many of them are infinitely bigger ??? Last edited by StainlessS; 21st July 2019 at 22:17. Reason: update |
21st July 2019, 23:21 | #260 | Link | |
avisynth, avs script, avs+, banding, generator, hbd, mod |
