Old 7th November 2013, 22:23   #81  |  Link
frencher
French Love
Originally Posted by HWK View Post
Does it work for you? I tired with Directshowmvcplugin but no go for me and then I decied to send whole package to author for testing. Except magic path is stereoplayer.exe instead mvc toavi.exe
Look my tutorial from my signature, i have updated my tutorial for support yuv from ffdshow (up of 1920x1080)
If I understand
2013-11-29 MVC Player Free v0.0.2.6 BD & 3D BD's Player, Demuxer v0.0.0.8b, Recoder. Tutorial
Demo for MVC Player Free: Trailer 3D
3DBD's Free - v0.0.0.0005.exe Old
Programing free for all.
frencher is offline   Reply With Quote
Old 7th November 2013, 22:25   #82  |  Link
frencher
French Love
I would think so, give it a try and let us know how it goes for you.
F:\MVC Player\MVCtoAVI.exe>"F:\MVC Player\MVCtoAVI.exe\Tools\Frim MVC Decoder Encoder\FRIMEncode.exe" mvc -i "F:\MVC Player\MVCtoAVI.exe\Preview.avs" -avi -sbs 2 -viewoutput -o H:\L.h264 -o H:\R.h264 -b 60000 -u 4
FRIM Encoder version 1.11 (build: Nov  7 2013)
 - based on Intel(R) Media SDK (version: 4.0.760.60435)
Input format    YUV420
Output video    AVC
MFX dll:        F:\MVC Player\MVCtoAVI.exe\Tools\Frim MVC Decoder Encoder\libmfxsw32.dll
Source picture:
 Resolution             1920x1088
 Crop X,Y,W,H           0,0,1920,1080
Destination picture:
Frame rate              23.976
Bitrate control         CBR
 bitrate                60000
GOP structure:
 GOP length             24
 I-/P-frame distance    4
 IDR-frame interval     1
 GOP type               Opened
Num of slices           6
Target usage            4 (balanced)
Memory type             system
Media SDK impl          sw
Media SDK version       1.7
Processing started
Frame number: 37969
Old 7th November 2013, 22:28   #83  |  Link
frencher
French Love
Originally Posted by colinhunt View Post
Does this mean I can feed it demuxed h264 files directly from a 3DBD?
Yes directly from iso 3DBD without demuxing (With Avisynth by DirectShowMVCSource in next update of MVC Player Free)
Old 7th November 2013, 22:53   #84  |  Link
videofan3d
Yes -
demux main and dependent view (e.g. using eac3to -demux xxx.ssif) please try it...
videofan3d is offline   Reply With Quote
Old 7th November 2013, 23:02   #85  |  Link
frencher
French Love
new crash with avisynth script... (Ten recodage with x264 x86 and no crash, no crash with export to YUV)
Old 7th November 2013, 23:05   #86  |  Link
HWK
HWK's Avatar
Originally Posted by videofan3d View Post
FRIMDecode mvc -i input_L.h264 -i input_R.h264 -o output.yuv
I think it would be better if naming convention is like this
-i input_L.h264 > -i input_B.h264
-i input_R.h264 > -i input_D.h264
B: Base, D: Dependent
Since some movies have inverse in order how they store stream.
If you fail to plan; you plan to fail, would you not agree? Think about it.
HWK is offline   Reply With Quote
Old 7th November 2013, 23:11   #87  |  Link
videofan3d
Right - next release I'll update documentation to be more self-explanatory.
Old 7th November 2013, 23:13   #88  |  Link
videofan3d
- What is the length (in minutes) of the movie you are processing?
- Are you using avisynth script or elementary view .h264?
Old 7th November 2013, 23:14   #89  |  Link
HWK
HWK's Avatar
If I understand
Thank you, that make sense I will give it a try, however still it would be nice to feed full sbs to encoder with directshowmvcsourceplugin only and get encoding going.
Old 7th November 2013, 23:15   #90  |  Link
HWK
HWK's Avatar
Avisynth, it is also in the header of the post.
Old 7th November 2013, 23:16   #91  |  Link
frencher
French Love
OK i change my CMD Line
My tool for AVC/MVC order First view of SSIF.rar
Old 7th November 2013, 23:20   #92  |  Link
HWK
HWK's Avatar
Post was geared towards videofan3d
Old 7th November 2013, 23:22   #93  |  Link
frencher
French Love
With Avisynth
133402 frames total 266804
Old 7th November 2013, 23:22   #94  |  Link
tymoxa
videofan3d
Is it possible to add an option to decoder/transcoder (let's say it would be -d key) to have possibility of decoding/transcoding dependent view only?
tymoxa is offline   Reply With Quote
Old 7th November 2013, 23:26   #95  |  Link
HWK
HWK's Avatar
Originally Posted by tymoxa View Post
videofan3d
It make sense for decoder, however for transcoding and encoding I can't think of reason to add it.
Old 7th November 2013, 23:29   #96  |  Link
videofan3d
videofan3d
Do you mean to get only the R-eye?
Please note that from MVC principle: base view can be decoded to L-eye, but for decoding R-eye you need both: base view and dependent view together.
Old 7th November 2013, 23:32   #97  |  Link
HWK
HWK's Avatar
I think, what op is referring to ability to decode data from dependent view in such way that it can be viewed without any dependence.
Old 7th November 2013, 23:53   #98  |  Link
tymoxa
Exactly.
I want do something like this:
FRIMDecode mvc -i l.h264 -i r.h264 -o \\.\pipe\out.yuv -d | x264 --qp 0 -o dependent.264 - --fps 23.976 --input-res 1920x1080
Old 8th November 2013, 00:01   #99  |  Link
HWK
HWK's Avatar
Exactly.
oh, I see what you are saying. Good news we already have decoder which can do it for you and yes you can use X.264 encoder with it.
Old 8th November 2013, 00:02   #100  |  Link
Sharc
v1.11 named pipe still does not work here. Now I get the error:
Error: Unknown codec
encoders, mvc
