22nd November 2004, 20:58 | #41 | Link | |||
Swallowed in the Sea
@WinSomePix : ok...I see. I'll try to modify that. @Daphy : about your request :: a friend of mine wants the same thing. It's funny... Thanks for all guys and stay tuned. Maybe a new release tonight... |
23rd November 2004, 01:00 | #42 | Link | |
0.17 is available...;-)
@Jorel : your mailbox is full...I can't send you PM. So, I'll send you the pdf file and this last version tomorrow by mail. bye. Last edited by Kurtnoise; 23rd November 2004 at 01:09. |
23rd November 2004, 07:43 | #44 | Link |
Placement improved...
Hi Kurtnoise:
I checked ver 0.17 on our various machines and it opens properly in the center of the screen on all of them. Nice job. Also, it is no longer too big for 1024x768. The change did introduce a small problem with the font layout in the interface, probably caused by the fact that we use the "Large Size (120 DPI)" font size setting on all our XP machines. The resizing you did of your program's window makes several instances of text lines get cut off at the end of the line. For instance, in the WAV/PCM tab, each instance of the word "wave" next to the output channel radio buttons is missing one or more letters. I can e-mail you a couple of screen shots if that would help. Making the whole BeLight window a little wider might solve the problem, or using a slightly smaller typefont. Best regards. |
23rd November 2004, 10:26 | #45 | Link | |
Re: Placement improved...
Hey,
23rd November 2004, 10:35 | #46 | Link |
L.A.M.E. developer
May I suggest something similar to this for the mp3 options:
http://lame.sourceforge.net/lame_ui_example.html |
23rd November 2004, 11:20 | #48 | Link |
Miles Freak
MUX/LST Option
Hi Krutnoise,
is it possible to make a nice GUI menue for MUX/LST file list where it´s possible simply to mark the files (or selecting the path to the single file - like your input/output option) in order FL,FR,C,LFE,SL,SR to create an automatic MUX list or file1,file2... for LST? I guess this would be a very confortable addon for all users! THX
CYA Daphy |
23rd November 2004, 13:36 | #49 | Link | |
Re: MUX/LST Option
23rd November 2004, 13:59 | #50 | Link |
He meant, that he want...
A function that create´s automatically the mux list from six mono files. He want a place in the gui who he can choose/search the mono waves. LeftFront-->c:\the\place\where\the\LeftFront-File is RightFront-->c:\the\place\where\the\RightFront-File is and so on... LF RF C BR BL LFE Do you understand ? |
23rd November 2004, 14:35 | #52 | Link | |
XviD User
One last request and I wont bother you anymore Is it possible to add the 'priority' CPU feature? I typically set BeSweet to run in 'Idle' mode so I can do other tasks while BeSweet encodes. EDIT- Oooops, the LAME '--resample 44.1' command does not seem to function. Bug? Last edited by MacAddict; 23rd November 2004 at 14:42. |
23rd November 2004, 14:56 | #55 | Link | |
Miles Freak
FL,FR,C,LFE,SL,SR
CYA Daphy |
23rd November 2004, 14:57 | #56 | Link | |
XviD User
BeSweet v1.5b29 by DSPguru. -------------------------- Using azid.dll v1.9 (b922) by Midas (midas@egon.gyaloglo.hu). Using lame_enc.dll v1.32 (4/11/2004), Engine 3.97 <http://www.mp3dev.org/>. Logging start : 11/23/04 , 08:51:44. BeSweet.exe -core( -input D:\pb64 AC3 T01 3_2ch 448Kbps DELAY 0ms.ac3 -output Z:\pb64 AC3 T01 3_2ch 448Kbps DELAY 0ms.mp3 -logfile D:\pb64 AC3 T01 3_2ch 448Kbps DELAY 0ms.log ) -azid( -s stereo -c normal -L -3db ) -ota( -hybridgain ) -lame( --alt-preset 80 ) [00:00:00:000] +------- BeSweet ----- [00:00:00:000] | Input : D:\pb64 AC3 T01 3_2ch 448Kbps DELAY 0ms.ac3 [00:00:00:000] | Output: Z:\pb64 AC3 T01 3_2ch 448Kbps DELAY 0ms.mp3 [00:00:00:000] | Floating-Point Process: Yes [00:00:00:000] | PostGain normalize to : 0.97 [00:00:00:000] +-------- AZID ------- [00:00:00:000] | Input Channels Mode: 3/2, Bitrate: 448kbps [00:00:00:000] | Output Stereo mode: Stereo [00:00:00:000] | Total Gain: 10.000dB, Compression: Normal [00:00:00:000] | LFE levels: To LR -3.0dB, To LFE 0.0dB [00:00:00:000] | Center mix level: BSI [00:00:00:000] | Surround mix level: BSI [00:00:00:000] | Dialog normalization: -4dB [00:00:00:000] | Rear channels filtering: No [00:00:00:000] | Source Sample-Rate: 48.0KHz [00:00:00:000] +-------- LAME ------- [00:00:00:000] | 'abr 80' preset is used [00:00:00:000] +--------------------- [00:27:04:416] Gain of 4.5dB had been asserted to file. [00:27:04:416] Conversion Completed ! [00:27:04:416] Actual Avg. Bitrate : 80kbps [00:02:14:000] <-- Transcoding Duration Logging ends : 11/23/04 , 08:53:58. |
23rd November 2004, 15:27 | #58 | Link |
Hi.
Thanks for this very good gui. In the german forum a user asked a question... "Is it possible to save my own settings in the gui" Could you integrate a function that saves the settings, in a .ini file perhaps ?? It could be very useful... |
23rd November 2004, 15:38 | #59 | Link | |
@MacAddict: I'm checking the trick. Use SSRC instead of --resample Lame function. I think it's more accurate and it works fine. |
23rd November 2004, 15:44 | #60 | Link |
(schein)heilig
Cosmetic suggestions (meaning: to consider if todo list is about to get empty ):
- Don’t use underlined text (e.g. on the Vorbis tab). Non-underlined is much better to read. - For translations labels/checkboxes/etc. adjusting to the text length would be nice (within limits that don’t mess up the GUI of course). P.S.: Wow, already the third version in three days. Pretty impressing. About as fast as Gabest in his best days. And that’s saying something!
Brother John When lost in BeSweet's options, have a look at the Commandline Reference. DVD nach MPEG-4 klappt nicht? Verzweifelt? Auf zum Encodingwissen! |
