Old 28th November 2008, 12:29   #1641  |  Link
new_age
SW & FW developer/modder
new_age's Avatar
END OFFTOPPIC !!!
new_age is offline
Old 28th November 2008, 22:20   #1642  |  Link
Originally Posted by kebulek View Post
neuron2: I just had a 1-2s glitch in my HD stream and DGAVCIndex 1.0.6 did it unwatchable for 12 seconds (still image with many blocks). :-( Is this DGAVCIndex's fault or just bad stream?
If your GOPs are long then a large section of video can be destroyed by a short glitch.
Guest is offline
Old 28th November 2008, 22:27   #1643  |  Link
@new_age
See here:
http://forum.doom9.org/showthread.ph...03#post1217903
Guest is offline
Old 29th November 2008, 10:05   #1644  |  Link
new_age
new_age's Avatar
Thanks for the info. Will be hard: using laptop. :-)
Anyway I've temporaly solved by using CoreAVC and DirectShowSource but it is slower than AVCSource.
new_age is offline
Old 1st December 2008, 21:10   #1645  |  Link
canTsTop
canTsTop's Avatar
i have "bad" sample http://www.mediafire.com/?y4tej0guuns
it indexes ok, but then i load avs in virtualdub, virtualdub stops responding and after 20-25 seconds virtualdub shows green frame, then i go forward frame by frame, i see correct picture at frame 7. and from frame 7 i step backwards and some frames that were previously green, now they correct.
sorry for bad english
EDIT:
ffdshow don't understand this sample too...
canTsTop is offline
Old 1st December 2008, 23:36   #1646  |  Link
Originally Posted by canTsTop View Post
i have "bad" sample
Yes, you do. The transport stream is corrupted. I can't help you with that.
Guest is offline
Old 2nd December 2008, 09:41   #1647  |  Link
komisar
komisar's Avatar
neuron2
Can you compile DGAVCDec with this patch to support H.264 predictive lossless?
..::[I am live here]..::..[My x264 CLI/VFW builds and tools]::..
komisar is offline
Old 2nd December 2008, 11:40   #1648  |  Link
canTsTop
canTsTop's Avatar
sorry about that, i don't know what happened to that sample...
here is same 10mb from same recording, but this time its not corrupted (checked with TS Packet Editor) http://www.mediafire.com/?5tyzt3ljthn
canTsTop is offline
Old 2nd December 2008, 14:28   #1649  |  Link
If it won't apply to the older version of libavcodec I use, then I can't absorb it. I'm not able to update libavcodec, due to several critical regressions for frame accurate seeking that the developers consider low priority (which in practice means do it yourself or forget it). Unfortunately I have too much of my own work to get involved in libavcodec development.
Guest is offline
Old 2nd December 2008, 14:36   #1650  |  Link
The stream contains no IDRs. You'll have to enable Treat I as IDR and accept that the first few frames will be trash.
Is that from the Hauppauge HD-PVR? If so, you can use the Graphedit hack to enable IDRs.
Guest is offline
Old 2nd December 2008, 15:18   #1651  |  Link
canTsTop
canTsTop's Avatar
its recorded from DVB-T with DVBViewer. i enabled Treat I as IDR options, but still it takes long time to open, for sample (10mb) ~23 seconds, and whole recordind (700mb) virtualdub stops responding but uses ~90% CPU and i waiting like 10 minutes now
canTsTop is offline
Old 2nd December 2008, 15:23   #1652  |  Link
OK, I'm looking again to see why the open is taking so long.
Guest is offline
Old 2nd December 2008, 16:21   #1653  |  Link
I've found and fixed the problem. Actually, your stream has RPS's so it should be fine. There was a bug in my handling of open GOPs.
Preparing a new release...
Guest is offline
Old 2nd December 2008, 16:44   #1654  |  Link
Version 1.0.7
* Fixed a bug in handling of open GOPs that caused problems when the first GOP of the stream is open.
http://neuron2.net/dgavcdec/dgavcdec.html
Guest is offline
Old 2nd December 2008, 16:50   #1655  |  Link
canTsTop
canTsTop's Avatar
Thank You for quick fix, now it works ok
canTsTop is offline
Old 2nd December 2008, 17:44   #1656  |  Link
komisar
komisar's Avatar
neuron2
Why? You surces not free? May be I compile with "this support" and test....
komisar is offline
Old 2nd December 2008, 18:36   #1657  |  Link
Why?
Why what?
Your sources not free?
Correct. It's not open source. But see below.
I use libavcodec as a DLL. The change you seek would be made there. Refer to the file libavcodec.txt in my distribution for details. I advise you not to bother trying to upgrade to the latest ffmpeg code as it is broken for random access. You can certainly try to patch the version I am using, but I don't know if the patches will cleanly apply to that older version.
Guest is offline
Old 2nd December 2008, 20:10   #1658  |  Link
canTsTop
canTsTop's Avatar
here is another sample http://www.mediafire.com/?moznmzzzymz , its recorded with VLC in linux
problem is wrong audio delay detection, DGAVCIndex detects DELAY 11ms in this sample, but its more than 1 second incorrect
canTsTop is offline
Old 2nd December 2008, 21:14   #1659  |  Link
Investigating...
Thanks. I've needed such a clear demonstration for some time. It plays in sync in VLC.
Guest is offline
Old 3rd December 2008, 14:34   #1660  |  Link
komisar
komisar's Avatar
neuron2, sorry for my misunderstand (more beer not good, sorry). Where can I get you use version of libavcodec?
komisar is offline
