2nd November 2004, 22:20 | #3001 | Link | |
I'm afraid we've to stop
Re: Compressibility Pass sloooow...
Gordian Knot Family: Gordian Knot: website, download Auto Gordian Knot: Website and download, tutorial, FAQ |
3rd November 2004, 06:57 | #3002 | Link | |
Re: Re: Compressibility Pass sloooow...
Sometimes my mind plays tricks on me Cheers Taurus |
3rd November 2004, 18:07 | #3003 | Link | |
4th November 2004, 13:34 | #3004 | Link |
Mr. Sandman
Good, but i think further tweaking for compressibility without loosing sharpness is not possible (or there is only a very little space for improvement).
4th November 2004, 15:03 | #3005 | Link | |
What source are you using? Don't want to compare apple with Poire or peaches Normally I use a crystal clear sequenz, compare it to a mainstream one ,and as the salt on the butter, a real noisy clip. Of course some real action and very slow movements...smoke and water.. Cheers Taurus |
4th November 2004, 19:21 | #3007 | Link | |
4th November 2004, 20:20 | #3008 | Link |
Yes, same source. Correct.
I edit this post. Un-installed and re-installed AutoGK again. Works perfect now. Dunno what was wrong? Thanks for an absolute awesome software! Now if we could get "range-encode" this would complete this superb software. Keep up the great work len0x! Last edited by Mouse; 4th November 2004 at 20:59. |
5th November 2004, 01:30 | #3010 | Link | |
Actually in reserve
Re: Range encode.
Hello ukb007 or anybody else,
Thanks in advance. Did
Having a problem with AutoGK? Read & use the FAQ & MORE FAQ first Want to exchange on AutoGK? try doom10.org In reserve (inactive) for an undefined period of time. |
5th November 2004, 07:27 | #3011 | Link | |
Re: Re: Range encode.
Of course, DVD2AVI is not used anymore. DGIndex is what it's called now. The FAQ is somewhat outdated at times, cos of often changes in program When the encoding process starts and DGIndex launches, maximize it from the toolbar. Hit Escape, then F5, again Escape. Now you are able to scroll through the clip. Set your desired cut and trim markers and select Save Project under File Menu. Make sure you overwrite existing *.d2v File. AutoGk will go on after this little tweak as in normal operation modus. Voila! Cheers Taurus |
5th November 2004, 08:37 | #3012 | Link |
Actually in reserve
Re: Re: Re: Range encode.
@ Taurus,
I could have searched a long time. So is "range" to be understood (my english is kind of rusty needs a lot of WD40 ) as something like: -subset(s) to select within a set of vobs- ? Thanks for the info, good day to you Did
Having a problem with AutoGK? Read & use the FAQ & MORE FAQ first Want to exchange on AutoGK? try doom10.org In reserve (inactive) for an undefined period of time. Last edited by BigDid; 6th November 2004 at 00:49. |
5th November 2004, 12:44 | #3013 | Link |
me
Cosmetic issue with 1.73:
The log window doesn't scroll properly. Instead of the text filling each line of the window, with new text appearing at the bottom and old text scrolling off the top, new text sometimes re-writes the window, so that there is only one or two lines in the window. Scrolling didn't always work correctly in 1.60 - sometimes at start-up the old text wouldn't scroll up, but once you used the scrollbars to have the last line of text appear at the end of the window, it would thereafter work correctly. |
5th November 2004, 19:56 | #3016 | Link | |
No big words: My favourite is V2. Beta4 adds some artificial sharpness which might be useful at specific sources. But my overall impression is, that V2 gives a more natural appeal to mainstream rips. Even on high coloured (Nemo, Monster, Shrek)animatations the look is more shimmering and roundish, not so harsh as with beta4. As always, comparision was made @ Q=2, 720:XXX, one pass, AutoGk-avs. Didn't test it on television screen. I think, Sharktooth does a good Job on Beta4, it will remain in my collection of useful matrices.(V2 too). But on the other hand,if we look for a more universal matrice, V2 is the right way. Will do some more crosschecking with older matrices as well, if I find the time for new roundup. Cheers Taurus |
5th November 2004, 20:34 | #3018 | Link | |
Re: mp3 kb/s in 1.73
If the source compresses this well, sometimes you get an undershoot. Don't worry, the more bits and bytes are for the video If your concern is constant bitrate, just use cbr. For some standalone players it's also a good decision. But remember, only in vbr mode bit distribution follows the source. So in low spectral parts bits are saved for high spectral consuming parts. Is there any audible loss? Just trust your ears and don't count on numbers. Cheers Taurus |
5th November 2004, 20:50 | #3019 | Link |
me
@Taurus,
this was the first encoding I had done in which there was a meaningful gap between desired bit-rate and bit-rate as reported by GS (and I've encoded a fair amount with AutoGK). I can't A-B the original audio against the mp3, but speech usually requires a much lower bit-rate than music and this movie has very little music. Also the movie is older and is stereo (rather than 5.1). I'd like to make sure there's no issue, mainly for when I'm encoding more demanding material. I doubt len0x is changing the audio parts of the code, so I doubt there's an issue, but one never knows. |
6th November 2004, 14:50 | #3020 | Link |
Mr. Sandman
Oh well audio encoding is done thru LAME. So i doubt len0x will change it.
Now, beta4 and the sharpness "issue"... Can you explain what does it mean "artificial sharpness"? Maybe some screenshots would help... However Shrek and Nemo are CG... I have some doubts about "Monster"... is it Monster & Co. (CG) or Monster? In the first case i agree with you. V2 has a softer coefficient scaling that's preferable for CG-cartoonish materials, while beta 4 is more film-oriented. Maybe len0x could implement an easy workaround for those kind of movies (a hidden option) that will select a specific matrix (V2 for example) for that purpouse.
6th November 2004, 18:57 | #3021 | Link | |
As I stated before, it's my personal point of view. Beta4 is quite desirable at darkish "real" film content. Did some short cuts on Matrix Reloaded, its quite different with V2. On this special clips, beta4 is the winner. But all depends on the eyes, viewing distance, monitor, etc. I don't have a TFT screen, so it might be an error on my side. About screenshots: Surely I have made a lot of them in the past. But to my opinion they don't reflect visuality correct. If the quant distribution changes, a picture in motion looks quite different compared to a static one. I will do some more testing if you want me to do so. Maybe a hint which source to use, so we can talk at even level. There are no real bad matrices around, they are just different for special purposes. So for AutoGk we have to find the universal one, which suits the needs for the Pro's and the Noobs. That's why I normally tend to a more smoother matrice because of noobs mistakes So, now I have to go out and do some real living. Thanks for your feedback. Cheers Taurus |
7th November 2004, 01:14 | #3022 | Link |
Posts: n/a
Hi BigDid
Range means a specific chosen duration of movie material starting at a point of your choice.
Taurus is right. DVD2AVI is not the name of the program used now; it's DGIndex, although the resulting file extension is still d2v. If you are new to AGK then this link may help you. You select the range in the DGIndex window that you open, by means of a slider at the bottom for positioning of your start and end points of the range, and then using [ and ] buttons for fixing those points. DGIndex.exe will then index only that part (range) of the movie for use in the AGK. Regards. Last edited by ukb007; 7th November 2004 at 01:22. |
7th November 2004, 22:58 | #3023 | Link | |
Actually in reserve
Re: Range encode
Hi ukb007
- changing the AR - changing the range; for this one I have an immediate use for mpeg2 captured files. Instead of splitting the file(s) before feeding AGK, I should be able to do it via Dgindex inside AGK. Will try it with next capture. I have more immediate concerns with my standalone going bork with a 2Gb encode of the LOTR2 (640 wide, vbr mp3 192kbs); Too much bitrate at 1h25mn during the attack of the wargs. I will test different possibilities and eventually come back to the forum for help. I already tried a smaller file (1.53Gb 608 wide vbr 160: works) but the goal is to retain same quality with a 2Gb or near file without the standalone freezing (The H&B 3220 has been tested Ok up to 6000kbs!). From what I have read, it may be related with the absence of the vbv buffer that is/will be included with the 1.1 xvid encoder. Wondering if using the 1.1 beta and checking the vbv box before doing a normal encode with AGK would do it? Anyhow, thanks for your time and good infos Best regards Did
Having a problem with AutoGK? Read & use the FAQ & MORE FAQ first Want to exchange on AutoGK? try doom10.org In reserve (inactive) for an undefined period of time. Last edited by BigDid; 8th November 2004 at 06:15. |
8th November 2004, 00:57 | #3024 | Link | |
me
8th November 2004, 06:14 | #3026 | Link | |
Actually in reserve
High birates for standalone
To DVD -R mainly but I could transfer the 2Gb file to +R or +RW if needed; burner is a LiteOn 832S with external enclosure via USB2. Did
8th November 2004, 07:07 | #3027 | Link | |
And some small hint. Don't mess around with different versions of Xvid. There was a time, when people complained about AutoGk not working right. They got overshoots and undershoots, even lost their hair, cos of wrong versions and or mixed up installs. So just use it if you know exactly what your doing Cheers Taurus |
8th November 2004, 07:13 | #3028 | Link | |
You can queue as many encodes as you want from there...and go to bed for three or mor days. Cheers Taurus |
8th November 2004, 15:04 | #3029 | Link | |
8th November 2004, 15:04 | #3030 | Link | |
8th November 2004, 15:07 | #3031 | Link | |
version 1.74 beta is up
8th November 2004, 15:16 | #3032 | Link |
Member
Lenox
hi .. don't particapate much but do check in once in a while.
thanks for the program have used it a few times. I made to encodings using the same settings in autoGK the difference - one was DivX 5.2 and one XviD(whatever is boundeled with Autogk) using version 1.73. i figured that i would get the same resolution in both but the xvid one was twice the size just thought that i would post the info in case it wasn't supposed to be that way. also the quality of the divx one i thought was a lot worse .. any way here are the two log files The Divx Log File [11/7/2004 6:14:41 AM] AutoGK 1.73b [11/7/2004 6:14:41 AM] OS: WinXP (5.1.2600).2 [11/7/2004 6:14:41 AM] Job started. [11/7/2004 6:14:41 AM] Input dir: D:\TITANIC\VIDEO_TS [11/7/2004 6:14:41 AM] Output file: D:\TITANIC\VIDEO_TS\Titanic - DivX.avi [11/7/2004 6:14:41 AM] Audio: English [11/7/2004 6:14:41 AM] Subtitles: none [11/7/2004 6:14:41 AM] Codec: DivX [11/7/2004 6:14:41 AM] Target size: 700Mb [11/7/2004 6:14:41 AM] Started encoding. [11/7/2004 6:14:41 AM] Demuxing and indexing. [11/7/2004 6:17:41 AM] Processing file: D:\TITANIC\VIDEO_TS\VTS_01_1.VOB [11/7/2004 6:17:41 AM] Processing file: D:\TITANIC\VIDEO_TS\VTS_01_2.VOB [11/7/2004 6:17:41 AM] Processing file: D:\TITANIC\VIDEO_TS\VTS_01_3.VOB [11/7/2004 6:17:41 AM] Processing file: D:\TITANIC\VIDEO_TS\VTS_01_4.VOB [11/7/2004 6:17:41 AM] Source aspect ratio: 4:3 [11/7/2004 6:17:41 AM] Source resolution: 720x480 [11/7/2004 6:17:41 AM] Found NTSC source. [11/7/2004 6:17:41 AM] Analyzing source. [11/7/2004 6:30:33 AM] Source has percentage of interlacing in motion areas: 46.34 [11/7/2004 6:30:33 AM] Source has percentage of telecined patterns: 99.08 [11/7/2004 6:30:33 AM] Source has percentage of progressive patterns: 0.92 [11/7/2004 6:30:33 AM] Source has percentage of interlaced patterns: 0.00 [11/7/2004 6:30:33 AM] Source is considered to be FILM. [11/7/2004 6:30:33 AM] Found 279873 frames [11/7/2004 6:30:33 AM] Encoding audio. [11/7/2004 7:03:30 AM] Audio size: 181,810,712 bytes (173.39 Mb) [11/7/2004 7:03:30 AM] Overhead: 18,054,784 bytes (17.22 Mb) [11/7/2004 7:03:30 AM] Video size: 534,137,704 bytes (509.39 Mb) [11/7/2004 7:03:30 AM] Target bitrate is: 366kbps [11/7/2004 7:03:30 AM] Running compressibility test. [11/7/2004 7:03:30 AM] Writing the following script to D:\TITANIC\VIDEO_TS\agk_tmp\Titanic - DivX_comptest.avs =========================================================== LoadPlugin("C:\PROGRA~1\AutoGK\DGMPGDec\DGDecode.dll") LoadPlugin("C:\PROGRA~1\AutoGK\filters\autocrop.dll") LoadPlugin("C:\PROGRA~1\AutoGK\filters\decomb.dll") LoadPlugin("C:\PROGRA~1\AutoGK\filters\RemoveGrainSSE2.dll") movie = mpeg2source("D:\TITANIC\VIDEO_TS\agk_tmp\Titanic - DivX.d2v") cropclip = autocrop(movie,mode=0,wmultof=4,hmultof=4,samples=10,aspect=0,threshold=34,samplestartframe=0) fixed_aspect = 0.888888888888889 c_width = width(cropclip) c_height = round(height(cropclip) / fixed_aspect) input_par = float(c_width)/float(c_height) input_par = input_par > 1.4 ? input_par : (4.0/3.0) out_width = 640 out_height = round(float(out_width) / input_par) hmod = out_height - (floor(out_height / 16 ) * 16) out_height = (hmod > 4) ? (out_height + (16 - hmod)) : (out_height - hmod) new_aspect = (float(out_width) / float(out_height)) / fixed_aspect Telecide(movie,order=1,guide=1,post=2).Decimate(mode=0) autocrop(mode=0,wmultof=4,hmultof=4,samples=10,aspect=new_aspect,threshold=34,samplestartframe=0) LanczosResize(out_width,out_height) DRemoveGrain(mode=2) SelectRangeEvery(280,14) =========================================================== [11/7/2004 7:17:21 AM] Duration was: 13 minutes 47 seconds [11/7/2004 7:17:21 AM] Speed was: 16.92 fps. [11/7/2004 7:17:22 AM] Compressibility percentage is: 18.12 [11/7/2004 7:17:22 AM] Using softer resizer. [11/7/2004 7:17:22 AM] Chosen resolution is: 336x160 ( AR: 2.10 ) [11/7/2004 7:17:22 AM] Predicted comptest value is: 62.14 [11/7/2004 7:17:22 AM] Running first pass. [11/7/2004 7:17:22 AM] Writing the following script to D:\TITANIC\VIDEO_TS\agk_tmp\Titanic - DivX_movie.avs =========================================================== LoadPlugin("C:\PROGRA~1\AutoGK\DGMPGDec\DGDecode.dll") LoadPlugin("C:\PROGRA~1\AutoGK\filters\autocrop.dll") LoadPlugin("C:\PROGRA~1\AutoGK\filters\decomb.dll") LoadPlugin("C:\PROGRA~1\AutoGK\filters\RemoveGrainSSE2.dll") movie = mpeg2source("D:\TITANIC\VIDEO_TS\agk_tmp\Titanic - DivX.d2v") cropclip = autocrop(movie,mode=0,wmultof=4,hmultof=4,samples=10,aspect=0,threshold=34,samplestartframe=0) fixed_aspect = 0.888888888888889 c_width = width(cropclip) c_height = round(height(cropclip) / fixed_aspect) input_par = float(c_width)/float(c_height) input_par = input_par > 1.4 ? input_par : (4.0/3.0) out_width = 336 out_height = round(float(out_width) / input_par) hmod = out_height - (floor(out_height / 16 ) * 16) out_height = (hmod > 4) ? (out_height + (16 - hmod)) : (out_height - hmod) new_aspect = (float(out_width) / float(out_height)) / fixed_aspect Telecide(movie,order=1,guide=1,post=2).Decimate(mode=0) autocrop(mode=0,wmultof=4,hmultof=4,samples=10,aspect=new_aspect,threshold=34,samplestartframe=0) BicubicResize(out_width,out_height,0,0.5) DRemoveGrain(mode=2) =========================================================== [11/7/2004 9:13:15 AM] Duration was: 1 hour, 55 minutes 50 seconds [11/7/2004 9:13:15 AM] Speed was: 40.27 fps. [11/7/2004 9:13:15 AM] Running second pass. [11/7/2004 11:04:46 AM] Duration was: 1 hour, 51 minutes 25 seconds [11/7/2004 11:04:46 AM] Speed was: 41.86 fps. [11/7/2004 11:04:46 AM] Job finished. ----------------------- The XviD Log File [11/7/2004 11:04:47 AM] AutoGK 1.73b [11/7/2004 11:04:47 AM] OS: WinXP (5.1.2600).2 [11/7/2004 11:04:47 AM] Job started. [11/7/2004 11:04:47 AM] Input dir: D:\TITANIC\VIDEO_TS [11/7/2004 11:04:47 AM] Output file: D:\TITANIC\VIDEO_TS\Titanic - XviD.avi [11/7/2004 11:04:47 AM] Audio: English [11/7/2004 11:04:47 AM] Subtitles: none [11/7/2004 11:04:47 AM] Codec: XviD [11/7/2004 11:04:47 AM] Target size: 700Mb [11/7/2004 11:04:47 AM] Started encoding. [11/7/2004 11:04:47 AM] Demuxing and indexing. [11/7/2004 11:07:43 AM] Processing file: D:\TITANIC\VIDEO_TS\VTS_01_1.VOB [11/7/2004 11:07:43 AM] Processing file: D:\TITANIC\VIDEO_TS\VTS_01_2.VOB [11/7/2004 11:07:43 AM] Processing file: D:\TITANIC\VIDEO_TS\VTS_01_3.VOB [11/7/2004 11:07:43 AM] Processing file: D:\TITANIC\VIDEO_TS\VTS_01_4.VOB [11/7/2004 11:07:43 AM] Source aspect ratio: 4:3 [11/7/2004 11:07:43 AM] Source resolution: 720x480 [11/7/2004 11:07:43 AM] Found NTSC source. [11/7/2004 11:07:44 AM] Analyzing source. [11/7/2004 11:20:03 AM] Source has percentage of interlacing in motion areas: 46.34 [11/7/2004 11:20:03 AM] Source has percentage of telecined patterns: 99.08 [11/7/2004 11:20:03 AM] Source has percentage of progressive patterns: 0.92 [11/7/2004 11:20:03 AM] Source has percentage of interlaced patterns: 0.00 [11/7/2004 11:20:03 AM] Source is considered to be FILM. [11/7/2004 11:20:03 AM] Found 279873 frames [11/7/2004 11:20:03 AM] Encoding audio. [11/7/2004 11:51:48 AM] Audio size: 181,810,712 bytes (173.39 Mb) [11/7/2004 11:51:48 AM] Overhead: 11,194,880 bytes (10.68 Mb) [11/7/2004 11:51:48 AM] Video size: 540,997,608 bytes (515.94 Mb) [11/7/2004 11:51:48 AM] Running compressibility test. [11/7/2004 11:51:48 AM] Writing the following script to D:\TITANIC\VIDEO_TS\agk_tmp\Titanic - XviD_comptest.avs =========================================================== LoadPlugin("C:\PROGRA~1\AutoGK\DGMPGDec\DGDecode.dll") LoadPlugin("C:\PROGRA~1\AutoGK\filters\autocrop.dll") LoadPlugin("C:\PROGRA~1\AutoGK\filters\decomb.dll") LoadPlugin("C:\PROGRA~1\AutoGK\filters\RemoveGrainSSE2.dll") movie = mpeg2source("D:\TITANIC\VIDEO_TS\agk_tmp\Titanic - XviD.d2v") cropclip = autocrop(movie,mode=0,wmultof=4,hmultof=4,samples=10,aspect=0,threshold=34,samplestartframe=0) fixed_aspect = 0.888888888888889 c_width = width(cropclip) c_height = round(height(cropclip) / fixed_aspect) input_par = float(c_width)/float(c_height) input_par = input_par > 1.4 ? input_par : (4.0/3.0) out_width = 640 out_height = round(float(out_width) / input_par) hmod = out_height - (floor(out_height / 16 ) * 16) out_height = (hmod > 4) ? (out_height + (16 - hmod)) : (out_height - hmod) new_aspect = (float(out_width) / float(out_height)) / fixed_aspect Telecide(movie,order=1,guide=1,post=2).Decimate(mode=0) autocrop(mode=0,wmultof=4,hmultof=4,samples=10,aspect=new_aspect,threshold=34,samplestartframe=0) LanczosResize(out_width,out_height) DRemoveGrain(mode=2) SelectRangeEvery(300,15) =========================================================== [11/7/2004 12:07:27 PM] Duration was: 15 minutes 39 seconds [11/7/2004 12:07:27 PM] Speed was: 14.90 fps. [11/7/2004 12:07:27 PM] Compressibility percentage is: 23.27 [11/7/2004 12:07:27 PM] Chosen resolution is: 608x272 ( AR: 2.24 ) [11/7/2004 12:07:27 PM] Predicted comptest value is: 25.94 [11/7/2004 12:07:27 PM] Running first pass. [11/7/2004 12:07:27 PM] Writing the following script to D:\TITANIC\VIDEO_TS\agk_tmp\Titanic - XviD_movie.avs =========================================================== LoadPlugin("C:\PROGRA~1\AutoGK\DGMPGDec\DGDecode.dll") LoadPlugin("C:\PROGRA~1\AutoGK\filters\autocrop.dll") LoadPlugin("C:\PROGRA~1\AutoGK\filters\decomb.dll") LoadPlugin("C:\PROGRA~1\AutoGK\filters\RemoveGrainSSE2.dll") movie = mpeg2source("D:\TITANIC\VIDEO_TS\agk_tmp\Titanic - XviD.d2v") cropclip = autocrop(movie,mode=0,wmultof=4,hmultof=4,samples=10,aspect=0,threshold=34,samplestartframe=0) fixed_aspect = 0.888888888888889 c_width = width(cropclip) c_height = round(height(cropclip) / fixed_aspect) input_par = float(c_width)/float(c_height) input_par = input_par > 1.4 ? input_par : (4.0/3.0) out_width = 608 out_height = round(float(out_width) / input_par) hmod = out_height - (floor(out_height / 16 ) * 16) out_height = (hmod > 4) ? (out_height + (16 - hmod)) : (out_height - hmod) new_aspect = (float(out_width) / float(out_height)) / fixed_aspect Telecide(movie,order=1,guide=1,post=2).Decimate(mode=0) autocrop(mode=0,wmultof=4,hmultof=4,samples=10,aspect=new_aspect,threshold=34,samplestartframe=0) LanczosResize(out_width,out_height) DRemoveGrain(mode=2) =========================================================== [11/7/2004 2:56:46 PM] Duration was: 2 hours 49 minutes 18 seconds [11/7/2004 2:56:46 PM] Speed was: 27.55 fps. [11/7/2004 2:56:47 PM] Expected quality of first pass size: 25.95 [11/7/2004 2:56:47 PM] Running second pass. [11/7/2004 6:56:43 PM] Duration was: 3 hours 59 minutes 56 seconds [11/7/2004 6:56:43 PM] Speed was: 19.44 fps. [11/7/2004 6:56:43 PM] Job finished. ---------------------------- thanks again for the great program
Thanks to all for the great programs out there and thanks to all for the support given on these forums |
8th November 2004, 15:23 | #3033 | Link | |
Re: Lenox
8th November 2004, 15:40 | #3035 | Link | |
8th November 2004, 15:57 | #3036 | Link |
Mr. Sandman
Len0x, could you please try beta4 with other sources too?
My tests show beta4 has better (!!!) compressibility than V2 in 3 out of 4 encodes...
8th November 2004, 16:24 | #3037 | Link | |
8th November 2004, 16:38 | #3038 | Link |
Mr. Sandman
Ok, what do you think of Taurus comments about V2 and beta4?
Should i "soften" beta 4?
8th November 2004, 16:46 | #3039 | Link |
I don't know yet - I need to do more tests. I haven't really tested it on any cartoons (and probably will not be able as I don't own anything apart from Anymatrix, that can be a good test though). But I agree with Taurus on one thing - V2 is indeed very solid multipurpose matrix.
8th November 2004, 17:44 | #3040 | Link | |
Mr. Sandman
