3rd December 2003, 14:53 | #601 | Link | |
I'm afraid we've to stop
Re: Large filesize
0.64 beta should correct this problem.
Gordian Knot Family: Gordian Knot: website, download Auto Gordian Knot: Website and download, tutorial, FAQ |
3rd December 2003, 15:04 | #602 | Link | |
3rd December 2003, 16:38 | #603 | Link |
spice captain
some results speed wise
A 9 min star wars clip
divx encode (latest 5.1.1 pro) auto width 512 first pass 36.6fps second pass 39.92fps ( 6 mins per pass ) xvid encode ?? auto width 576 first pass 23.18fps second pass 23.07fps (10mins per pass) Both projected and actual file sizes the same (within 50bytes) both play perfectly on my PC but the xvid does not play well on my standalone However xvid clips using the std codec do work on my standalone. divx faster and more compatible ..so far.. AN option to set the process priority of the main task and all sub-tasks would be great too... so you can surf while autogek'ing in the background.
A melange of ecstacy. Last edited by Wolfman; 3rd December 2003 at 16:50. |
3rd December 2003, 16:51 | #604 | Link | |
Xubuntu21.04 AVS+3.7 x265
Xubuntu 21.04 // AviSynth+ 3.7.0 (r3406, master, x86_64) // x265 3.5+20+2-8c44f9e9b [DJATOM's Mod] |
3rd December 2003, 17:10 | #605 | Link | ||
Re: some results speed wise
Were you using 0.64 ? Quote:
Set it to lowest or even lower. then save settings and they will be picked up automatically everytime VDubMod starts.
3rd December 2003, 18:37 | #608 | Link |
Still oversized movies with latest version
The encode is still slightly oversized (a lot less though)
[12/2/2003 3:23:51 PM] Input dir: X:\bob\Part 2 - Day Of Days [12/2/2003 3:23:51 PM] Output file: F:\bob encode\2\divx5 vx xvid 1 test\divx511.avi [12/2/2003 3:23:51 PM] Audio: English [12/2/2003 3:23:51 PM] Subtitles: Nederlands [12/2/2003 3:23:51 PM] Target size: 1400Mb [12/2/2003 3:23:51 PM] Custom audio settings: AC3 [12/2/2003 3:23:51 PM] Started encoding. [12/2/2003 3:23:51 PM] Demuxing and indexing. [12/2/2003 3:25:16 PM] Analyzing source. [12/2/2003 3:30:10 PM] Source is considered to be interlaced. [12/2/2003 3:30:10 PM] Analyzing PAL source with different field order. [12/2/2003 3:35:10 PM] Source is considered to be interlaced. [12/2/2003 3:35:10 PM] Found 74981 frames [12/2/2003 3:35:10 PM] Indexing subtitles. [12/2/2003 3:36:44 PM] Audio size: 143963136 [12/2/2003 3:36:44 PM] Overhead: 2730368 [12/2/2003 3:36:44 PM] Video Size: 1321312896 [12/2/2003 3:36:44 PM] Target bitrate is: 3524kbps [12/2/2003 3:36:44 PM] Running compressibility test. [12/2/2003 3:45:06 PM] Duration was: 8 minutes 20 seconds [12/2/2003 3:45:06 PM] Speed was: 7.49 fps. [12/2/2003 3:45:06 PM] Compressibility percentage is: 76.85 [12/2/2003 3:45:06 PM] Chosen width is: 704 [12/2/2003 3:45:06 PM] Predicted comptest value is: 76.85 [12/2/2003 3:45:06 PM] Running first pass. [12/2/2003 5:20:55 PM] Duration was: 1 hour, 35 minutes 48 seconds [12/2/2003 5:20:56 PM] Speed was: 13.04 fps. [12/2/2003 5:20:56 PM] Running second pass. [12/2/2003 6:34:12 PM] Duration was: 1 hour, 13 minutes 15 seconds [12/2/2003 6:34:12 PM] Speed was: 17.06 fps. [12/2/2003 6:34:12 PM] Splitting video into: F:\bob encode\2\divx5 vx xvid 1 test\divx511.CD1.avi [12/2/2003 6:35:07 PM] Splitting video into: F:\bob encode\2\divx5 vx xvid 1 test\divx511.CD2.avi [12/2/2003 6:36:09 PM] Splitting video into: F:\bob encode\2\divx5 vx xvid 1 test\divx511.CD3.avi [12/2/2003 6:36:10 PM] Job finished. |
3rd December 2003, 19:03 | #609 | Link | |
Re: Still oversized movies with latest version
3rd December 2003, 19:41 | #610 | Link |
spice captain
just another request
A way to preview the audio file you are going to use would be good.
ALso just finished a full encode and it was slighlty oversized asked for size 870mb (to fit 99mincdr) and the file came out to 891mb .. 192k vbr audio used, maybe this is the problem??
A melange of ecstacy. |
3rd December 2003, 19:50 | #611 | Link | |
Re: just another request
XenoDaSouljah only got slight oversize(3.5Mb) and you're that large(21Mb)... Can please ppl which are having oversize problems say which source (PAL/NTSC) are they using?
3rd December 2003, 21:07 | #613 | Link | |
I though I missed something rather large here...
3rd December 2003, 21:16 | #614 | Link |
finaly i've found some time to make some DivX5 Tests. Mostly testing several short streams (about 3-5 mins).
mostly i had a bit undersized files (just about 100kb-1,1MB), no oversized files...
3rd December 2003, 23:12 | #615 | Link |
The X in DivX
Autogk 0.60
divx 5.11 pal sources (25 fps) aiming for 2cd rips (1400 mb) ac3 sound auto resizing did 3 movies, all 3 were 28-30 mb off Autogk 0.64: 1.468.125.184 Bytes splitted: 733.202.432 Bytes (699 mb) 731.232.256 Bytes (697 mb) = 1.464.434.688 Bytes 2 mb to Short???
AutoGK rulez! |
3rd December 2003, 23:12 | #616 | Link |
How about a Divx quality slider? There could be the current setting and a "high quality" setting which would be 4 passes (3 standard and the last one at "slowest").
ps. this is only supported on 5.1.x |
3rd December 2003, 23:16 | #617 | Link | |
3rd December 2003, 23:25 | #618 | Link |
sizing problems
OK, looks like I solved oversizing issue - that's good. I will look into slight undersize during following couple of days (I can't see where i was wrong atm, but no worries ). May be it's general problem - in current GK you might not notice that because split actually increases size since interleaving settings are reset when splitting (don't tell anyone I fixed that in AutoGK and GK in CVS but not compiled 0.28.6.4 yet). So now I'm getting slightly undersized files as well. So we'll see - i have to do more tests. If you want to help try encoding manually in GK and compare (I'm trying to be at least as accurate as GK and after that we may try to be even more accurate...)
@ najt I knew that someone eventually asks for that (multipass). We'll see about that afterwards. But in general if you have so much spare time, then IMHO it's better to invest it in XviD encoding, which only disadvantage was speed...
Gordian Knot Family: Gordian Knot: website, download Auto Gordian Knot: Website and download, tutorial, FAQ Last edited by len0x; 3rd December 2003 at 23:28. |
3rd December 2003, 23:41 | #619 | Link |
And about the hyperthreading issue. SubRip also crashes, but I can't even start it, while AutoGK doesn't crash so often. It is written in Delphi (I pressume AutoGK is also) so check borland's developer network for a solution. Could be a bug in a dll that SubRip and AutoGK use.
btw, runtime error 216 is an access violation. |
3rd December 2003, 23:46 | #620 | Link | |
Graphite mod
@len0x,
Finished my second test encode. Results summarized: Movie: Indiana Jones III. Encoding mode: Maximum Quality (unlimited size) Code:
AutoGK Output Encode Encode Version Codec file size Time Speed ------------------------------------------------- 0.5 XviD 3.01-GB 4:05:06 12.41 0.6 DivX 3.10-GB 2:35:02 19.62 Quote:
MPEG4 quality with MPEG2? - Try the Poor Man's DVD. FACAR - As seen on TV! - The Complete Idiot's Guide to a good DVD Conversion. Time is money. Try D2Sroba for DVD2SVCD (FAQ) and save both. All electricity bills supported! Do you know how much overscan and which resolution your TV has? Find out if NTSC. Moderator: 1: one who arbitrates 2: one who presides over an assembly, meeting, or discussion 3: a substance (as graphite) used for slowing down neutrons in a nuclear reactor (Webster) |
4th December 2003, 00:42 | #621 | Link |
don't blame me!
Help me please.
I am too stupid. I can not even get AutoGK 0.64 to run. First it told me, "Xvid not found..., app will now exit." Ok, I installed Xvid. Now the AutoGK tells me "is not found, app will now exit.", without telling me who or what is exactly missing. Anybody got this problem? Thanks for a hint. |
4th December 2003, 00:54 | #622 | Link | |
Re: Re: Still oversized movies with latest version
(source was a pal dvd) Last edited by XenoDaSouljah; 4th December 2003 at 00:56. |
4th December 2003, 00:57 | #623 | Link | |
4th December 2003, 01:10 | #625 | Link | |
Re: Re: Re: Still oversized movies with latest version
4th December 2003, 01:12 | #626 | Link | |
Re: Re: Re: Re: Still oversized movies with latest version
4th December 2003, 01:15 | #627 | Link | |
Re: Re: Re: Re: Re: Still oversized movies with latest version
4th December 2003, 01:23 | #628 | Link | |
Re: Re: Re: Re: Re: Re: Still oversized movies with latest version
4th December 2003, 01:33 | #630 | Link | |
Re: Re: Re: Re: Re: Re: Re: Still oversized movies with latest version
*edit* you can use the same avs file which was created in tmp dir *edit2* do you see the same bitrate in GK as you see in the logs of AutoGK ?
Gordian Knot Family: Gordian Knot: website, download Auto Gordian Knot: Website and download, tutorial, FAQ Last edited by len0x; 4th December 2003 at 01:37. |
4th December 2003, 02:09 | #632 | Link |
DVD Rebuilder!
problem with divx 5.1.1 pro
I have problem with divx 5.1.1 pro,
the comp. test is ok, but it will not start the 1st-pass, somehow the Vdubmob doesn't like the color space (error -2) ??? I try with the xvid the same vobs with no problem |
4th December 2003, 05:21 | #633 | Link |
I used 0.64 and it worked great.
This may be a stupid question, but I couldn't find an answer in the forums anywhere. Can Auto GK be used to convert DV .avi files to Divx? I have a bunch of DV home movies that I want to convert to Divx. I have been using Dr. Divx, but I would love to use AutoGK if possible. If there is a tutorial somewhere for that, please point me there. |
4th December 2003, 06:01 | #634 | Link |
load mpg
Hello...
I've been using autogk every time that I do an xvid encode and I have one request. That would be to load/encode a mpg file, not just vob's. It would be handy to compress tv captures. JJ |
4th December 2003, 10:33 | #637 | Link |
(incf encode-mpeg-counter)
for those who would like to use it to encode dv-stuff. \begin{joke-offtopic} *shall we also play guess the programming language* \end{joke-offtopic} Last edited by rmagere; 4th December 2003 at 10:35. |
4th December 2003, 11:30 | #638 | Link |
AGK 0.64 and DivX 5.11
Just my experience: I tried to encode a movie with DivX 5.11 pro and it did not work under automatic settings! This morining, after 7 hours of computing, VirtualDub reported in the status bar 23% done! I did another test this morning, where after 1 hour only 2% were done. XVid did fine with 0.5. I'll give it a try with 0.64 soon.
4th December 2003, 12:21 | #639 | Link |
In my tests I can see that divx5 files always slightly undersized (and it's the same for GK), and I have no idea how come XenoDaSouljah got oversized one... More tests from him would be appreciated.
@All About AVI/MPG input - I have only so much free time to work on this, eventually support for those would be added I guess, but no promices on when.
4th December 2003, 13:42 | #640 | Link | |
