Old 16th May 2012, 10:54   #11001  |  Link
DragonQ
You can force your GPU to stay in P1 when using CUVID with certain tweaker programs but this may not provide enough power for lower-end cards aimed at the HTPC market. Using DXVA2 Native is better in terms of power usage.
Old 16th May 2012, 11:02   #11002  |  Link
aufkrawall
With those cards, P0 state may consume less power than P12 state with big Fermis.
Doesn't work with madVR and QS still consumes less power.
Old 16th May 2012, 13:53   #11003  |  Link
shadowdogg
I have only noticed this to happen in HP1 ultimate edition but it keeps wanting to restart to the beginning part way through the track? Then randomly fix itself later.. it doesn't do that with TMT5 or FFDshow audio decoder
shadowdogg is offline   Reply With Quote
Old 16th May 2012, 15:15   #11004  |  Link
egur
QuickSync Decoder author
Originally Posted by aufkrawall View Post
I'm curios for QuickSync deinterlacing.
With 1080p VC-1 interlaced my GPU still has to switch to P0 state with shader deinterlacing, very annoying.
HQ deinterlacing via QS "for free" would really be a nice thing.
I really got exited about QS in general.
In QuickSync, the deinterlacing is ASIC not shaders for superior power/performance (same goes for everything you see in the driver's Media control panel).
My decoder has already basic support for it so LAV + QS DI is not far.
The price will be more memory copying, but the next feature will be output of DXVA frames. I'll also add the option to copy the DXVA frames so subtitle could be added on them. I'll ask for suggestions/requirement when it's relevant.
Eric Gur,
Processor Application Engineer for Overclocking and CPU technologies
Intel QuickSync Decoder author
Intel Corp.
egur is offline   Reply With Quote
Old 16th May 2012, 16:51   #11005  |  Link
aufkrawall
Will the quality be about the same as CUVID or madVR?
Old 16th May 2012, 19:52   #11006  |  Link
egur
I think MadVR uses DXVA deinterlacing which will be the same.
CUVID will be different and we need some test clips. My guess is that for most clips, they will produce similar results. I'm not familiar at all with the DI quality of CUVID.
Eric Gur,
Intel Corp.
Old 16th May 2012, 19:54   #11007  |  Link
nevcairiel
It uses the same DXVA deinterlacing. I was hoping aufkrawall realized by now that all deinterlacing done is the same GPU deinterlacing. :P
Of course CUVID uses NVIDIAs deinterlacing....
Old 16th May 2012, 21:44   #11008  |  Link
Fullmetal Encoder
That's interesting.
So, Nvidia, AMD and Intel have a dedicated function on the chip to do HQ deinterlacing?
Edit: Or at least in the driver.
Define "high quality."
While hardware de-interlacing I've seen is better than nothing it still leaves obnoxious distortions in the image. So far, nothing I've seen can compare to QTGMC. It really is a shame that we can't abstract QTGMC into an algorithm that could be implemented in such a way as to run on a GPU.
Fullmetal Encoder is offline   Reply With Quote
Old 16th May 2012, 22:10   #11009  |  Link
aufkrawall
Alright.
I just lent that term from the LAV decoder GUI.
I haven't tried QTGMC yet, but now that you mention it, I will do so.
That weird tearing artifacts are really totally fugly.
Old 16th May 2012, 22:34   #11010  |  Link
DragonQ
I can't see any deinterlacing artefacts on a VP4 GPU. I'm sure the algorithm is better than older GPUs though because my VP2 GPU's deinterlacing doesn't look as good in fast moving scenes.
Old 16th May 2012, 22:48   #11011  |  Link
aufkrawall
I see kind of tearing when he is moving his hand quickly:
http://forum.doom9.org/showpost.php?...3&postcount=15
Old 16th May 2012, 22:53   #11012  |  Link
ajp_anton
ajp_anton's Avatar
Originally Posted by STaRGaZeR View Post
That only applies to uncompressed video.
How else would I compare the two? Both double the uncompressed data, so they both probably slightly-less-than-double the compressed data.
I was countering the "4:2:0 sucks on colored edges" argument.
Old 16th May 2012, 23:13   #11013  |  Link
kolak
QTGMC and deinterlacing in LAV decoder is like day and night
I have not seen anything, which comes close to QTGMC- including DigitalVision DVO filters. They have 20 years experience in motion/video aspects, but even so QTGMC is better. Maybe Teranex box can match it, but I would not be so sure.
Problem with QTGMC is speed
Old 16th May 2012, 23:21   #11014  |  Link
MasterNobody
2160p 4:2:0 quadruple uncompressed bitrate not double as 1080p 4:4:4. And as was mentioned already chroma samples in 4:2:0 are not aligned with luma so you can't simply downsize luma to get 4:4:4.
MasterNobody is offline   Reply With Quote
Old 16th May 2012, 23:47   #11015  |  Link
xv
Why shouldn´t it be possible to create 4:4:4 by downsizing? You just need to know chroma position and use correct subpixel-cropping during resize. AviSynth-resizers support that (you can use float parameters as source position):
...Resize(clip clip, int target_width, int target_height, float src_left, float src_top, float -src_right, float -src_bottom)
I think you will have a position change of 0.5 pixel towards the bottom for standard 4:2:0 chroma position (at the bottom 0.5 pixel are missing and at the top 0.5 pixel are added by the resizer)
Any news for DV sound problem? Problem reproduceable with my sample?
xv is offline   Reply With Quote
Old 17th May 2012, 00:20   #11016  |  Link
STaRGaZeR
4:2:0 hater
Compressed obviously, because that's what would be distributed eventually.
Regarding the bitrate, that's not true at all. Encoders do a much better job discarding info when compressing than just blindly removing 3/4 of the color samples. For a given bitrate, if you feed the encoder with 4:4:4 and 4:2:0, 4:4:4 will look much better without sacrificing luma quality.
The same thing happens with audio. Just feed the encoder with your 48kHz source and let it decide what is important and what is not, instead of lowpassing the source to 24kHz and compressing that. At a given bitrate, the 48kHz one will sound much, much better.
Specs, GTX970 - PLS 1440p@96Hz
Originally Posted by Manao View Post
That way, you have xxxx[p|i]yyy, where xxxx is the vertical resolution, yyy is the temporal resolution, and 'i' says the image has been irremediably destroyed.
STaRGaZeR is offline   Reply With Quote
Old 17th May 2012, 01:11   #11017  |  Link
ajp_anton
ajp_anton's Avatar
I never mentioned 2160p. I specifically said increase the resolution so that the bitrate doubles. It doesn't give the same chroma resolution as simply going 4:4:4, but it also increases the luma resolution
That's true... I was somehow thinking lossless compression. Yes, a (good) lossy encoder should be able to decide where to keep the chroma at high quality and where not to.
Old 17th May 2012, 01:34   #11018  |  Link
Fullmetal Encoder
Yes, I'd really like to see a direct comparison between Teranex and QTGMC. Though I doubt Teranex could beat it. And yeah it's slow but if memory serves the last time I tested it I was able to get it to run with Preset="slow" in real time without video freezing and that's with a Core i7 860 at stock speeds. Hell even at medium preset it's still better than the deinterlacing on my Radeon 5850. Makes me wonder what will be possible with a Haswell "E" processor at end of next year which is probably what I'll be upgrading to.
The only way I can think of that you could find better deinterlacing than with QTGMC would be with a manual frame-by-frame approach.
We need to get -Vit- and Didée jobs with Teranex so they can straighten out their act.
Old 17th May 2012, 02:29   #11019  |  Link
Andy o
Originally Posted by SamuriHL View Post
For media converter from ArcSoft it works fine. For madVR, not so much. I have to use Egur's trick of setting up a fake display. But I have CUVID now so I don't much care about it for madVR. QS is freaking *FAST* for transcoding blu-rays to mp4's for my Xoom, though. Like 7 minutes fast. It's insane.
How about if you connect the display to the Intel output, and use Virtu to access 3D graphics from NV instead? I think such a solution would work for me, if I could have an NV card with Intel HDMI audio, if Intel doesn't have the "silent stream" thing.
MSI MAG X570 TOMAHAWK WIFI, Ryzen 5900x, RTX 3070, Win 10-64.
Pioneer VSX-LX503, LG OLED65C9
Andy o is offline   Reply With Quote
Old 17th May 2012, 02:58   #11020  |  Link
SamuriHL
SamuriHL's Avatar
Wouldn't you wanna do the opposite then? I believe Nev said connecting Intel to the receiver for audio and the nVidia card to the display for video works fine. I haven't tried it cause I don't know where the hell I put my spare HDMI cables. But I'm seriously considering it because the 680 has massive overscan issues when going through the Pio Elite. I have to set a custom res to get it to work and it makes me unhappy. I'm replacing the TV sometime this year with a plasma screen, but, that's a few months away at the earliest.
