4th February 2012, 19:49 | #8803 | Link |
on the subject of dvd playback, this is what I do, and it works for some reason:
lav video and lav splitter don't connect use microsoft dtv-dvd video decoder and dvd navigator instead add ffdshow audio processor (you can even disable mixer,add 32 float output for it, so it isn't actually doing anything) voila, the open dvd function of mpc hc now works for some reason, having it go through another audio filter prevents macrovision errors. renethx at avsforums detailed all the possibilities for dvd playback, including this method http://www.avsforum.com/avs-vb/showp...&postcount=654 Last edited by mindbomb; 4th February 2012 at 19:52. |
4th February 2012, 20:39 | #8804 | Link | |
Otherwise, how could I have watched smooth DVDs back in the days on my 600mhz laptop? |
4th February 2012, 22:02 | #8805 | Link | |
MPC-HC 2.2.1 |
5th February 2012, 00:16 | #8807 | Link |
Could you be a bit more specific?
My hobby website |
5th February 2012, 00:33 | #8808 | Link | |
i think you have to decrypt the dvds first? idk |
5th February 2012, 00:49 | #8809 | Link |
I cannot be specific if the specifics haven't been specified yet
The main deal is that the .ax files will no longer mess with the registry in "unsafe" ways. This makes no difference at all for the decoders, but the splitter will need extra help to get going, which the installer will provide instead.
5th February 2012, 01:16 | #8811 | Link |
It is very much possible that ripping to harddrive makes a difference in avoiding the Copy-Protect error. I tested with an actual DVD disc. Depending on the filterset I get either Macrovision error or Copy-Protect error.
MPC-HC 2.2.1 |
5th February 2012, 02:51 | #8813 | Link |
Just wait for Native
@Nev Runtime wrong Detected 2:20 min (no seek possible) http://www.mediafire.com/?7611h5nk120y9cm VLC = 1:37 ??? (seeking ok) Mpc-HC Splitter = ok Mainconcept Splitter = ok Av splitter = fail (0:01) Lav Splitter = fail (0:01) Microsoft Splitter = fail (0:01)
all my compares are riddles so please try to decipher them yourselves :) It is about Time Join the Revolution NOW before it is to Late ! http://forum.doom9.org/showthread.php?t=168004 Last edited by CruNcher; 5th February 2012 at 04:46. |
5th February 2012, 04:50 | #8814 | Link | |
There is a degree of respect that needs to be held for developers who share their work with others for nothing other than appreciation and interest. This is important Pepp, it makes people feel valued when you treat them with respect, they in turn will reciprocate this back to you, everyone wins. What Madshi said was neither antagonistic nor negative IMO. In fact I never in my time on the forum seen him as being either of those two things! Even when directed with somewhat harsh criticisms in what I have considered to be in a rude manner, this always spoke volumes to me as a good judge of his character. What was said merely serves as a warning to others and was just basic socializing, I actually found the post quite humorous Remember, these projects are created for their enjoyment, thankfully we can share in it by discussing ideas and testing new features. Please place yourself in their shoes before commenting, thanks. |
5th February 2012, 05:21 | #8815 | Link | |
The fact that you find the instigation of negative posts towards users humorous is in fact a sad reflection on your own social defects. Last edited by Pepp; 5th February 2012 at 05:23. |
5th February 2012, 05:49 | #8816 | Link | |
I used to be able to play DVDs with MPC, but it didn't support post-processing; I could play DVDs with ffdshow, but it didn't properly support menus; with the appreciated release of LAV, I was hoping to get better playback for all codecs including DVD with an opportunity to also do processing with GPU and CPU. One must understand that DVD playback is far more than decoding: to get the best results when upscaling to an HDTV, one must de-interlace well and post-process the video for noise and other artifacts. There is a thread on AVSforum I believe about getting the best results for DVD upscaling, using ffdshow, but it requires a top of the line CPU due to the supersampling and avisynth processing routines included. Eventually I would like to achieve similar quality effects, but using both GPU and CPU to reduce the hardware requirements. My Oppo 93 met all my requirements for DVD and Bluray, because it uses a Qdeo VP, but now that file playback is being eroded by the studios, I need a replacement and currently an HTPC is the likeliest candidate as none of the media players do Video Processing. Last edited by IanD; 5th February 2012 at 05:51. |
5th February 2012, 08:47 | #8817 | Link |
@Nev
Snow playback issue http://www.mediafire.com/?c4j4l6xoooae6c2 ffplay = ok lav splitter + lav video = fails connection
all my compares are riddles so please try to decipher them yourselves :) It is about Time Join the Revolution NOW before it is to Late ! http://forum.doom9.org/showthread.php?t=168004 |
5th February 2012, 09:30 | #8818 | Link |
Bleh, some moderator should take a look at the IPs of those "Jan 2012" concern trolls who suspiciously appeared after the first guy went MIA knowing that others have put that name under their ignore lists.
MSI MAG X570 TOMAHAWK WIFI, Ryzen 5900x, RTX 3070, Win 10-64. Pioneer VSX-LX503, LG OLED65C9 |
5th February 2012, 09:57 | #8819 | Link | |
Firefox User
5th February 2012, 10:01 | #8820 | Link | |
