Old 25th November 2011, 00:54   #7301  |  Link
rica
Thanks dude but what is MC 17?
rica is offline   Reply With Quote
Old 25th November 2011, 00:55   #7302  |  Link
SamuriHL
SamuriHL's Avatar
JRiver's MediaCenter version 17. A commercial player that can use directshow filters such as LAV Filters, madVR, etc. It's a great player.
Old 25th November 2011, 00:58   #7303  |  Link
rica
Yeah. I remember it from my earlier Kernel/Wasapi bitstreaming trials
These are the audio-only applications which have wasapi plugins:
Foobar2000
XMPlay
and commercial MediaCenter13 (no plug-in seperately)
quoted from avsforum's HTPC section. (March 8th, 2009)
Old 25th November 2011, 00:59   #7304  |  Link
SamuriHL
SamuriHL's Avatar
I would think you'd appreciate the audio capabilities built into that player.
Old 25th November 2011, 01:08   #7305  |  Link
rica
I'm sure if you are saying. I will try MC again. Thanks.
Old 25th November 2011, 01:12   #7306  |  Link
SamuriHL
SamuriHL's Avatar
It's the player I've been using the most. It works EXTREMELY well with LAV Filters. I have it set to decode all my audio and turn on a feature they call Video Clock. Basically it emulates what ReClock does. Apparently madshi worked with them on that feature which is why it works really well with madVR, as well. I haven't even begun to dive into the audio features, but, this thing is loaded. WASAPI exclusive? No problem. Event driven WASAPI exclusive? No problem. Basically it just rocks.
Old 25th November 2011, 01:15   #7307  |  Link
rica
Then please post your scripts.
Old 25th November 2011, 01:27   #7308  |  Link
SamuriHL
SamuriHL's Avatar
My scripts wouldn't be useful to anyone else. Highly customized for my build environment. Nonetheless if you want the copy script:
@ECHO OFF
set SRC="\\SAMURI-PC\Users\Samuri\Downloads\Video\LAVFilters"
ECHO ____________________________________
ECHO *****Updating MC17 private copy*****
ECHO ------------------------------------
set DEST="C:\Users\Samuri\AppData\Roaming\J River\Media Center 17\Plugins\lav"
robocopy %SRC% %DEST% /PURGE
set SRC="C:\Program Files (x86)\ArcSoft\TotalMedia Theatre 5\Codec"
robocopy %SRC% %DEST% dtsdecoderdll.dll
PAUSE
The reason I'm using a network path is that any machine on my network can run this script and get my updated LAV Filters. My build script copies them to the Downloads\Video\LAVFilters folder. As you can see it purges all the files in the private lav folder in MC17. This is in case any files change/get removed between LAV versions. Hasn't happened lately but it has happened before so I add the purge in there. That means anything that's not in my Downloads\Video\LAVFilters folder will be deleted. After that's done, it copies in the DTS decoder from TMT5. I do it that way in case they release a new version that updates it. That way I always have the latest. Unlikely this is going to help anyone, but, there it is if you need it.
Old 25th November 2011, 01:40   #7309  |  Link
rica
OK, i've changed my PC's name to "Samuri" and it works
Sure just a joke, thanks for the info.
Old 25th November 2011, 01:41   #7310  |  Link
SamuriHL
SamuriHL's Avatar
ROFL I told you it was highly customized! hehehehe
Old 25th November 2011, 01:50   #7311  |  Link
rica
Sorry i forgot to say i even put Lav Filters folder into samuri\downloads\video folder
Old 25th November 2011, 01:51   #7312  |  Link
SamuriHL
SamuriHL's Avatar
Excellent, you're ALL set now!
Old 25th November 2011, 01:59   #7313  |  Link
rica
Yes i know it seems very fake-selfcustomized, anyways
Old 25th November 2011, 02:43   #7314  |  Link
rica
Originally Posted by rica View Post
Gave it a go and sure 0.41 is ready to be published
Thanks nev for all your efforts.
I felt i need to repeat that since it might have been lost in our chat with samuri.
Old 25th November 2011, 03:55   #7315  |  Link
Sebastiii
Hi
So far i can tell, it works really nice it solve my seeking issue on some sample (by creating an index so first seek can take some second (10 seconds) but after that seek was ok).
Chapters is working.
Subtitles too.
Maybe (on my side) audio switching between stream was a little slower but working
Ofc all related to mkv
Thanks Nevcairiel
HTPC : i7 920 6Go Win10(x64) / Nvidia 1050Ti / P6T Deluxe / Harman-Kardon AVR-355.
Sebastiii is offline   Reply With Quote
Old 25th November 2011, 07:43   #7316  |  Link
roytam1
Firefox User
@nev:
I'm getting git submodule update issue:
/d/lavfsplitter$ git submodule update
fatal: reference is not a tree: 8fd7a6e82ff6e54cc66001e6ae38dddaffb8b29c
Unable to checkout '8fd7a6e82ff6e54cc66001e6ae38dddaffb8b29c' in submodule path 'ffmpeg'
roytam1 is offline   Reply With Quote
Old 25th November 2011, 08:08   #7317  |  Link
nevcairiel
Originally Posted by roytam1 View Post
@nev:
Just use the same ffmpeg as from the mkv branch, i didn't update the reference on the master branch because it seemed useless.
Old 25th November 2011, 08:38   #7318  |  Link
roytam1
Firefox User
I see.
New nightly (mkv branch with master changes merged):
http://roy.orz.hm/lavf-w32-nightlies...ter-19c9e9f.7z
diff (RV3/4 key frame with master changes merged):
http://roy.orz.hm/lavf-w32-nightlies...r-19c9e9f.diff
Old 25th November 2011, 14:38   #7319  |  Link
fastplayer
nev, is the new MKV demuxer also used for WebM files?
fastplayer is offline   Reply With Quote
Old 25th November 2011, 14:40   #7320  |  Link
nevcairiel
WebM files are just mkv files with some feature limitations, so yes of course.
