Old 4th September 2009, 13:14   #9301  |  Link
tebasuna51
tebasuna51's Avatar
Originally Posted by Bozster View Post
I archive all my movies as DTS 1.5mbps because I can't hear the difference above that even with DTS-MA or TrueHD. The DD (480,640) and DTS (768) are different story. I can hear those being softer when compared to HD audio but anything at 1.5mbps I can't hear it.
Is your choice.
But try encode a DTS-MA or TrueHD to AC3 640 Kb/s and compare with DTS 1.5Mb/s
tebasuna51 is offline
Old 4th September 2009, 14:00   #9302  |  Link
raquete
Is your choice.
i never could hear differences using wave sources in 24b/48k.
AC3 640K is really "the way to go" with short size and play in all standalones(i never saw standalones that can't play 640K but i can be wrong as i don't know all models(of course)).
observation: i only use AFTEN(WAVtoAC3Enc) for AC3.(is the same AC3 encoder used in EAC3to)
with others encoders used before i always found "issues" and was posted somewhere in this audio forum.
raquete is offline
Old 4th September 2009, 16:30   #9303  |  Link
yesgrey
Just for curiosity, do you think that AC3 640kbps sounds better than DTS 1.5Mbps?
yesgrey is offline
Old 4th September 2009, 16:54   #9304  |  Link
tebasuna51
tebasuna51's Avatar
I just say: AC3 is more efficient than DTS.
I think I put this comparative 3 times in this thread:
http://tech.ebu.ch/docs/tech/tech3324.pdf
Old 4th September 2009, 20:59   #9305  |  Link
Blue_MiSfit
Derek Prestegard IRL
Blue_MiSfit's Avatar
I usually keep the AC3 track for compatibility purposes - and S/PDIF transport. At 448+kbps it's honestly "good enough" for me! If I must transcode something, it's always to Nero AAC-LC. The default Q=.5 sounds very good to me, and it's almost always smaller than 640kbps AC3.
I find the tasty high resolution / bitrate audio tracks tempting, but I'm rarely impressed by the difference. Once in a blue moon I'll FLAC a high-res track - but AAC is usually awesomely awesome for my tastes!
BTW - excellent link, tebasuna51! It was an interesting read, and further substantiates what folks have been saying on doom9 for years
~MiSfit
Blue_MiSfit is offline
Old 4th September 2009, 22:28   #9306  |  Link
yesgrey
Thanks! and sorry to make you repeat yourself...
yesgrey is offline
Old 6th September 2009, 09:08   #9307  |  Link
Bozster
http://www.ebu.ch/CMSimages/en/tec_d...tcm6-53801.pdf
I read the comparison..however I can tell you that DTS 1.5mbps is virtually indistinguishable from DTS-MA or TrueHD even in controlled conditions and blind tests by experts.
DD/DD+ at 640kbps can indeed be better than DTS 768 but based on tests the only versions that provided maximum quality at lowest sizes without sacrificing quality were DTS 1.5mbps and DD+ 1.5bmps and above.
You can read about comparisons here:
http://www.hemagazine.com/node/Dolby...compressed_PCM
They visited both DTS and Dolby labs.
They did say that even though DTS-MA, TrueHD and LPCM offered high bitrates and excellent quality, DD and DTS held very good even at 448/640/768 bitrates. Even though they could distinguish the audio difference with these lower bitrate codecs (they say it did sound a bit softer and flatter) they would be good enough to majority of people while DTS 1.5 and DD+ 1.5+ couldn't be spotted at all in blind tests against DTS-MA/TrueHD/LPCM.
This is why I chose to encode my movies with DTS 1.5mbps. I even have SurCode encoder where I encode TrueHD as DTS 1.5mbps.
Just some thoughts.
Bozster is offline
Old 6th September 2009, 09:12   #9308  |  Link
Bozster
Is your choice.
So you think that I wouldn't hear a difference between AFTEN'ed TrueHD track as AC3 640 vs DTS 1.5?
I mean, I'd definitely do that because it would mean better compatibility with PS3 and xbox 360 which i have everywhere around my house as extenders but based on above articles I'm feeling more confident encoding as DTS 1.5 as I'm trusting these blind tests myself so I want to be sure.
Bozster is offline
Old 6th September 2009, 11:11   #9309  |  Link
yesgrey
That's not what I've read...
They weren't capable of hearing the difference between the lossless formats and DTS-HD High Resolution / DD+ 1.5mbps.
DTS-HD High Resolution is between 2.0 and 6.0mbps, and the core DTS are 768kbps (DVD) and 1536kbps(BR). They were capable of noticing a slightly difference between the core DTS's and the lossless, but between DD 640kbps and the lossless only one of them was able to tell the difference. So, that test also seems to indicate that DD 640kbps is equal or slightly better than DTS 1536kbps.
There was an important distinction in the two tests, though. In Dolby it was a blind test, but in DTS it wasn't. It's "easier" to spot a difference when you know that should be there...
Edit: Don't forget also that in Dolby it was only a 10s test, and by their description of the sound it did not seem to be a very hard to compress piece. A soundtrack is more than 1H30m, so maybe it's not such a good idea to relly your decision in a comparison made with only 10s of a soundtrack...
yesgrey is offline
Old 6th September 2009, 12:14   #9310  |  Link
tebasuna51
tebasuna51's Avatar
Maybe my english is so bad, but at the link you provide there aren't comparasion between DTS and AC3, only between uncompressed audio and AC3/DTS and the conclusion is:
"The lossless, Dolby Digital Plus, and DTS-HD High Resolution compressed tracks were just a little more open and airy. I hate to say it, but they just sounded more realistic and transparent. The 448 kbps Dolby Digital and standard DTS tracks were less so, a little more closed off. Between the 640 kbps Dolby Digital and the uncompressed, the difference was even less noticeable."
I think he compare 448 Kb/s DD with 1.5 Mb/s DTS, and say 640 Kb/s DD is better.
Old 6th September 2009, 12:42   #9311  |  Link
raquete
@ Bozster
chose one music(send me some options, maybe i have here)
i will encode in 5.1 and send: AC3-640k, DTS-1.5Mb, the seperateds waves useds as sources (L,R,C,LFE,LS,RS) and multichannel wave too.
after hear AC3 and DTS, tell us "who is who". after that compare the sound with the waves.
deal? :-)
raquete is offline
Old 6th September 2009, 13:19   #9312  |  Link
RonaldoSan
I have a 6 channel wav file (created with eac3to) that I need to cut up into 6 wav files containing each their own channel.
Is this possible with eac3to?
RonaldoSan is offline
Old 6th September 2009, 15:28   #9313  |  Link
G_M_C
Originally Posted by RonaldoSan View Post
I have a 6 channel wav file (created with eac3to) [...]
Reprocess the source, and use the commandline to save "WAVs" in stead of "WAV".
G_M_C is offline
Old 6th September 2009, 17:15   #9314  |  Link
RonaldoSan
I was looking to avoid that, but I guess that is what I have to do.
Thanks for you help.
Old 6th September 2009, 18:24   #9315  |  Link
tebasuna51
tebasuna51's Avatar
You can use the multichannel wav like input because is a lossless process:
eac3to multichan.wav mono.wavs
Old 7th September 2009, 00:20   #9316  |  Link
amgeex
amgeex's Avatar
Just a quick question. When one does a eac3to -demux movie.mpls, the audio is not touched, right? The .dtsma audio I get is pure and not dependant on any decoders I have (or don't have) installed on my computer, right?
Thanks in advance!
amgeex is offline
Old 7th September 2009, 04:14   #9317  |  Link
Bozster
Nope I disagree.. he meant in comparison to 448k DD and 768 DTS (as that's the standard DTS). The 1.5mbps DTS is not really standard.
Bozster is offline
Old 7th September 2009, 11:16   #9318  |  Link
yesgrey
It's the standard for Blu-ray.
yesgrey is offline
Old 7th September 2009, 11:33   #9319  |  Link
raquete
and DTS 1.536 Mb/s (we can name as 1.5Mb) for dvd.
if DTS 768 is the standard, DD 448K win for miles and the competition between formats is without sense.
raquete is offline
Old 7th September 2009, 20:19   #9320  |  Link
Snowknight26
A nice feature for eac3to would extracting a FLAC stream from an mkv file. Currently, the FLAC stream is decoded then encoded back to FLAC.
Snowknight26 is offline
eac3to
