15th March 2017, 02:19 | #3141 | Link |
there are already isy()
See My Avisynth Stuff |
15th March 2017, 21:35 | #3142 | Link |
converttoy() converttofloat() subtitle(PixelType().string()+" "+isY().string()) convertbits(32) subtitle(PixelType().string()+" "+isY().string(),y=16) convertbits(16) subtitle(PixelType().string()+" "+isY().string(),y=32) convertbits(14) subtitle(PixelType().string()+" "+isY().string(),y=48) convertbits(12) subtitle(PixelType().string()+" "+isY().string(),y=64) convertbits(10) subtitle(PixelType().string()+" "+isY().string(),y=80) convertbits(8) subtitle(PixelType().string()+" "+isY().string(),y=96) I'll give you an hint...
powered by Google Translator Last edited by Motenai Yoda; 15th March 2017 at 21:43. |
15th March 2017, 23:42 | #3143 | Link |
16th March 2017, 13:33 | #3145 | Link | |
Acid fr0g
@turment on Telegram |
16th March 2017, 16:37 | #3146 | Link |
New Avisynth build.
Avisynth+ r2455-MT Code:
v2455 (20170316), changes since v2440 ------------------------------------- # Fixes IsY() script function returned IsY8() (VideoInfo::IsY was not affected) # other modification, additions ConvertBits, dither=1 (Floyd-Steinberg): allow any dither_bits value between 0 and 8 (0=b/w) Last edited by pinterf; 16th March 2017 at 17:37. Reason: Edit: Quick 2454->2455, dither_bits=0 for 10->10 bits now work |
16th March 2017, 17:55 | #3149 | Link | |
dither_bits=0 -> 2 levels dither_bits=1 -> 3 levels dither_bits=2 -> 5 levels dither_bits=3 -> 9 levels |
16th March 2017, 22:47 | #3150 | Link |
no, no convert will done, input = output, but you can do it by your self, there are no need for dither dll without lsb in first place
16th March 2017, 23:25 | #3151 | Link |
Professional Code Monkey
I HATE YOU ALL
The baked code related to PClip doesn't error out if AVS_Linkage is null. Instead it does nothing. This means that if a PClip (and probably most other objects too) is constructed with null linkage it'll consist of uninitialized memory and will most likely crash if the linkage is set later. Just crash immediately if this happens, you'll save the world a lot of bugs that way.
17th March 2017, 07:42 | #3153 | Link |
convertbits(16)
SMDegrain() convertbits(10,dither=1,dither_bits=8)
17th March 2017, 09:51 | #3155 | Link |
I just find this by chance https://github.com/DJATOM/TCPDeliver/releases I put the link since there are no TCPDeliver in avs+
18th March 2017, 07:31 | #3157 | Link | |
Using noise pattern Since v1.5 it is possible to get noise pattern (shape) by spectrum analysis of some empty block (without any objects), and then to reduce the noise with the same pattern in whole frame and in whole clip. It may be useful for removal of film (especially amateur 8 mm) grain and analog TV capture interference.
In order to use noise pattern method in place of ordinary (blind) method you must: Firstly switch show mode pshow=true, and set some non-zero value pfactor=1.0. Then select frame number and some block position, thus the block shown must not contain any objects beside typical noise pattern. The switch off show mode pshow=false, and set noise reduction strength, recomended value pfactor= 0.5 to 1.0. The best windows type for this method is wintype=2. The sigma and beta parameters are not used in this denoising method, but you can use this method in show mode pshow=true to estimate sigma value for ordinary denoising method (it is not strictly the same, but similar value). Last edited by VS_Fan; 18th March 2017 at 07:36. |
18th March 2017, 10:51 | #3159 | Link | ||
Location: Terneuzen, Zeeland, the Netherlands, Europe, Earth, Milky Way,Universe
Please try this script and you will get the error message too. Code:
result = (selectresult([<"select result", 0, 3, 1>])) #function selectresult() see end of script SetFilterMTMode("DEFAULT_MT_MODE", 2) source= AviSource("Z:\VDP\VdP_Sp2.avi") A = source B = source.tweak(sat=2.0) C = source.converttoRGB().GamMac() D = source.sharpen(1.0) eval(result) [Multi Tasking=0] Prefetch(4) [/Multi Tasking] function selectresult(int index) { return Select(index,"A","B","C","D") } Fred.
About 8mm film: http://www.super-8.be Film Transfer Tutorial and example clips: https://www.youtube.com/watch?v=W4QBsWXKuV8 More Example clips: http://www.vimeo.com/user678523/videos/sort:newest |
21st March 2017, 10:27 | #3160 | Link |
Fred, I cannot help you with that at the moment.
Is there anybody out there who can tell that the compilation of the existing AvsPmod project is easy and straightforward? Now I have some work with masktools, then it seems that there are still a couple of things to investigate. - Scriptclip mt behaviour - vdubfilter (deshaker issue at exit) - PClip thing, that Myrsloik has kindly noticed and possibly presented him some happy hours and turned his hair grey. - avspmod ...zimg |
