Old 4th April 2014, 01:34   #2021  |  Link
Aleksoid1978
Aleksoid1978's Avatar
Originally Posted by giannifante View Post
Hello,
minor problem, seems that there is a wrong line in mpc-be.ini file, [InternalFilters] section.
[InternalFilters]
vdec_canopus=1
=1
vdec_dirac=1
Using latest version 1.4.2.4752
Thanks. Fixed.
AMD Ryzen 5 3600 /GIGABYTE B450 Gaming X /Patriot 32Gb@3200 /Kingston 500Gb M.2 /RTX 4060 /Samsung U28R550UQI /OLED Philips 55OLED707 /Yamaha RX-V471 + NS-555 + NS-C444 + NS-333 + YST-SW215
Aleksoid1978 is offline   Reply With Quote
Old 4th April 2014, 15:47   #2022  |  Link
Mercury_22
OSD it's not working in Full screen mode with EVR or EVR-CP but it's working with madVR in this release
EDIT This is happening ONLY if menu bar is hidden = only in "Frame only" mode and "Hide borders" mode
Intel UHD Graphics 750; Win 10 22H2
Mercury_22 is offline   Reply With Quote
Old 5th April 2014, 02:39   #2023  |  Link
Aleksoid1978
I do not understand(my english is not good ). See me a screen of main window(in window mode), and screen meny "View".
Old 5th April 2014, 08:15   #2024  |  Link
Mercury_22
Press ctrl + 0 until this is how MPC-BE looks like
This is "Hide borders" mode
or
Old 5th April 2014, 10:04   #2025  |  Link
Aleksoid1978
I check - OSD is show, all ok.
Old 5th April 2014, 10:39   #2026  |  Link
wanezhiling
Same here, OSD shows well.
Old 6th April 2014, 13:28   #2027  |  Link
Mercury_22
I've discovered that this is happening ONLY when using LAV splitter and video decoder (only latest git tested)!
When using internal splitters and video decoders OSD it's working OK in full screen too !
Also MPC-BE.1.4.2.4742 and LAV doesn't have this problem !
Old 6th April 2014, 18:42   #2028  |  Link
alexins
MPC-BE DEV
alexins's Avatar
MPC-BE 1.4.3.4771 Dev.:
MPC-BE 1.4.3.4771 Dev (sourceforge.net)
MPC-BE 1.4.3.4771 Dev (dev.mpc-next.ru)
Win11 x64, i7 8700K 5Ghz, ASUS MAXIMUS X HERO, G.Skill (2x8GB) Trident Z F4-3600C16D-16GTZ, RX 5700,TV Philips 43PUS6703/12, Zappiti 4K HDR
Media Player Classic - BE x86/x64. Team of developers.
alexins is offline   Reply With Quote
Old 6th April 2014, 20:05   #2029  |  Link
Mercury_22
OSD it's working OK in this rev
So it seems that only the "Stable" version has the bug which is kinda ironical
Old 7th April 2014, 16:40   #2030  |  Link
alexins
MPC-BE DEV
alexins's Avatar
MPC-BE 1.4.3.4778 Dev.:
MPC-BE 1.4.3.4778 Dev (sourceforge.net)
MPC-BE 1.4.3.4778 Dev (dev.mpc-next.ru)
Old 8th April 2014, 12:31   #2031  |  Link
bozek
I can confirm that the OSD is broken in the 1.4.2.4752. Though I can't really determine what triggers the bug because it only happens sometimes. If it's really fixed in the dev channel, then a quick update in the stable version would be welcome.
bozek is offline   Reply With Quote
Old 8th April 2014, 17:00   #2032  |  Link
alexins
MPC-BE DEV
alexins's Avatar
MPC-BE 1.4.3.4783 Dev.:
MPC-BE 1.4.3.4783 Dev (sourceforge.net)
MPC-BE 1.4.3.4783 Dev (dev.mpc-next.ru)
Old 10th April 2014, 19:45   #2033  |  Link
alexins
MPC-BE DEV
alexins's Avatar
MPC-BE 1.4.3.4793 Dev.:
MPC-BE 1.4.3.4793 Dev (sourceforge.net)
MPC-BE 1.4.3.4793 Dev (dev.mpc-next.ru)
Old 11th April 2014, 09:23   #2034  |  Link
vayra
I would like to know if you can use custom pixel shaders, as mpc hc, thanks
vayra is offline   Reply With Quote
Old 14th April 2014, 06:43   #2035  |  Link
adrianmak
Could I use custom shaders in mpc-be as of mpc-hc 1.7.2 or greater ?
I tried to put sweetfx video shaders in mpc-be shaders folder, but it didn't recgonize.
http://forum.doom9.org/showthread.php?t=170357&page=3
adrianmak is offline   Reply With Quote
Old 15th April 2014, 01:03   #2036  |  Link
Aleksoid1978
Can you give me a sample of any shader's file.
Old 17th April 2014, 19:28   #2037  |  Link
alexins
MPC-BE DEV
alexins's Avatar
MPC-BE 1.4.3.4808 Dev.:
MPC-BE 1.4.3.4808 Dev (sourceforge.net)
MPC-BE 1.4.3.4808 Dev (dev.mpc-next.ru)
Old 19th April 2014, 15:04   #2038  |  Link
wanezhiling
http://url.cn/PydOxV
Playback fails since 20sec, mpc-hc is fine.
Old 19th April 2014, 15:51   #2039  |  Link
alexins
MPC-BE DEV
alexins's Avatar
MPC-BE 1.4.3.4814 Dev.:
MPC-BE 1.4.3.4814 Dev (sourceforge.net)
MPC-BE 1.4.3.4814 Dev (dev.mpc-next.ru)
Old 20th April 2014, 03:02   #2040  |  Link
wanezhiling
Oh the file contains two different bit rates
