6th May 2017, 21:55 | #21802 | Link |
lav audio messed up
is it just my machine or is LAV audio totally messed up, or is it the creaters update?
I cant get DTS to bitstream and its not sending the right information to my speakers. Rears are summed and i'm getting not height, height is being summed to front left and right. if i play my test audio files in windows films and TV it works find, its just anything with LAV filters, whats going on??? edit: found this.... Microsoft Response The Creators Update, and Windows Insider builds 14980 and later, broke "encoding Audio Processing Objects" that are used in third-party drivers to power things like Dolby Digital Live and DTS Connect, where the output of the Windows shared-mode audio engine is sent to an external decoder such as a S/PDIF audio receiver. We have a fix in Insider builds 16183 and later. Depending on how well this works we will consider pushing out an update to the Creators Update. from Matthew v - Microsoft Engineer i am on 15063.250 (1703) right now so hopefully we will get this sooner then the gap to 16183 fee Last edited by mclingo; 6th May 2017 at 23:49. |
7th May 2017, 22:46 | #21803 | Link | |
I'm not sure waiting for this fix from MS will fix your problem. Or are you really decoding your DTS to LPCM in LAV, and then re-encoding it with DTS Connect?
HTPC: Windows 10 22H2, MediaPortal 1, LAV Filters/ReClock/madVR. DVB-C TV, Panasonic GT60, Denon 2310, Core 2 Duo E7400 oc'd, GeForce 1050 Ti 536.40 |
8th May 2017, 07:07 | #21804 | Link |
Btw converting floats to 32bit integers can still cause clicks for loud sounds after all this years. Recommendation in the past was to use 24bit integers instead but for my setup this means the need to do another conversion to 32bit next.
8th May 2017, 09:25 | #21805 | Link |
If the audio exceeds 100%, then it can't be converted to integer without loss. Thats just how it is, and your audio file is likely bad for exceeding the valid range.
8th May 2017, 10:46 | #21806 | Link | |
I thought that initially but if you read the thread it relates to just playback of DTS files. DTS files play fine in the windows apps, just not in LAV filter and FFD filter apps. If you're right than i'm not sure where to do, anyone else on creaters update have fulling working DTS-DTX - note, it might appear to be working ok but mine is summing chanels together that shouldnt be. |
8th May 2017, 14:18 | #21807 | Link |
Support request - #11
Problem with LAV Audio Decoder(v0.69.0-45_Nightly_32-bit) with MP3 format. I have audio distortion with this HLS-stream:
http://wse.planeta-online.tv:1935/li.../playlist.m3u8 p.s. If i use "Nero Audio Decoder 2" i didn't have such problem. Any feedback would be appreciated. |
8th May 2017, 14:45 | #21809 | Link |
Support request - #12
Problem with LAV Audio Decoder(v0.69.0-45_Nightly_32-bit) with TrueHD+AC3 format. I have audio distortion with this file:
https://www.dropbox.com/s/8x1i95a15w...thd%2Bac3?dl=0 p.s. If i use "ffdshow Audio Decoder" i didn't have such problem. Any feedback would be appreciated. |
8th May 2017, 15:30 | #21810 | Link | |
You can't just mix two audio codecs into one stream, and expect software to figure it out. We have containers with multiple-stream support for this.
LAV Filters - open source ffmpeg based media splitter and decoders Last edited by nevcairiel; 8th May 2017 at 15:34. |
9th May 2017, 00:12 | #21811 | Link |
LAV Video was already updated to the new SDK in the last couple hours to make use of the new functionality.
9th May 2017, 01:14 | #21813 | Link |
pretty sure the problems I am having with windows 10 creaters update and DTS are connected to LAV filters, if I add the FFDSHOW filters and knock off DTS from LAV formats I get full bitstreaming back in in MPC-BE and KODI.
its a ballache to have to add these filters but at least I have a workaroud now. Recap: cant get DTS to bit stream using LAV filters and PCM is no longer outputting DTS-X height dignals. I dont think this is purely LAV though as i went back to 68.1 and that didnt fix the problem, its a combination for LAV and creaters update I think. Some people might not even know theres is broke, few people bit stream, fewer have DTS-X speakers setups with ceiling or heights. Have all of you using creaters update tested your DTS setups? |
9th May 2017, 01:17 | #21814 | Link |
Either you bitstream, or you don't. There is no way to half-bitstream and somehow lose your height channels.
Bitstreaming still works perfectly fine for me (receiver recognizes DTS-HD MA and everything), but I don't have any DTS:X hardware, and not going to buy any. If Creators Update broke it, I suggest you complain to Microsoft and/or your graphics drivers, which control HDMI bitstreaming.
LAV Filters - open source ffmpeg based media splitter and decoders Last edited by nevcairiel; 9th May 2017 at 01:28. |
9th May 2017, 11:07 | #21816 | Link | |
I've no idea if creaters update has caused this or not, I think it has as I rolled back LAV, MADVR, reclock and graphics/HDMI drivers back a few months and it didn't fix it. |
9th May 2017, 12:42 | #21817 | Link |
ROQ is supported by LAV Splitter. To make playback work the RoQV mediatype {56516F52-0000-0010-8000-00AA00389B71} needs to be added to the video decoder by nevcairiel.
VIVO is only partially supported by FFmpeg. Most samples don't play. Last edited by clsid; 9th May 2017 at 12:59. |
9th May 2017, 23:05 | #21818 | Link |
ROQ works with MPC-BE's internal splitter (ROQ Source) and decoder (ROQ Video Decoder) but it will not work with LAV Filters far as I can tell. Judging by the list of supported formats in the configuration for LAV, what clsid is saying makes sense... adding that would be great!
VIVO files are very hit or miss all around. VLC and LibreOffice claim to play them but both choke on most of them. SMPlayer fairs better but is also not quite perfect. I have not seen LAV Filters work with them at all... not sure if this is possible? Maybe a handful of files out there do work? As I understand it, most of the files are H263 and G723... |
10th May 2017, 12:50 | #21820 | Link | |
