7th May 2004, 15:03 | #41 | Link |
Retired, but still around
Could somebody mirror these files?
/Add: I posted some results of using different matrices with CCE. The 6of9 showes a rather large increase of filesize. I'm wondering if the matrices you guys used are specific to XVid? Also, the matrix that gives one of the best compressions in MPEG2 is one called Bach1. I also wonder what effect it might have on XVid encodes? Bach1 Code:
8, 16, 19, 22, 26, 27, 29, 34 16, 16, 22, 24, 27, 29, 34, 37 19, 22, 26, 27, 29, 34, 34, 38 22, 22, 26, 27, 29, 34, 37, 40 22, 26, 27, 29, 32, 35, 40, 48 26, 27, 29, 32, 35, 40, 48, 58 26, 27, 29, 34, 38, 46, 56, 69 27, 29, 35, 38, 46, 56, 69, 83 16, 18, 20, 22, 24, 26, 28, 30 18, 20, 22, 24, 26, 28, 30, 32 20, 22, 24, 26, 28, 30, 32, 34 22, 24, 26, 30, 32, 32, 34, 36 24, 26, 28, 32, 34, 34, 36, 38 26, 28, 30, 32, 34, 36, 38, 40 28, 30, 32, 34, 36, 38, 42, 42 30, 32, 34, 36, 38, 40, 42, 44
How to Optimize Bitrate for CCE multipass Last edited by DDogg; 7th May 2004 at 18:11. |
7th May 2004, 21:53 | #43 | Link |
LigH, you did a terrific job on this utility. You shouldn't let these XVid guys keep it all a secret . Love the way it handles TMPG and CCE. That used to be such a pain to do by hand.
One very trivial thing for the list, I noticed when exporting to CCE 2.62 + you have to put a space in dialog to activate the OK button. No problem doing it, but at first glance I thought this feature was not available, so it might confuse somebody just starting to use it. Thanks again for doing such a professional job on a utility this whole community can use.
How to Optimize Bitrate for CCE multipass |
7th May 2004, 21:56 | #44 | Link |
Brazilian Anime Ripper
I can't get matrix editor, link is broken. Can anybody send to acrespo@wasbr.com pleas?
Capture cards: Compro VideoMate Gold+ (Philips SAA7134 based) (not active) Hauppauge PVR 150MCE (not active) ATI TV Wonder Elite (active) |
7th May 2004, 22:22 | #45 | Link | |
Moderator, Ex(viD)-Mascot
SixOfNine's quality at quant=3 is better than, for example, HVS-best-picture at quant=2; thus you should do a compressiblity-test with it at quant=3 (a first pass with 6of9 should be done at quant=3, also). Didée's idea with 6of9 was to have smaller, more accurate quantization steps and I guess this is mainly responsible for it. That aside, quant=2 with 6of9 is well possible for '3-CD' (=half a DVD-R) encodes and looks quite marvellous. With XviD, that is; I suppose with MPEG-2 quant=2 the result will become too large. BTW, it would be great if a piece of software could show us, how a matrix 'scales' at different quantizers...(*cough*) Perhaps we would find out that Bach's matrix at quant=3 has the same effect as HVS-best at quant=2 or something like that.
It's a man's life in Doom9's 52nd MPEG division. "The cat sat on the mat." ATM I'm thoroughly enjoying the Banshee - a fantastic music player/ripper for Linux. Give it a whirl! Last edited by Teegedeck; 7th May 2004 at 22:39. |
7th May 2004, 22:35 | #46 | Link |
Bored...
Hmm, 2Pass encoding (low/med/high bitrates) followed by a PSNR test would be nice...
If nobody else wants to do this, I could do it the next weeks !!! Thought about this... Matrix lobby shootout (as usually) @ 1000/2000/3000 kbps Suggestions for settings etc. ??? Bye Last edited by Soulhunter; 7th May 2004 at 22:37. |
7th May 2004, 23:27 | #47 | Link |
Use every feature and the kitchen-sink, of course.
(Just trying to push those encoding times to the max, again...)
It's a man's life in Doom9's 52nd MPEG division. "The cat sat on the mat." ATM I'm thoroughly enjoying the Banshee - a fantastic music player/ripper for Linux. Give it a whirl! |
7th May 2004, 23:44 | #48 | Link | |
Bored...
So, with 3 different bitrates about 25 minutes... Using 10 matrices would give estimated 6 hours (including setup n' PSNR tests) !!! Bye |
8th May 2004, 00:20 | #49 | Link |
Bored...
Btw, after reading DDogg's test I did this here...
Source: The Matrix - Lobby Shootout / 3:07 min. @ 25fps / 1024x576 pix. (Lanczos) XviD v.1 RC4 (Koepis) / Quantizer2 / No B-VOP's / VHQ 1 Results: Matrix: Fox Home Entertainment / Filesize: 365.252.608 Bytes Matrix: SemiInsane / Filesize: 338.434.048 Bytes Matrix: Selur - High datarate / Filesize: 261.918.720 Bytes Matrix: Selur's Matrix / Filesize: 260.757.504 Bytes Matrix: Didees SixOfNine Max=20 / Filesize: 236.367.872 Bytes Matrix: Didees SixOfNine Max=24 / Filesize: 235.177.984 Bytes Matrix: Acaila's / Filesize: 228.622.336 Bytes Matrix: Andreas 78er / Filesize: 195.287.040 Bytes Matrix: Soulhunters (v3) / Filesize: 194.543.616 Bytes Matrix: Soulhunters (v4) / Filesize: 160.976.896 Bytes Matrix: HVS Best Picture / Filesize: 159.289.344 Bytes Matrix: Standard MPEG / Filesize: 150.237.184 Bytes Matrix: HVS Better Picture / Filesize: 140.699.648 Bytes Matrix: HVS Good Picture / Filesize: 136.632.320 Bytes Matrix: Standard H.263 / Filesize: 130.297.856 Bytes Matrix: Bach1 / Filesize: 128.780.288 Bytes (update) Matrix: Jawor 1CD Matrix / Filesize: 121.341.952 Bytes (update) Matrix: AVAMAT6 / Filesize: 106.104.832 Bytes Matrix: Bulletproof's Heavy Compression / Filesize: 101.152.768 Bytes Matrix: Ultimate Matrix / Filesize: 93.820.928 Bytes Bye Last edited by Soulhunter; 9th May 2004 at 21:30. |
8th May 2004, 03:20 | #50 | Link |
Soulhunter, I think I am seeing some direct relationships as I had also done 6of9-20 and Acaila's. They fell in the same relationship you are showing. I wonder if you can add Bach1 (listed above) and Jawors' to you list. I think they will fall the same place in your list and mine. If so, we have a correlation (somewhat) of techniques between Mpeg4 and Mpeg2 which might prove to have some value.
8th May 2004, 04:05 | #51 | Link |
Soulhunter: I didn't understand the conclusions of your test. Bigger size means better quality?
I need the best matrix for quality encodes of anime series (20 minutes each episode), with 640x480 and 175 Mbytes size. I tried your Soulhunter anime, Jawor and H.263. The best is H.263!!! I set xvid RC4 to no B-VOP, trellis, chroma motion and optimizer, vhq 1.
8th May 2004, 17:34 | #52 | Link | |||
Bored...
But that does mean nothing... Quote:
1st. Each matrix is case/source sensitive... 2nd. I made my matrix not for such low bitrates !!! 3rd. Try to use B-VOP's for this kind of encodes... Bye Last edited by Soulhunter; 8th May 2004 at 18:01. |
8th May 2004, 20:46 | #53 | Link |
Soulhunter: I did some tests with B-VOP (1/1/1) and the quality really improve with your matrix and jawor, better than H263. I am doing tests with VHQ4 now, but the time for 2nd pass is really long (2hs instead 45 min with vhq1).
9th May 2004, 20:35 | #54 | Link |
@ acrespo:
My ffdshow / XviD mirror killed my bandwidth, someone downloaded from there like hell - I'll have to remove it; but unfortunately, I'm not able to access my server part at the moment, I'll have to contact my provider as soon as possible. Hopefully tomorrow it may be repaired... __ @ DDogg: Would you mind asking the right person for hosting it at doom9 Downloads? Or do you have something else in mind (e.g. moving the thread)? Please forgive me, but english is not my main language - I might miss some background thoughts hidden deeply in your answer... Last edited by LigH; 9th May 2004 at 20:41. |
10th May 2004, 02:51 | #56 | Link |
LigH, i will sure ask Doom9 to consider hosting it. It is fine work and all encoders of all MPx persuasions can benefit from using it and having it easily available.
Soulhunter, thanks, so I was not going nuts after all! :-D
10th May 2004, 14:35 | #57 | Link |
! - User - !
Feature Request
hi, one thing I would really like to see is a matrix explorer/browser. Currently one has to load matrices one by one in order to see what is 'inside'.
I imagine /dream of a second window which lists all the matrix files that are the current directory. One of thise is highlighted and the corresponding matrix is displayed in the right 'editor window'. And, 'of course', if you push the 'down-arrow' the next file is highlihted and the editor window updates to the 'content of this next file. Just dreaming ...
Keep your tone warm and your sigs decent! |
11th May 2004, 00:05 | #58 | Link | |
Bored...
Bye |
12th May 2004, 03:17 | #60 | Link | |
www.mrbass.org DVDShrink | DVD2DVD | DVDFAB | Mac guides |
