Old 21st January 2012, 01:12   #14061  |  Link
jdobbs
Originally Posted by Capsbackup View Post
I believe the AVCHD=1--Strict AVCHD is meant for Movie Only, and has no effect on full backups.
That is correct. If you are doing a full backup, it has to be BD format because it's quite possible it is not AVCHD compliant (e.g. BD-J).
Website: www.jdobbs.net
Old 21st January 2012, 01:13   #14062  |  Link
jdobbs
Originally Posted by Ch3vr0n View Post
Think i've found a small bug. Just finished doing an alternate output for a miniseries blu-ray to pal DVD-5, the encode went ok but the temp folder was not removed. More specifically, during the remuxing / rebuilding a folder called THE_PILLARS_OF_THE_EARTH_D1 was created, when done with the process the final output folder was created called THE_PILLARS_OF_THE_EARTH_D1_DVD that contained the VOB files. However the now empty THE_PILLARS_OF_THE_EARTH_D1 folder was not deleted. A small glitch in the folder deleting process?
Yeah, that folder gets created for no reason when you've selected ALTERNATE output -- I need to correct that.
Old 21st January 2012, 01:16   #14063  |  Link
jdobbs
Originally Posted by busch42 View Post
Had a problem backing up killer elite which I bought, Kept coming up x264.exe has stopped working, Finally I got it, Had to go into the BDRebuilder Setup menu and check this option to turn it on:Use X264's internal LAVF for decoding. Now I tried to do main movie only to a dvd-5 but now that's coming up x264.exe has stopped working, Do I have to go back and change = Use X264's internal LAVF for decoding and turn it off?
That just means there is a problem in the configuration of AVISYNTH, HAALI, or FFDSHOW. When you select LAVF, they aren't used -- but sometimes they have to be used. So you need to correct the configuration problem. I'd suggest you uninstall BD-RB, HAALI, FFDSHOW, and AVISYNTH and reinstall from the links in the first post. Sometimes other software can change settings and cause issues.
Old 21st January 2012, 17:40   #14064  |  Link
jfcarbel
Programmer
Sol any titles using Java (BD-J) for their menus would not work on a BD-5/9 for any standalone?
Is there a easy way to tell its a BD-J menu?
Any one had luck on the Panasonics with this AVCHD=1?
As I have many full backups on BD-9 that are not recognized as valid BD by my standalone Panny BD-85 player.
I wonder if I can take these full backups and run them thru BD-Rebuilder again with AVCHD=1 set and it would fix them?
jfcarbel is offline   Reply With Quote
Old 21st January 2012, 21:10   #14065  |  Link
Ch3vr0n
@Jdobbs: i happened to be behind the computer when it was creating the final output structure. apparantly the redundant folder (without the _DVD) gets created during the stage "Creating ALTERNATE MOVIE-ONLY structure (Pt 1)..." and before converting the subtitles to dvd standard. The _DVD labelled folder was created during the final "Creating DVD File Structure" message. Maybe this will help you pinpoint the the place in the code and ease the fix
Ch3vr0n is offline   Reply With Quote
Old 22nd January 2012, 05:04   #14066  |  Link
BuddTX
I apologize in advance if the answer to my problem exists in this thread, but the searches that I have done did not provide any answers.
So here is my issue.
I CAN successfully make an MKV backup (movie only) of a Blu-Ray dvd. I have created at least 34 MKV files, so I know that I can make MKV's from ripped Blu-Ray disks.
However, I cannot successfully make an MKV from a ripped DVD.
I am using the method that Jdobbs posted here (post 18):
I think the best MKV backups of DVDs can be done like this (it's how I do it):
1. Use multiAVCHD to convert the DVD movie to Blu-Ray. Since MPEG-2/AC3 is a legal BD format, the file will not be reencoded, so you have a pristine copy to work with.
2. Use BD-RB to do the MKV backup using X264. That way to get size/quality benefit of AVC in your MKV.
I have tried using several different ALTERNATE MOVIE only output, and I even made my own setting.
Now the interesting thing, is that I CAN successfully create an MP4 file, from the same source that I am trying to create an MKV file.
Also, I have tried uninstalling and re-installing all the support files (Avisynth_258.exe, MatroskaSplitter.exe, ffdshow_rev3882_20110613_clsid.exe), and I downloaded the recommended version from the links at the first post on this thread.
So here are my details:
INSPECT:
- Windows Version: 6.1 [7601]
- AVISYNTH Version: [2.5.8.0], Ok
- HAALI Splitter: [1.9.42.1], Ok
- FFDSHOW: [3882], Ok
- WIN7 preferred AVC CODEC:  Ok
- WIN7 preferred VC-1 CODEC:  Ok
- WIN7 preferred MPEG2 CODEC:  Ok
- FFDSHOW VC-1 set to "wmv9", Ok
- FFDSHOW MPEG2 set to "libavcodec":  Ok
- FFDSHOW AVC set to "ffmpeg-mt":  Ok
- BD Rebuilder v0.39.0.7, Ok
- X264:  Ok
- AFTEN:  Ok
- FAAC:  Ok
- MP4BOX:  Ok
- WAVI:  Ok
- TSMUXER:  Ok
BD-REBUILDER.LOG
(As you can see, I tried several times, using different settings
the SUCCESSFUL MP4 file
ALSO, NOT trying to be a jerk by posting a long LOG file, just want to show that I tried using different settings)
[05:18:57] BD Rebuilder v0.39.07 (beta)
  - Source:  AVCHD
  - Input BD size: 5.30 GB
  - Approximate total content: [02:23:57.411]
  - MOVIE-ONLY/ALTERNATE OUTPUT mode enabled
  - Mode: MP4 Container, 1920x1080, Auto-AAC
  - Audio Settings: AC3=1 DTS=1 HD=0 Kbs=640
[05:19:17] PHASE ONE, Encoding
 - [05:19:17] Processing: VID_00000 (1 of 2)
 - [05:19:17] Extracting A/V streams [VID_00000]
 - [05:23:25] Reencoding video [VID_00000]
   - Source Video: MPEG-2, 720x480
   - Rate/Length: 29.970fps, 191,941 frames
   - Convert: 1920x1080, 29.970fps, 191,941 frames
   - Bitrate: 9,005 Kbs
 - [05:23:26] Reencoding: VID_00000, Pass 1 of 2
 - [07:43:45] Reencoding: VID_00000, Pass 2 of 2
 - [14:16:13] Video Encode complete
 - [14:16:13] Processing audio tracks
   - Track 4352 (eng): Reencoding audio to AAC...
 - [14:31:16] Multiplexing M2TS
 - [14:31:16] Processing: VID_00001 (2 of 2)
 - [14:31:16] Extracting A/V streams [VID_00001]
 - [14:32:31] Reencoding video [VID_00001]
   - Rate/Length: 29.970fps, 66,922 frames
   - Convert: 1920x1080, 29.970fps, 66,922 frames
   - Bitrate: 9,263 Kbs
 - [14:32:31] Reencoding: VID_00001, Pass 1 of 2
 - [15:19:22] Reencoding: VID_00001, Pass 2 of 2
 - [17:34:42] Video Encode complete
 - [17:34:42] Multiplexing M2TS
[17:34:42]PHASE ONE complete
[17:34:42]PHASE TWO - Rebuild Started
 - [17:34:42] Rebuilding stream 00000 [1 of 2]
 - [17:34:42] Rebuilding stream 00001 [2 of 2]
 - [17:34:42] Building ALTERNATE OUTPUT Structure
[17:52:31] - Encode and Rebuild complete
[17:52:31]JOB: AVCHD finished.
[23:16:41] BD Rebuilder v0.39.07 (beta)
  - Source:  AVCHD
  - Mode: MKV Container, 1920x1080, Auto-AAC
[23:16:45] PHASE ONE, Encoding
 - [23:16:45] Processing: VID_00000 (1 of 2)
 - [23:16:45] Extracting A/V streams [VID_00000]
 - [23:20:47] Reencoding video [VID_00000]
 - [23:20:47] Reencoding: VID_00000, Pass 1 of 1
[23:40:18]PHASE ONE aborted by user request
[00:01:56] BD Rebuilder v0.39.07 (beta)
  - Source:  AVCHD
  - Mode: BP MKV Container, 720x480/576, 640Kbs DD5.1
[00:01:57] PHASE ONE, Encoding
 - [00:01:57] Processing: VID_00000 (1 of 2)
 - [00:01:57] Extracting A/V streams [VID_00000]
 - [00:05:38] Reencoding video [VID_00000]
 - [00:05:38] Reencoding: VID_00000, Pass 1 of 1
 - [01:07:48] Video Encode complete
 - [01:07:48] Processing audio tracks
 - [01:07:54] Multiplexing M2TS
 - [01:07:54] Processing: VID_00001 (2 of 2)
 - [01:07:55] Extracting A/V streams [VID_00001]
 - [01:08:42] Reencoding video [VID_00001]
 - [01:08:43] Reencoding: VID_00001, Pass 1 of 1
 - [01:28:51] Video Encode complete
 - [01:28:51] Multiplexing M2TS
[01:28:51]PHASE ONE complete
[01:28:51]PHASE TWO - Rebuild Started
 - [01:28:51] Rebuilding stream 00000 [1 of 2]
 - [01:28:51] Rebuilding stream 00001 [2 of 2]
 - [01:28:51] Building ALTERNATE OUTPUT Structure
[01:29:12] - Failed to REBUILD
[03:36:50] BD Rebuilder v0.39.07 (beta)
  - Source:  AVCHD
[03:36:53] PHASE ONE, Encoding
 - [03:36:53] Processing: VID_00000 (1 of 2)
 - [03:36:53] Extracting A/V streams [VID_00000]
 - [03:41:20] Reencoding video [VID_00000]
 - [03:41:21] Reencoding: VID_00000, Pass 1 of 1
 - [03:55:04] Video Encode complete
 - [03:55:04] Processing audio tracks
 - [03:55:15] Multiplexing M2TS
 - [03:55:15] Processing: VID_00001 (2 of 2)
 - [03:55:15] Extracting A/V streams [VID_00001]
 - [03:56:07] Reencoding video [VID_00001]
 - [03:56:07] Reencoding: VID_00001, Pass 1 of 1
 - [04:00:07] Video Encode complete
 - [04:00:07] Multiplexing M2TS
[04:00:07]PHASE ONE complete
[04:00:07]PHASE TWO - Rebuild Started
 - [04:00:07] Rebuilding stream 00000 [1 of 2]
 - [04:00:07] Rebuilding stream 00001 [2 of 2]
 - [04:00:07] Building ALTERNATE OUTPUT Structure
[04:00:11] - Failed to REBUILD
[04:01:56] BD Rebuilder v0.39.07 (beta)
  - Source:  AVCHD
[04:02:06] PHASE ONE, Encoding
 - [04:02:06] Processing: VID_00000 (1 of 2)
 - [04:02:06] Extracting A/V streams [VID_00000]
 - [04:06:15] Reencoding video [VID_00000]
   - Bitrate: 872 Kbs
 - [04:06:16] Reencoding: VID_00000, Pass 1 of 2
 - [04:19:49] Reencoding: VID_00000, Pass 2 of 2
 - [04:34:03] Video Encode complete
 - [04:34:03] Processing audio tracks
 - [04:34:09] Multiplexing M2TS
 - [04:34:09] Processing: VID_00001 (2 of 2)
 - [04:34:09] Extracting A/V streams [VID_00001]
 - [04:34:55] Reencoding video [VID_00001]
   - Bitrate: 872 Kbs
 - [04:34:55] Reencoding: VID_00001, Pass 1 of 2
 - [04:39:33] Reencoding: VID_00001, Pass 2 of 2
 - [04:44:22] Video Encode complete
 - [04:44:22] Multiplexing M2TS
[04:44:22]PHASE ONE complete
[04:44:22]PHASE TWO - Rebuild Started
 - [04:44:22] Rebuilding stream 00000 [1 of 2]
 - [04:44:22] Rebuilding stream 00001 [2 of 2]
 - [04:44:22] Building ALTERNATE OUTPUT Structure
[04:44:36] - Failed to REBUILD
[11:56:01] BD Rebuilder v0.39.07 (beta)
  - Source:  AVCHD
- Resuming from previously started job.
[11:56:05] PHASE ONE, Encoding
[11:56:05]PHASE ONE complete
[11:56:05]PHASE TWO - Rebuild Started
 - [11:56:05] Rebuilding stream 00000 [1 of 2]
 - [11:56:05] Rebuilding stream 00001 [2 of 2]
 - [11:56:05] Building ALTERNATE OUTPUT Structure
[11:56:48] - Failed to REBUILD
[12:02:39] BD Rebuilder v0.39.07 (beta)
  - Source:  AVCHD
[12:02:42] PHASE ONE, Encoding
[12:02:42]PHASE ONE complete
[12:02:42]PHASE TWO - Rebuild Started
 - [12:02:42] Rebuilding stream 00000 [1 of 2]
 - [12:02:42] Rebuilding stream 00001 [2 of 2]
 - [12:02:42] Building ALTERNATE OUTPUT Structure
[12:03:27] - Failed to REBUILD
[12:03:56] BD Rebuilder v0.39.07 (beta)
  - Source:  AVCHD
[12:04:03] PHASE ONE, Encoding
 - [12:04:03] Processing: VID_00000 (1 of 2)
 - [12:04:03] Extracting A/V streams [VID_00000]
 - [12:08:24] Reencoding video [VID_00000]
   - Bitrate: 872 Kbs
 - [12:08:25] Reencoding: VID_00000, Pass 1 of 2
 - [12:21:59] Reencoding: VID_00000, Pass 2 of 2
 - [12:36:10] Video Encode complete
 - [12:36:10] Processing audio tracks
 - [12:36:16] Multiplexing M2TS
 - [12:36:16] Processing: VID_00001 (2 of 2)
 - [12:36:16] Extracting A/V streams [VID_00001]
 - [12:37:04] Reencoding video [VID_00001]
   - Bitrate: 872 Kbs
 - [12:37:04] Reencoding: VID_00001, Pass 1 of 2
 - [12:41:41] Reencoding: VID_00001, Pass 2 of 2
 - [12:46:29] Video Encode complete
 - [12:46:29] Multiplexing M2TS
[12:46:29]PHASE ONE complete
[12:46:29]PHASE TWO - Rebuild Started
 - [12:46:29] Rebuilding stream 00000 [1 of 2]
 - [12:46:29] Rebuilding stream 00001 [2 of 2]
 - [12:46:29] Building ALTERNATE OUTPUT Structure
[12:46:43] - Failed to REBUILD
[14:42:31] BD Rebuilder v0.39.07 (beta)
  - Source:  AVCHD
[14:42:33] PHASE ONE, Encoding
 - [14:42:33] Processing: VID_00000 (1 of 2)
 - [14:42:33] Extracting A/V streams [VID_00000]
 - [14:46:36] Reencoding video [VID_00000]
   - Bitrate: 3,000 Kbs
 - [14:46:36] Reencoding: VID_00000, Pass 1 of 2
 - [16:14:29] Reencoding: VID_00000, Pass 2 of 2
 - [17:41:15] Video Encode complete
 - [17:41:15] Processing audio tracks
 - [17:56:20] Multiplexing M2TS
 - [17:56:20] Processing: VID_00001 (2 of 2)
 - [17:56:20] Extracting A/V streams [VID_00001]
 - [17:56:59] Reencoding video [VID_00001]
 - [17:56:59] Reencoding: VID_00001, Pass 1 of 2
 - [18:27:15] Reencoding: VID_00001, Pass 2 of 2
 - [18:56:44] Video Encode complete
 - [18:56:44] Multiplexing M2TS
[18:56:44]PHASE ONE complete
[18:56:44]PHASE TWO - Rebuild Started
 - [18:56:44] Rebuilding stream 00000 [1 of 2]
 - [18:56:44] Rebuilding stream 00001 [2 of 2]
 - [18:56:44] Building ALTERNATE OUTPUT Structure
[18:57:22] - Failed to REBUILD
BDREBUILDER.INI
[Options]
VERSION=0.39.0.7
MODE=2
ENCODE_QUALITY=0
ONEPASS_ENCODING=0
AUTO_QUALITY=1
AUDIO_TO_KEEP=eng;
SUBS_TO_KEEP=all
SD_CONVERT=0
OPEN_GOP=0
RESIZE_1080=0
DEINTERLACE=1
SD_TO_1080=1
CONVERT_WIDE=0
DTS_REENCODE=1
AC3_REENCODE=1
AC3_640=1
AC3_192=0
KEEP_HD_AUDIO=0
AVCHD=0
REMOVE_WORKFILES=0
MOVIE_ONLY_LOOP=1
REMOVE_OUTPUT=0
USE_FILTERS=0
BDMV_CERT_ONLY=0
USE_LAVF=0
IVTC_PULLDOWN=0
ASSUME_DVD_PAL=0
UNMASK_CHAPTER=0
COMPLETION_BEEP=0
AUDIO_TRACK_LIMIT=1
SUBTITLE_TRACK_LIMIT=1
CUSTOM_TARGET_SIZE=10240
MOVIEONLY_TYPE=17
ALTCRF=20
ALT_TARGET=10240
ALTMETHOD=1
ALTAUTOCROP=0
AUTO_BIAS=3
TARGET_SIZE=23500
[Paths]
WORKING_PATH=C:\BD_REBUILDER\WORKING PATH\
SOURCE_PATH=C:\MULTIAVCHD-WORK\DEVILS_ADVOCATE\AVCHD\
Avchd.inf
[Status]
LABEL=AVCHD
VERSION=v0.39.07 (beta)
SOURCE_SIZE=5695444992
SOURCE_VIDEO_SIZE=5695444992
TARGET_SIZE=24641536000
REDUCTION=4.32653392923859
RESIZE_1080=0
AUDIO_TO_KEEP=eng;
KEEP_HD_AUDIO=0
SUBS_TO_KEEP=all
BACKUP_MODE=1
MOVIEONLY_TYPE=17
USE_LAVF=0
QUICK=0
ENCODE_STEP=0
COMPLETED=2
REBUILD_COMPLETE=0
[00000]
AUDIO=1
PGS=
SCAN=2
VIDEO2=0
V2MBRATE=0
M2TS_TARGET=18145584644
NSIZE=0
FLINK=0
MLINK=0
[00001]
SCAN=2
VIDEO2=0
V2MBRATE=0
M2TS_TARGET=6495951356
AUDIO=1
NSIZE=0
FLINK=0
MLINK=0
Lastcmd.txt
"C:\BD_Rebuilder\tools\x264.exe"
"C:\BD_REBUILDER\WORKING PATH\WORKFILES\VID_00001.AVS"
 --preset superfast --bluray-compat --b-pyramid none --weightp 1 --qpmin=0 --bitrate 3000 --level 4.1 --qpfile
"C:\BD_REBUILDER\WORKING PATH\WORKFILES\VID_00001.CHP"
 --aud --nal-hrd vbr --pic-struct --vbv-bufsize 15000 --keyint 48 --min-keyint 1 --ipratio 1.1 --pbratio 1.1
--vbv-maxrate 15000 --fake-interlaced --threads auto --slices 4 --thread-input --stats
"C:\BD_REBUILDER\WORKING PATH\WORKFILES\VID_00001.AVS.264.stats"
 --pass 2 --output "C:\BD_REBUILDER\WORKING PATH\WORKFILES\VID_00001.AVS.264"
alternate.txt (the one that I created)
caption=MKV Container, 720x480/576, 640Kbs DD5.1
vBitrate=872
aBitrate=640
aType=0
vFormat=6
cType=1
Thank you for any advice you can offer!
And THANK YOU JDobbs for some really nice software!
BuddTX is offline   Reply With Quote
Old 22nd January 2012, 07:12   #14067  |  Link
jdobbs
No. That isn't the point I was making. Lots of players play BD-5/9 full backups fine. What I said was that AVCHD has many restrictions that differentiate it from standard blu-ray. For example it doesn't allow DTS audio, VC-1 or MPEG-2 video, or any BD-J... and there's a lot more.
Old 22nd January 2012, 07:17   #14068  |  Link
jdobbs
@BuddTX
I'll do some testing and see what I come up with.
Old 22nd January 2012, 22:58   #14069  |  Link
Ch3vr0n
just did about half a dozen rebuilds of the miniseries pillars of the earth. Rebuilds went succesful except for 2 things. If i choose pal output the audio was out of sync, ntsc and audio's fine. 2nd thing i noticed was that even though the output size was set to DVD-9 total size on job completion was way undersized and fits a DVD-5.
[20:42:07] BD Rebuilder v0.39.07 (beta)
- Source: PILLARS_OF_THE_EARTH_D3
- Input BD size: 10,71 GB
- Approximate total content: [00:52:55.500]
- Windows Version: 6.0 [6002]
- Mode: DVD-9, 720x480/576, AC3 Audio
[20:42:07] PHASE ONE, Encoding
- [20:42:07] Processing: VID_00003 (1 of 1)
- [20:42:07] Extracting A/V streams [VID_00003]
- [20:45:14] Reencoding video [VID_00003]
- Source Video: VC-1, 1920x1080
- Rate/Length: 24,000fps, 76.212 frames
- Bitrate: 8.104 Kbs
- [20:45:14] Reencoding: VID_00003
- [22:13:27] Video Encode complete
- [22:13:27] Processing audio tracks
- Track 4352 (eng): Reencoding audio to AC3...
- Track 4353 (eng): Reencoding audio to AC3...
- [22:21:50] Multiplexing M2TS
[22:21:50]PHASE ONE complete
[22:21:50]PHASE TWO - Rebuild Started
- [22:21:50] Rebuilding stream 00003 [1 of 1]
- [22:21:50] Building ALTERNATE OUTPUT Structure
- [22:21:50] Converting 1 subtitles to DVD format.
- [22:22:11] Starting MPLEX.
- [22:24:46] Multiplexing 1 subtitles into stream.
- [22:26:32] Building DVD File Structure.
[22:28:23] - Encode and Rebuild complete
- WORKFILES folder removed.
[22:28:23]JOB: PILLARS_OF_THE_EARTH_D3 finished.
total file size was 2.77GB, did get lucky by accident though, actually wanted a DVD-5 output.
Old 24th January 2012, 02:42   #14070  |  Link
Priapismic
This is the strangest thing; My 0.39.07 will not work because it is expired...
How is that possible???
Priapismic is offline   Reply With Quote
Old 24th January 2012, 03:04   #14071  |  Link
A.Fenderson
Mine's working: double-check date/time on your pc.
A.Fenderson is offline   Reply With Quote
Old 24th January 2012, 03:12   #14072  |  Link
jdobbs
Your PC's date is wrong. That version isn't due to expire until sometime in February.
Old 24th January 2012, 03:48   #14073  |  Link
Priapismic
All right now. Just replaced defective memory and did not notice it had done that. Thank you!
Old 24th January 2012, 17:01   #14074  |  Link
kctobyjoe
BUG .39.07 most recent
The option to create an ISO image is checked but GREYED OUT
HELP
YOU have my email to be able to reply
kctobyjoe@comcast.net
kctobyjoe is offline   Reply With Quote
Old 24th January 2012, 18:24   #14075  |  Link
Adbear
do you have Imgburn installed?
Adbear is offline   Reply With Quote
Old 26th January 2012, 18:56   #14076  |  Link
busch42
jdobbs, I took your advise about deleting all the programs and the reinstalling them ( BDrebuilder, Avisynth, ffdshow, Matroska splitter), Everything worked fine. This week I went and bought Real Steel and 50/50 bluray movies, Ran both movies to my hard drive with DVDFab, Used BDrebuilder to rip Real Steel to a bd25 disk no problem, But when I went to do the same for movie 50/50 it did the same thing as last week ( x264.exe cannot continue). Seems like it will let me do 1 movie, then I have to delete everything and reinstall to continue, unless I do what I did last week (which it did work again) go into setup and enable x264's internal LAVF for decoding.
busch42 is offline   Reply With Quote
Old 27th January 2012, 02:47   #14077  |  Link
jdobbs
You need to look at other software on your system... something is changing the settings without your knowledge/consent, it's likely it is whatever you are using to play it back.
If you have any CODECs or CODEC PACKS on your system -- remove them. FFDSHOW has every codec anyone should ever need.
Old 28th January 2012, 09:46   #14078  |  Link
Sharc
Probably not a bug, just an observation:
When I follow the route
BD original => BD5 backup (movie only) => Alternate output DVD, the audio of the Alternate DVD is in some cases out of sync (up to few seconds).
When I do
BD original => Alternate output DVD, the audio of the Alternate DVD is in sync.
So some video/audio sync info seems to get lost in the first case.
Old 28th January 2012, 15:04   #14079  |  Link
jdobbs
When I do
That's really weird. Can you post your INI file and give me an example of a disc that will do it?
Old 28th January 2012, 21:50   #14080  |  Link
Ch3vr0n
i noticed that too on my recent conversions but i had "assume pal" enabled for movie only mode. I removed that checkbox and audio was in sync
