7th November 2008, 23:58 | #664 | Link |
Former Technical Janitor
goto line#'s editing question
I've noticed that changing where goto's jump manually then further edits in that pgc throw the goto destination line#'s off (because they don't get adjusted automatically).
EG. (example pgc code) 1 set gprm(0) = (mov) 0 2 if ( gprm(0) != 0 ) then { Goto line 4 } 3 (JumpTT) Jump to Title 1 4 set gprm(0) = (mov) 1 5 if( gprm(0) != 0 ) then { Goto line 7 } 6 (JumpTT) Jump to Title 2 7 NOP If I were to highlight 2 lines of code, from a different PGC, and copy them, then highlight line 3 in the above example and paste replace... The goto4 on line 2 doesn't change to goto5. Furthermore, any attempt to add or delete lines (above line 2) after doing that also causes the goto line numbers to not change accordingly. Perhaps this is by design or maybe it can be accomodated to enhance the editing capabilities of pgcedit!? |
8th November 2008, 09:25 | #666 | Link |
PgcEdit daemon
@ david42: See the menu: Options -> Command Editor -> Auto renumber GOTOs when commands added/removed.
@ IVaN_000: See the menu: Options -> Input/Output -> Create backup when a DVD is opened for the first time. However, I recommend to leave this option ticked, as PgcEdit uses the backup folder for different purposes. The new version will use it even more. For example, PgcEdit will save the menu buttons in a special file in the backup folder so that it will not need to scan the VOBs each time the DVD is reloaded. Note also the function File -> Backups -> Delete Backup(s). It is easy to remove all backups before burning the DVD. (And btw ImgBurn skips them automatically when they are in the VIDEO_TS folder, so you don't even need to take care of them. Unfortunately, Nero is not so smart.)
4th December 2008, 02:24 | #668 | Link |
PgcEdit daemon
I hope I'll be ready to drop it in your fireplace!
