4th January 2009, 16:00 | #5981 | Link | |
Kid for Today
I've asked Vincent Burel for a debug winamp2 plugin coz Haruhiko said it would help to see why it's freezing when we open new files. anyhow, I will bug Seb.26 for that OzoneMP fix if Haruhiko can tell me where the "glitch" is....Seb.26 is a friend of mine and he knows his C++ sh*t(being a professional coder and all)....it's just that he told me that the ffdshow audio code was a hell of a mess, so any pointer would be greatly appreciated very basic resolution condition would do you know no need for realtime monitor detection IMHO. Last edited by leeperry; 4th January 2009 at 16:08. |
4th January 2009, 17:25 | #5982 | Link |
Turkey Machine
Isn't there a hard limit in the number of codecs listed anyway?
On Discworld it is clearly recognized that million-to-one chances happen 9 times out of 10. If the hero did not overcome huge odds, what would be the point? Terry Pratchett - The Science Of Discworld |
4th January 2009, 18:30 | #5984 | Link |
Nope.
MPC-HC 2.2.1 |
4th January 2009, 21:25 | #5985 | Link |
Turkey Machine
OK, fair enough.
I have another "bug" to report. In de-interlacing, the kernel deinterlacers (blend and bob) are both broken as performance has gone completely to pot. Kernel bob used to be my favourite deinterlacer, now I can't use it cos it's not fast enough. What changed?
5th January 2009, 02:09 | #5986 | Link | |
For example, the screen resolution is 1680x1050, the resize is set at 1360x768... When I switch the resize setting to "Screen resolution", the video will be resized to screen's resolution, but with the wrong aspect ratio... This only happens when "Keep original aspect ratio" is chosen... Is this an expected behavior..? |
5th January 2009, 09:39 | #5987 | Link |
Hey guys,
Hope this is the right place to post this. I just installed the x64 version (2547) but I already had 32bit version installed at that time. It was working really nicely under Vista 64bit. After realising I had both installed, I uninstalled 32bit version and rebooted, and I don't think the 64bit version is working. When I play videos the performance is bad (I have xvid codec installed), and FFDShow settings don't seem to have any effect, plus I don't have the FFDShow icons for video or audio on the task bar. Would installing 64bit version alongside 32bit version cause an improper installation? What's the best procedure for a complete uninstallation so I can fix the install? Thanks for your help. |
5th January 2009, 10:31 | #5988 | Link | |
As for changing the settings for ffdshow with both installed, say you wanted to change settings for ffdshow32, there would 2 copies of "Video Decoder Configuration" in your Start Menu. When you mouse over it, the 32bit one would show something like "rundll (C:\Windows\SysWOW64)" in the tooltip, clicking on this will open ffdshow video config for the 32bit version. As for the x64 version, the tooltip will be "rundll (C:\Windows\system32)". It also looks to me that you're not using MPC-HC x64, which is why the ffdshow systray icons aren't showing up after you installed the 32-bit version. If you want to uninstall, just run the ffdshow uninstaller from the Start Menu, again there should be 2. Furthermore, there should also be 2 ffdshow folders, one under "C:\Program Files\ffdshow" for the x64 version, and one under "C:\Program Files (x86)\ffdshow" for the 32 bit version. In any case, you should be able to just reinstall the x64 version, uninstall it, if you're missing the uninstaller. Then reinstall the 32-bit version and stick with that. IMO stick to the 32-bit version only unless you have a good reason to use the x64 version. I have the x64 version of ffdshow installed for use with Windows Media Encoder x64. You don't need to reboot, just make sure any applications that use ffdshow are closed. |
5th January 2009, 12:17 | #5989 | Link | |
ffdshow/AviSynth wrangler
So either something else in some other part of ffdshow changed recently that makes it run slow, or you're using a build/an installer where a ff_kernelDeint.dll compiled with debug settings was included instead of the ICL compiled one... I'll try a recent build when I get home tonight - where did you get yours? xvidvideo.ru?
now playing: [artist] - [track] ([album]) Last edited by Leak; 5th January 2009 at 12:22. |
5th January 2009, 14:31 | #5990 | Link | |
Please ask in MPC-HC thread. |
5th January 2009, 16:43 | #5991 | Link | |
Media Control author
The following MS API is used to do this : GetSystemMetrics But it works on the primary monitor (which is the one that will hold the video) But what would be the benefit of this feature ? Last edited by albain; 5th January 2009 at 16:58. |
5th January 2009, 17:01 | #5992 | Link | |
MPC-HC 2.2.1 |
5th January 2009, 17:16 | #5993 | Link | |
MPC-HC Project Manager
there has been an interesting RV40(realvideo) commit to the ffdshow svn:
5th January 2009, 18:24 | #5994 | Link | |
np: Other People's Children - Suicide Common (A Number Of Small Things (Disc 2))
now playing: [artist] - [track] ([album]) |
5th January 2009, 18:34 | #5995 | Link | |
Turkey Machine
5th January 2009, 18:43 | #5997 | Link |
SF also has a few hundred old builds:
http://sourceforge.net/project/showf...ease_id=436746
MPC-HC 2.2.1 Last edited by clsid; 5th January 2009 at 18:48. |
6th January 2009, 01:43 | #5998 | Link |
Well, I want to use ffdshow to correct the primaries of my display.
See this post a few pages back. Currently, I have to use an Avisynth filter for it, but I already suggested the addition of the 3D LUT to ffdshow. And each display have different primaries, so, for each display, I have to use a different 3D LUT. That's why I need the preset selection by the screen resolution... or I have to change it manually each time I switch between my monitor and my projector... |
6th January 2009, 02:20 | #5999 | Link |
4:2:0 hater
One thing I've noticed in the installer:
There are several formats that have two possible decoders, like MPEG-2 for example. However, most of these formats don't have two suboptions in the installer, they're either checked or unchecked. This means that if for example you select wmv9 decoder for WMV3/9 and then you install a new build, as the installer doesn't have an option for wmv9 it defaults to "checked". And when you actually look at WMV3/9 in the new installed build, it's configured as libavcodec, the first choice. There are quite a few formats affected by this, like Xvid, WMV1/7, WMV2/8, WMV3/9,etc. Also both MPEG-2 decoders seek perfectly now, libmpeg2 a bit faster with the recent changes. |
