27th May 2014, 15:24 | #26501 | Link |
How often do you actually play VP9? I never. For H.264 the difference is between 5 and 15%. Nice, but not really important since any decent CPU can easily handle even 4K video. For 1080p content the difference here is like 1% CPU usage.
MPC-HC 2.2.1 |
27th May 2014, 17:53 | #26502 | Link |
It does already have some ASM, some of which is for x64 only.
There also is x86 compatible ASM for the VP9 decoder. The fact that there is more ASM for x64 doesn't mean x86 doesn't get any love. The easy stuff is just done first. Plus some optimizations are only possible for x64 due to higher amount of available registers.
MPC-HC 2.2.1 |
27th May 2014, 18:06 | #26503 | Link |
Either madshi will provide a 64-bit version at some point or he won't.
Personally, I don't think its a huge effort to produce both 32-bit and 64-bit for well written code, but of course thats up to madshi and his priorities.
LAV Filters - open source ffmpeg based media splitter and decoders Last edited by Guest; 27th May 2014 at 18:21. Reason: remove OT content |
27th May 2014, 18:14 | #26504 | Link |
Well, I suspect the primary reason why madshi hasn't made a x64 build yet is because he does not want to test on and support two architectures at this moment. So maybe once madVR hits 1.0, *poof* there will suddenly be a x64 build.
MPC-HC 2.2.1 |
27th May 2014, 18:21 | #26505 | Link |
Discussion of HEVC decoder optimization is OT and posts were deleted.
Say to yourself over and over: MadVR support/development thread. Open a new thread if you want to go on a tangent. Post a link to the new thread if you like. Thank you. I have added a statement about the moderation policy for this thread at the end of the first post. Please familiarize yourselves with it. Thank you. Last edited by Guest; 27th May 2014 at 23:08. |
28th May 2014, 03:58 | #26506 | Link |
Anyone tried 14.6 drivers to see if they improved NNEDI3 performance?
http://www.anandtech.com/show/8058/a...tionality-more |
28th May 2014, 19:25 | #26507 | Link |
AMD Catalyst 14.6 beta on NNEDI3 OpenCL performance
I get pretty much the same performance on 14.6 beta compared to 13.12 but with much stable redering queues.
Huge plus for 14.6 beta is I can minimize banding caused by my panel by setting the color depth to 8 bpc on the new Catalyst feature. With the new feature, I don't need to set my madVR bitdepth setting to 6 bit just to minimize banding. I can just leave it to 8 bit and have lesser noise.
Windows 10 64-bit PowerColor HD R9 270 |
28th May 2014, 21:43 | #26508 | Link |
Early reports say that the BSODs are gone with 14.6 as well, though it's hard to say for sure with such a small sample size.
Test patterns: Grayscale yuv444p16le perceptually spaced gradient v2.1 (8-bit version), Multicolor yuv444p16le perceptually spaced gradient v2.1 (8-bit version) |
29th May 2014, 00:55 | #26510 | Link |
Troubleshooter
I'm encountering an issue with madVR playing videos as detailed below, and I'm interested in hearing peoples theories about it.
Video: MPEG4 Video (H264) 1280x720 23.976fps [V: h.264 [jpn] (h264 high L4.0, yuv420p, 1280x720) [default]] Audio: AAC 48000Hz stereo [A: aac 2ch [jpn] (aac, 48000 Hz, stereo) [default]] Subtitle: Advanced SubStation Alpha [S: subtitles & notes [eng] (ssa/ass) [default]] Subtitle: UTF-8 [S: No subtitles] When playing on my TV in extended mode, and the following set as display modes the TV may switch to: 1080p60, 1080p59, 1080p30, 1080p29, 1080p24, 1080p23 My TV switches to 23.97211hz to most closely match the 23.976 fps video, but it drops a ton of frames (odd to me considering rendering average is 11.26ms). Picture 1 If I force on Smooth Motion the dropped frames stop, but extreme blurring is present. Picture 2 If I delete out the supported display modes except for 60hz and 59 hz. I can run the videos without dropped frames, but get the occasional presentation glitch (which looks like a dropped frame on the screen when the glitch occurs). Picture 3 I use the 59/60hz screen method since that is the best viewing experience out of the three given what happens with each, but it seems like the ideal viewing would be with the first one where the system switches the tv display to match the video fps. Any theories why the 23hz screen refresh rate is having the dropped frames? Any suggestions for troubleshooting?
System specs: Sager NP9150 SE with i7-3630QM 2.40GHz, 16 GB RAM, 64-bit Windows 10 Pro, NVidia GTX 680M/Intel 4000 HD optimus dual GPU system. Video viewed on LG notebook screen and LG 3D passive TV. |
29th May 2014, 01:49 | #26511 | Link |
My quick guess as to why smooth motion looks blurry would be that your TV doesn't do 23.972 correctly, is it taking 24Hz in but displaying at 60? Maybe a short log file (zipped) when it is dropping frames would help shed some light on it? Does smooth motion still look blurry if turned on for option 3? I assume this is on your Win 8.1 system? Just to rule out extra complications, does the same thing happen without subtitles?
Have you tried Reclock? It is useful even for only testing as maybe the refresh rate mismatch is causing more dropped frames than expected (I have experienced this before). I assume your screen shot wasn't after 1+ days of video playback. |
29th May 2014, 02:14 | #26512 | Link | |
even after disabling all performance for quality options, I only keep it enabled with it's default setting 'only if there would be motion judder without it'. |
29th May 2014, 02:43 | #26513 | Link | |
with smoothmotion frames aren't dropped but displaying 30 fps in 23 with smoothmotions looks not that good... easy to check with a sample. you get presentation glitches if you run out of Vram and you put all queue to maximum ... you don't need them this high try lower values. you can disable the new path windows mode and there should be no way for presentations glitches anymore. BTW you should use aero if you use windowed mode. |
29th May 2014, 03:59 | #26514 | Link | ||||||||
Troubleshooter
59hz with Smooth Motion screen shot You are correct that it is on my Windows 8.1 system. Quote:
Finally in answer to your last question. If you're referring to playing video non-stop for 24 hours then no I was not, but if your asking if I was marathoning episodes (as in watching a bunch in a row playing them back to back) then yes I was. Quote:
My system has 16GB of RAM, the GPU 4GB GDDR5 (as reported by GPU-Z), so I don't think its maxing out my VRAM. GPU-Z reports Dynamic Memory Usage 751 MB (at most) when watching a video if both queues are set at their maximum.
System specs: Sager NP9150 SE with i7-3630QM 2.40GHz, 16 GB RAM, 64-bit Windows 10 Pro, NVidia GTX 680M/Intel 4000 HD optimus dual GPU system. Video viewed on LG notebook screen and LG 3D passive TV. Last edited by Anime Viewer; 29th May 2014 at 04:18. Reason: added results for dropping both queues to 4 |
29th May 2014, 05:19 | #26515 | Link |
I had the same sort of issue before. Splitter reported 23 fps so madvr changed to 24hz. It was vfr and had 29 fps sections so there's not really anything madvr can do about it and more a problem with the splitter. I fixed it by using 48hz but it's still not a great solution.
PC: FX-8320 GTS250 HTPC: G1610 GTX650 PotPlayer/MPC-BE LAVFilters MadVR-Bicubic75AR/Lanczos4AR/Lanczos4AR LumaSharpen -Strength0.9-Pattern3-Clamp0.1-OffsetBias2.0 |
29th May 2014, 06:25 | #26516 | Link | ||
you can check the fps with EVR CP in mpc-hc just play the file and press control + j you can see the FPS at the top left wait 5 sec at a part where MadVR drops frames. the opening is a usually a good part for this. Quote:
it is possible to add min FPS, max FPS and avg FPS in file infos. the splitter just uses 1 FPS value. MadVR has use these informations too to switch to the best possible refreshrate. MadVR with SM at 60 hz does an awesome job on these files! |
29th May 2014, 08:39 | #26517 | Link | |
Splitters will typically report the FPS of the first segment in the file, but it doesn't really matter, as no matter which you report, its going to be wrong at some point. DirectShow doesn't let you report anything else to the decoder and renderer. Smooth Motion is probably the best way to deal with those files.
29th May 2014, 22:37 | #26518 | Link | |
Troubleshooter
madVR and VFR videos
One Piece VFR pic Based on that as a test I went in and edited my list of all display modes madVR may switch to: in madVR settings for the tv so that it only included the 29hz and 30hz options. It then opened it in the 30hz, and played without any dropped frames or presentation glitches. As far as madVR working with VFR videos (don't know if its plausible): If madVR could detect the high point of video fps (in this case 29.97) then check against the list of all display modes madVR may switch to: section and switch to that mode (or the closest one with a higher hz - it would be better to repeat frames than drop them right?-) that might be a good way to deal with VFR videos. From a testing perspective if we had a rule code for the high fps algorithm we could make profiles with each of the supported modes for the screen, and tell it in certain cases to use the different profiles. Something like: Code:
if (Hfps <= 23) "23hz screen profile" else if (Hfps <=24) "24hz screen profile" else if (Hfps <=29) "29hz screen profile" else if (Hfps <=30) "30hz screen profile" else if (Hfps <=59) "59hz screen profile" else if (Hfps <=60) "60hz screen profile" else "standard display modes profile" Edit: Looks like profiles can't be created for the "devices" group in madVR settings (as things are now). I was thinking about creating profiles and rules using the srcFps code for now and setting them to use one display mode higher then what the source FPS is detected at , but that doesn't look doable without profiles for the "devices" area. example: Code:
if (srcFps <= 23) "24hz screen profile" else if (srcFps <=24) "29hz screen profile" else if (srcFps <=29) "230hz screen profile" else if (srcFps <=30) "59hz screen profile" else if (srcFps <=59) "60hz screen profile" else if (srcFps <=60) "60hz screen profile" else "standard display modes profile"
System specs: Sager NP9150 SE with i7-3630QM 2.40GHz, 16 GB RAM, 64-bit Windows 10 Pro, NVidia GTX 680M/Intel 4000 HD optimus dual GPU system. Video viewed on LG notebook screen and LG 3D passive TV. Last edited by Anime Viewer; 29th May 2014 at 22:56. Reason: added srcFps theory |
29th May 2014, 23:01 | #26519 | Link | |
if a file is VFR you should use the highes possible refreshrate with smoothmotion don't forget some parts are 23 or even 26 or time stamps change from frame to frame.
detection is not possible see here: Quote:
29th May 2014, 23:38 | #26520 | Link |
It really depends on the variableness of the framerate. SM is the safe option but in my case it was maybe 5% of the video that was >23 fps. I chose to deal with the judder in those parts over the motion blur. IIRC mediainfo only listed original fps 23.976 so I don't know if anything could really be done with the file, splitter or madvr to work around it. You'd think with madvr's lookahead it could enable SM for that 5% in my case but I don't think it did.
