11th January 2017, 04:00 | #41981 | Link | |
But if I use full RGB with a TV, do not lose details? Sorry for insist, I want to understand. I am very upset, but, I am reading contradictory information from this web: RGB Full will display video games and other 0-255 content at the correct 0-255 range. TV, Movies and other video range use the RGB Limited range 16-235 . http://referencehometheater.com/2014...ll-vs-limited/ Q: My TV supports Full mode, shouldn’t I use this? A: No. TVs support Full to make them easier to calibrate. Most TVs will not display a black level below 16 because video content should never have it. By letting you see Black 15 or 14, it can make it easier to calibrate the display and get the black level correct. However, you really should not use this as your main setting as most displays are not designed to display levels below 16, and often introduce color tints when doing white levels past 240 or so. Additionally, if you restrict yourself to levels 16-235 you wind up with a brighter image with a better contrast ratio, as you can turn up the contrast level higher. Contrast Ratio is the thing your eye notices most, and so it will produce a more pleasing image.
"To infinity, and beyond!" |
11th January 2017, 08:29 | #41983 | Link | |
QB the Slayer
QB
11th January 2017, 12:22 | #41984 | Link | |
But I do not understand why the page says otherwise and gives incorrect information.
11th January 2017, 12:48 | #41985 | Link |
May I ask 2 little questions ?
1) I'm watching 1080p BluRay sources on a good 1080p REC709 projector, what's the ultimate algorithm to be used? Luma doubling + chroma doubling? I have an i7@4.4Ghz + GTX960. 2) I'm using 60Hz FRC via SVP. To make it work with madvr I have set the FFDShow Raw video filter + avisynth in MPCHC, together with LAV Video Filter (mandatory for Madvr), in external filters. Everything seems working fine. What I don't understand, is why don't I get frame dropping, as I reach 20ms average render time. Because SVP is supposed to work on the raw video, Madvr should see 60fps, and the render time should be under 16ms, isn't it? Frame dropping starts after 33ms render time, as if SVP was working after Madvr. Is it normal? Is it possible to change this?
I7 2600K@4.4 / GTX1080 / ACER M550 (DLP 4K) / Catleap (IPS 1440p) / Onkyo SE200 Sound card |
11th January 2017, 15:11 | #41987 | Link |
It's generally accepted that going an all-PC levels chain is the way to go if you can. My TV can switch to PC levels but I do get more banding than if I output TV levels from MadVR and with TV set to TV levels (GPU at PC levels). This may be a stupid question but I'm not sure how the conversions work. Eg with YCbCr luma goes to 235 but chroma goes to 240. When Madvr converts to RGB does it scale both luma and chroma to 235? What happens to the chroma information 235-240? And how does it handle WTW information, is that also all scaled to 235? |
11th January 2017, 16:46 | #41988 | Link |
WTW (and BTB) is clipped, but is is clipped by the display when in limited range too so this isn't very different.
The 240 v.s. 235 is not an issue, the matrix converting YCbCr always uses 0-255 with different weights to go to limited or full range RGB, it is not a two step conversion to RGB, with one step doing the conversion and one scaling the range.
madVR options explained |
11th January 2017, 17:00 | #41989 | Link | |
11th January 2017, 17:57 | #41990 | Link |
@madshi
do you think i reached the lowest possible overhead with MadVR comparing here against EVR Sync in a split load test ? MadVR Performance Settings (low overhead) interesting with MadVR MPC-BE shows in it's FPS counter 60 FPS measured not like with EVR Sync the exact 59.940 also if MadVRs Statistics shows that. In Power output i measured around ~5W overhead vs EVR Sync for MadVR in that configuration. But that's not even the worst case MadVR really seems to become more inefficient the more it's scaling even nearest neighbor becomes crazy inefficient fulllscreen and is tasking the GPU Shaders like crazy ???
all my compares are riddles so please try to decipher them yourselves :) It is about Time Join the Revolution NOW before it is to Late ! http://forum.doom9.org/showthread.php?t=168004 Last edited by CruNcher; 11th January 2017 at 18:55. |
11th January 2017, 19:11 | #41992 | Link |
If you can see WtW your display is not properly calibrated for limited range input, with limited range input 16 is 0% brightness and 235 is 100%. That means the display should never show blacker than black or whiter than white.
11th January 2017, 19:27 | #41993 | Link |
Ok lesson learned MadVR needs to be configured per source
Nearest Neighbor/Billinear = 200W DXVA = 150W Inline with EVR Sync now Huh DXVA gets lost if nothing of the gui is being drawn ? So there is no other way then to intentional downscale the image (draw a gui element, or resize it) or the overhead on the shaders will stay on billinear or nearest neighbor ? So the middle layer is never low overhead except when using DXVA explicitly from the Decoder, and this isn't override able via the options at all ?
all my compares are riddles so please try to decipher them yourselves :) It is about Time Join the Revolution NOW before it is to Late ! http://forum.doom9.org/showthread.php?t=168004 Last edited by CruNcher; 11th January 2017 at 20:53. |
11th January 2017, 19:54 | #41994 | Link | |
"Originally Posted by nevcairiel For the level settings, there is basically 3 combinations of settings: (1) TV accepts PC/Full levels: Set madVR to PC/Full, set GPU to PC/Full - This is usually considered the better option, if your TV can do it. (2) TV accepts only TV/Limited levels: (a) Set GPU to PC/Full and set madVR to TV/Limited (b) Set GPU to TV/Limited and set madVR to PC/Full In the second case, both a and b have small drawbacks. With (a), you get crushed black/white on the desktop, but everything is perfect in madVR. With (b), you get proper colors everywhere, except that the GPU is doing the PC range -> TV range conversion, which may not be the highest quality and end up in banding. NEVER set both madVR to TV/Limited AND GPU to TV/Limited, you get double range compression. Because of these drawbacks with either a or b, its usually recommended to use (1) if your TV accepts it. Its only "downside" is that BTB/WTW are lost, but its arguable if those are even worth keeping. If you insist on WTW/BTB, the 2a setting is probably the next best for video quality, if you can live with crushed black/white on the Desktop." End quote. Now, whether or not to choose to clip WTW in the TV using the contrast control is up for debate and has been for years. Last edited by iSeries; 11th January 2017 at 20:21. |
11th January 2017, 21:26 | #41995 | Link |
I wasn't trying to say the digital values for WtW and BtB never make it to the display, only that you never see them so whether they are clipped by madVR or displayed exactly the same as if they had been clipped doesn't make any difference to the image.
In this digital age I think it is totally appropriate that contrast is as high as possible, there is no analog uncertainty in a 100% signal so there is no reason to run below max contrast. Also contrast is the most limiting aspect of most modern displays, reducing contrast in order to "keep" WtW is a tragedy.
11th January 2017, 21:37 | #41996 | Link |
Ouch i looked at old issues virtually all of those are fixed (options added) in 0.91.5 and performance (stability) pretty awesome as well on low overhead config.
Core Render Performance on a really high level Updating options in MPC-BE though still can cause to much CPU overhead causing frames to get dropped by MadVR when pushing "Apply" Needs to be better separated from each other thread wise (async)
all my compares are riddles so please try to decipher them yourselves :) It is about Time Join the Revolution NOW before it is to Late ! http://forum.doom9.org/showthread.php?t=168004 Last edited by CruNcher; 11th January 2017 at 22:44. |
11th January 2017, 23:33 | #41997 | Link | |
I prefer to bitstream so I've decided to keep it with 16-235 output via the GPU control panel. Not sure why using 0-255 output via the GPU with madVR set to 16-235 for the display looks different to the GPU outputting 16-235 with madVR set to 0-255 for the display.. Could be beneficial for madVR to have a level checker image included to perhaps assist users. 0-255 -> 16-235 vs 16-235 -> 0-255 |
12th January 2017, 00:09 | #41998 | Link | |
12th January 2017, 00:12 | #41999 | Link | |
True, a lot of displays go very weird when contrast is set too high.
madVR options explained Last edited by Asmodian; 12th January 2017 at 00:15. |
12th January 2017, 01:15 | #42000 | Link | |
For anyone interested in this video and others, link. Last edited by ryrynz; 12th January 2017 at 01:19. |
