21st May 2008, 01:26 | #4881 | Link |
Yup exactly, it's encoding now so no worries. When I tried to do the second video on the disk I got a TON of overlap errors and the result, after the second pass, wouldn't play. <shrug> It's just the director's extras stuff and consisted of like 10 different files of wildly differing sizes. First I've had like that - it was a mess! Was all of 40mins long too (lol)
21st May 2008, 03:58 | #4882 | Link | |
Eac3to And More GUI |
21st May 2008, 05:54 | #4883 | Link | |
<shrug> Last edited by boykster; 21st May 2008 at 05:57. |
21st May 2008, 08:57 | #4884 | Link | ||
I wish that was true!! Quote:
21st May 2008, 11:09 | #4885 | Link | |
Anyway, thanks for your time man! Last edited by nautilus7; 21st May 2008 at 11:11. |
21st May 2008, 13:09 | #4886 | Link | |
(1) Have you tested CoreAVC? Testing with Cyberlink is not a proof yet, since there have been cases where Cyberlink gracefully played bad MKV muxes (created by mkvtoolnix) while CoreAVC showed artifacts. So a good test is always to try both Cyberlink and CoreAVC. If both show a perfect artifact free image, usually the mux should be fine. (2) Does the problem also occur with the original m2ts file? If yes, that would be the proof that the decoder is at fault and not the MKV remux. |
21st May 2008, 14:05 | #4887 | Link |
1. CoreAVC decoded the sample fine.
2. Can't play the m2ts file in mpc (i can't play any .m2ts file in mpc - don't know why, they just load but nothing happens), but it plays fine in powerdvd and nero showtime. |
21st May 2008, 16:47 | #4888 | Link |
Sorry if this is a basic question. I'm not new to transcoding, but I've never tried to transcode TrueHD before.
I'm having some trouble converting an HD DVD file so I can play it back on my PS3.
I'm trying to decode track 3 -- the others are alternate language and director's commentary. I've tried ripping just track 3 to an .evo file, but the error is the same. I've read that I can decode TrueHD audio if I have Nero 7 and the HD/ Blu Ray plugin, but as far as I know, Nero 7 isn't sold any more. I also have the movie on regular DVD, which has the normal ac3 track, but the problem is that the HD video and the DVD-ripped audio don't play in sync together. I'm not sure of what I can do to get these files to play together in sync, so I would be really grateful for any help on how I can get around this problem (regardless of if it's TrueHD, ac3 or not). Thanks. Any help is really appreciated! Last edited by richard99uk; 21st May 2008 at 16:49. |
23rd May 2008, 03:25 | #4889 | Link | ||
23rd May 2008, 09:55 | #4891 | Link |
The error is there, even in that small of a sample.
23rd May 2008, 10:32 | #4892 | Link |
Thanks for the National Treasure 2 sample. I can confirm that there is a DTS track in the movie - it's the audio track of the PiP content. And that DTS track is really strange. It doesn't contain any conventional DTS elements. I mean there's no core. There are only DTS-HD packets in the stream. eac3to doesn't know what to do with that kind of track, that's why you see the complaint in the log. You don't need to worry, this is really only the PiP audio.
Have you guys noticed that this is one of the first Blu-Rays with a *TRUE* PiP video/audio stream in it? As you can see in the eac3to log, a secondary h264 video stream is detected. That's the first Blu-Ray I've seen with a 2ndary video track! |
23rd May 2008, 13:08 | #4895 | Link |
Never heard of "DTS-Express" yet. What I can say is that the data packages in the PiP audio stream have the same "signature" (first for bytes) for each audio block as the additional DTS-HD audio packages in a DTS-HD stream have. Is there a DTS-Express specification available somewhere?
Yeah, that should be the same. It seems that PiP is beginning to be spread for Blu-Ray now. |
23rd May 2008, 14:24 | #4896 | Link | |
Also, the original is actually two files -- that's why I rebuilt it instead of using eac3to directly on the file. Are there any extra commands I need to tell eac3 to move on to the second file automatically? Thanks again for your help! |
23rd May 2008, 17:21 | #4899 | Link |
mpls support is there is is tranparrent. Point eac3to to the folder containing all the BluRay files and it will list all the titles, with info showing which m2ts files are joined, and the streams they contain.
Using eac3to_and_more_gui makes it easy using the 'Add Folder' button. Cheers, Beastie. |
23rd May 2008, 18:25 | #4900 | Link | |
b4k3d
eac3to |
