12th August 2010, 18:27 | #5601 | Link |
I can't check right now, but my guess is that profile produces blu-ray compatible output if the resolution and framerate matches. (If the --nal-hrd switch is used and keyint is set to 24 my assumption is probably correct.) If you just want stuff that's generally compatible with DXVA and hardware players use the dxva profile (HD in your case).
New versions of mkvmergegui have header removal compression on by default which causes issues with hardware players and some software. If you use the mkv muxer in the latest megui version it will be deactivated so you should't have issues. You can also deactivate it in mkvmergegui, but you'll have to do it for each track individually. |
12th August 2010, 18:47 | #5602 | Link |
Thanks for that Nurbs, what is a good CQ figure for HD stuff? is the default 20 a good starting point or will it differ from movie to movie
The Internet: where men are men, women are men, and children are FBI Agents |
12th August 2010, 19:08 | #5603 | Link |
Personally I use 20 for SD (from DVD) and 21 for HD (like you I also resize my blu-rays to 720p). You should test it for yourself because it really comes down to personal preference. I basically encoded some samples at different CRF values after I decided on preset (veryslow with AQ mode 2) and tuning (film or animation). Then I decided which value was still acceptable to me and subtracted 1 to be on the safe side.
As a note: None of my 720p encodes which usually include 2 or 3 stereo audio tracks came out larger than 4 GB. |
12th August 2010, 20:04 | #5604 | Link |
Mine are going to come out large as im keeping the DTS which i down graded from DTS-HD, am testing CQ 20 and CQ 21 on avatar , at the moment CQ 20 is saying about 3.4GB so shouldn't be much more than 4GB, will see which i think looks good to my eyes and then let her rip
Edit: may have to rethink the DTS - some of the files are near enough the same size as the video :-p
The Internet: where men are men, women are men, and children are FBI Agents Last edited by Carpo; 12th August 2010 at 20:54. |
13th August 2010, 09:22 | #5606 | Link |
1. Click one click encoder
2. Click config on the OneClick profile 3. Click Config on the avisynth profile 4. Overwrite the <deinterlace> line with the deinterlacer you would like you use, once done click new and create a new AviSynth preset. Then click OK 5. Make sure that the AviSynth profile you have just created is selected on the OneClick config dialog window. unselect automatic deinterlacing. configure the video and audio presets as you need. Click new down the bottom and name the OneClick conf then click ok to close the OneClick. 6. Make sure the new OneClick profile to created is selected and start queuing jobs. Hopefully make sense been drinking and soon to be smoking
A Man Eating Duck |
13th August 2010, 12:27 | #5607 | Link | |
With AAC you could use around 320 kbps for good quality, but AAC support for 5.1 tracks is not that good. Some devices downmix it to stereo and most don't support bitstreaming from what I've heard. I only use stereo so AAC is an obvious choice for me. |
13th August 2010, 12:39 | #5608 | Link | |
Also, I'm not sure but is the FieldDeinterlacer the decomb.dll one? Last edited by invy; 13th August 2010 at 12:41. Reason: added quoted text |
13th August 2010, 19:02 | #5609 | Link | |
I re-encoded the DTS to 768 and its still 800meg+ glad i also ripped the ac3 audio along with the AC3 ;-) even at 448kbps they may be big but not as big as the DTS, so like you say i should go with that
13th August 2010, 23:28 | #5610 | Link | |
eg for loading yadif i would replace <deinterlace> with Code:
Load_Stdcall_Plugin("C:\Program Files (x86)\MeGUI\tools\yadif\yadif.dll") Yadif(order=1) Code:
LoadPlugin("C:\Program Files (x86)\MeGUI\tools\avisynth_plugin\TDeint.dll") TDeint(order=1)
A Man Eating Duck Last edited by AMED; 13th August 2010 at 23:43. |
15th August 2010, 02:08 | #5611 | Link |
Is there a way to pause encodes, shut down the computer and continue where one left off later?
This functionality would be really useful for me. When strong thunderstorms come around, I like to turn off and unplug my electronics. |
15th August 2010, 02:48 | #5612 | Link |
@lubczyk
Not possible but you could standby/hibernate the OS and use a power strip with surge protection.
15th August 2010, 02:52 | #5613 | Link |
Try installing VirtualBox and run x264 inside the emulated operated system.... I don't know how fast x264 would run but other things run pretty fast on my emulated machine (virtualization capable cpu sure helps)
You can then just suspend the whole virtual machine to disk. |
15th August 2010, 03:03 | #5614 | Link |
I'm skeptical but worth a try.
17th August 2010, 16:05 | #5615 | Link |
Am still getting this damn message. Can anyone please provide some help on this? I don't know what else to do. Thank you.
Chumbo |
17th August 2010, 17:36 | #5616 | Link |
Is MeGUI able to re encode a mkv x264 file into another one? Because when I'm trying to import my mkv file into the File Indexer, the File Indexer either crashes (dgavcindex.exe is not responding blablabla, when there is audio in the video) or seems idle as it doesn't seem to work on my file. Maybe I'm doing something wrong?
17th August 2010, 17:50 | #5617 | Link | |
The Black Reaper
An alternative would be to open the .mkv with avs script creator. |
17th August 2010, 18:36 | #5619 | Link | |
As I understand you you have tried to run the command line directly. Are there any errors shown on the command line? You can try to replace the vfw4x264.exe with avs4x264.exe in your command line. Does it still crash? |
megui |
