15th March 2012, 17:56 | #9901 | Link | |
In the playback case you have the Asic which sends the data to the CPU/GPU which sends it to the discreet GPU and back to the renderer of course that is implying overhead then compared when you do it in 1 straight way but the Asic is so fast that it might be usefull @ all, especialy if you start to mix different things together on both sides in a efficient way (managing different tasks)
all my compares are riddles so please try to decipher them yourselves :) It is about Time Join the Revolution NOW before it is to Late ! http://forum.doom9.org/showthread.php?t=168004 Last edited by CruNcher; 15th March 2012 at 18:03. |
15th March 2012, 18:05 | #9903 | Link |
Using QuickSync for decoding and then your dedicated card for display is certainly fine. I would probably also consider software decoding if you have a beefy CPU.
Note that post-processing on interlaced material is not a good idea (unless the first step of that post-processing is deinterlacing)
15th March 2012, 18:32 | #9904 | Link |
Well my cpu (i3 2105) meter sits @ 7% with DXVA Native and @ 10% with QuickSync on a 1080p H264 video. So thats not a huge diference if u ask me
What is funny though is that now i have to keep an eye for shitty drivers by both ATI and Intel That sounds interesting, hehe |
15th March 2012, 18:58 | #9905 | Link | |
I'm thinking that dxva copyback requires at least uvd 2.2. "The UVD 2.2 features a re-designed local memory interface" - wikipedia so that would explain poor performance on the 4850 and 4870, which have uvd 2.0. |
15th March 2012, 19:13 | #9906 | Link |
If it doesn't work for you, don't use it.
Nothing i can do. I still stick by my opinion that the renderer queue doesn't indicate a too slow decoder directly. Check the decoder queue, if thats empty its obvious.
15th March 2012, 22:53 | #9907 | Link |
Yea, it's not a big deal, I can manage without hardware acceleration on that computer anyway. It's just that I have been recommending people with amd graphics cards to try out dxva copyback with madvr, but perhaps I should add a warning for people with older cards.
Another thing, with the latest stable nvidia drivers, there is occassional artifacts with vc-1 for vp2 hardware in cuvid. I assume it is all driver related, so is there one that anyone can recommend? edit: i found that I had to go back all the way to forceware 275. Someone tell nvidia to fix it in their newer drivers! Last edited by mindbomb; 15th March 2012 at 23:56. |
16th March 2012, 00:59 | #9908 | Link |
Nev, I have an anamorphic PAL DVD that isn't displayed with the correct AR when LAV splitter and LAV video are used. If I open the full DVD (MS DVD navigator is used) and use libmpeg2 as decoder the AR is correct. If I open either a VOB or the corresponding .IFO, I get the wrong AR with LAV. "Use Stream AR" is checked in LAV Video. Is this expected behavior considering LAV can't access the VIDEO_TS.IFO at the moment?
16th March 2012, 02:58 | #9909 | Link | |
Edit : what renderer are you using ? (EVR, EVR-CP, MadVR, VMR9, ...) Last edited by Pat357; 16th March 2012 at 03:01. Reason: Renderer ? |
16th March 2012, 03:39 | #9911 | Link |
Any chance of adding RIFF WAVE DTS audio support? Let me clarify that by adding that it is RIFF WAVEfmt in the header. Same goes for some AC3 files I have.
EDIT: Nevermind. I've decided to use bsconvert on them all. BTW that speedup on one particular DTS file still exists. If I bitstream with ffdshow it plays at the correct speed so something in the path of LAV Audio filter does something weird to the stream inccorectly flagging it as 48Khz methinks so the receiever tries to decode it as such. All very odd. If I can find a way to split the file I will send you a chunk to playback for yourself. Last edited by oddball; 16th March 2012 at 05:54. |
16th March 2012, 07:27 | #9912 | Link |
Like i explained before, when bitstreaming the decoder does not flag a file as anything. Its all in the DTS headers themself. I also explained that when i used ffdshow on that file, i got no playback, but with LAV it was fine. So something is odd in your receiver that somehow combined with ffdshows oddnes makes for working audio again. :d
16th March 2012, 11:37 | #9913 | Link |
nvidia user
Hello!
Sorry, if has already been reported about it. When I use the path Programs - LAV Filters - LAV audio Configuration, the window looks like this - http://firepic.org/images/2012-03/16/az9v6wde1s34.png Settings are not available. When I use the filters manager in the player (to open LAV Audio Decoder settings) - have no problem's - http://firepic.org/images/2012-03/16/gpvm92s293bp.png WinXP SP3 x86, LAV Filters v0.49, WinXP default theme. |
16th March 2012, 11:38 | #9914 | Link |
I tried to reproduce this problem on Windows XP, and everything is fine for me. Cannot reproduce, cannot fix.
16th March 2012, 12:28 | #9916 | Link | |
Also, last report i got about this claimed that LAV Video didn't have this problem.
16th March 2012, 13:15 | #9917 | Link | |
The renderer doesn't matter, it's just a decoder issue. How to provide a sample? It's a DVD remux, a bit too big to upload. |
16th March 2012, 13:35 | #9918 | Link |
Cut a small sample using some tool like DGSplit, check if the problem persists. Should preferably be at least 10 seconds of playback, maybe 20-30MB in size.
16th March 2012, 15:46 | #9920 | Link |
What he means is that the last person to have a similar problem was having it with the LAV Audio Configuration window (I think) but the LAV Video Configuration window was fine. For you, it's the other way around.
TV Setup: LG OLED55B7V; Onkyo TX-NR515; ODroid N2+; CoreElec 9.2.7 |
