5th January 2012, 04:16 | #7861 | Link |
I am not a fan of the Loudness Equalization feature of Win7. I prefer controlling volume just for video playback. Everything else is already loud enough.
A mixer is already on Nev's ToDo list. Hopefully that will include an option to apply a gain to the center channel when downmixing. That is one way to solve the volume issue. Another would be a simple normalization option like in ffdshow.
MPC-HC 2.1.7.2 |
5th January 2012, 04:27 | #7862 | Link |
I'm not a fan of it either, but it's a temporary workaround.
Does ffdshow apply a gain to the center channel automatically (when using its mixer w/ the 2.0 preset)? That would explain why people say they had a higher volume w/ it (than the Windows built-in mixer). Note: they didn't turn on normalization in ffdshow. The higher volume was "out-of-the-box" after choosing 2.0 channel mixer in the installer. EDIT: Until a custom built-in mixer will be available in LAV Audio... Maybe it would be possible to control the Windows mixer a bit: http://msdn.microsoft.com/en-us/library/ms678838.aspx (the SetLevel method inherited from IPerChannelDbLevel) Last edited by Superb; 5th January 2012 at 04:37. |
5th January 2012, 07:45 | #7866 | Link |
It still is somehow related to partial acceleration, because it doesn't happen on cards with full acceleration capabilities. It might just be coincidence and depend on the series of the card, but somewhere is another factor in there.
5th January 2012, 07:47 | #7867 | Link | |
There are several ways to fake that, the most useful being the "fake" VGA monitor which you can just trick Windows into using. I think it was also linked before, but so everyone sees it, here its again: http://forum.doom9.org/showthread.ph...86#post1532786 Another general limitation is that the decoder only works on Vista/7, but thats a limitation in Intels drivers and i doubt it'll ever change. So, no XP love for you!
LAV Filters - open source ffmpeg based media splitter and decoders Last edited by nevcairiel; 5th January 2012 at 11:45. |
5th January 2012, 13:18 | #7869 | Link |
Hi folks, I'd like to report a possible bug with lav splitter and the lord of the ring italian blu-ray extended edition. All my others blu-ray plays flawlessly but with these ones the audio tracks are not recognized correctly. LAV recognizes 6 tracks in the stream, see the image attached: the first (english eac3 mono) according to the package specs, should be DTS-HD 6.1 and crashes MPC if selected. The second (italian ac3 stereo) should be DTS-HD 6.1 too but outputs no audio if selected. The others are commentary and work good.
Power dvd recognizes 6 audio tracks too, english,italian,4x english and works good with each one. Media info report attached (doesn't make much sense to me too) Thank you very much for your hard work. |
5th January 2012, 13:20 | #7870 | Link |
Fantasy Codecs writer
to:nevcairiel i Compiling last lav but i can not see IntelQuickSyncDecoder.dll ?
i not install intel media sdk !but comp ffdshow i can Comp IntelQuickSyncDecoder.dll! do i need install last intel media sdk beta? Last edited by betaking; 5th January 2012 at 13:57. |
5th January 2012, 13:42 | #7871 | Link |
Broadband Junkie
If I load LAVSplitter.ax in MPC-HC as an external filter (using Browse) without it actually being registered, I've occasionally been getting crashes in MPC-HC citing avformat-lav-53.dll when opening a new video. No idea if this is a MPC-HC bug or a LAV bug, but even though this is non-standard usage, I'd be nice if it worked reliably.
5th January 2012, 13:44 | #7872 | Link |
That mode is somewhat unstable in MPC-HC for filters that rely on external dlls, i tried to fix it some time ago, but it never worked 100%. Its a MPC-HC bug. Register the filters already.
5th January 2012, 13:46 | #7873 | Link | |
Use a tool like DGSplit to cut the first few MB off, and then upload it to mediafire or multiupload.
5th January 2012, 14:04 | #7876 | Link | ||
Unselecting through the filter properties does nothing to media types, because its not running with elevated access. I've been pondering on removing all sorts of media type handling from the DLL and let only the installer do it, that way it would seem more consistent (and only registering the filter would not do "harm", because it wouldn't touch anything) Quote:
Also, that only applies to decoding of course, the issue reported above seems to be an issue with identifying the streams in LAV Splitter, long before decoding happens.
LAV Filters - open source ffmpeg based media splitter and decoders Last edited by nevcairiel; 5th January 2012 at 14:07. |
5th January 2012, 14:21 | #7877 | Link | ||
I can probably make the software fallback process a bit faster, though. One of these days i will need to make the installer smarter, however duplicating the compat checks in the installer is somewhat annoying. If the auto-select process is fast enough i might add an "Auto" option that probes and selects the appropriate HW decoder. Quote:
LAV Filters - open source ffmpeg based media splitter and decoders Last edited by nevcairiel; 5th January 2012 at 14:29. |
5th January 2012, 14:28 | #7878 | Link | |
Broadband Junkie
My main concern with installing splitters which support a lot of formats like LAV, is their tendency to break the Media Type registry settings for most other installed splitters/source-filters, including windows default splitters/source-filters which use quartz.dll and are unable to be easily re-registered, and even when you don't want to use the splitter you just installed for those formats. Currently I'm forced to backup my registry key each time I install/test a new splitter so my system doesn't get left in a completely broken state if I choose the disable/uninstall at some point. This gets rather annoying, which is why the MPC-HC feature to use external filters without installing/registering is handy, it it was working reliably. Last edited by cyberbeing; 5th January 2012 at 14:33. |
5th January 2012, 14:31 | #7879 | Link | |
5th January 2012, 14:49 | #7880 | Link |
I am using lav audio and also reclock. If I play a dolby digital 5.1 file or a dts 5.1 file, I get dolby digital 5.1 wich is fine. If I play dts-es file however, I dont get digital surround but just dolby pro logic. Is there anything I can do to make my setup work with dts-es or 6.1 surround files?
