1st September 2007, 18:34 | #3321 | Link | |
HDConvertToX author
on hybrid is more slow, but the result as the same as fixed order BUT the aswer change a lot if you "switch" Interlace with Film in that case film type can be hybrid, most of the time for anime or "honk kong" film production, rarely on hollywood movie there is hydrid film type. i think id better to post a fragment of unprocessed vob to asvisynth forum and ask better help (anyway i first will try NOT allowing Hybrid, just FILM. Most of time isn't hybrid...) BHH
HDConvertToX: your tool for BD backup MultiX264: The quick gui for x264 AutoMen: The Mencoder GUI AutoWebM: supporting WebM/VP8 |
2nd September 2007, 04:47 | #3323 | Link | |
warpsharpened
In the case of anime, in pretty much every case I've seen using NTSC Region1 DVD's, it's going to be a fixed field order that just needs decimating (i.e. IVTC/3:2 pulldown). Furthermore, most of the time, American films also just need some IVTC (film/decimating selection does the same thing) to restore the original 23.96fps movie. I have yet to see a film that uses a hybrid order. |
2nd September 2007, 06:59 | #3324 | Link |
HDConvertToX author
@wizboy11
fully agree, that's way i suggest to use film.. and not allowing hybrid BHH
3rd September 2007, 14:20 | #3325 | Link |
What setting I can use to crop everything to 16:9?
I see different options on different screens about resizing and cropping and confused which one I need to use. I want any incoming material regardless of type to fully fill 16:9 screen even if it will involve cropping (no distortion though). Which setting do I need to choose? Is it generally possible? G |
4th September 2007, 22:05 | #3326 | Link |
@buzzqw
Hi buzz, hi all!
Im just wondering if you guys have still trouble with BAutoDeint crashing? For me it is ramdomly crashing. Sometimes it works, sometimes not. Another win32-exception. Seems as if a file could not be read. The problem occurs not when I am running a test without automkv. Everything is fine running it from a shell. |
5th September 2007, 07:11 | #3327 | Link | ||
warpsharpened
Resizing is to 16:9 would mean a resolution of 704x396 (for xvid) or 704x400 (for h264 to maintain MOD16). However, you can also just do it at the main DVD resolution of 720x480 and for a muxing AR in mkv of 16:9. It depends what you want to do with it. You can also resize it up to maintain your vertical resolution to something like 848x480. Quote:
Maybe it's you... Reinstall avisynth and ffdshow if it's using "directshowsource". I really don't know whats up. Maybe buzzqw could offer some more incite on the problem. |
5th September 2007, 07:15 | #3328 | Link | |
HDConvertToX author
could be due to the new reading of stdout... i will re re re check BHH
5th September 2007, 14:50 | #3329 | Link |
Hi Buzz,
Just to say thanks for a great app. I've tried a few of the 'all in one' solutions out there and IMO AutoMKV is the one with the clearest UI. It gives me the level of customization that I need without overcomplicating encodes and so far is working like a charm. |
5th September 2007, 15:47 | #3330 | Link |
HDConvertToX author
@Miraelsol
thanks for your kind words! i do my best for making AutoMKV a better application! stay tuned for next update! BHH
5th September 2007, 17:59 | #3331 | Link |
@wizboy11
Yeah, that's what I was thinking too. But under automkv it keeps on crashing. Running it from shell it no problem. So I guess there's nothing wrong with avisynth or ffdshow, since it didn't use "directshowsource".
But I reinstalled avisynth and ffdshow again. Still the same. So buzzqw could be right, that it is automkv's new stdout or stdin or whatever. Let him check! Last edited by klicker4546; 5th September 2007 at 18:16. |
5th September 2007, 18:04 | #3332 | Link | |
@buzzqw
And last but not least, thanks for your great work on automkv! |
5th September 2007, 18:18 | #3333 | Link |
I've been using AutoGK for awhile now but I thought I'd try AutoMKV. I'm still a newbie though when it comes to DVD ripping so apologies in advance for my stupid questions.
If I set the container to be MKV then the output should be an MKV file, right? If the movie name is Looney_Tunes, should the output be Looney_Tunes.mkv? The reason I ask is because I end up with movie.mkv in the temp folder. The only thing I see in the selected output folder is the log file. When I play movie.mkv, there's no audio. Any idea what could be the cause of this? Did I do something wrong? Here's the log file: Code:
18:01:42 0.89 - - - - - - - - - - - - - START JOBS - - - - - - - - - - - - - - 18:01:42 Selected Input file: I:\DVD Backup\Looney_Tunes_Back_In_Action\VIDEO_TS\VTS_01_0.IFO 18:01:42 Selected Output dir: F:\My Videos\Rips\temp\ 18:01:42 Selected Final Name: Looney_Tunes 18:01:42 Selected Container type: MKV 18:01:42 Selected Encoder: XviD 18:01:42 Selected Size: 1/4 DVD-R / 1 18:01:42 Selected Profile: 1_Pass_High Performance.xml 18:01:42 Selected Resizer: SimpleResize (neutral soft) / 640 18:01:42 Selected Filters: RemoveGrain(mode=2) 18:01:42 Selected Deinterlacer: AUTO 18:01:42 Selected Field Order: AUTO 18:01:42 NeroAACEnc.exe: not present 18:01:42 Enabled CRF/CQ AutoRes at 2.5 value 18:01:42 Using Matrix: Jawor's 1CD Quantization Matrix.cqm 18:01:42 Track Language 1: English (AC3 6ch, 0xBD 0x80) [0] 18:01:42 Audio Codec 1: Lame 18:01:42 Audio Quality 1: 192 18:01:42 Audio Channel 1: Stereo 18:01:42 Track Language 2: Suomi (AC3 6ch, 0xBD 0x82) [0] 18:01:42 Audio Codec 2: Lame 18:01:42 Audio Quality 2: 192 18:01:42 Audio Chennel 2: Stereo 18:01:42 Advanced Audio Settings DUMP Track 1 18:01:42 Nero Option Profiles: AUTO --- Encoding Mode: Quality 18:01:42 CCT Option Profiles: AUTO --- Channel Options: AUTO 18:01:42 Lame Settings: ABR 18:01:42 Audio Normalization: 1 18:01:42 Frequency: AUTO --- Tempo: NONE --- Pitch: NONE --- Other Add: 18:01:42 Advanced Audio Settings DUMP Track 2 18:01:42 Nero Option Profiles: AUTO --- Encoding Mode: Quality 18:01:42 CCT Option Profiles: AUTO --- Channel Options: AUTO 18:01:42 Lame Settings: ABR 18:01:42 Audio Normalization: 1 18:01:42 Frequency: AUTO --- Tempo: NONE --- Pitch: NONE --- Other Add: 18:01:42 Selected 1' Sub tracks: English 0 (0xBD 0x20) [0] wide 18:01:42 Selected 2' Sub tracks: Suomi 1 (0xBD 0x22) [0] wide 18:01:42 18:01:42 Starting SubRipping 18:03:17 Subtitle Size: 3031040 bytes 18:03:17 Finished SubRipping 18:03:17 Starting Indexing 18:03:17 Dgindex CMD: E:\Data\Software\Media\Video\Conversion\AutoMKV089\exe\dgindex\dgindex.exe -FO=0 -OM=1 -TN=1,2 -YR=2 -AIF=[I:\DVD Backup\Looney_Tunes_Back_In_Action\VIDEO_TS\VTS_01_1.vob] -OF=[F:\My Videos\Rips\temp\movie] -exit -minimize 18:05:19 Finished indexing 18:05:19 Starting fixing audio delay on track number 1 18:05:19 DelayCut CMD: E:\Data\Software\Media\Video\Conversion\AutoMKV089\exe\dgindex\Delaycut.exe -auto -out "F:\My Videos\Rips\temp\fixed1.ac3" "F:\My Videos\Rips\temp\movie T01 3_2ch 384Kbps DELAY -24ms.ac3" 18:05:19 Original 1 Audio Size: 252997632 bytes 18:05:25 Fixed 1' Audio Size: 252996096 bytes 18:05:25 Finished fixing audio delay 18:05:25 Encoding F:\My Videos\Rips\temp\fixed1.ac3 To Mp3 with 192 ABR Preset 18:28:59 Encoded 1' Audio Track: 123250656 bytes 18:28:59 Encoding F:\My Videos\Rips\temp\ To Mp3 with 192 ABR Preset 18:29:02 Unable to encode Audio2, trying with DirectShowSource! 18:29:02 Encoding F:\My Videos\Rips\temp\ To Mp3 with 192 ABR Preset 18:29:04 Unable to encode Audio, even with DirectShowSource!, trying with FFmpeg! 18:31:06 Broken audio found. No one press abort. I will continue 18:31:06 Encoded 2' Audio Track: -1 bytes 18:31:06 Unable to encode Audio, even with DirectShowSource!, trying with FFmpeg! 18:33:08 Broken audio found. No one press abort. I will continue 18:33:08 Encoded 2' Audio Track: -1 bytes 18:33:14 Number of Frames: 131769 18:33:14 Framerate: 25.000000 18:33:14 Movie length in Seconds: 5271 18:33:14 Movie Width/Height: 720/576 18:33:14 DgIndex AR: 16:9 18:35:01 Deinterlace Test: Processing completed. Type is determined to be progressive. 18:35:01 Single Pass Encoding XviD: "E:\Data\Software\Media\Video\Conversion\AutoMKV089\exe\encoder\xvid_encraw.exe" -single -bitrate 1746 -threads 0 -max_bframes 1 -imax 16 -quality 5 -vhqmode 0 -pmax 16 -bmax 16 -bquant_ratio 162 -ostrength 0 -nopacked -nochromame -qmatrix "E:\Data\Software\Media\Video\Conversion\AutoMKV089\profiles\XviD-profiles\matrix\Jawor's 1CD Quantization Matrix.cqm" -i "F:\My Videos\Rips\temp\movie.avs" -type 2 -mkv "F:\My Videos\Rips\temp\movie.mkv" 19:36:35 Only Movie Size: 991120467 bytes 19:36:35 E:\Data\Software\Media\Video\Conversion\AutoMKV089\exe\matroska\mkvmerge.exe" -o "F:\My Videos\Rips\temp\Looney_Tunes.mkv_pre" --track-name -1:"Looney_Tunes" --aspect-ratio 0:2.415094 --chapters "E:\Data\Software\Media\Video\Conversion\AutoMKV089\exe\chapters.txt" "F:\My Videos\Rips\temp\movie.mkv" --language -1:eng --default-track -1:yes "F:\My Videos\Rips\temp\audio2.mp3" --language -1:fin "F:\My Videos\Rips\temp\audio2.mp3" "F:\My Videos\Rips\temp\Looney_Tunes.idx" --title "Done with AutoMKV 0.89 http://forum.doom9.org/showthread.php?p=854221 " 19:36:36 Final Muxed size: -1 bytes 19:36:36 Encoding finished: 01:01:35 elapsed time 19:36:36 ----------------------------------------------------------------------- 19:36:36 Script AutoCrop.log 19:36:36 19:36:36 Crop(6,76,708,424) 19:36:36 ----------------------------------------------------------------------- 19:36:36 Script Resmovie.avs 19:36:36 ----------------------------------------------------------------------- 19:36:36 Script movie.avs 19:36:36 19:36:36 LoadPlugin("E:\Data\Software\Media\Video\Conversion\AutoMKV089\exe\filter\AddGrain.dll") 19:36:36 LoadPlugin("E:\Data\Software\Media\Video\Conversion\AutoMKV089\exe\filter\autocrop.dll") 19:36:36 LoadPlugin("E:\Data\Software\Media\Video\Conversion\AutoMKV089\exe\filter\aWarpSharp(Pruned).dll") 19:36:36 LoadPlugin("E:\Data\Software\Media\Video\Conversion\AutoMKV089\exe\filter\blockbuster.dll") 19:36:36 LoadPlugin("E:\Data\Software\Media\Video\Conversion\AutoMKV089\exe\filter\cnr2.dll") 19:36:36 LoadPlugin("E:\Data\Software\Media\Video\Conversion\AutoMKV089\exe\filter\ColorMatrix.dll") 19:36:36 LoadPlugin("E:\Data\Software\Media\Video\Conversion\AutoMKV089\exe\filter\Convolution3D.dll") 19:36:36 LoadPlugin("E:\Data\Software\Media\Video\Conversion\AutoMKV089\exe\filter\corrector.dll") 19:36:36 LoadPlugin("E:\Data\Software\Media\Video\Conversion\AutoMKV089\exe\filter\DctFilter.dll") 19:36:36 LoadPlugin("E:\Data\Software\Media\Video\Conversion\AutoMKV089\exe\filter\Decomb.dll") 19:36:36 LoadPlugin("E:\Data\Software\Media\Video\Conversion\AutoMKV089\exe\filter\Deen.dll") 19:36:36 LoadPlugin("E:\Data\Software\Media\Video\Conversion\AutoMKV089\exe\filter\degrainmedian.dll") 19:36:36 LoadPlugin("E:\Data\Software\Media\Video\Conversion\AutoMKV089\exe\filter\DGDecode.dll") 19:36:36 LoadPlugin("E:\Data\Software\Media\Video\Conversion\AutoMKV089\exe\filter\EEDI2.dll") 19:36:36 LoadPlugin("E:\Data\Software\Media\Video\Conversion\AutoMKV089\exe\filter\FFMpegSource.dll") 19:36:36 LoadPlugin("E:\Data\Software\Media\Video\Conversion\AutoMKV089\exe\filter\FFT3DFilter.dll") 19:36:36 LoadPlugin("E:\Data\Software\Media\Video\Conversion\AutoMKV089\exe\filter\FluxSmooth.dll") 19:36:36 LoadPlugin("E:\Data\Software\Media\Video\Conversion\AutoMKV089\exe\filter\frfun7.dll") 19:36:36 LoadPlugin("E:\Data\Software\Media\Video\Conversion\AutoMKV089\exe\filter\hqdn3d.dll") 19:36:36 LoadPlugin("E:\Data\Software\Media\Video\Conversion\AutoMKV089\exe\filter\LeakKernelDeint.dll") 19:36:36 LoadPlugin("E:\Data\Software\Media\Video\Conversion\AutoMKV089\exe\filter\MaskTools.dll") 19:36:36 LoadPlugin("E:\Data\Software\Media\Video\Conversion\AutoMKV089\exe\filter\medianblur.dll") 19:36:36 LoadPlugin("E:\Data\Software\Media\Video\Conversion\AutoMKV089\exe\filter\MipSmooth.dll") 19:36:36 LoadPlugin("E:\Data\Software\Media\Video\Conversion\AutoMKV089\exe\filter\MSharpen.dll") 19:36:36 LoadPlugin("E:\Data\Software\Media\Video\Conversion\AutoMKV089\exe\filter\mt_masktools.dll") 19:36:36 LoadPlugin("E:\Data\Software\Media\Video\Conversion\AutoMKV089\exe\filter\mvtools.dll") 19:36:36 LoadPlugin("E:\Data\Software\Media\Video\Conversion\AutoMKV089\exe\filter\NicAudio.dll") 19:36:36 LoadPlugin("E:\Data\Software\Media\Video\Conversion\AutoMKV089\exe\filter\RemoveGrainS.dll") 19:36:36 LoadPlugin("E:\Data\Software\Media\Video\Conversion\AutoMKV089\exe\filter\RepairS.dll") 19:36:36 LoadPlugin("E:\Data\Software\Media\Video\Conversion\AutoMKV089\exe\filter\SangNom.dll") 19:36:36 LoadPlugin("E:\Data\Software\Media\Video\Conversion\AutoMKV089\exe\filter\SimpleResize.dll") 19:36:36 LoadPlugin("E:\Data\Software\Media\Video\Conversion\AutoMKV089\exe\filter\SoundOut.dll") 19:36:36 LoadPlugin("E:\Data\Software\Media\Video\Conversion\AutoMKV089\exe\filter\TBilateral.dll") 19:36:36 LoadPlugin("E:\Data\Software\Media\Video\Conversion\AutoMKV089\exe\filter\TDeint.dll") 19:36:36 LoadPlugin("E:\Data\Software\Media\Video\Conversion\AutoMKV089\exe\filter\TIVTC.dll") 19:36:36 LoadPlugin("E:\Data\Software\Media\Video\Conversion\AutoMKV089\exe\filter\TomsMoComp.dll") 19:36:36 LoadPlugin("E:\Data\Software\Media\Video\Conversion\AutoMKV089\exe\filter\TTempSmooth.dll") 19:36:36 LoadPlugin("E:\Data\Software\Media\Video\Conversion\AutoMKV089\exe\filter\UnDot.dll") 19:36:36 LoadPlugin("E:\Data\Software\Media\Video\Conversion\AutoMKV089\exe\filter\UnFilter.dll") 19:36:36 LoadPlugin("E:\Data\Software\Media\Video\Conversion\AutoMKV089\exe\filter\VSFilter.dll") 19:36:36 LoadPlugin("E:\Data\Software\Media\Video\Conversion\AutoMKV089\exe\filter\warpsharp.dll") 19:36:36 #loadpluginstart 19:36:36 19:36:36 #test1 19:36:36 19:36:36 Import("E:\Data\Software\Media\Video\Conversion\AutoMKV089\exe\filter\BlindDeHalo3_mt2.avsi") 19:36:36 Import("E:\Data\Software\Media\Video\Conversion\AutoMKV089\exe\filter\FastLineDarken 1.3 MT MOD.avsi") 19:36:36 Import("E:\Data\Software\Media\Video\Conversion\AutoMKV089\exe\filter\HybridFuPP.avsi") 19:36:36 Import("E:\Data\Software\Media\Video\Conversion\AutoMKV089\exe\filter\LanczosPlus.avsi") 19:36:36 Import("E:\Data\Software\Media\Video\Conversion\AutoMKV089\exe\filter\Lem.avsi") 19:36:36 Import("E:\Data\Software\Media\Video\Conversion\AutoMKV089\exe\filter\LimitedSharpenFaster.avsi") 19:36:36 Import("E:\Data\Software\Media\Video\Conversion\AutoMKV089\exe\filter\MCBob_v03c.avsi") 19:36:36 Import("E:\Data\Software\Media\Video\Conversion\AutoMKV089\exe\filter\mvbob.avsi") 19:36:36 Import("E:\Data\Software\Media\Video\Conversion\AutoMKV089\exe\filter\QMlib.avsi") 19:36:36 Import("E:\Data\Software\Media\Video\Conversion\AutoMKV089\exe\filter\seesaw.avsi") 19:36:36 Import("E:\Data\Software\Media\Video\Conversion\AutoMKV089\exe\filter\spresso.avsi") 19:36:36 #importstart 19:36:36 19:36:36 #test2 19:36:36 19:36:36 movie = mpeg2source("F:\My Videos\Rips\temp\movie.d2v") 19:36:36 function getOrder(clip c) { 19:36:36 order = GetParity(c) ? 1 : 0 19:36:36 Return order } 19:36:36 #filter1start 19:36:36 19:36:36 #test3 19:36:36 19:36:36 #cropstart 19:36:36 19:36:36 cropclip = autocrop(movie,mode=0,wmultof=4,hmultof=4,samples=40,aspect=0,threshold=34,samplestartframe=0) 19:36:36 fixed_aspect = 1.422222 19:36:36 c_width = width(cropclip) 19:36:36 c_height = Round(height(cropclip) / fixed_aspect) 19:36:36 input_par = float(float(c_width)/float(c_height)) 19:36:36 input_par = input_par > 1.4 ? input_par : (4.0/3.0) 19:36:36 out_width = 640 19:36:36 out_height = Round(float(out_width) / input_par) 19:36:36 hmod = out_height - (floor(out_height / 16 ) * 16) 19:36:36 out_height = (hmod > 4) ? (out_height + (16 - hmod)) : (out_height - hmod) 19:36:36 new_aspect = (float(out_width) / float(out_height)) / fixed_aspect 19:36:36 autocrop(movie,mode=0,wmultof=4,hmultof=4,samples=40,aspect=new_aspect,threshold=34,samplestartframe=0) 19:36:36 19:36:36 #resizestart 19:36:36 19:36:36 #test4 19:36:36 19:36:36 SimpleResize(out_width,out_height) 19:36:36 #filter2start 19:36:36 19:36:36 #test5 19:36:36 19:36:36 RemoveGrain(mode=2) 19:36:36 ColorMatrix(mode="Rec.709->Rec.601") 19:36:36 ----------------------------------------------------------------------- 19:36:36 Script mkvmaudio.avs 19:36:36 19:36:36 LoadPlugin("E:\Data\Software\Media\Video\Conversion\AutoMKV089\exe\filter\NicAudio.dll") 19:36:36 LoadPlugin("E:\Data\Software\Media\Video\Conversion\AutoMKV089\exe\filter\SoundOut.dll") 19:36:36 LoadPlugin("E:\Data\Software\Media\Video\Conversion\AutoMKV089\exe\filter\FFmpegSource.dll") 19:36:36 NicAC3Source("F:\My Videos\Rips\temp\fixed1.ac3") 19:36:36 #Applying STEREO downmixing routines 19:36:36 function stereo(clip a) 19:36:36 { 19:36:36 flr = GetChannel(a, 1, 2) 19:36:36 fcc = GetChannel(a, 3) 19:36:36 lfe = GetChannel(a, 4) 19:36:36 lfc = MixAudio(fcc, lfe, 0.2071, 0.2071) 19:36:36 mix = MergeChannels(lfc, lfc) 19:36:36 lrc = MixAudio(flr, mix, 0.2929, 1.0) 19:36:36 blr = GetChannel(a, 5, 6) 19:36:36 Return MixAudio(lrc, blr, 1.0, 0.2929) 19:36:36 } 19:36:36 # 19:36:36 6==Audiochannels() ? stereo() : last 19:36:36 function addvideo(clip c) { 19:36:36 blankclip(length = Int(100 * AudioLengthF(c) / float(audiorate(c))), fps=100) 19:36:36 Return audiodub(last,c) 19:36:36 } 19:36:36 Normalize() 19:36:36 Soundout(output="mp3",type=0,format=0,autoclose=true,mode=1,abrrate=192,showoutput=false,filename="audio.mp3") 19:36:36 ----------------------------------------------------------------------- 19:36:36 Script mkvmaudio.bat 19:36:36 ----------------------------------------------------------------------- 19:36:36 Script mkvmaudio2.avs 19:36:36 19:36:36 LoadPlugin("E:\Data\Software\Media\Video\Conversion\AutoMKV089\exe\filter\NicAudio.dll") 19:36:36 LoadPlugin("E:\Data\Software\Media\Video\Conversion\AutoMKV089\exe\filter\SoundOut.dll") 19:36:36 DirectShowSource("F:\My Videos\Rips\temp\") 19:36:36 #Applying STEREO downmixing routines 19:36:36 function stereo(clip a) 19:36:36 { 19:36:36 flr = GetChannel(a, 1, 2) 19:36:36 fcc = GetChannel(a, 3) 19:36:36 lfe = GetChannel(a, 4) 19:36:36 lfc = MixAudio(fcc, lfe, 0.2071, 0.2071) 19:36:36 mix = MergeChannels(lfc, lfc) 19:36:36 lrc = MixAudio(flr, mix, 0.2929, 1.0) 19:36:36 blr = GetChannel(a, 5, 6) 19:36:36 Return MixAudio(lrc, blr, 1.0, 0.2929) 19:36:36 } 19:36:36 # 19:36:36 6==Audiochannels() ? stereo() : last 19:36:36 function addvideo(clip c) { 19:36:36 blankclip(length = Int(100 * AudioLengthF(c) / float(audiorate(c))), fps=100) 19:36:36 Return audiodub(last,c) 19:36:36 } 19:36:36 Normalize() 19:36:36 Soundout(output="mp3",type=0,format=0,autoclose=true,mode=1,abrrate=192,showoutput=false,filename="audio2.mp3") 19:36:36 ----------------------------------------------------------------------- 19:36:36 Script mkvmaudio2.bat 19:36:36 19:36:36 "E:\Data\Software\Media\Video\Conversion\AutoMKV089\exe\BeSweet\ffmpeg.exe" -vn -i "F:\My Videos\Rips\temp\" -f mp3 -ac 2 -ab 128 "F:\My Videos\Rips\temp\audio2.mp3" 19:36:36 19:36:36 - - - - - - - - - - - - FINISHED JOBS - - - - - - - - - - - - - - - - - |
5th September 2007, 19:19 | #3334 | Link | |||
HDConvertToX author
@Aylwin
First of all Welcome to the Forum take a look at log Quote:
Starting Indexing 18:03:17 Dgindex CMD: E:\Data\Software\Media\Video\Conversion\AutoMKV089\exe\dgindex\dgindex.exe -FO=0 -OM=1 -TN=1,2 -YR=2 -AIF=[I:\DVD Backup\Looney_Tunes_Back_In_Action\VIDEO_TS\VTS_01_1.vob] -OF=[F:\My Videos\Rips\temp\movie] -exit -minimize 18:05:19 Finished indexing BUT the second audio isn't SUOMI! look better here Quote:
that's mean (0x82) SUOMI was the THIRD audio (0x80,0x81,0x82) BUT in Dgindex is reported TN=1,2 what's mean ? when you have ripped the dvd you have removed the SECOND audio track (0x81), but the ifo wasn't update and so AutoMKV instructed dgindex to demux the second audio in list.. but the second audio wasn't present! since suomi was the third (0x82) ... take it easy don't remove audio stream when you rip OR FOR THIS RIP select on audio list "All Audio Tracks" if your vobs contain only english and suomi tracks i hope to be clear BHH
6th September 2007, 13:15 | #3336 | Link |
I have a problem which i cant solve... its related to the resize routine as far as i can tell.
I will have to post 2 log files to make clear what i mean. First is the log file of my settings in which the movie encodes just fine (aborted the encode because of the time consuming process): Code:
14:05:03 0.89 - - - - - - - - - - - - - START JOBS - - - - - - - - - - - - - - 14:05:03 Selected Input file: E:\RIPPEN\BB\ep1\VTS_01_0.IFO 14:05:03 Selected Output dir: E:\RIPPEN\temp\ 14:05:03 Selected Final Name: VIDEO_TS 14:05:03 Selected Container type: MKV 14:05:03 Selected Encoder: X264 14:05:03 Selected Size: 324 / 1 14:05:03 Selected Profile: 2_Pass_Extreme_Quality.xml 14:05:03 Selected Resizer: Spline36Resize (neutral sharp) / Automatic 14:05:03 Selected Filters: derainbow(6).Deen("w3d",2,2,4).LimitedSharpenFaster(ss_x=1.5, ss_y=1.5, smode=3, strength=50, overshoot=1, undershoot=1).fastlinedarkenMOD(thinning=0) 14:05:03 Selected Deinterlacer: Partly Film 14:05:03 Selected Field Order: AUTO 14:05:03 Manual Crop: Enabled 14:05:03 Left Crop: 8 14:05:03 Top Crop: 0 14:05:03 Right Crop: 4 14:05:03 Botton Crop: 0 14:05:03 Manual Width: 720 14:05:03 Manual Height: 480 14:05:03 Track Language 1: NONE 14:05:03 Audio Codec 1: Lame 14:05:03 Audio Quality 1: 80 14:05:03 Audio Channel 1: Stereo 14:05:03 Advanced Audio Settings DUMP Track 1 14:05:03 Nero Option Profiles: AUTO --- Encoding Mode: Quality 14:05:03 CCT Option Profiles: AUTO --- Channel Options: AUTO 14:05:03 Lame Settings: ABR 14:05:03 Audio Normalization: 1 14:05:03 Frequency: AUTO --- Tempo: NONE --- Pitch: NONE --- Other Add: 14:05:03 Advanced Audio Settings DUMP Track 2 14:05:03 Nero Option Profiles: AUTO --- Encoding Mode: Quality 14:05:03 CCT Option Profiles: AUTO --- Channel Options: AUTO 14:05:03 Lame Settings: ABR 14:05:03 Audio Normalization: 1 14:05:03 Frequency: AUTO --- Tempo: NONE --- Pitch: NONE --- Other Add: 14:05:03 14:05:04 Starting Indexing 14:05:04 Dgindex CMD: E:\RIPPEN\AutoMKV084\exe\dgindex\dgindex.exe -FO=0 -OM=0 -YR=2 -AIF=[E:\RIPPEN\BB\ep1\VTS_01_1.vob] -OF=[E:\RIPPEN\temp\movie] -exit -minimize 14:06:12 Finished indexing 14:06:12 Finished fixing audio delay 14:06:13 Number of Frames: 51051 14:06:13 Framerate: 29.970030 14:06:13 Movie length in Seconds: 1704 14:06:13 Movie Width/Height: 720/480 14:06:13 DgIndex AR: 4:3 14:06:13 Starting X264 14:06:13 Command Line 1' Pass X264: E:\RIPPEN\AutoMKV084\exe\encoder\x264.exe --pass 1 --bitrate 1593 --stats "E:\RIPPEN\temp\.stats" --ref 1 --no-b-adapt --progress --keyint 250 --bframes 3 --qpmin 10 --qpmax 51 --no-psnr --filter -2,-1 --subme 1 --direct auto --vbv-maxrate 25000 --me dia --no-ssim --b-pyramid --analyse none --threads auto --thread-input --output NUL "E:\RIPPEN\temp\movie.avs" 14:06:13 Command Line 2' Pass X264: E:\RIPPEN\AutoMKV084\exe\encoder\x264.exe --pass 2 --bitrate 1593 --stats "E:\RIPPEN\temp\.stats" --progress --keyint 250 --bframes 3 --qpmin 10 --qpmax 51 --no-psnr --mixed-refs --trellis 1 --ref 5 --filter -2,-1 --direct auto --vbv-maxrate 25000 --me umh --no-ssim --weightb --b-pyramid --b-rdo --bime --analyse p8x8,b8x8,i4x4,i8x8,p4x4 --8x8dct --threads auto --thread-input --output "E:\RIPPEN\temp\movie.mp4" "E:\RIPPEN\temp\movie.avs" 14:06:37 Finished 1' Pass X264 14:06:41 "E:\RIPPEN\AutoMKV084\exe\matroska\mkvmerge.exe" -o "E:\RIPPEN\temp\VIDEO_TS.mkv" --track-name -1:"VIDEO_TS" --aspect-ratio 1:1.000000 --chapters "E:\RIPPEN\AutoMKV084\exe\chapters.txt" "E:\RIPPEN\temp\movie.mp4" --title "Done with AutoMKV 0.89 http://forum.doom9.org/showthread.php?p=854221 " 14:06:41 Final Muxed size: -1 bytes 14:06:41 Encoding finished: 00:00:04 elapsed time but that result gives me blocks around fine lines, so i dont want to enlarge, i just want to crop, and shape it back to 4:3, so now i use the same crop setting, but the resize to 708 x 472 (a pretty common resolution): Code:
14:07:20 0.89 - - - - - - - - - - - - - START JOBS - - - - - - - - - - - - - - 14:07:20 Selected Input file: E:\RIPPEN\BB\ep1\VTS_01_0.IFO 14:07:20 Selected Output dir: E:\RIPPEN\temp\ 14:07:20 Selected Final Name: VIDEO_TS 14:07:20 Selected Container type: MKV 14:07:20 Selected Encoder: X264 14:07:20 Selected Size: 324 / 1 14:07:20 Selected Profile: 2_Pass_Extreme_Quality.xml 14:07:20 Selected Resizer: Spline36Resize (neutral sharp) / Automatic 14:07:20 Selected Filters: derainbow(6).Deen("w3d",2,2,4).LimitedSharpenFaster(ss_x=1.5, ss_y=1.5, smode=3, strength=50, overshoot=1, undershoot=1).fastlinedarkenMOD(thinning=0) 14:07:20 Selected Deinterlacer: Partly Film 14:07:20 Selected Field Order: AUTO 14:07:20 Manual Crop: Enabled 14:07:20 Left Crop: 8 14:07:20 Top Crop: 0 14:07:20 Right Crop: 4 14:07:20 Botton Crop: 0 14:07:20 Manual Width: 708 14:07:20 Manual Height: 472 14:07:20 Track Language 1: NONE 14:07:20 Audio Codec 1: Lame 14:07:20 Audio Quality 1: 80 14:07:20 Audio Channel 1: Stereo 14:07:20 Advanced Audio Settings DUMP Track 1 14:07:20 Nero Option Profiles: AUTO --- Encoding Mode: Quality 14:07:20 CCT Option Profiles: AUTO --- Channel Options: AUTO 14:07:20 Lame Settings: ABR 14:07:20 Audio Normalization: 1 14:07:20 Frequency: AUTO --- Tempo: NONE --- Pitch: NONE --- Other Add: 14:07:20 Advanced Audio Settings DUMP Track 2 14:07:20 Nero Option Profiles: AUTO --- Encoding Mode: Quality 14:07:20 CCT Option Profiles: AUTO --- Channel Options: AUTO 14:07:20 Lame Settings: ABR 14:07:20 Audio Normalization: 1 14:07:20 Frequency: AUTO --- Tempo: NONE --- Pitch: NONE --- Other Add: 14:07:20 14:07:20 Starting Indexing 14:07:20 Dgindex CMD: E:\RIPPEN\AutoMKV084\exe\dgindex\dgindex.exe -FO=0 -OM=0 -YR=2 -AIF=[E:\RIPPEN\BB\ep1\VTS_01_1.vob] -OF=[E:\RIPPEN\temp\movie] -exit -minimize 14:08:37 Finished indexing 14:08:37 Finished fixing audio delay 14:08:37 Number of Frames: 51051 14:08:37 Framerate: 29.970030 14:08:37 Movie length in Seconds: 1704 14:08:37 Movie Width/Height: 720/480 14:08:37 DgIndex AR: 4:3 14:08:37 Starting X264 14:08:37 Command Line 1' Pass X264: E:\RIPPEN\AutoMKV084\exe\encoder\x264.exe --pass 1 --bitrate 1593 --stats "E:\RIPPEN\temp\.stats" --ref 1 --no-b-adapt --progress --keyint 250 --bframes 3 --qpmin 10 --qpmax 51 --no-psnr --filter -2,-1 --subme 1 --direct auto --vbv-maxrate 25000 --me dia --no-ssim --b-pyramid --analyse none --threads auto --thread-input --output NUL "E:\RIPPEN\temp\movie.avs" 14:08:38 Command Line 2' Pass X264: E:\RIPPEN\AutoMKV084\exe\encoder\x264.exe --pass 2 --bitrate 1593 --stats "E:\RIPPEN\temp\.stats" --progress --keyint 250 --bframes 3 --qpmin 10 --qpmax 51 --no-psnr --mixed-refs --trellis 1 --ref 5 --filter -2,-1 --direct auto --vbv-maxrate 25000 --me umh --no-ssim --weightb --b-pyramid --b-rdo --bime --analyse p8x8,b8x8,i4x4,i8x8,p4x4 --8x8dct --threads auto --thread-input --output "E:\RIPPEN\temp\movie.mp4" "E:\RIPPEN\temp\movie.avs" 14:08:41 Finished 1' Pass X264 14:08:45 "E:\RIPPEN\AutoMKV084\exe\matroska\mkvmerge.exe" -o "E:\RIPPEN\temp\VIDEO_TS.mkv" --track-name -1:"VIDEO_TS" --aspect-ratio 1:1.000000 --chapters "E:\RIPPEN\AutoMKV084\exe\chapters.txt" "E:\RIPPEN\temp\movie.mp4" --title "Done with AutoMKV 0.89 http://forum.doom9.org/showthread.php?p=854221 " 14:08:46 Final Muxed size: -1 bytes 14:08:46 Encoding finished: 00:00:05 elapsed time Nothing is different except for the resolution... what am i doing wrong here? EDIT: another little question... Is it possible to encode in 29.970 fps? When i encode that movie to h264, it is 23.976 fps, which gives me some video glitches... Is it some setting that i had wrong? Last edited by tha_reaper; 6th September 2007 at 13:40. |
6th September 2007, 16:21 | #3337 | Link |
HDConvertToX author
open the last movie.avs in virtualdub.. any errors ?
for frame rate just select NONE in denterlacer, selecting Film (hybrid) it will decimate BHH
6th September 2007, 20:33 | #3338 | Link |
Hello everyone, first, thanks you, your log is amazing !
But well, it worked fine for me untill 2-3 day ago. When the encoding is finished (after 1 or 2 pass, i tried both), there isn't any final output video file, there are just files in the TEMP folder (audio only, video only without subtitle and more), but not the muxed one in the defined folder. I don't think that i've changed any options nor updapted / installed new log. I tried to change some options, i used version 0.89 then 0.89a,i also did a Search on my computer and even tried on another computer of mine, but there isn't any final output file. Code:
09:45:34 0.89 - - - - - - - - - - - - - START JOBS - - - - - - - - - - - - - - 09:45:34 Selected Input file: E:\VOB MERGED.vob 09:45:34 Selected Output dir: C:\Documents and Settings\Never.NEVER-665B2060A\Desktop\temp\ 09:45:34 Selected Final Name: Nodame Cantabile Beta 01 09:45:34 Selected Container type: MP4 09:45:34 Selected Encoder: X264 09:45:34 Selected Size: 232 / 1 09:45:34 Selected Profile: 2_Pass_Insane_Quality.xml 09:45:34 Selected Resizer: BicubicResize (sharp=0,0.75) / 720 09:45:34 Selected Filters: RemoveGrain(mode=2) 09:45:34 Selected Deinterlacer: Film 09:45:34 Selected Field Order: AUTO 09:45:34 Enabled CRF/CQ AutoRes at 18 value 09:45:34 Track Language 1: All Audio Tracks 09:45:34 Audio Codec 1: Nero AAC 09:45:34 Audio Quality 1: 0.60 09:45:34 Audio Channel 1: Stereo 09:45:34 Load external subtitle file: -add "F:\Nodame Cantabile\Sous titres Nodame 01 avec kara.ass" "F:\Nodame Cantabile\Plaque ecole 01.ass" 09:45:34 Advanced Audio Settings DUMP Track 1 09:45:34 Nero Option Profiles: AUTO --- Encoding Mode: Quality 09:45:34 CCT Option Profiles: AUTO --- Channel Options: AUTO 09:45:34 Lame Settings: ABR 09:45:34 Audio Normalization: 1 09:45:34 Frequency: AUTO --- Tempo: NONE --- Pitch: NONE --- Other Add: 09:45:34 Advanced Audio Settings DUMP Track 2 09:45:34 Nero Option Profiles: AUTO --- Encoding Mode: Quality 09:45:34 CCT Option Profiles: AUTO --- Channel Options: AUTO 09:45:34 Lame Settings: ABR 09:45:34 Audio Normalization: 1 09:45:34 Frequency: AUTO --- Tempo: NONE --- Pitch: NONE --- Other Add: 09:45:34 Activate Anamorphic Encoding 09:45:34 09:48:51 Starting fixing all audio files 09:48:52 DelayCut CMD: C:\Documents and Settings\Never.NEVER-665B2060A\My Documents\New Folder\exe\dgindex\Delaycut.exe -auto -out "C:\Documents and Settings\Never.NEVER-665B2060A\Desktop\temp\fixed1.wav" "C:\Documents and Settings\Never.NEVER-665B2060A\Desktop\temp\movie T01 48K 16bit 2ch.wav" 09:50:44 Encoding C:\Documents and Settings\Never.NEVER-665B2060A\Desktop\temp\fixed1.wav to NeroAAC with 0.60 quality 09:52:30 ForceFilm Detected: 99.900002% FILM found 09:52:46 Number of Frames: 40766 09:52:46 Framerate: 29.970030 09:52:46 Movie length in Seconds: 1361 09:52:46 Movie Width/Height: 720/480 09:52:46 DgIndex AR: 16:9 09:52:46 Starting X264 09:52:46 Command Line 1' Pass X264: C:\Documents and Settings\Never.NEVER-665B2060A\My Documents\New Folder\exe\encoder\x264.exe --pass 1 --bitrate 1222 --stats "C:\Documents and Settings\Never.NEVER-665B2060A\Desktop\temp\.stats" --ref 1 --no-b-adapt --progress --keyint 250 --bframes 3 --qpmin 10 --qpmax 51 --no-psnr --no-fast-pskip --filter -2,-1 --subme 1 --direct auto --vbv-maxrate 25000 --me dia --no-ssim --merange 32 --b-pyramid --analyse none --threads auto --thread-input --sar 64:54 --output NUL "C:\Documents and Settings\Never.NEVER-665B2060A\Desktop\temp\movie.avs" 09:52:46 Command Line 2' Pass X264: C:\Documents and Settings\Never.NEVER-665B2060A\My Documents\New Folder\exe\encoder\x264.exe --pass 2 --bitrate 1222 --stats "C:\Documents and Settings\Never.NEVER-665B2060A\Desktop\temp\.stats" --progress --keyint 250 --bframes 3 --qpmin 10 --qpmax 51 --no-psnr --no-fast-pskip --mixed-refs --trellis 2 --ref 16 --filter -2,-1 --subme 6 --direct auto --vbv-maxrate 25000 --me umh --no-ssim --merange 32 --weightb --b-pyramid --b-rdo --bime --analyse p8x8,b8x8,i4x4,i8x8,p4x4 --8x8dct --threads auto --thread-input --sar 64:54 --output "C:\Documents and Settings\Never.NEVER-665B2060A\Desktop\temp\movie.mp4" "C:\Documents and Settings\Never.NEVER-665B2060A\Desktop\temp\movie.avs" 10:15:52 Finished 1' Pass X264 13:40:21 Only Movie Size: 208184699 bytes 13:40:21 "C:\Documents and Settings\Never.NEVER-665B2060A\My Documents\New Folder\exe\matroska\MP4Box.exe" -add "C:\Documents and Settings\Never.NEVER-665B2060A\Desktop\temp\movie.mp4":par=1.777778 -add "C:\Documents and Settings\Never.NEVER-665B2060A\Desktop\temp\audio1.mp4" -add -add "F:\Nodame Cantabile\Sous titres Nodame 01 avec kara.ass" "F:\Nodame Cantabile\Plaque ecole 01.ass" -fps 29.970030 -new "C:\Documents and Settings\Never.NEVER-665B2060A\Desktop\temp\Nodame Cantabile Beta 01_full.mp4" 13:40:22 Final Muxed size: -1 bytes 13:40:22 Encoding finished: 03:24:29 elapsed time 13:40:22 ----------------------------------------------------------------------- 13:40:22 Script AutoCrop.log 13:40:22 13:40:22 Crop(10,0,700,480) 13:40:22 ----------------------------------------------------------------------- 13:40:22 Script Resmovie.avs 13:40:22 ----------------------------------------------------------------------- 13:40:22 Script movie.avs 13:40:22 13:40:22 LoadPlugin("C:\Documents and Settings\Never.NEVER-665B2060A\My Documents\New Folder\exe\filter\AddGrain.dll") 13:40:22 LoadPlugin("C:\Documents and Settings\Never.NEVER-665B2060A\My Documents\New Folder\exe\filter\autocrop.dll") 13:40:22 LoadPlugin("C:\Documents and Settings\Never.NEVER-665B2060A\My Documents\New Folder\exe\filter\aWarpSharp(Pruned).dll") 13:40:22 LoadPlugin("C:\Documents and Settings\Never.NEVER-665B2060A\My Documents\New Folder\exe\filter\blockbuster.dll") 13:40:22 LoadPlugin("C:\Documents and Settings\Never.NEVER-665B2060A\My Documents\New Folder\exe\filter\cnr2.dll") 13:40:22 LoadPlugin("C:\Documents and Settings\Never.NEVER-665B2060A\My Documents\New Folder\exe\filter\ColorMatrix.dll") 13:40:22 LoadPlugin("C:\Documents and Settings\Never.NEVER-665B2060A\My Documents\New Folder\exe\filter\Convolution3D.dll") 13:40:22 LoadPlugin("C:\Documents and Settings\Never.NEVER-665B2060A\My Documents\New Folder\exe\filter\corrector.dll") 13:40:22 LoadPlugin("C:\Documents and Settings\Never.NEVER-665B2060A\My Documents\New Folder\exe\filter\DctFilter.dll") 13:40:22 LoadPlugin("C:\Documents and Settings\Never.NEVER-665B2060A\My Documents\New Folder\exe\filter\Decomb.dll") 13:40:22 LoadPlugin("C:\Documents and Settings\Never.NEVER-665B2060A\My Documents\New Folder\exe\filter\Deen.dll") 13:40:22 LoadPlugin("C:\Documents and Settings\Never.NEVER-665B2060A\My Documents\New Folder\exe\filter\degrainmedian.dll") 13:40:22 LoadPlugin("C:\Documents and Settings\Never.NEVER-665B2060A\My Documents\New Folder\exe\filter\DGDecode.dll") 13:40:22 LoadPlugin("C:\Documents and Settings\Never.NEVER-665B2060A\My Documents\New Folder\exe\filter\EEDI2.dll") 13:40:22 LoadPlugin("C:\Documents and Settings\Never.NEVER-665B2060A\My Documents\New Folder\exe\filter\FFMpegSource.dll") 13:40:22 LoadPlugin("C:\Documents and Settings\Never.NEVER-665B2060A\My Documents\New Folder\exe\filter\FFT3DFilter.dll") 13:40:22 LoadPlugin("C:\Documents and Settings\Never.NEVER-665B2060A\My Documents\New Folder\exe\filter\FluxSmooth.dll") 13:40:22 LoadPlugin("C:\Documents and Settings\Never.NEVER-665B2060A\My Documents\New Folder\exe\filter\frfun7.dll") 13:40:22 LoadPlugin("C:\Documents and Settings\Never.NEVER-665B2060A\My Documents\New Folder\exe\filter\hqdn3d.dll") 13:40:22 LoadPlugin("C:\Documents and Settings\Never.NEVER-665B2060A\My Documents\New Folder\exe\filter\LeakKernelDeint.dll") 13:40:22 LoadPlugin("C:\Documents and Settings\Never.NEVER-665B2060A\My Documents\New Folder\exe\filter\MaskTools.dll") 13:40:22 LoadPlugin("C:\Documents and Settings\Never.NEVER-665B2060A\My Documents\New Folder\exe\filter\medianblur.dll") 13:40:22 LoadPlugin("C:\Documents and Settings\Never.NEVER-665B2060A\My Documents\New Folder\exe\filter\MipSmooth.dll") 13:40:22 LoadPlugin("C:\Documents and Settings\Never.NEVER-665B2060A\My Documents\New Folder\exe\filter\MSharpen.dll") 13:40:22 LoadPlugin("C:\Documents and Settings\Never.NEVER-665B2060A\My Documents\New Folder\exe\filter\mt_masktools.dll") 13:40:22 LoadPlugin("C:\Documents and Settings\Never.NEVER-665B2060A\My Documents\New Folder\exe\filter\mvtools.dll") 13:40:22 LoadPlugin("C:\Documents and Settings\Never.NEVER-665B2060A\My Documents\New Folder\exe\filter\NicAudio.dll") 13:40:22 LoadPlugin("C:\Documents and Settings\Never.NEVER-665B2060A\My Documents\New Folder\exe\filter\RemoveGrainS.dll") 13:40:22 LoadPlugin("C:\Documents and Settings\Never.NEVER-665B2060A\My Documents\New Folder\exe\filter\RepairS.dll") 13:40:22 LoadPlugin("C:\Documents and Settings\Never.NEVER-665B2060A\My Documents\New Folder\exe\filter\SangNom.dll") 13:40:22 LoadPlugin("C:\Documents and Settings\Never.NEVER-665B2060A\My Documents\New Folder\exe\filter\SimpleResize.dll") 13:40:22 LoadPlugin("C:\Documents and Settings\Never.NEVER-665B2060A\My Documents\New Folder\exe\filter\SoundOut.dll") 13:40:22 LoadPlugin("C:\Documents and Settings\Never.NEVER-665B2060A\My Documents\New Folder\exe\filter\TBilateral.dll") 13:40:22 LoadPlugin("C:\Documents and Settings\Never.NEVER-665B2060A\My Documents\New Folder\exe\filter\TDeint.dll") 13:40:22 LoadPlugin("C:\Documents and Settings\Never.NEVER-665B2060A\My Documents\New Folder\exe\filter\TIVTC.dll") 13:40:22 LoadPlugin("C:\Documents and Settings\Never.NEVER-665B2060A\My Documents\New Folder\exe\filter\TomsMoComp.dll") 13:40:22 LoadPlugin("C:\Documents and Settings\Never.NEVER-665B2060A\My Documents\New Folder\exe\filter\TTempSmooth.dll") 13:40:22 LoadPlugin("C:\Documents and Settings\Never.NEVER-665B2060A\My Documents\New Folder\exe\filter\UnDot.dll") 13:40:22 LoadPlugin("C:\Documents and Settings\Never.NEVER-665B2060A\My Documents\New Folder\exe\filter\UnFilter.dll") 13:40:22 LoadPlugin("C:\Documents and Settings\Never.NEVER-665B2060A\My Documents\New Folder\exe\filter\VSFilter.dll") 13:40:22 LoadPlugin("C:\Documents and Settings\Never.NEVER-665B2060A\My Documents\New Folder\exe\filter\warpsharp.dll") 13:40:22 #loadpluginstart 13:40:22 13:40:22 #test1 13:40:22 13:40:22 Import("C:\Documents and Settings\Never.NEVER-665B2060A\My Documents\New Folder\exe\filter\BlindDeHalo3_mt2.avsi") 13:40:22 Import("C:\Documents and Settings\Never.NEVER-665B2060A\My Documents\New Folder\exe\filter\FastLineDarken 1.3 MT MOD.avsi") 13:40:22 Import("C:\Documents and Settings\Never.NEVER-665B2060A\My Documents\New Folder\exe\filter\HybridFuPP.avsi") 13:40:22 Import("C:\Documents and Settings\Never.NEVER-665B2060A\My Documents\New Folder\exe\filter\LanczosPlus.avsi") 13:40:22 Import("C:\Documents and Settings\Never.NEVER-665B2060A\My Documents\New Folder\exe\filter\Lem.avsi") 13:40:22 Import("C:\Documents and Settings\Never.NEVER-665B2060A\My Documents\New Folder\exe\filter\LimitedSharpenFaster.avsi") 13:40:22 Import("C:\Documents and Settings\Never.NEVER-665B2060A\My Documents\New Folder\exe\filter\MCBob_v03c.avsi") 13:40:22 Import("C:\Documents and Settings\Never.NEVER-665B2060A\My Documents\New Folder\exe\filter\mvbob.avsi") 13:40:22 Import("C:\Documents and Settings\Never.NEVER-665B2060A\My Documents\New Folder\exe\filter\QMlib.avsi") 13:40:22 Import("C:\Documents and Settings\Never.NEVER-665B2060A\My Documents\New Folder\exe\filter\seesaw.avsi") 13:40:22 Import("C:\Documents and Settings\Never.NEVER-665B2060A\My Documents\New Folder\exe\filter\spresso.avsi") 13:40:22 #importstart 13:40:22 13:40:22 #test2 13:40:22 13:40:22 movie = mpeg2source("C:\Documents and Settings\Never.NEVER-665B2060A\Desktop\temp\movie.d2v") 13:40:22 function getOrder(clip c) { 13:40:22 order = GetParity(c) ? 1 : 0 13:40:22 Return order } 13:40:22 #filter1start 13:40:22 13:40:22 #test3 13:40:22 13:40:22 movie = tfm(movie,d2v="C:\Documents and Settings\Never.NEVER-665B2060A\Desktop\temp\movie.d2v").tdecimate() 13:40:22 #cropstart 13:40:22 13:40:22 cropclip = autocrop(movie,mode=0,wmultof=4,hmultof=4,samples=40,aspect=0,threshold=34,samplestartframe=0) 13:40:22 fixed_aspect = 1 13:40:22 c_width = width(cropclip) 13:40:22 c_height = Round(height(cropclip) / fixed_aspect) 13:40:22 input_par = float(float(c_width)/float(c_height)) 13:40:22 input_par = input_par > 1.4 ? input_par : (4.0/3.0) 13:40:22 out_width = 720 13:40:22 out_height = Round(float(out_width) / input_par) 13:40:22 hmod = out_height - (floor(out_height / 16 ) * 16) 13:40:22 out_height = (hmod > 4) ? (out_height + (16 - hmod)) : (out_height - hmod) 13:40:22 new_aspect = (float(out_width) / float(out_height)) / fixed_aspect 13:40:22 autocrop(movie,mode=0,wmultof=4,hmultof=4,samples=40,aspect=new_aspect,threshold=34,samplestartframe=0) 13:40:22 13:40:22 #resizestart 13:40:22 13:40:22 #test4 13:40:22 13:40:22 BicubicResize(out_width,out_height,0,0.75) 13:40:22 #filter2start 13:40:22 13:40:22 #test5 13:40:22 13:40:22 RemoveGrain(mode=2) 13:40:22 TextSub("F:\Nodame Cantabile\Plaque ecole 01.ass") 13:40:22 ----------------------------------------------------------------------- 13:40:22 Script mkvmaudio.avs 13:40:22 13:40:22 LoadPlugin("C:\Documents and Settings\Never.NEVER-665B2060A\My Documents\New Folder\exe\filter\NicAudio.dll") 13:40:22 LoadPlugin("C:\Documents and Settings\Never.NEVER-665B2060A\My Documents\New Folder\exe\filter\SoundOut.dll") 13:40:22 WavSource("C:\Documents and Settings\Never.NEVER-665B2060A\Desktop\temp\fixed1.wav") 13:40:22 function addvideo(clip c) { 13:40:22 blankclip(length = Int(100 * AudioLengthF(c) / float(audiorate(c))), fps=100) 13:40:22 Return audiodub(last,c) 13:40:22 } 13:40:22 Normalize() 13:40:22 ConvertAudioTo16bit() 13:40:22 #Applying STEREO downmixing routines 13:40:22 function stereo(clip a) 13:40:22 { 13:40:22 flr = GetChannel(a, 1, 2) 13:40:22 fcc = GetChannel(a, 3) 13:40:22 lfe = GetChannel(a, 4) 13:40:22 lfc = MixAudio(fcc, lfe, 0.2071, 0.2071) 13:40:22 mix = MergeChannels(lfc, lfc) 13:40:22 lrc = MixAudio(flr, mix, 0.2929, 1.0) 13:40:22 blr = GetChannel(a, 5, 6) 13:40:22 Return MixAudio(lrc, blr, 1.0, 0.2929) 13:40:22 } 13:40:22 # 13:40:22 6==Audiochannels() ? stereo() : last 13:40:22 Soundout(output="cmd",type=1,autoclose=true,executable="C:\Documents and Settings\Never.NEVER-665B2060A\My Documents\New Folder\exe\besweet\neroaacenc.exe",prefilename=" -ignorelength -q 0.60 -if - -of audio1.mp4",postfilename="",nofilename=true,showoutput=false) 13:40:22 ----------------------------------------------------------------------- 13:40:22 Script mkvmaudio.bat 13:40:22 13:40:22 "C:\Documents and Settings\Never.NEVER-665B2060A\My Documents\New Folder\exe\matroska\\VirtualDubMod\VirtualDubMod.exe" "C:\Documents and Settings\Never.NEVER-665B2060A\Desktop\temp\mkvmaudio.avs" /x 13:40:22 ----------------------------------------------------------------------- 13:40:22 Script mkvmaudio2.avs 13:40:22 ----------------------------------------------------------------------- 13:40:22 Script mkvmaudio2.bat 13:40:22 13:40:22 - - - - - - - - - - - - FINISHED JOBS - - - - - - - - - - - - - - - - - |
6th September 2007, 21:26 | #3339 | Link |
HDConvertToX author
@Never
First of all Welcome to the Forum! i think the problem is sub try launching from dos the muxing.bat what is the error ? (i am not sure that ssa subs are allowed in mp4, or at least using this version of mp4box) BHH
6th September 2007, 21:41 | #3340 | Link |
Hi, i tried to launch muxing.bat from dos, the error is "The system cannot find the path specified"
Here a pic well i think that ass work because i already did it (1-2 week ago) EDIT: trying to encode without ASS) EDIT2: well, no final video output too XD Last edited by Never; 6th September 2007 at 22:29. |
