27th July 2013, 20:03 | #164 | Link | |
However, the MPC-HC devs are working on making XySubFilter work with the internal renderers, as well.
28th July 2013, 03:22 | #165 | Link | |
Thanks for the reply. |
1st August 2013, 01:28 | #167 | Link |
To developers - filter can't render some subtitle from DVD(VOBSUB). If need - i can upload example of this files.
AMD Ryzen 5 3600 /GIGABYTE B450 Gaming X /Patriot 32Gb@3200 /Kingston 500Gb M.2 /RTX 4060 /Samsung U28R550UQI /OLED Philips 55OLED707 /Yamaha RX-V471 + NS-555 + NS-C444 + NS-333 + YST-SW215 |
1st August 2013, 06:49 | #168 | Link | |
Broadband Junkie
None the less, if it is broken in all versions of VSFilter, please provide a sample. |
1st August 2013, 09:53 | #169 | Link |
Yes - it' samples work in MPC-BE. But fail in MPC-HC/XySubFilter/xy-VSFilter.
1st August 2013, 11:27 | #171 | Link |
Broadband Junkie
XySubFilter contains all the VOBSUB fixes from JEEB's branch, so it's most likely the same behavior.
I took a quick look, and it seems like we are missing this commit from MPC-BE r1459. Would need a sample to confirm this fixes Aleksoid's issue though. Last edited by cyberbeing; 1st August 2013 at 11:30. |
1st August 2013, 13:07 | #172 | Link | |
1st August 2013, 18:45 | #174 | Link |
Broadband Junkie
It shouldn't be too hard to follow our GIT development enough to get a general idea of what we've been working on, but the concept of "nightly builds" is not really compatible with our development style. Not a major problem from our point of view, since we don't accept bug reports or offer support on anything but official releases anyway. |
2nd August 2013, 01:13 | #175 | Link |
Here is a sample - http://aleksoid.voserver.net/Sample/Subtitle/DVD/
Another sample - http://aleksoid.voserver.net/Sample/Subtitle/VOBSUB/, also do not show subtitle, maybe the same bug.
AMD Ryzen 5 3600 /GIGABYTE B450 Gaming X /Patriot 32Gb@3200 /Kingston 500Gb M.2 /RTX 4060 /Samsung U28R550UQI /OLED Philips 55OLED707 /Yamaha RX-V471 + NS-555 + NS-C444 + NS-333 + YST-SW215 Last edited by Aleksoid1978; 2nd August 2013 at 01:21. |
2nd August 2013, 02:52 | #177 | Link | |
Broadband Junkie
3rd August 2013, 23:06 | #178 | Link |
"auto-reload sub after detecting modification" option seems broken.
editing subtitle file cause no change at screen (both options checked), but CPU load increasing significantly (about 50-60% per core from 6-12%) and keep that level. tested with MPC-BE r3149/madVR 0.86.10/LAV 0.58.2/.ass subs |
4th August 2013, 01:51 | #179 | Link | |
Broadband Junkie
11th August 2013, 00:10 | #180 | Link |
I'm having a small problem with XySubFilter. When viewed on my 119" white screen I can see some faint horizontal artifacting between letters (two very thin barely visible horizontal lines between the upper and lower parts of the letters). It seems like it's some problem with the transparency of the background. I think I had the same problem on the MPC internal filter and that's actually a reason for the switch.
I'm using MPC-HC and LAV filters with madVR (all latest versions). My GPU is the iGPU on A10-5700. I'm not using DXVA. Any solutions to the issue? Last edited by Gagorian; 11th August 2013 at 00:14. |
