9th January 2020, 21:20 | #1062 | Link |
How do the VS and XY differ, and how do they compare to MPC-HC internal?
In my simple tests the VS seems unstable for some reason and can crash, but it seems to work when XY messes up, in one case XY shows the wrong subtitle when you jump in the video, it will show the previous (i think) for one subtitle, then when the next one comes it's in sync again. MPC-HC has issue when jumping where it sometimes doesn't show any subtitles for awhile (i think it's in combination with madvr). |
10th January 2020, 21:20 | #1063 | Link |
xy VSfilter renders the subs on the video so the quality can only be as good as the resolution of the video and they are usually sub sampled.
XY subfilter uses a custom API created by madshi these subtitles can be moved independent from the video be rendered at any resolution or color correct you name it. the ISR in mpc-hc is vs filter based it is rendered on an extra surface just like xy subfilter but missed much of the features if you are using a 3D LUT for color correction it is not applied to the subtitles. it pretty similar to xy VSfilter still slower but not much. |
15th January 2020, 15:01 | #1064 | Link |
The following link contains updated and mostly stable versions of XyVSFilter and XySubFilter in both 32 and 64bit iterations.
Filters updated on Apr 22th. 2021 Last edited by Shark007; 23rd April 2021 at 00:12. Reason: update |
17th January 2020, 05:58 | #1065 | Link | |
I haven't touched any settings that i know of either when it comes to the subfilters. |
21st January 2020, 12:38 | #1068 | Link |
No, I cannot share anything official. I just downloaded them from a publicly available distribution.
I can tell you that the author is a regular reader here and is aware that I posted these filters. If he wants to share the patches that were applied, thats up to him. |
23rd January 2020, 04:39 | #1069 | Link | |
3rd July 2020, 16:28 | #1073 | Link |
Please Help - Performance XySubFilter.
I have dropped frames with 4K@60Hz and XySubFilter enabled (20-30 Frames/sec dropped) with ISR(integrated subtitle renderer) i have no dropped frames (mpc-hc and mpc-be). with XySubFilter the video is playing without droped frames until the first subtitle appears, and after that i have droped frames. |
12th July 2020, 19:57 | #1074 | Link | |
I've built it based on the code found here: https://github.com/jesec/xy-VSFilter/tree/cr-libass The initial spike on rendering subs the first time, as well as subsequent ones are much lower than with the GDI based fonts rendering. I've only uploaded the 64 bit binaries. Let me know if you need the 32 bit ones. Last edited by KoD; 12th July 2020 at 20:00. |
15th July 2020, 12:39 | #1075 | Link |
@KoD
i had to install - Microsoft Visual C++ Redistributable 2015-2019 https://support.microsoft.com/en-gb/...al-c-downloads But Your Filter has the same Problem. the problem are not subsequent subs. after first sub is displayed madvdr is dropping frames - doesn't matter if there are frames or not. procedure: Fim starts without dropped frames. 15 seconds later first sub is displayed, now frames get dropped (i could live with that). Now frames are dropped permanent, even when there are no subs to display. even when i seek back to start pos i have dropped frames. i think, MadVR is rendering subs even when nothing is to display (Mixing empty Image). I can send you a sample file(80MB) with WeTransfer if you want (mail adress with private message). thanks, onur |
15th July 2020, 22:43 | #1076 | Link |
as soon as madVR displays a sub it needs more time to renderer frames. that's why it like to drop frames the first time a sub is show to me this si a bug because it know this for a long time that it has to render the subs soon.
and even if subs are not renderd the shader that take the processing power are still run you can easily see this in the advanced render stats. but i you didn't check the rendertimes there is no way to proof if this is the same problem. |
16th July 2020, 11:55 | #1077 | Link |
@huhn
integrated sub filter in mpc-be, mpc-hc have no problems. when sub has to be rendered it gets rendered, without sub there is no perfomance waste. XySubFilter or MadVR has a performance waste in that situation - which should be easy to fix. Stop Rendereing subs when no sub is shown. |
16th July 2020, 20:31 | #1079 | Link |
@clsid, by the way, thanks for keeping mpc-hc alive.
Unfortunately my player has no internal sub renderer. i only test with mpc-hc/mph-be. and i think i am in the right forum to post problems with XySubFilter. Is there nobody who can say, yes thats true, XySubFilter or MadVR is wasting performance when there is no subtitle to display. I am glad that people post answers, but most of them are pointless. if there is somebody to test, i can send(wetransfer to email) sample file (80MB 4K 59Hz HDR file). thanks, onur |
