7th July 2011, 22:47 | #761 | Link |
Overdrive: As Revgen has said, there are other scripts used for undoing such conversions (together with deinterlacing). I really don't want QTGMC to become some kind of general purpose conversion script, sorry.
____ bob6779: Very complex settings. Probably too complex. There are some interactions there that you likely don't want. For example sharpness limiting (especially temporal) will tend to remove the rather subtle results of source match. SourceMatch=3 is probably overkill. The GrainRestore value looks very high (for NoiseProcess=2) and is probably strengthening grain, although the TR2=3 setting is counteracting that to some degree. Have you tried the more straightforward EZKeepGrain setting together with NoisePreset instead of all those noise settings? That together with source match and sharpness tweaking usually gets most detail. ____ Mini-Me: Your script worked for me on a random video. It might be the hpad/vpad issue. QTGMC sets hpad/vpad in the super clip to work around a bug in MVTools 2.5.11.1 and earlier. The values set depend on resolution and may not be 8, the default. Same values must be used in your subsequent MSuper call. This requirement will be lifted in the next version. You can calculate and use the same values (see QTGMC script at line noted below), or since you are using the latest MVTools you could edit QTGMC itself (don't want to release a new version just for this): - Around line 340, find 4 lines dealing with hpad/vpad - Delete them and replace with: Code:
hpad=8 vpad=8 Last edited by -Vit-; 7th July 2011 at 23:08. |
7th July 2011, 23:57 | #762 | Link | |
8th July 2011, 10:37 | #763 | Link | ||
Thanks for the tip . Quote:
8th July 2011, 10:57 | #764 | Link |
Constantly learning
Having some difficulty with the speed of QTGMC. I've used QTGMC for awhile now but recently something happened with megui/avisynth or something that affected the two. Anyways, I had to reinstall avisynth and megui and start all over from scratch. This wouldn't be a problem except that QTGMC isn't as fast as it was prior to my problems. I used to get very close to real time (a frame or two less) on the first pass and just slightly over half the fps using QTGMC (an i7 920 helps haha). ALL of my settings are exactly the same now that I've had to reinstall avisynth/megui but I'm getting NOWHERE close to what I was getting. I had to change my current settings to FASTER to get just 15 fps now. So, I'm wondering, am I using an MT version that isn't the same as my last? Is there something else it could be? My directories haven't changed, hardware hasn't changed. I can't think of anything else that's changed and could be making such a significant difference in speed other than my avisynth/wrong plugin versions used for QTGMC . Any help is appreciated
Win7 Megui 2028 QTGMC script 3.32 Downloaded and used the modified plugins package via the qtgmc thread Fully interlaced material kept original fr rate EXACT same settings (both qtgmc AND x264). I know because I've used them so much and made my own personal changes to the settings. QTGMC settings are basically default settings. Avisynth 258 MT My CPU usage seems to fluctuate a bit more using this setup. It used to stay pretty much at 99%. It's odd now though. If I use "FASTER" I get full CPU usage as I used to but if I use "MEDIUM" it hovers around 90. Don't know if that's useful but it seems to me it could be. edit: would reverting to 3.25 possibly be one/a solution? Also, looking at my program files I do somewhat remember having both 2.5 and 2.6 avs installed. Last edited by rtjnyoface; 8th July 2011 at 11:10. |
8th July 2011, 11:22 | #765 | Link | |
Just check the file properties of your avisynth.dll in the system32 directory (or wherever it's located on Win7). Edit: Even better - Create a small script with just this line: Code:
Version() Last edited by Groucho2004; 8th July 2011 at 11:25. |
8th July 2011, 11:24 | #766 | Link |
Constantly learning
Alright. I followed the instructions in the modified plugins zip.
Changes: - I started out getting 16 fps with full cpu usage and then for some reason it gradually went down...and down....and down to now less than 4 and still dropping (is it going to get to 0?). CPU usage at ~15% with a max of 3 threads being used. What in the world is going on here? Attached is a picture of megui's status window, my cpu usage, and a picture of my trash can to show which files were deleted after following the instructions in the zip file. I just replaced what was there (even if it was the same file) Whew....hope we can clear this up. Last edited by rtjnyoface; 8th July 2011 at 11:33. |
8th July 2011, 11:26 | #767 | Link | |
Constantly learning
I've already listed the dll version. 2585
Ran the script. 2.58 tsp MT version 5 (mod seraphy) Quote:
Uploaded with ImageShack.us Last edited by rtjnyoface; 8th July 2011 at 11:31. Reason: pic |
8th July 2011, 11:33 | #769 | Link | |
Anyway, it would help if you posted your script and the encoder settings. |
8th July 2011, 11:36 | #770 | Link | ||
Constantly learning
8th July 2011, 11:43 | #771 | Link |
The script looks OK but are you sure that you are using the correct DLLs for QTGMC?
I see in your screen shot a plugin directory called "2.6x Plugins" which is most likely a leftover from your 2.6 installation. Also, Avisynth 2.5x needs a different version of masktools than 2.6x. Just make sure that the correct plugins are located in the correct plugin directory. Edit - It looks like you have about 4 different locations with plugins. Very messy. Last edited by Groucho2004; 8th July 2011 at 11:46. |
8th July 2011, 11:48 | #772 | Link | ||||
Constantly learning
4 Different locations? How do you figure that? The picture was from my trash can. All the plugins and such are in the avs folder and the system 32 folder (32b here). If I've got it wrong please let me know. Be the first thing to correct... Last edited by rtjnyoface; 8th July 2011 at 11:53. |
8th July 2011, 11:59 | #773 | Link |
Which one?
OK, at least three: Code:
C:\Program Files\Megui\tools\dgindex C:\Program Files\Megui\tools\avisynth_plugin <your actual Avisynth plugin folder as referenced in the registry> -> [HKEY_LOCAL_MACHINE\SOFTWARE\AviSynth] |
8th July 2011, 12:03 | #774 | Link | ||
Constantly learning
edit: man, that megui avs directory was a horrible overlook on my part. Geez... Last edited by rtjnyoface; 8th July 2011 at 12:08. |
8th July 2011, 12:15 | #775 | Link | |
I meant which plugin directory.
I was just pointing out that source filters and plugins are loaded from various locations in your script which can be error-prone. You either load plugins by specifying the path or you use the autoload function. In your case it seems a bit blurry as to what is loaded from where. |
8th July 2011, 14:42 | #776 | Link |
Pig on the wing
Is MeGUI one of those applications in which you have to add Distributor() as the last line in the script to get MT working?
8th July 2011, 16:08 | #778 | Link |
Pig on the wing
I'm not so sure about that, it's more about the way MeGUI and Avisynth discuss with each other. If MeGUI uses the VfW interface, then Distributor() is not needed because it is automatically called. If it talks to Avisynth directly, the call is needed.
8th July 2011, 16:35 | #779 | Link | |
if( !strcasecmp( filename_ext, "avs" ) ) { res = h->func.avs_invoke( h->env, "Import", arg, NULL ); FAIL_IF_ERROR( avs_is_error( res ), "%s\n", avs_as_string( res ) ) /* check if the user is using a multi-threaded script and apply distributor if necessary. adapted from avisynth's vfw interface */ AVS_Value mt_test = h->func.avs_invoke( h->env, "GetMTMode", avs_new_value_bool( 0 ), NULL ); int mt_mode = avs_is_int( mt_test ) ? avs_as_int( mt_test ) : 0; h->func.avs_release_value( mt_test ); if( mt_mode > 0 && mt_mode < 5 ) { AVS_Value temp = h->func.avs_invoke( h->env, "Distributor", res, NULL ); h->func.avs_release_value( res ); res = temp; } } |
