Old 1st February 2008, 22:49   #21  |  Link
Gussy
It seems I'd better stick with MPEG2.
Gussy is offline   Reply With Quote
Old 3rd February 2008, 14:03   #22  |  Link
ron spencer
DVD Magistrate
mpeg2? why? that is very compressed as well...again if you are archiving for the purposes that the video MEANS something to you, use DV....it is the only one that gives you ability to edit in future, or upsample to HD....mpeg2 is not the way to go either.
ron spencer is offline   Reply With Quote
Old 4th February 2008, 00:48   #23  |  Link
Sagekilla
x264aholic
DV is nothing but a intraframe only MPEG-2. It's not MPEG-2 exactly, but it's similar to just using I-Frames in MPEG-2. With that said, I'd recommend using regular MPEG-2. Bit for bit, the addition of having predicted frames should give MUCH better quality at the same bitrate. Besides, any modern CPU can very easily decode MPEG-2 -very- quickly.
Sagekilla is offline   Reply With Quote
Old 4th February 2008, 04:21   #24  |  Link
Ranguvar
Ranguvar's Avatar
So I think the verdict is... if you want simple, use high bitrate MPEG-2 (I'd do 8MB/s, but you decide).
If you want to save some space and aren't afraid of complex options, slower decoding (for now)... then x264 High@4.1.
Ranguvar is offline   Reply With Quote
Old 4th February 2008, 13:40   #25  |  Link
ron spencer
DVD Magistrate
nonsense.....just try to reencode mpeg2...see the mess you get...mpeg 2 is not archival....but hey, its your memories
Old 4th February 2008, 17:22   #26  |  Link
weaver4
I think the two good choices are:
1) DivX 6.x - Home Theater Profile
2) H264 - HP@L4.1
Both of these should be around 10 years from now.
But, archive the codec too; just in case.
weaver4 is offline   Reply With Quote
Old 5th February 2008, 00:10   #27  |  Link
Ranguvar
Ranguvar's Avatar
Aha! Found something
http://forum.doom9.org/showthread.php?t=126304
Old 2nd March 2008, 07:45   #28  |  Link
emrah61
Vhq1
Precision 6
Trellis On
Qpel On
2 31 2 31 2 31 2 31
Sixofnine (not Hvs!)
Two Pass Between 2800->4000 Kpbs
And Always Use Original Audio Stream (mp2)
And It Seems %100 Lossless.. The Eye Cant See Any Of Difference.. Belive Me!.. It's %50 Of Original File..
emrah61 is offline   Reply With Quote
Old 2nd March 2008, 10:00   #29  |  Link
burfadel
I wouldn't go avi container either, there's no guarantee's it will be around in 10 years time. You could remux the video if required, but that just takes extra effort!
