Old 27th March 2012, 23:23   #12901  |  Link
DragonQ
Well then you're using software decoding with MadVR. If you really want to use DXVA2 with MadVR, use DXVA2 Copy-Back mode.
HTPC Hardware: Intel Celeron G530; nVidia GT 430
HTPC Software: Windows 7; MediaPortal 1.19.0; Kodi DSPlayer 17.6; LAV Filters (DXVA2); MadVR
TV Setup: LG OLED55B7V; Onkyo TX-NR515; Minix U9-H
Old 28th March 2012, 14:57   #12902  |  Link
deado
Well I found a temporary solution to getting fullscreen exclusive working in Windows 8 - just kill Windows Explorer first before you play a file, then fullscreen excl. works =)
EDIT: Actually a slightly more convenient way is to just 'Restart' explorer (not kill it) - this also seems to work. I don't know exactly why just doing this fixes everything, but it does.
deado is offline   Reply With Quote
Old 28th March 2012, 16:55   #12903  |  Link
Kado
Otaku
Kado's Avatar
Just a quick question...
Is there a difference in using madvr built in h.264 decoder or using lav decoder or ffdshow performance wise and IQ?
Cheers!
In the school, the three guys met. Their relation had been changed in the season, and turned into three love stories.
Kado is offline   Reply With Quote
Old 29th March 2012, 00:01   #12904  |  Link
magnusr
A noob question.
I am using mpchc x86 + hali media splitter + lav video x86 + madvr. Should I set LAV video configuration to use hardware decoder NVIDIA CUVID? It's set to NONE at the moment. Everything works fine.
I selected LAV video x86 and lav audio x86 during lav installation (I didn not select the LAV splitter).
Using GTX 680 under Windows 7 x64 SP1.
magnusr is offline   Reply With Quote
Old 29th March 2012, 00:22   #12905  |  Link
nx6
Playing with MKV files...
nx6's Avatar
Why fix what isn't broken?
Intel Core i7 920, 6 GB RAM | GeForce GTX670 | Win8.1 | LAV 0.64 / MadVR 0.87.10 | Zoom Player v10 / MPC-HC 1.7.8
nx6 is offline   Reply With Quote
Old 29th March 2012, 00:32   #12906  |  Link
Owyn
Cheers!
It has one? O_o
Cuz I use ffdshow (along with madVR) so it could play 10bit video
Owyn is offline   Reply With Quote
Old 29th March 2012, 00:59   #12907  |  Link
Kado
Otaku
Kado's Avatar
Well... Maybe some multi threading optimizations or new libavcodec versions as lav filter and ffdshow are updated more regularly... They all play 10bit though...
Sent from my Defy using Tapatalk 2
Old 29th March 2012, 08:28   #12908  |  Link
magnusr
It's just that i recently swapped from ati to nvidia. Maybe I should take use of hardware acceleration?
Anyway tried it and seems to work fine with both none and nvidia cuvid.
Old 29th March 2012, 11:37   #12909  |  Link
chros
chros's Avatar
My GTX 680 findings with NVIDIA WHQL driver 301.10. Windows 7 X64 SP1. Connected to 63" Samsung Plasma using hdmi.
Had to do the inf fix for 0-255 rgb before install.
How can I tell if I need this fix? (I'm using a laptop with nvidia 9600m GT + hdmi)
Thanks
Ryzen 5 2600,Asus Prime b450-Plus,16GB,MSI GTX 1060 Gaming X 6GB(v385.28),Win10 LTSB 1607,MPC-BEx64+LAV+MadVR,Yamaha RX-A870,LG OLED65B8(2160p@23/24/25/29/30/50/59/60Hz)
Old 29th March 2012, 12:12   #12910  |  Link
DragonQ
DXVA2 Native is the best if it works because it uses the least resources and power. DXVA2 Copy-Back and CUVID are the next best options for hardware acceleration, especially if you want to use MadVR (which doesn't work with LAV DXVA2 Native).
Old 29th March 2012, 14:05   #12911  |  Link
magnusr
Thanks
Black will look grey. washed out...
Old 29th March 2012, 17:20   #12912  |  Link
n3w813
If madVR can't be used with LAV DXVA2 native, then what is the next best renderer to use?
n3w813 is offline   Reply With Quote
Old 29th March 2012, 18:24   #12913  |  Link
DragonQ
EVR I presume.
I use MadVR on my desktop with DXVA2 Copy-Back but my laptop isn't powerful enough to play some 1080i/25 streams without using DXVA2 Native, so I use EVR instead. I also use EVR on my HTPC but that's purely because MediaPortal doesn't support MadVR, unfortunately.
Old 29th March 2012, 22:48   #12914  |  Link
chros
chros's Avatar
Well, the problem is that it's all relative. How can I be sure of that?
Old 29th March 2012, 22:51   #12915  |  Link
mark0077
If you can get a pure black image, and make it fullscreen, you can either just try to remember how dark it was compared to the side of you're TV / rim before and after, or perhaps take a photograph before or after trying to keep the camera in the exact same position. For me its quite obvious as when it works, the black is as jet black as the rim of the TV, when its not OK, its worlds away from being anywhere near the same as the TVs rim.
A solution I found, instead of having to edit the inf file (which means for example the driver won't install then in Windows 8 as it has been modified), I install the NVidia drivers normally and open regedit and simply search (Ctrl-F) for an nvidia related drivers area entry like perhaps
UserModeDriverGUID
Everywhere you find it (F3 to find next occurance), add the DWORD entry below next to it.
SetDefaultFullRGBRangeOnHDMI
setting its value to 1.
Then just reboot, or perhaps change resolution once or twice, and the color difference will noticibly kick in. I'm sure someone could make a nice little .bat script to do this also Might be a nicer solution than editing inf files all of the time.
mark0077 is offline   Reply With Quote
Old 30th March 2012, 02:36   #12916  |  Link
futurex
Pardon me if this has been asked before, but is there any difference, all other things being equal, between madvr and evr custom pres when playing 1080p on a 1080p display? I take it madvr has better scaling etc but is any scaling actually done in this case? What about a resolution such as 1920x800? Does that need to be scaled?
Thanks!
futurex is offline   Reply With Quote
Old 30th March 2012, 04:36   #12917  |  Link
dansrfe
Thanks!
The short answer is yes, scaling is done even if the width and/or height match the screen size and madVR does a better job of that than any other renderer does on the basis of objective and subjective tests and data. The long answer exists on the first page and within previous pages of this thread.
Old 30th March 2012, 06:09   #12918  |  Link
Zachs
Suptitle, MediaPlayer.NET
Thanks!
It's hard to notice given a 1080p on 1080p display, but if you playback any free to air stuff at lower res which is then scaled up, EVR-CP is absolutely horrendous. MadVR is the only renderer capable of giving me exactly how my sammy TV would scale the video. My wife used to complain recorded TV shows look inferior (and thought it was all normal coming from VHS days) until I changed it to MadVR.
Although one thing I'd like to point out is that the scaling algo of my sammy TV tends to lean towards the softer ones with little ringing. Those algos provide the best match.
Zachs is offline   Reply With Quote
Old 30th March 2012, 12:15   #12919  |  Link
Negi
MadVR won't work if the monitor is in vertical orientation
I often watch videos when my monitor is in a vertical orientation (1200x1600) out of laziness, but I noticed that under these circumstances together with the LAV filters, madVR dies horribly. It does not display any video, and then the audio stream dies within two minutes. Then, depending on the video, mpc-hc crashes. This is completely fixed by changing the orientation back. I am not sure if this happens with ffdshow, but it definitely happens with the LAV filters.
Negi is offline   Reply With Quote
Old 30th March 2012, 14:22   #12920  |  Link
Hypernova
Thanks!
Actually, I believe the most important feature of madVR is not scaling, but the fact that it avoids (almost) all the messing up your video card driver can made. Another one is madVR use the best possible conversion/dithering if you need one. Personally, the reason I first use madVR, despite the fact that my GPU at the time cannot quite handle it, is the better dithering. It clearly show less color-banding for me.
Spec: Intel Core i5-3570K, 8g ram, Intel HD4000, Samsung U28D590 4k monitor+1080p Projector, Windows 10.
Hypernova is offline   Reply With Quote
