Old 25th September 2020, 13:55   #30001  |  Link
LowDead
Elit Amans
@Ch3vr0n: WOW Congrats for that!
Anyway here's an update on that file from "The Natural" that gives TSmuxer4k a mild to, at times, severe headaches..
General
Complete name                            : B:\WORK\NATURAL__THE
Format                                   : Blu-ray Clip info / Blu-ray Clip info
File size                                : 1.14 KiB
Duration                                 : 2 min 8 s
Overall bit rate mode                    : Variable
Overall bit rate                         : 22.5 Mb/s
Maximum Overall bit rate                 : 35.5 Mb/s
OverallBitRate_Precision_Min             : 22462713
OverallBitRate_Precision_Max             : 22462888
Video
Menu ID                                  : 1 (0x1)
Format                                   : HEVC
Format/Info                              : High Efficiency Video Coding
Format profile                           : Main 10@L5.1@High
HDR format                               : SMPTE ST 2086, HDR10 compatible
Codec ID                                 : 36
Bit rate                                 : 21.4 Mb/s
Width                                    : 3 840 pixels
Height                                   : 2 160 pixels
Display aspect ratio                     : 16:9
Frame rate                               : 59.940 (60000/1001) FPS
Chroma subsampling                       : 4:2:0 (Type 2)
Bit depth                                : 10 bits
Bits/(Pixel*Frame)                       : 0.043
Stream size                              : 328 MiB
Color range                              : Limited
Color primaries                          : BT.2020
Transfer characteristics                 : PQ
Matrix coefficients                      : BT.2020 non-constant
Mastering display color primaries        : Display P3
Mastering display luminance              : min: 0.0050 cd/m2, max: 4000 cd/m2
Source                                   : 00337.m2ts / 00337.m2ts
Audio
Menu ID                                  : 1 (0x1)
Format                                   : AC-3
Format/Info                              : Audio Coding 3
Commercial name                          : Dolby Digital
Codec ID                                 : 129
Bit rate mode                            : Constant
Bit rate                                 : 192 kb/s
Channel(s)                               : 2 channels
Channel layout                           : L R
Sampling rate                            : 48.0 kHz
Frame rate                               : 31.250 FPS (1536 SPF)
Stream size                              : 2.95 MiB
Language                                 : English
Service kind                             : Complete Main
bsid                                     : 8
Dialog Normalization                     : -31
Dialog Normalization                     : -31 dB
compr                                    : -0.28
compr                                    : -0.28 dB
dsurmod                                  : 1
dsurmod                                  : Not Dolby Surround encoded
acmod                                    : 2
lfeon                                    : 0
dialnorm_Average                         : -31
dialnorm_Average                         : -31 dB
dialnorm_Minimum                         : -31
dialnorm_Minimum                         : -31 dB
dialnorm_Maximum                         : -31
dialnorm_Maximum                         : -31 dB
dialnorm_Count                           : 1153
compr_Average                            : 0.67
compr_Average                            : 0.67 dB
compr_Minimum                            : -4.08
compr_Minimum                            : -4.08 dB
compr_Maximum                            : 5.74
compr_Maximum                            : 5.74 dB
compr_Count                              : 1072
dynrng_Average                           : 0.66
dynrng_Average                           : 0.66 dB
dynrng_Minimum                           : -4.08
dynrng_Minimum                           : -4.08 dB
dynrng_Maximum                           : 5.88
dynrng_Maximum                           : 5.88 dB
dynrng_Count                             : 1133
format_identifier                        : AC-3
//LD
LowDead is offline   Reply With Quote
Old 26th September 2020, 09:18   #30002  |  Link
cartman0208
Got my hands on a disc that also consists of 24p and 60p videos.
Couldn't find any issues with x265 or nvenc:
[09.25.20] BD Rebuilder v0.61.16
[22:18:02] Source: GEMINI_MAN
- Input BD size: 86,10 GB
- Approximate total content: [02:17:58.350]
- Target BD size: 47,36 GB
- Windows Version: 6.2 [9200]
- Quality: Good (Fastest, BD-25+), CRF
- Decoding/Frame serving: FFMPEG
[22:18:03] PHASE ONE, Encoding
- [22:18:03] Processing: VID_00000 (1 of 3)
- [22:18:03] Extracting A/V streams [VID_00000]
- [22:18:10] Reencoding video [VID_00000]
- Source Video: HEVC, 3840x2160
- Rate/Length: 23,976fps, 528 frames
- [22:18:10] Reencoding: VID_00000, Pass 1 of 1
- [22:18:34] Video Encode complete
- [22:18:34] Processing audio tracks
- [22:18:34] Multiplexing M2TS
- [22:18:38] Processing: VID_00579 (2 of 3)
- [22:18:38] Extracting A/V streams [VID_00579]
- [22:19:07] Reencoding video [VID_00579]
- Rate/Length: 59,940fps, 10.940 frames
- [22:19:07] Reencoding: VID_00579, Pass 1 of 1
- [22:26:01] Video Encode complete
- [22:26:01] Processing audio tracks
- [22:26:01] Multiplexing M2TS
- [22:26:07] Processing: VID_00003 (3 of 3)
- [22:26:07] Extracting A/V streams [VID_00003]
- [22:48:58] Reencoding video [VID_00003]
- Rate/Length: 59,940fps, 420.962 frames
- [22:48:59] Performing CRF Prediction...
- Analyzing 12,00 11,05 [11,05]
- [22:55:23] Encoding using constant rate factor.
- [03:34:42] Video Encode complete
- [03:34:42] Processing audio tracks
- Track 4354 (deu): Keeping original audio
- [03:34:42] Multiplexing M2TS
[03:47:33]PHASE ONE complete
[03:47:33]PHASE TWO - Rebuild Started
- [03:47:33] Rebuilding BD file Structure
[03:47:54] - Encode and Rebuild complete
[03:47:54] Writing BD structure to ISO file
- ImgBurn completed successfully
[03:56:11] JOB: GEMINI_MAN finished.
IMO 60fps in a movie looks phenomenal ... no idea why all the movies stick with 24fps ... whatever this soap opera effect is, that people complain about, I have no issues with that
cartman0208 is offline   Reply With Quote
Old 26th September 2020, 14:31   #30003  |  Link
jdobbs
Probably because most movies are mastered on film at 24fps.
Website: www.jdobbs.net
Old 26th September 2020, 20:00   #30004  |  Link
MrVideo
MrVideo's Avatar
Not anymore. A majority of movies are shot on video, using cameras specifically designed for movies. Some directors still like shooting on film, but the film is digitally transferred and edited.
One such company making digital cameras is Red (red.com). The other is Arri (www.arri.com/en/camera-systems/cameras).
Shooting at 60fps would result in the movie not getting shown in many theaters, as they are not equipped with the very expensive projectors to do so. Even 48fps movies are limited.
Old 26th September 2020, 21:16   #30005  |  Link
Ch3vr0n
Does this 61.16 release include the updated frim or did you not have more time to tinker with it?
Ch3vr0n is offline   Reply With Quote
Old 26th September 2020, 22:11   #30006  |  Link
jdobbs
Sorry. I haven't played with it at all yet.
Old 26th September 2020, 22:12   #30007  |  Link
jdobbs
Yeah, I was aware that most have gone digital now. But I'm also referring to the other million+ or so releases that happened before that.
Old 26th September 2020, 22:13   #30008  |  Link
Ch3vr0n
no worries. Was just a question. In the mean time i've been tinkering with nvenc, sad to say i can't reproduce your problem. Maybe its because your GPU is actually of a newer generation than mine. That'll change though when my 3090 hopefully arrives in a couple weeks ^^
Old 27th September 2020, 14:56   #30009  |  Link
jdobbs
I got a strange error today:
MapSMtoCores undefined SMversion 7.5!
It happens when I try to encode a movie with X264. It's related to CUVID on my NVIDIA card. If I turn CUVID off it works. Oddly, it worked fine yesterday and I don't see anything that has changed (no updates etc.).
Is anyone familiar with this? Is there a fix?
[Edit] Well... it seems to have gone away with the installation of an updated version of LAV Filters. I may have to update the first post of the thread with a newer version for download. I'll need to do some testing first. Unfortunately that may delay release of the new version. Still wondering what changed overnight, though.
Old 27th September 2020, 15:41   #30010  |  Link
Ch3vr0n
You mean X264 as frameserver instead of DGDecNV? I can run a test with my 1080 if you want.
Old 27th September 2020, 15:52   #30011  |  Link
gonca
I believe he means that he was using LAV with hardware acceleration (CUVID) for frame serving
jdobbs
Could it be one of those once in a blue moon glitches?
gonca is offline   Reply With Quote
Old 27th September 2020, 16:57   #30012  |  Link
jdobbs
jdobbs
No. I can repeat it easily with the version of LAV Filters in the first post. It seems to only happen, though, when reencoding a 2160p source using X264. In my case I was creating ALTERNATE output using a preset that creates an MKV. I'm going to try it with a different 2160p source and see if happens then also.
[Edit] I tried it with another 2160p source and it ran fine. I think the issue is related to that specific source. It was an odd UHD file without HDR that I'd downloaded for a specific bug fix test. I think it is fine the way it is.
Old 27th September 2020, 23:58   #30013  |  Link
jdobbs
BD Rebuilder v0.61.17 Test Release
I think this version is ready for release, but since using the new version of TSMUXER to do all muxing actions can affect a lot of things, I'd like to post it as a test version so some of you experienced users can run it through the ringer before I officially release it.
You can download it from this link: BD-RB v0.61.17
Please provide feedback as to whether or not you find any anomalies. Thanks.
Changes for this release:
- Corrected an issue in which attempts to
  perform a size-correcting second pass on
  an AVC source could result in an error
  "PredictAndEncode() 00011  2994".
- Made adjustments to correct for bad time
  codes in .SUP files that could result in
  certain oddly formatted multi-part sources
  (shows itself as subtitles that extend
  well beyond the lenght of the movie)
- Added changes that will prevent occurance
  of some "Bitstream exception" errors.
- Implemented default use of v2.6.16 of
  TSMUXER for all TSMUXER functions.  In
  order to disable and return to v2.6.12
  use hidden option "ENABLE_NEW_TSMUXER=0".
- Added a routine that catches previously
  undetected errors in AAC encoding and then
  attempts reencoding via a new method.
- Corrected a setting used with HEVC that
  could assert HDR when it is not present in
  the original source.
- Updated TSMUXER4K to the 2020-09-25 build.
- Other minor corrections and cosmetic fixes.
Old 28th September 2020, 18:50   #30014  |  Link
Ch3vr0n
a few quick questions @jdobbs
* is this switch SPECIAL_3D_MUX=1 still needed for in-mux 3D or even at all? (maybe make it a setting instead of hidden option?)
* i'm trying to create movie-only output type but i can't figure it out. I'd like "MKV, Full-SBS (3D), but recoded audio (aac or ac3, but surround intact or recoded to 5.1, codec don't care)". Ideally for an estimated filesize of around 4-8gb. Is this doable?
Old 28th September 2020, 19:47   #30015  |  Link
Emulgator
Big Bit Savings Now !
Emulgator's Avatar
Might still be lurking around: The tsMuxeR 2.6.16 beta versions I tested (from December 2019 until July 2020) were not able to mux 1280x720x50p without packet loss. I kept tsMuxeR 1.10.6 in my toolbox for such reason, muxed ok.
Right now I have no such project, If I find time I will start trying newer tsMuxeR versions on such files.
P.S. Found my test project. Looks good for now.
No packet loss anymore with tsMuxeR git-32db2aa x64 2020-09-25--02-25-44.
P.P.S. And a concatenated ~5h 1280x720x50p project was muxed fine too.
BDEdit 0.49b finds no more packet loss.
Old 28th September 2020, 23:09   #30016  |  Link
jdobbs
Good to know. Thanks.
Old 28th September 2020, 23:49   #30017  |  Link
jdobbs
All SPECIAL_3D_MUX does is not add the InsertSEI and contSPS parameters to the video line of the META file. It was reported to help with pixelation... but I can't confirm that it does. But it should have no affect on MKV output.
It's been a while since I've done 3D, but In order to output SBS, you should just add:
OUTPUT_SBS=1
to your BDREBUILDER.INI file. Alternatively you can set it by selecting "Output SBS/OU Movie-Only Output" from the SETTINGS dialog (it sets/resets OUTPUT_SBS). On my system I also have to add:
FRIM_SW_DECODE=1
You should then be able to pick any of the "No Resize" options for output. For example you might choose "MKV Container, NO_RESIZE, AutoGOP, Auto-AC3". In order to set to a certain output size you can select "VBR Target Size..." when you are selecting the ALTERNATE output. You could also choose "One Pass CRF Target Size...".
[Edit] You'll have to use either X264 or X265. I just tried one using NVENCC and it choked on the input. Not sure why, but I'm guessing it either doesn't like the sizing or it has an issue with the AVS. I'll look at it for the next release.
Old 29th September 2020, 00:19   #30018  |  Link
meadrocks
Watchmen DC
mediainfo looks correct on Watchmen Dir Cut, will watch it tonight. Doing Howls Moving Castle next.
meadrocks is offline   Reply With Quote
Old 29th September 2020, 16:56   #30019  |  Link
Ch3vr0n
i thought that switch was needed for was needed for in-mux 3D, or is that another one? I can find alternate. I have enabled the SBS switch. The 2 profiles that semi match what i want i believe are "MP4/MKV Full-SBS (3D)" but they both use intact audio. I don't mind it being downscaled to 5.1 ac3/aac. There's no profile for that.
Old 29th September 2020, 19:05   #30020  |  Link
jdobbs
Please re-read my response. You don't need to choose a profile that says "Full-SBS" in it. You just need to select one that says "No Resize".
