Old 28th September 2019, 16:47   #28821  |  Link
FilipeAmadeuO
@FilipeAmadeuO
You said you have many titles that experienced the issue. Can you give me a list of them in the hope that I have one of them to work with?
[09/28/19] BD Rebuilder v0.60.25
[16:05:19] Source:  STAR_WARS_STORY_-_SOLO_(UHD)
  - Input BD size: 52,77 GB
  - Approximate total content: [02:16:43.320]
  - Target BD size: 91,80 GB
  - Windows Version: 6.2 [9200]
  - Auto Quality: Very Good (Very Fast), ABR
  - Decoding/Frame serving: FFMPEG
[16:05:19] PHASE ONE, Encoding
 - [16:05:19] Processing: VID_00058 (1 of 5)
 - [16:05:19] Extracting A/V streams [VID_00058]
 - [16:08:00] Reencoding video [VID_00058]
 - [16:08:00] Keeping original video (no reencode)
 - [16:08:00] Processing audio tracks
   - Track 4353 (eng): Keeping original audio
   - Track 4354 (fra): Keeping original audio
   - Track 4355 (spa): Keeping original audio
   - Track 4356 (tha): Keeping original audio
 - [16:08:00] Multiplexing M2TS
 - [16:11:55] Processing: VID_00062 (2 of 5)
 - [16:11:55] Extracting A/V streams [VID_00062]
   - Extracting video streams [VID_00062]
   - Extracting audio/subtitle streams [VID_00062]
 - [17:08:26] Reencoding video [VID_00062]
 - [17:08:26] Keeping original video (no reencode)
 - [17:08:26] Processing audio tracks
 - [17:08:26] Multiplexing M2TS
 - [17:44:23] Processing: VID_00063 (3 of 5)
 - [17:44:23] Extracting A/V streams [VID_00063]
 - [17:44:35] Reencoding video [VID_00063]
 - [17:44:35] Keeping original video (no reencode)
 - [17:44:35] Processing audio tracks
 - [17:44:35] Multiplexing M2TS
 - [17:44:45] Processing: VID_00064 (4 of 5)
 - [17:44:45] Extracting A/V streams [VID_00064]
 - [17:44:57] Reencoding video [VID_00064]
 - [17:44:57] Keeping original video (no reencode)
 - [17:44:57] Processing audio tracks
 - [17:44:57] Multiplexing M2TS
 - [17:45:12] Processing: VID_00065 (5 of 5)
 - [17:45:12] Extracting A/V streams [VID_00065]
 - [17:45:22] Reencoding video [VID_00065]
 - [17:45:22] Keeping original video (no reencode)
 - [17:45:22] Processing audio tracks
 - [17:45:22] Multiplexing M2TS
[17:45:34]PHASE ONE complete
[17:45:34]PHASE TWO - Rebuild Started
 - [17:45:34] Rebuilding BD file Structure
[17:45:51] - Encode and Rebuild complete
[17:45:51] JOB: STAR_WARS_STORY_-_SOLO_(UHD) finished.
FilipeAmadeuO is offline   Reply With Quote
Old 29th September 2019, 05:07   #28822  |  Link
Acerjen
One title I am having that issue with is Everest. Here is the BDREBUILDER.INI
[Options]
VERSION=0.60.0.25
ENCODER=0
MODE=0
ENCODE_QUALITY=5
ONEPASS_ENCODING=2
AUTO_QUALITY=0
TARGET_SIZE=23500
AUDIO_TO_KEEP=eng;
SUBS_TO_KEEP=all
SD_CONVERT=0
OPEN_GOP=0
RESIZE_1080=0
RESIZE_1440=0
RESIZE_720=0
DEINTERLACE=1
SD_TO_1080=0
IGNORE_3D=0
CONVERT_WIDE=0
DTS_REENCODE=0
AC3_REENCODE=0
AC3_640=1
AC3_192=0
KEEP_HD_AUDIO=1
AUDIO_DRC=0
DECODER=0
AVCHD=1
REMOVE_WORKFILES=1
REMOVE_OUTPUT=0
USE_FILTERS=0
BDMV_CERT_ONLY=0
IVTC_PULLDOWN=0
ASSUME_DVD_PAL=0
FRIMSOURCE=0
COMPLETION_BEEP=0
OUTPUT_SBS=0
NEROAAC=0
SUPTITLE=0
AUDIO_TRACK_LIMIT=1
SUBTITLE_TRACK_LIMIT=0
CUSTOM_TARGET_SIZE=23500
MOVIEONLY_TYPE=3
ALTCRF=23
ALT_TARGET=1024
ALTMETHOD=1
ALTAUTOCROP=0
ALT_CRF_TARGET=1024
PGSTOSRT=0
SUPPRESS_FF_WARNING=1
MENU_AUDIO=C:\BD_Rebuilder\tools\blankclip\blank.ac3
IMPORT_THRESHOLD=15
QUICK_PLAY_THRESHOLD=10
MENU_AUTO_BACKGROUND=1
MENU_AUTO_DVDAUDIO=1
MENU_PLAY_SEQUENTIAL=0
MENU_START_WITH_MENU=1
IMPORT_LIMIT_LANG=0
IMPORT_KEEP_PLAYALL=0
[Paths]
WORKING_PATH=F:\00 - 4K ENCODING\
DGIndexNV=C:\Program Files (x86)\dgdecnv2051\DGIndexNV.exe
DGDecNV=C:\Program Files (x86)\dgdecnv2051\DGDecodeNV.dll
SOURCE_PATH=F:\MOVIES (UHD)\EVEREST (UHD)\
I will report back after I rerun it through BD Rebuilder as I have deleted the log files you need. Thanks. Later.
Acerjen
Acerjen is offline   Reply With Quote
Old 29th September 2019, 12:40   #28823  |  Link
jdobbs
Originally Posted by Michi View Post
I made over twenty UHD full backups and all backups have this bug.
Name them.
I have encoded numerous discs... and none have that issue. Just to test your report I have done two more (wasting more than 30 hours of my video computer's time encoding) -- and both came out with the times being exactly what they should have been.
Website: www.jdobbs.net
Old 29th September 2019, 12:40   #28824  |  Link
jdobbs
@FilipeAmadeuO
My mistake. That should have been addressed to Michi.
Old 29th September 2019, 12:44   #28825  |  Link
jdobbs
@Acerjen
Thanks for the INI file.
The disc I ran last night was the one reported to have "shutter" problems. I'll test it some time today and see if I can repeat that issue.
Old 29th September 2019, 13:21   #28826  |  Link
FilipeAmadeuO
Yes, the player stops 10 minutes short of the end and this is the time length, that show tsmuxer in the screenshot.
I can confirm this issue.
Tested disc "Pirates of the Caribenean - Dead Man tell no tales" UHD. Did not removed anything from the disc and just rebuilded (no vídeo encode, no áudio/subtitles removal)
The rebuilded file is smaller and check the Windows time info.
Original: 02:09:06
Rebuilded: 01:43:34
BD Info reports the same time on original and rebuilded but the m2ts it´s smaller.
Old 29th September 2019, 13:23   #28827  |  Link
jdobbs
Yep. There is definitely an issue with transition between M2TS files on SOLO. It's possible this may be related to what Michi reported, but I'm not sure. I'll see what I can find.
Old 29th September 2019, 13:24   #28828  |  Link
jdobbs
Original: 02:09:06
Rebuilded: 01:43:34
Unfortunately I don't have that disc.
Can you play back the end of the two files and see if they match? I want to see if the time discrepancy is in the M2TS itself, or the what is reported in the CLPI. I suspect it may be in the CLPI based on what I saw in SOLO. But if part of the file isn't being encoded -- that may be a bigger issue outside of BD-RB (and a lot harder to fix).
Old 29th September 2019, 14:03   #28829  |  Link
FilipeAmadeuO
Removed
Old 29th September 2019, 14:12   #28830  |  Link
Michi
My BD Rebuilder.ini:
[Options]
VERSION=0.60.0.25
MODE=0
ENCODER_MENU=1
ENCODE_QUALITY=5
ONEPASS_ENCODING=2
AUTO_QUALITY=0
AUDIO_TO_KEEP=deu;gem;ger;
SUBS_TO_KEEP=deu;gem;ger;gmh;goh;gsw;
SD_CONVERT=0
OPEN_GOP=1
RESIZE_1080=0
DEINTERLACE=0
SD_TO_1080=0
CONVERT_WIDE=0
DTS_REENCODE=0
AC3_REENCODE=0
AC3_640=0
AC3_192=0
KEEP_HD_AUDIO=1
AVCHD=0
REMOVE_WORKFILES=1
MOVIE_ONLY_LOOP=1
REMOVE_OUTPUT=1
USE_FILTERS=0
BDMV_CERT_ONLY=0
USE_LAVF=1
IVTC_PULLDOWN=0
ASSUME_DVD_PAL=0
UNMASK_CHAPTER=0
COMPLETION_BEEP=0
DGDECNV=0
AUDIO_TRACK_LIMIT=0
CUSTOM_TARGET_SIZE=66000
TARGET_SIZE=47366
AUTO_BURN=2
MOVIEONLY_TYPE=40
ALTCRF=18
ARCHIVE_265=1
ARCHIVE_AUDIO=100
ARCHIVE_CRF=16
ARCHIVE_ENABLE=1
ARCHIVE_LIMIT=1
ALT_TARGET=7800
ALTMETHOD=0
ALTAUTOCROP=0
QUICK_EXTRAS=0
OUTPUT_3D=0
RESIZE_1440=0
RESIZE_720=0
NEROAAC=0
SUPTITLE=0
IGNORE_3D=0
OUTPUT_SBS=0
ENCODER_MENU=1
HC_PROFILE=BEST
IMPORT_HEVC_INTACT=1
MIN_M2TS_SIZE=20
NEW_CRF_PREDICTION=1
MULTIPROCESS=0
THREADS=auto
BD5_SIZE=4520
BD9_SIZE=8200
BD25_SIZE=23200
QUALITY_ULTRA=1
FRIMSOURCE=0
ENCODER=0
DGDECIM=1
FRIM_SW_DECODE=1
FRIM_SW_ENCODE=1
PRIORITY_CLASS=1
IMPORT_THRESHOLD=15
DECODER=2
AUDIO_DRC=0
IMPORT_LIMIT_LANG=0
ALT_CRF_TARGET=4000
PGSTOSRT=0
[Paths]
SOURCE_PATH=E:\4K BLU RAY\CLIFFHANGER.1993.2160P
WORKING_PATH=Q:\4K\
Name them.
The following discs have that issue and the end is shorter (I would like to update the list):
Creed - Rockys Legacy 2015
Creed II 2018
Allied 2016
Cliffhanger Studio Canal Version 1993
The little Mermaid 1989
Wildes Venedig
Ballon 2018
Apollo 13 1995
Asterix 2018
Ghostbuster 1984
I deleted the most backups.
Today I'm testing more and send logs to Jdobbs.
Michi is offline   Reply With Quote
Old 29th September 2019, 15:46   #28831  |  Link
Michi
Wildes Venedig Log:
[09.29.19] BD Rebuilder v0.60.25
[14:57:43] Source: WILDES_VENEDIG
- Input BD size: 25,80 GB
- Approximate total content: [00:53:08.921]
- Target BD size: 22,66 GB
- Quality: Good (Fastest, BD-25+), ABR
- Audio Settings: AC3=0 DTS=0 HD=1 Kbs=448
[14:57:43] PHASE ONE, Encoding
- [14:57:43] Processing: VID_00005 (1 of 1)
- [14:57:43] Extracting A/V streams [VID_00005]
- [15:01:25] Reencoding video [VID_00005]
- Source Video: HEVC, 3840x2160
- Rate/Length: 25,000fps, 78.047 frames
- Bitrate: 35.000 Kbs
- [15:01:25] Reencoding: VID_00005, Pass 1 of 1
- [16:38:08] Video Encode complete
- [16:38:08] Processing audio tracks
- Track 4352 (deu): Keeping original audio
- Track 4353 (deu): Keeping original audio
- [16:38:09] Multiplexing M2TS
[16:44:47]PHASE ONE complete
[16:44:47]PHASE TWO - Rebuild Started
- [16:44:47] Rebuilding BD file Structure
[16:44:51] - Encode and Rebuild complete
[16:44:51] Writing BD structure to ISO file
- ImgBurn completed successfully
- WILDES_VENEDIG folder removed.
- WORKFILES folder removed.
[16:45:12] JOB: WILDES_VENEDIG finished.
Old 29th September 2019, 17:56   #28832  |  Link
Mark_Venture
[Paths]
SOURCE_PATH=E:\4K BLU RAY\CLIFFHANGER.1993.2160P.UHD.BLURAY.HDR.HEVC.DTS-HD.MA.5.1-HDBEE\
WORKING_PATH=Q:\4K\
Are you working on discs you owned and ripped yourself or something you downloaded?
I ask because the source path looks like something that was downloaded.
Mark_Venture is offline   Reply With Quote
Old 29th September 2019, 18:18   #28833  |  Link
Michi
I edit the path.
Old 29th September 2019, 18:32   #28834  |  Link
prologic
Original: 02:09:06
Rebuilded: 01:43:34
I did this film, exept I took some audio and subtitle streams out ..
Just checked the movie , and the length of the film is
02:09:06 ... I did Toy story 4 , it has many m2ts files, around 126 ..
took the unwanted streams out , and worked a treat ..have my size set at stupid size 900500 , because I only take out streams , these days .
prologic is offline   Reply With Quote
Old 29th September 2019, 18:57   #28835  |  Link
FilipeAmadeuO
I think it was my mistaque. The problem was generated because of low free disc size space. Rebuilded again and working perfect.
Old 29th September 2019, 19:02   #28836  |  Link
gamete
Is it possibile make a backup of 4K bluray into BD25 or BD50 ?
The 4k bluray have same structure of bluray ?
Thanks
gamete is offline   Reply With Quote
Old 29th September 2019, 19:22   #28837  |  Link
prologic
Thanks
Yes it is possible, thats what this thread is all about, but still in test yet.
I personally do all my cartoon type stuff on bd25 .
Old 29th September 2019, 19:25   #28838  |  Link
Michi
Ghostbuster 1984:
[16:46:48] Source: GHOSTBUSTERS.1984
- Input BD size: 57,65 GB
- Approximate total content: [02:09:54.241]
[16:46:48] PHASE ONE, Encoding
- [16:46:48] Processing: VID_00001 (1 of 2)
- [16:46:48] Extracting A/V streams [VID_00001]
- [16:51:44] Reencoding video [VID_00001]
- Rate/Length: 23,976fps, 151.248 frames
- Bitrate: 26.056 Kbs
- [16:51:44] Reencoding: VID_00001, Pass 1 of 1
- [20:09:52] Video Encode complete
- [20:09:52] Processing audio tracks
- Track 4355 (deu): Keeping original audio
- [20:09:53] Multiplexing M2TS
- [20:17:55] Processing: VID_00100 (2 of 2)
- [20:17:55] Extracting A/V streams [VID_00100]
- [20:17:59] Reencoding video [VID_00100]
- Rate/Length: 23,976fps, 346 frames
- Bitrate: 7.723 Kbs
- [20:17:59] Reencoding: VID_00100, Pass 1 of 1
- [20:18:19] Video Encode complete
- [20:18:19] Processing audio tracks
- [20:18:19] Multiplexing M2TS
[20:18:23]PHASE ONE complete
[20:18:23]PHASE TWO - Rebuild Started
- [20:18:23] Rebuilding BD file Structure
[20:18:35] - Encode and Rebuild complete
[20:18:35] Writing BD structure to ISO file
- GHOSTBUSTERS.1984 folder removed.
[20:19:08] JOB: GHOSTBUSTERS.1984 finished.
Old 29th September 2019, 19:53   #28839  |  Link
Ch3vr0n
@Michi
Just because you edit the path from
to
doesn't make it an original disc magically. No retail disc uses that entire string as a disc name. Ever.
That is a pirated release, which means most likely
GHOSTBUSTERS.1984
is aswell. Which is against the forum rules (specifically nr 6). We can't assist you any further, and i doubt jdobbs will too at this point. Get the original discs, then come back. Anything else, is off limits.
Ch3vr0n is offline   Reply With Quote
Old 30th September 2019, 10:30   #28840  |  Link
gamete
Bd25 ?,how % of compression ?
