22nd January 2010, 18:02 | #6742 | Link |
@Atak
Did you look at that 50M sample to see why it isn't recognizing the PCM audio? Suggestion: In the audio track dropdown, if would be great if you could list the audio specs instead of the filename. On my system I can't see the whole filename, gets chopped off, but I can see enough that I have to go look in the temp directory and play the audio track to see what exactly the specs are for it. Example of what I'm talking about: "DTS 5.1 768kbit" |
22nd January 2010, 22:20 | #6744 | Link | |
/dev/null
22nd January 2010, 22:31 | #6745 | Link | ||
23rd January 2010, 00:53 | #6746 | Link |
The Black Reaper
This is sort of a newbie question, not sure if this is the right place to ask.
When converting some youtube videos, the output tend to have squarish block during dark scene taken in the night. How can I improve the output? Edit: It plays okay on MPC but when I play it on my PSP, the block appears. Last edited by Lighto; 23rd January 2010 at 12:56. |
23rd January 2010, 02:19 | #6748 | Link |
Posts: n/a
i just want to convert it to 640 ac3 but it seems that eac3 converts it to pcm during the demuxing process and the result audio is slowed down and has static which is then encoded to ac3 with the problems from the pcm file. it's definitely dtshd 6.1 not a dts es file. this is straight from the blu-ray.
23rd January 2010, 05:08 | #6749 | Link | |
23rd January 2010, 16:37 | #6750 | Link | |
Posts: n/a
23rd January 2010, 17:04 | #6751 | Link |
Try to remux your BD movie with TSmuxer without downconverting DTS audio. Import remuxed file again in ripbot264.
23rd January 2010, 18:51 | #6752 | Link |
Feature Request
More options around audio profiles. Audio profiles as text files, and users can create/edit/customise as they wish, similar to Encoder profiles for Video. Or alternatively an option to specify XCOPY, CBR or VBR, and (if not XCOPY) then Audio Encoder from drop down, and then lastly bitrate another drop down of say 32, 48, 64, 128, 256, 384, 448, 640, 1536. Clearly would need to take into account source audio type etc For the main video work I put through RipBot264, I only need basic audio. At present I edit the job1_EncodeAudio.cmd to adjust down from say 65536 to 49152. But it means I have to also go and adjust the x264 parameters with 2-pass to take this into account and increase video bitrate accordingly. Of course, this is just my own need - no idea how many others would find this useful... And I can work around this, so just asking on the chance this is easy-ish to accomplish (it's probably not at all, and I'm totally naive to think it can be easily done) |
23rd January 2010, 19:08 | #6753 | Link | |
23rd January 2010, 20:25 | #6754 | Link | |
I've searched the forum and the thread. Someone posted a bunch of registry entries and there was one isWhitelist entry for ffdshow. I've checked my registry and the registry key is there. I'd like to be able to use this program again. |
23rd January 2010, 20:49 | #6755 | Link | |
I've found that DVDFab rips my BDs much faster than MakeMKV for some reason. And RipBot264 can demux the LPCM from the m2ts file. Problem solved. I've got an mkv that ripbot created but somehow it used the audio from another job. I don't want to have to reencode the video. Any suggestions on how I can just rip the DTS track off the BD so I can remux it with the video in the MKV? |
23rd January 2010, 21:14 | #6756 | Link |
tsmuxer
24th January 2010, 13:49 | #6759 | Link |
FLAC is only available for lossless audio! I checked your movie (http://www.blu-raystats.com/Stats/Stats.php) and it has plain DTS audio not DTS-MA!
24th January 2010, 14:04 | #6760 | Link | |
@Atak: Is is possible to add this option? |
