Old 15th July 2019, 14:30   #6921  |  Link
Stereodude
Originally Posted by LigH View Post
Ah, I missed these examples... I would have given a better guess if I knew them.
So it seems to be:
x265 --pools "4,4,4,4,+,-,-,-"
x265 --pools "4,4,4,4,-,+,-,-"
x265 --pools "4,4,4,4,-,-,+,-"
x265 --pools "4,4,4,4,-,-,-,+"
Or am I still wrong? ... In this case, I may misunderstand the nodes in contrast to the specific cores.
P.S.: I asked in the x265 developer mailing list.
I didn't try any of those, but this system only has 1 numa node (8C/16HT) and those command lines would be for a system with 4 numa nodes, and they're contradicting. "0,0,0,4" would put 0 thread pools on the first 3 Numa nodes and 4 on the 4th. "4,4,4,4" would put 4 thread pools on each of the 4 Numa nodes. "+,-,-,-" would put a thread pool with an number equal to the logical cores in the first node and none on the next 3. So, you've got conflicting instructions on the command line.
By my reading and messing with them (I do have a dual Numa node system) you have control over nodes, but not over cores.
I'll be curious to see what reply you get on the mailing list.
Stereodude is offline   Reply With Quote
Old 15th July 2019, 23:23   #6922  |  Link
MeteorRain
結城有紀
I have never made x265 to set its affinity as I intended so I always use my modded version of avs4x264 to do the job, which overwrites the affinity after x265 launches.
Regarding to your qpfile usage, honestly I have no similar usage of those so I don't have good suggestions for you. Usually if I want to force an IDR I'll just cut that as a new segment.
I'll take a quick look at the source code and see if I can find a way to do a seek easily. If it's easy enough to implement I'll slipstream it into my patch set.
MeteorRain is offline   Reply With Quote
Old 16th July 2019, 00:50   #6923  |  Link
MeteorRain
結城有紀
And -- I might be wrong, but -- I don't see any code with qpfile that takes into account seek option. That means you'll have to shift your qpfile for any seek option you applied in the command line.
Old 16th July 2019, 03:21   #6924  |  Link
MeteorRain
結城有紀
https://down.7086.in/x265-10bit-avisynth-seek-test.zip
qpfile still needs manual shifting.
Old 16th July 2019, 03:33   #6925  |  Link
Stereodude
So if I tell it to drop an I frame at frame 6000 and I tell it to seek to frame 5000 to start the encode it doesn't subtract 5000 from 6000 and know to place it at 1000 in the encode (which is frame 6000 in the source)?
Old 16th July 2019, 04:21   #6926  |  Link
MeteorRain
結城有紀
That is correct as far as I know.
Old 17th July 2019, 00:25   #6927  |  Link
mandarinka
mandarinka's Avatar
Originally Posted by Boulder View Post
I see there are two recent commits related to hierachial motion estimation. I couldn't find anything specific as to what the use cases would be, does anyone have any insights? Or is this once again one of those things that just appear in the encoder out of the blue (probably requested by some paying client) and the devs leave it at that.
If I'm not mistaken, this method could perhaps improve the search by allowing it to find more distant motion vectors (large motion difference between frames say in anime action sequences?). I'm completely assuming, haven't tried yet.
Has anybody here tested it?
(Edit: also, is it finished/ready for testing yet, or are there more incoming patches to plumb it together?)
mandarinka is offline   Reply With Quote
Old 17th July 2019, 13:34   #6928  |  Link
tuanden0
New commit with new aq-mode
--aq-mode <0|1|2|3|4>
Adaptive Quantization operating mode. Raise or lower per-block quantization based on complexity analysis of the source image. The more complex the block, the more quantization is used. This offsets the tendency of the encoder to spend too many bits on complex areas and not enough in flat areas.
disabled
AQ enabled
AQ enabled with auto-variance (default)
3. AQ enabled with auto-variance and bias to dark scenes. This is recommended for 8-bit encodes or low-bitrate 10-bit encodes, to prevent color banding/blocking. 4. AQ enabled with
tuanden0 is offline   Reply With Quote
Old 17th July 2019, 13:45   #6929  |  Link
quietvoid
From my quick testing using --hme with --hme-search hex,star,hex is 3x slower than just --me star (subme 5) with --preset slower.
Even hex,hex,hex is still 10% slower, so not sure what the use case is when it's that slow.
quietvoid is offline   Reply With Quote
Old 17th July 2019, 17:04   #6930  |  Link
vpupkind
The point is having a much larger search range. On high resolutions (e.g. 4K) the current search range is very small and is not great at capturing fast motion. With HME, using 3 levels with range of 32 will get you to the range of 224. The current default for star, hex, et al is less than 64.
The other point is better coherency of motion field at high resolutions.
vpupkind is offline   Reply With Quote
Old 17th July 2019, 18:21   #6931  |  Link
mandarinka
mandarinka's Avatar
Any reason why --HME uses hex, umh, umh as its default motion searches, but generally x265 uses --me star in its presets?
(would Star be better than UMH in HME, and generally outside of HME?)
Old 17th July 2019, 19:21   #6932  |  Link
froggy1
ffx264/ffhevc author
froggy1's Avatar
I guess performance reasons. I use hme-search=star for all levels (L0,1,2)
ffx264--ffhevc--ffxvid
froggy1 is offline   Reply With Quote
Old 17th July 2019, 20:03   #6933  |  Link
Boulder
Pig on the wing
Boulder's Avatar
So basically the option has no practical use in encodes of sub-4K resolutions?
Old 17th July 2019, 20:04   #6934  |  Link
froggy1
froggy1's Avatar
I use it for Full HD movies. I find it looks a bit sharper compared to no hme
Old 18th July 2019, 12:49   #6935  |  Link
LigH
LigH's Avatar
x265 3.1+8-21db162c8622 (MSYS2, MinGW32 / MinGW64 + GCC 9.1.0)
   --[no-]hme                    Enable Hierarchical Motion Estimation. Default disabled
   --hme-search <string>         Motion search-method for HME L0,L1 and L2. Default(L0,L1,L2) is 1,2,2
   --aq-mode <integer>           Mode for Adaptive Quantization - 0:none 1:uniform AQ 2:auto variance 3:auto variance with bias to dark scenes 4:auto variance with edge information. Default 2
   --[no-]aq-motion              Block level QP adaptation based on the relative motion between the block and the frame. Default disabled
New German Gleitz board
Old 18th July 2019, 21:23   #6936  |  Link
Morku
@LigH
As silent reader I want to say thank you for the fresh, updated Encoders. Please never stop. Even when the board seems to fall asleep sometimes, we appreciate all the work. A Thank Button would be nice here. Every contribute is important
I hope Zathor is fine...?
Morku is offline   Reply With Quote
Old 19th July 2019, 13:00   #6937  |  Link
jlpsvk
what exctly that aq-mode 4 is doing? is it that "HEVC" aq? or? that HEVC aq was not so good... currently i am using aq-mode 2.
AMD Ryzen 9 3950X, 32GB DDR4-3200 CL16, RTX 2070, 1TB NVMe SSD, 56TB NAS
jlpsvk is offline   Reply With Quote
Old 19th July 2019, 18:17   #6938  |  Link
Jamaika
I add function qp zero, aq-mode doesn't work.
p->rc.aqMode = X265_AQ_EDGE;
p->bAQMotion = 1;
p->bEnableHME = 1;
p->hmeSearchMethod[1] = p->hmeSearchMethod[2] = X265_STAR_SEARCH;
x265 (build 178) - 3.1+8:[Windows][GCC 9.1.1][64 bit][noasm] 10bit - H.265/HEVC codec - Copyright 2013-2018 (c) Multicoreware, Inc - http://x265.org - options: cpuid=0 frame-threads=2 wpp no-pmode no-pme no-psnr no-ssim log-level=2 bitdepth=10 input-csp=2 fps=25/1 input-res=1568x1560 interlace=0 total-frames=1 level-idc=0 high-tier=1 uhd-bd=0 ref=1 no-allow-non-conformance repeat-headers annexb no-aud no-hrd info hash=0 no-temporal-layers no-open-gop min-keyint=1 keyint=1 gop-lookahead=0 bframes=0 b-adapt=0 no-b-pyramid bframe-bias=0 rc-lookahead=0 lookahead-slices=0 scenecut=0 radl=0 no-splice no-intra-refresh ctu=64 min-cu-size=8 rect amp max-tu-size=32 tu-inter-depth=4 tu-intra-depth=4 limit-tu=0 rdoq-level=2 dynamic-rd=0.00 no-ssim-rd signhide tskip nr-intra=0 nr-inter=0 no-constrained-intra strong-intra-smoothing max-merge=5 limit-refs=0 no-limit-modes me=2 subme=5 merange=92 temporal-mvp hme Level 0,1,2=1,3,3 no-weightp no-weightb no-analyze-src-pics deblock=-1:1 sao no-sao-non-deblock rd=6 no-early-skip no-rskip no-fast-intra no-tskip-fast no-cu-lossless b-intra no-splitrd-skip rdpenalty=0 psy-rd=2.00 psy-rdoq=0.00 no-rd-refine no-lossless cbqpoffs=0 crqpoffs=0 rc=cqp qp=0 aq-mode=0 aq-strength=0.00 no-cutree zone-count=0 no-strict-cbr qg-size=32 no-rc-grain qpmax=69 qpmin=0 no-const-vbv sar=0 overscan=0 videoformat=5 range=0 colorprim=2 transfer=2 colormatrix=2 chromaloc=0 display-window=0cll=0,0 min-luma=0 max-luma=1023 log2-max-poc-lsb=8 vui-timing-info vui-hrd-info slices=1 no-opt-qp-pps no-opt-ref-list-length-pps no-multi-pass-opt-rps scenecut-bias=0.05 no-opt-cu-delta-qp aq-motion no-hdr no-hdr-opt no-dhdr10-opt no-idr-recovery-sei analysis-reuse-level=5 scale-factor=0 refine-intra=0 refine-inter=0 refine-mv=0 refine-ctu-distortion=0 no-limit-sao ctu-info=0 no-lowpass-dct refine-analysis-type=33620483 copy-pic=1 max-ausize-factor=1.0 no-dynamic-refine no-single-sei no-hevc-aq no-svt no-field qp-adaptation-range=1.00
For what presets is it and additional functions? Can it be used for 10bit?
Jamaika is offline   Reply With Quote
Old 20th July 2019, 15:07   #6939  |  Link
_kermit
I have the same question
_kermit is offline   Reply With Quote
Old 20th July 2019, 18:18   #6940  |  Link
Selur
Selur's Avatar
--[no-]hevc-aq                Mode for HEVC Adaptive Quantization. Default disabled
--aq-strength <float>         Reduces blocking and blurring in flat and textured areas (0 to 3.0). Default 1.00
--qp-adaptation-range <float> Delta QP range by QP adaptation based on a psycho-visual model (1.0 to 6.0). Default 1.00
source: x265 --fullhelp
-> hevc-aq is still there, so aq-mode 4 should be something different
Notice: Since email notifications do not work here any more, it might take me quite some time to notice a reply to a thread,..
