Old 9th February 2018, 23:22   #5901  |  Link
Selur
Selur's Avatar
@Ma: thanks for the insight
Cu Selur
Notice: Since email notifications do not work here any more, it might take me quite some time to notice a reply to a thread,..
Old 10th February 2018, 01:11   #5902  |  Link
burfadel
I wonder whether lookahead could be repurposed to allow more efficient use of large CU size, or only use it when it appears most efficient to do so.
Old 10th February 2018, 10:39   #5903  |  Link
Anthonytex
Hello everyone, I know that this question was posted a lot of time so apologize: is it true that it's better to encode a 8bit video to 10bit even if the source it's 8 bit? What's the difference? Does the x265 encoder works better? Thank you
Anthonytex is offline   Reply With Quote
Old 10th February 2018, 10:46   #5904  |  Link
Selur
Selur's Avatar
-> Why does 10-bit save bandwidth (even when content is 8-bit)?
Old 10th February 2018, 11:10   #5905  |  Link
Boulder
Pig on the wing
Boulder's Avatar
Originally Posted by Ma View Post
I've made some tests about '--qg-size'. For my eyes '--qg-size 32' is better than '--qg-size 16'. After checking all possible values (8, 16, 32 and 64) the best is 64 (PSNR/SSIM and for my eyes). It is a bit strange, the default value in x265 is 32.
Funny thing is that in the "--tune film" thread, the exact opposite was suggested: http://forum.doom9.org/showthread.php?t=172458
Could you repeat the test with some high-detail film content, please?
Old 10th February 2018, 11:21   #5906  |  Link
Anthonytex
Thank you I've read that article, I was looking for something x265 specific rather than a general case
Old 10th February 2018, 12:21   #5907  |  Link
Dope
I haven't seen x265 to compress more efficiently in 10-bit. x264 - yes. But not x265.
Dope is offline   Reply With Quote
Old 10th February 2018, 17:15   #5908  |  Link
poisondeathray
Those are my findings too
Old 10th February 2018, 17:33   #5909  |  Link
Anthonytex
Thank you
Old 10th February 2018, 18:28   #5910  |  Link
Selur
Selur's Avatar
Still 10bit makes sense to avoid introducing banding artifacts,..
Old 11th February 2018, 14:44   #5911  |  Link
Asmodian
10-bit is still more efficient, only it is a very small improvement with x265 compared to x264. x265 uses a higher bit depth in important places internally, even when set to 8 bit; its internal data structures are not all required to use the same bit depth as the output video.
Also, banding is never good so that is also a quality/size efficiency boost.
madVR options explained
Old 11th February 2018, 15:10   #5912  |  Link
sneaker_ger
The problem is x265 can produce banding even at 10 bit. x264 10bit doesn't have those problems, it's "fire and forget". Hard to beat if you aim for high bitrate/high quality.
https://forum.doom9.org/showthread.p...53#post1762253
Old 11th February 2018, 17:34   #5913  |  Link
Ma
The problem with qg-size could be related to 8bit vs. 10bit question.
I've made tests with 10bit output and I prefer qg-size 64 (for 10bit output).
Maybe the change from 64 to 32 for qg-size was for 8bit output?
Ma is offline   Reply With Quote
Old 11th February 2018, 19:00   #5914  |  Link
IgorC
Filmgrain preservation is overrated
Filmgrain is just a noise. Pleasant noise, but still noise.
Iíd prefer video source without filmgrain than with it. Two reasons for that. First reason, microscopic details arenít drowned in grain. Second reason, significantly better compressibility. In the end you have better both: visual quality and compressibility. Win-win situation.
Good news that new Netflix series/shows have much less filmgrain or donít have it at all.
Instead of blaming x265 developers for not preserving grain itís time to forget about useless filmgrain to begin with
IgorC is offline   Reply With Quote
Old 12th February 2018, 16:30   #5915  |  Link
Sp00kyFox
Sp00kyFox's Avatar
Originally Posted by Motenai Yoda View Post
I would suggest a possible tune animation:
aq-mode 3 aq-strength 0.6 aq-motion qg-size 16 rc-lookahead +20 psy-rd 1.2 rdoq-level 2 psy-rdoq 0.3 deblock 1:-1 cbqpoffs -1 crqpoffs -1
can somebody actually provide an encoding example where aq-mode 3 is beneficial? made some tests a while ago and really can't say that it's better or worse than mode 1. both seem better than mode 2 though.
10bit-depth prevents banding artifacts better and since HEVC hardware decoders also support it unlike with AVC I don't see a reason not to use it.
it's the classic problem of video filtering to distinguish between grain and details. so a video encoder that fails to keep this picture information also has issues with keeping details. despite that grain can also create details over the temporal axis.
anyways, since the introduction of the new lambda tables (in v2.4) x265 does a great job with keeping grain. for me it has made x264 obsolete.
Sp00kyFox is offline   Reply With Quote
Old 13th February 2018, 23:18   #5916  |  Link
IgorC
Great.Thank you for clarifying that as I didn't followed x265 devt last year.
Old 14th February 2018, 10:57   #5917  |  Link
LigH
LigH's Avatar
x265 2.6+39-01b685d6fa33
CMake: fix generation of version info from .hg_archival.txt; fix output to pipe on Windows (enable binary mode)
New German Gleitz board
Old 18th February 2018, 18:24   #5918  |  Link
Barough
Barough's Avatar
x265 v2.6+42-52782aeb2081 (GCC 7.3.0, 32 & 64-bit 8/10/12bit Multilib Windows Binaries)
https://bitbucket.org/multicoreware/x265/commits/branch/default
Old 20th February 2018, 22:09   #5919  |  Link
VoodooFX
Definitely I had same problem with aq-mode=2 (and maybe with 3 too, I don't remember now), using default aq-mode=1 solved exact banding like in those screenshots.
VoodooFX is offline   Reply With Quote
Old 22nd February 2018, 13:15   #5920  |  Link
hajj_3
x265 v2.7 is out, can't find a changelog though.
