Old 26th February 2017, 20:01   #4861  |  Link
pingfr
Originally Posted by aymanalz View Post
Try just the limit refs 3.
x265.exe --crf 21 --aq-mode 1 --ctu 32 --qg-size 32 --deblock -6:-6 --me star --bframes 4 --rc-lookahead 60 --ref 5 --b-adapt 2 --tu-intra-depth 4 --tu-inter-depth 4 --merange 57 --weightp --weightb --scenecut 40 --rd 4 --limit-ref 3 --limit-modes --tskip --rect --amp --max-merge 5 --subme 5 --b-intra --no-rskip --no-sao --no-strong-intra-smoothing %1 -o %~n1.hevc
x265 [info]: HEVC encoder version 2.3+9-820f4327ddac
x265 [info]: build info [Windows][GCC 6.3.0][64 bit] 8bit+10bit+12bit
x265 [info]: using cpu capabilities: MMX2 SSE2Fast SSSE3 SSE4.2 AVX AVX2 FMA3 LZCNT BMI2
x265 [info]: Main profile, Level-4 (Main tier)
x265 [info]: Thread pool created using 8 threads
x265 [info]: Slices : 1
x265 [info]: frame threads / pool features : 3 / wpp(34 rows)
x265 [info]: Coding QT: max CU size, min CU size : 32 / 8
x265 [info]: Residual QT: max TU size, max depth : 32 / 4 inter / 4 intra
x265 [info]: ME / range / subpel / merge : star / 57 / 5 / 5
x265 [info]: Keyframe min / max / scenecut / bias: 25 / 250 / 40 / 5.00
x265 [info]: Lookahead / bframes / badapt : 60 / 4 / 2
x265 [info]: b-pyramid / weightp / weightb : 1 / 1 / 1
x265 [info]: References / ref-limit cu / depth : 5 / on / on
x265 [info]: AQ: mode / str / qg-size / cu-tree : 1 / 1.0 / 32 / 1
x265 [info]: Rate Control / qCompress : CRF-21.0 / 0.60
x265 [info]: tools: rect amp limit-modes rd=4 psy-rd=2.00 tskip signhide tmvp
x265 [info]: tools: b-intra lslices=6 deblock(tC=-6:B=-6)
x265 [info]: frame I: 3, Avg QP:22.55 kb/s: 28882.40
x265 [info]: frame P: 141, Avg QP:23.75 kb/s: 19361.90
x265 [info]: frame B: 456, Avg QP:28.24 kb/s: 6027.66
x265 [info]: Weighted P-Frames: Y:0.0% UV:0.0%
x265 [info]: Weighted B-Frames: Y:0.0% UV:0.0%
x265 [info]: consecutive B-frames: 0.7% 0.0% 0.0% 80.6% 18.8%
encoded 600 frames in 276.47s (2.17 fps), 9275.48 kb/s, Avg QP:27.15
Video
Format : HEVC
Format/Info : High Efficiency Video Coding
Format profile : Main@L4@Main
Codec ID : V_MPEGH/ISO/HEVC
Duration : 20s 0ms
Bit rate : 9 097 Kbps
Width : 1 920 pixels
Height : 1 080 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Frame rate : 30.000 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Bits/(Pixel*Frame) : 0.146
Stream size : 21.7 MiB (98%)
Writing library : x265 2.3+9-820f4327ddac:[Windows][GCC 6.3.0][64 bit] 8bit+10bit+12bit
Encoding settings : cpuid=1173503 / frame-threads=3 / numa-pools=8 / wpp / no-pmode / no-pme / no-psnr / no-ssim / log-level=2 / input-csp=1 / input-res=1920x1080 / interlace=0 / total-frames=600 / level-idc=0 / high-tier=1 / uhd-bd=0 / ref=5 / no-allow-non-conformance / no-repeat-headers / annexb / no-aud / no-hrd / info / hash=0 / no-temporal-layers / open-gop / min-keyint=25 / keyint=250 / bframes=4 / b-adapt=2 / b-pyramid / bframe-bias=0 / rc-lookahead=60 / lookahead-slices=6 / scenecut=40 / no-intra-refresh / ctu=32 / min-cu-size=8 / rect / amp / max-tu-size=32 / tu-inter-depth=4 / tu-intra-depth=4 / limit-tu=0 / rdoq-level=0 / dynamic-rd=0.00 / signhide / tskip / nr-intra=0 / nr-inter=0 / no-constrained-intra / no-strong-intra-smoothing / max-merge=5 / limit-refs=3 / limit-modes / me=3 / subme=5 / merange=57 / temporal-mvp / weightp / weightb / no-analyze-src-pics / deblock=-6:-6 / no-sao / no-sao-non-deblock / rd=4 / no-early-skip / no-rskip / no-fast-intra / no-tskip-fast / no-cu-lossless / b-intra / rdpenalty=0 / psy-rd=2.00 / psy-rdoq=0.00 / no-rd-refine / analysis-mode=0 / no-lossless / cbqpoffs=0 / crqpoffs=0 / rc=crf / crf=21.0 / qcomp=0.60 / qpstep=4 / stats-write=0 / stats-read=0 / ipratio=1.40 / pbratio=1.30 / aq-mode=1 / aq-strength=1.00 / cutree / zone-count=0 / no-strict-cbr / qg-size=32 / no-rc-grain / qpmax=69 / qpmin=0 / sar=0 / overscan=0 / videoformat=5 / range=0 / colorprim=2 / transfer=2 / colormatrix=2 / chromaloc=0 / display-window=0 / max-cll=0,0 / min-luma=0 / max-luma=255 / log2-max-poc-lsb=8 / vui-timing-info / vui-hrd-info / slices=1 / opt-qp-pps / opt-ref-list-length-pps / no-multi-pass-opt-rps / scenecut-bias=0.05 / no-opt-cu-delta-qp / no-aq-motion / no-hdr / no-hdr-opt
Default : Yes
Forced : No
Hard to tell.
pingfr is offline   Reply With Quote
Old 26th February 2017, 20:08   #4862  |  Link
darksiderg
i m using x265 2.3+1-7e225ae stable version. during 720p encode i noticed that my cpu usage was fluctuating from 40% to 80% vice versa. but it never reached 100. i used slow preset. is it normal?
darksiderg is offline   Reply With Quote
Old 26th February 2017, 20:10   #4863  |  Link
pingfr
And if blocking is the only issue you saw, increase the deblocking to -3,-3 or higher. Lowering deblocking by so much from default values, probably causes...blocking.
Trying now with a -3,-3. Will return in a bit with the results.
Old 26th February 2017, 20:12   #4864  |  Link
Boulder
Pig on the wing
Boulder's Avatar
Or leave the settings as they are and try --rskip. I could never tell if it was better on or off, but encoding is much faster enabled. It will probably increase the bitrate though.
Old 26th February 2017, 20:18   #4865  |  Link
pingfr
x265.exe --crf 21 --aq-mode 1 --ctu 32 --qg-size 32 --deblock -3:-3 --me star --bframes 4 --rc-lookahead 60 --ref 5 --b-adapt 2 --tu-intra-depth 4 --tu-inter-depth 4 --merange 57 --weightp --weightb --scenecut 40 --rd 4 --limit-ref 3 --limit-modes --tskip --rect --amp --max-merge 5 --subme 5 --b-intra --no-rskip --no-sao --no-strong-intra-smoothing %1 -o %~n1.hevc
x265 [info]: tools: b-intra lslices=6 deblock(tC=-3:B=-3)
x265 [info]: frame P: 141, Avg QP:23.75 kb/s: 19287.13
x265 [info]: frame B: 456, Avg QP:28.23 kb/s: 6014.92
encoded 600 frames in 264.24s (2.27 fps), 9248.22 kb/s, Avg QP:27.15
Video
Format : HEVC
Duration : 20s 0ms
Bit rate : 9 071 Kbps
Color space : YUV
Bit depth : 8 bits
Stream size : 21.6 MiB (98%)
Encoding settings : cpuid=1173503 / frame-threads=3 / numa-pools=8 / wpp / no-pmode / no-pme / no-psnr / no-ssim / log-level=2 / input-csp=1 / input-res=1920x1080 / interlace=0 / total-frames=600 / level-idc=0 / high-tier=1 / uhd-bd=0 / ref=5 / no-allow-non-conformance / no-repeat-headers / annexb / no-aud / no-hrd / info / hash=0 / no-temporal-layers / open-gop / min-keyint=25 / keyint=250 / bframes=4 / b-adapt=2 / b-pyramid / bframe-bias=0 / rc-lookahead=60 / lookahead-slices=6 / scenecut=40 / no-intra-refresh / ctu=32 / min-cu-size=8 / rect / amp / max-tu-size=32 / tu-inter-depth=4 / tu-intra-depth=4 / limit-tu=0 / rdoq-level=0 / dynamic-rd=0.00 / signhide / tskip / nr-intra=0 / nr-inter=0 / no-constrained-intra / no-strong-intra-smoothing / max-merge=5 / limit-refs=3 / limit-modes / me=3 / subme=5 / merange=57 / temporal-mvp / weightp / weightb / no-analyze-src-pics / deblock=-3:-3 / no-sao / no-sao-non-deblock / rd=4 / no-early-skip / no-rskip / no-fast-intra / no-tskip-fast / no-cu-lossless / b-intra / rdpenalty=0 / psy-rd=2.00 / psy-rdoq=0.00 / no-rd-refine / analysis-mode=0 / no-lossless / cbqpoffs=0 / crqpoffs=0 / rc=crf / crf=21.0 / qcomp=0.60 / qpstep=4 / stats-write=0 / stats-read=0 / ipratio=1.40 / pbratio=1.30 / aq-mode=1 / aq-strength=1.00 / cutree / zone-count=0 / no-strict-cbr / qg-size=32 / no-rc-grain / qpmax=69 / qpmin=0 / sar=0 / overscan=0 / videoformat=5 / range=0 / colorprim=2 / transfer=2 / colormatrix=2 / chromaloc=0 / display-window=0 / max-cll=0,0 / min-luma=0 / max-luma=255 / log2-max-poc-lsb=8 / vui-timing-info / vui-hrd-info / slices=1 / opt-qp-pps / opt-ref-list-length-pps / no-multi-pass-opt-rps / scenecut-bias=0.05 / no-opt-cu-delta-qp / no-aq-motion / no-hdr / no-hdr-opt
Default : Yes
Forced : No
Gained a speed increase of 0.10 fps, resulted file 60KB smaller and saw no differences, these nasty blocks in the water are still there.
Should I try with a -1:-1 deblocking value?
Old 26th February 2017, 20:20   #4866  |  Link
Boulder
Pig on the wing
Boulder's Avatar
Try the suggestions one by one and see which one causes the issue.
Old 26th February 2017, 20:23   #4867  |  Link
pingfr
It's hard to tell, these "blocks" might as well be present on the source used, but it's in .y4m format I have no software that can open these at all other than x265 itself.
Source is YachtRide from here:
http://ultravideo.cs.tut.fi/#testsequences
Old 26th February 2017, 20:27   #4868  |  Link
Boulder
Pig on the wing
Boulder's Avatar
You could encode as lossless and use that to check the frames.
Old 26th February 2017, 20:30   #4869  |  Link
darksiderg
Old 26th February 2017, 20:41   #4870  |  Link
pingfr
Lossless? is there like a --preset lossless?
Old 26th February 2017, 20:44   #4871  |  Link
sneaker_ger
--lossless
But there are players that can play .y4m, e.g. MPC-HC + LAV.
Old 26th February 2017, 20:52   #4872  |  Link
pingfr
@sneaker_ger: MPC-HC is a clear no-go for me.
https://drdump.com/UploadedReport.as...&SecondVisit=1
Old 26th February 2017, 20:53   #4873  |  Link
divxmaster
yes, great for comparisons, I create a --lossless sample and a --crf16 sample and compare to the rip I am doing at the time.
Lol, your command line a few posts back is now virtually identical to mine. I use a slightly lower --merange for 1080p
and --aq-mode 2, but apart from that, it is the same.
Also for *some* ultra clean sources, even crf 22 suffices, and is virtually indistinguishable to the crf16 comparison, and not distinguishable at normal viewing distances (48 inch screen, 102 inch screen)
Divxmaster
divxmaster is offline   Reply With Quote
Old 26th February 2017, 21:28   #4874  |  Link
aymanalz
BTW, is there a reason you are not encoding at 10 bits? That improves quality, although it might slow down the encode.
aymanalz is offline   Reply With Quote
Old 26th February 2017, 21:38   #4875  |  Link
LigH
LigH's Avatar
Originally Posted by darksiderg View Post
... my cpu usage was fluctuating from 40% to 80% vice versa. but it never reached 100. i used slow preset. is it normal?
Quite normal, yes. The HEVC algorithm as such has only a limited parallelizability. Parts of the encoding need to wait for other parts to finish first. This has been discussed many times before.
New German Gleitz board
Old 26th February 2017, 22:19   #4876  |  Link
pingfr
Originally Posted by divxmaster View Post
Lol, your command line a few posts back is now virtually identical to mine. I use a slightly lower --merange for 1080p and --aq-mode 2, but apart from that, it is the same.
What would be the benefits of switching to -aq 2?
Old 26th February 2017, 22:20   #4877  |  Link
pingfr
Backwards compatibility with "exotic" devices.
Old 27th February 2017, 00:53   #4878  |  Link
divxmaster
well primarily better quality. Although I haven't tried --aq 1 in recent versions of x265.
Ah, I see you do 8 bit encodes. I only do 10 bit encodes, but I see you use decoding hw that requires 8 bit.
Also, add --no-open-gop, or you *may* have seeking issues.
Cheers,
Divxmaster
Old 27th February 2017, 04:25   #4879  |  Link
darksiderg
thanks
Old 27th February 2017, 18:32   #4880  |  Link
aymanalz
This may be true for CPUs with many cores, but four normal 2 or 4 core processors, I think x265 should saturate all the cores. Especially at the "slow" preset, which is what he is using.
IIRC, the previous discussions were about 12/16 cores, or multiple CPUs not being fully utilized.
@darksiderg : What CPU are you using?
