18th October 2011, 16:33 | #10181 | Link | |
Why do you switch the display refresh rate *while* the movie is playing? That's not a good idea, generally, IMHO. madVR generally doesn't like it much if you modify the refresh rate behind its back. |
18th October 2011, 16:43 | #10182 | Link | |
18th October 2011, 17:21 | #10183 | Link | |
18th October 2011, 17:24 | #10184 | Link |
glitshes at 50hz playback
I get glithes with 50hz playback of 25p material with madvr. this does not happen if run the same material at 24p in 60hz for instance. I reported it some time ago and some1 else reported it also. is this a bug in madvr? not being able to handle this configuration.
thx |
18th October 2011, 17:48 | #10186 | Link | |
http://www.mediafire.com/?md2nxy7htx0qb50 |
18th October 2011, 18:07 | #10187 | Link | |
00001109 Render fullscreen windowed mode, covered by some windows 00001481 Render madVR window [madVR] "madVR" {-1920,120,0,1200} 00001491 Render covered by explorer.exe window [Shell_TrayWnd] {-2,1198,1922,1244} |
18th October 2011, 18:07 | #10188 | Link |
Yes I have also played lots of content over several months with different NVidia drivers at 60hz24p without glitches. It only happens with 50hz25p. Thou if I choose "overshoot max frame latency" it works. Just strange I guess what is causing it exactly. NVidia drivers I guess. ..
Software and hardware manufactures really do make it hard to get proper PQ. If I play at move with just windows 7 media player or something it’s just awful with crappy PQ and stuttering, dropped frames, no subtitles ect. Would be nice if I dint have to use reclock and other stuff just to watch a movie like on a blurry player. At least I got it to work but why do we have to work against the crappy software and hardware solutions of Microsoft, Intel, NVidia and whatnot. They don’t think users might watch a movie on their pc for entertainment. Only play games I guess. Nice that there are open source alternatives like Madvr thou to get things to work. Should be a simple thing to play a movie on a pc really. |
18th October 2011, 18:44 | #10192 | Link | |
In any case, it's not really a problem for me either way. I only mentioned it as a point of interest. |
18th October 2011, 20:12 | #10194 | Link | ||
Kid for Today
This said, the whining office has been closed for the past few weeks, I've made a dozen automatic ffdshow profiles that allow me to simply use my HTPC in a click'n'play fashion so I hardly ever play around w/ avisynth scripts in realtime anymore...the only feature I'd really like to see is the ability to disable the exclusive/windowed OSD, I believe I could remove them with an hex editor but the background would still show so that wouldn't really help anyway, mVR works like a charm and it's been a real treat so far! |
18th October 2011, 21:01 | #10195 | Link |
Hi all,
If using madVR, is there any reason to upgrade my HD5670 to HD6670? Is there some boost in terms of picture quality ( not speed )? Can I ignore this? http://www.tomshardware.com/reviews/...s,2925-14.html Thanks Pluto
__________________ System: Intel Core i5-6500, 16GB RAM, GTX1060, 75" Sony ZD9, Focal speakers, OS Win10 Pro, Playback: madvr/JRiver |
18th October 2011, 21:25 | #10197 | Link |
I didn't know I could use the dx11 option with a dx9 card (that sounded silly to me), but someone dared to ask for me and now I know
It does fix the glitches (dx11+ limit rendering times) but not for everything. 29.9/59.9 playback still suffers from a lot of glitches but 23.976/71.92 is fine however. nev's settings work too, but again not 100% of the time. In the end I'm just using the old FSE mode, it seems fine to me. Anything wrong with it? Could it be that it isn't affected by the same bugs (related to the nvidia drivers) as the new FSE? It doesn't monitor glitches (I think?) so I don't know if I have glitches or not but I don't feel them (while I do with the new FSE). Or maybe I haven't seen smooth playback in too long and I'm just used to it (unlikely, I'm a gamer and usually extremely sensitive about smoothness) Windowed mode doesn't always work properly either for me (bad performance with some high bitrate/high framerate files) so I need FSE where I get excellent performance even with super-high framerates/bitrates. Last edited by kalston; 18th October 2011 at 21:48. |
18th October 2011, 23:00 | #10198 | Link |
i have an ati 5670, i use madvr with lav splitter, video and audio filters. i have a profile in amd ccc which is set to 2d clocks 400mhz gpu clock and 900mhz memory clock.
runs very smooth and no dropped frames.but see if i dont use the profiles in my ccc madvr will push the clocks to there maximum.so aslong as things are running ok and no dropped frames i will stick with my 2d clock to keep temps and power abit lower |
18th October 2011, 23:13 | #10200 | Link | |
scroll a bit down
