Old 21st July 2015, 04:31   #32001  |  Link
RyuzakiL
Bilateral+JincAR+SuperRes4/0.66 from 1080pHQ Source
It seems the said config is very good PQ/Performance wise for processing 1080pHQ Source.
I'm really interested on doing Madshi's Format of Picture/Screenshot comparison series.
But for the life of me, i cannot grab a screenshot on DX11 FSE10bit mode?
or i should switch to DX11 Windowed FS 8bit mode?
RyuzakiL is offline   Reply With Quote
Old 21st July 2015, 04:45   #32002  |  Link
leeperry
Kid for Today
Yeah I'm also not too sure how to make screenshots in PotP, you'll apparently need to disable exclusive mode and press the <printscreen> key on your keyboard.
Old 21st July 2015, 06:10   #32003  |  Link
MistahBonzai
Yup - black images are not that informative
If working with MPC-HC these procedures will enable you to capture specific frames. I have to believe that there is a way to seek by frame in most video players..
This procedure saves the onscreen image assuming you are *not* in exclusive mode.
  1. Uncheck "enable automatic fullscreen exclusive mode" in MadVR "general settings".
  2. Open video in MPC-HC.
  3. Pause video.
  4. <Ctrl>+<g>
  5. specify desired frame - example Frame: (2000, 23.976)
  6. <alt>+<print screen>
  7. Paste into video editor.
This procedure saves the image from the MPC-HC image renderer and not from MadVR
  1. Open video in MPC-HC.
  2. Pause video.
  3. <Ctrl>+<G>
  4. specify desired frame - example Frame: (2000, 23.976)
  5. <Alt>+<i>
  6. Select either jpg or png.
  7. Save to the perefered folder.
Note: More than anything I would like a way to do MadVR screen shots from MPC-HC
MistahBonzai is offline   Reply With Quote
Old 21st July 2015, 09:05   #32004  |  Link
James Freeman
D3D11,FSE unreported stutter
FWIW, can you try setting the flush setting for "after intermediate render steps" to "flush & wait (sleep)"? Does that help? Probably not, but it would be important to know for me.
Nope. Still stutters.
System: i7 3770K, GTX660, Win7 64bit, Panasonic ST60, Dell U2410.
James Freeman is offline   Reply With Quote
Old 21st July 2015, 09:11   #32005  |  Link
QBhd
QB the Slayer
QBhd's Avatar
For PotPlayer Video==>Video Capture.... Or just use Ctrl+Alt+E to grab the screen frame. Might want to go the menu route first to make sure you save as bmp or png. Ctrl+E will grab the source frame.
QB
QBhd is offline   Reply With Quote
Old 21st July 2015, 10:02   #32006  |  Link
madshi
Thanks for the positive feedback, guys! Happy to hear you like my comparison post!
Originally Posted by Akeno View Post
Adaptive Sharpen: Seems pretty destructive when it comes to real life material. It works a lot better for anime material where there aren't as many fine details and is the most ideal image enhancer.
Yeah, I wasn't meaning to say that AdaptiveSharpen should never be used. It could be useful to sharpen overly soft sources, or simply to add some "pop". However, "Upscaling Refinement" was always planned by me to post-process an upscaled image in such a way that it gets nearer to the ground truth. So, I would say that for this specific purpose I would not recommend AdaptiveSharpen.
I'm not fully sure yet if the split with "image enhancements" and "upscaling refinement" will stay as it is. I've had the idea that I could probably modify FineSharp and AdaptiveSharpen so that they have the same effectiveness/strength when applied after upscaling compared to before upscaling. Sharpening after upscaling generally looks better. So it's possible the "image enhancements" may run after scaling in a future version, too (maybe with a trade quality option to perform it before scaling). But I don't know for sure yet.
FineSharp: Feels unusable at this point due to the extreme artifacts it produces, although I suppose there would be no problem with a nearly 100% clean source.
IIRC Didée also wrote it with very clean sources in mind. IMHO FineSharp does an amazing job considering its speed and simplicity. But requiring a perfectly clean source is of course problematic.
LumaSharpen: I can't see a reason to use it personally. It just isn't as noticeable as the other algorithms but maybe my settings are wrong.
There's a reason why I didn't include it in the comparison. LumaSharpen is very fast, but other than that I wouldn't recommend to use it.
On a side note, madshi, you recommend 32 Neurons as a minimum for luma doubling due to artifacts with 16. My system can't run 32 with 30fps material but I haven't noticed anything wrong with 16. Could you elaborate on what kind of artifacts there are or post some pictures?
Well, 16 neurons is ok, too, for many sources. It's just that it has a lot more aliasing in some situations (edge angles?) compared to 32. It depends on the situation, though. Often 16 neurons is just as good as 32 neurons.
Originally Posted by JarrettH View Post
I think we've gone a little overboard obsessed with sharpening. Doubling already increases sharpness and super-xbr needs no enhancement IMO.
Indeed. I'm waiting for denoising TBH.
Well, you guys would probably like it if madVR could magically turn any downscaled image back into its original high res image, wouldn't you? So that's exactly what I'm aiming at. If you look at the screenshots, the "sharpening" applied by SuperRes brings us nearer to the ground truth, which can only be considered a good thing, no?
That said, yes, some algorithms to clean up bad sources would be great. But I prefer to do one thing right first, before switching to the next thing.
Would it be possible to add super-xbr at 75 to this comparison?
Possible, yes, but I don't think it's worth the effort. super-xbr 75 is similar to super-xbr 100, just a bit softer with some less ringing. Should make no difference to directional artifacts.
Originally Posted by Gagorian View Post
madshi are you familiar with the DarbeeVision Darblet used amongst HT enthusiasts? I've been quite happy with the sharpening it provides (at low strength). I wonder if there's any similar algorithm available to run on the GPU?
I've not seen Darbee myself yet. But I've been told it does this:
> It's a frame-delayed unsharp mask. So if there's no
> movement in the scene, it's just plain unsharp mask.
> If there's a lot of movement, it's a random artifact
> generator. If there's a little movement, like on a slow
> pan or a helicopter shot, it's an unsharp mask that is
> more aggressive on one side of a detail and less
> aggressive on the other side, adding a little shadow.
So for still images, it should be somewhat similar to AdaptiveSharpen. One big disadvantage of current Darbee implementations is that if you let the display upscale (e.g. 4K display), Darbee is applied before upscaling. That's like applying AdaptiveSharpen in "image enhancements". It's effective, but ugly. You'd get better quality doing it after upscaling. But AFAIK current Darbee implementations don't have the power to do 4K.
Anyway, personally I'm not really a fan of the look that unsharp mask style sharpening produces. To my eyes it looks like fat lines get even fatter. It seems to "bloat up" the image somehow, adding more contrast and pop, but making the image look more artificial. You can see some of that in my screenshot comparison post when comparing AdaptiveSharpen to FineSharp. The look which AdaptiveSharpen produces is typical for unsharp mask style sharpening.
Originally Posted by baii View Post
I seem to get periodic frame drop (by either 1 or 2 frame on osd) when playing interlaced material in dx11 windowed mode. I don't seem to notice all(or any) the frame drop by eye(which is normal I think, consider it is 60fps video.., don't have that kind of eye xd). Would this be a osd glitch or real frame drop?
It is fine in dx11 fse or dx9.
I had play with all the vync/seperate device options, but none helps.
Configuration is win8.1, Amd dxva de-interlance, reclock, 30i material, 59/60hz screen. Tested in recent .14 and .20.
So it occurs with .14, too? Might be that your GPU is near its power limit, and using DX11 windowed mode just pushes it over the edge sometimes. Don't know for sure. It's probably a real drop. You might not see it during scenes where there's not a lot of motion. Is it a natively interlaced source (e.g. sports)? Or is it telecined film? In the latter case you could force madVR's film mode. That way GPU power reduces by a factor of 2.5x, while producing smoother playback (no 3:2 judder).
Originally Posted by MS-DOS View Post
However, using 256 neurons for NNEDI3 as "the best option" may not be a good idea. I've recently found an example where 256 neurons cause a very notable artifact:
Original -|- NNEDI3 128 -|- NNEDI3 256
See a tiny white vertical line above Ramzesss word right between "m" and "z" ? It's not present on the original image, nor with any neuron count below 256.
Yes, I see it. I'm not sure if 256 neurons are generally a bad idea, though. NNEDI3 is not artifact free. In my experience any neuron number can produce artifacts in some images, where a different neuron count might not produce an artifact. There might be situations where 128 neurons produce an artifact and 256 neurons do not. Anyway, 256 neurons is so expensive, most users won't have the GPU power for that, anyway. In any case, it's probably better to use a much lower neuron count and run some SuperRes passes afterwards.
Originally Posted by Hyllian View Post
I confess I was a non-believer of SuperRes, but now I can see the light! It's almost as good as waifu2x-castle.
waifu2x is quite amazing. It does clearly beat NNEDI256+SuperRes, when looking at the geometrical features in the castle image. However, I think SuperRes reproduces the trees better. All those "clever" upscaling algorithms often mess up trees and nature. SuperRes somehow manages to reproduce a more natural look there. Would be interesting to see how waifu2x+SuperRes would look like. With a bit of luck, it might combine the best of NNEDI3+SuperRes and waifu2x.
Anyway, Shiandow has estimated that waifu2x is probably at least 100x slower than NNEDI3-256, maybe more. So it's not suitable for real time video playback in the next 7 years at least, I would say.
It's just me or the sxbr+sres = nnedi3+sres? I can't spot a difference in a still, so in motion it should be even harder.
How many passes did you use for SuperRes in these examples?
It's not just you. They're almost identical. There's one artifact, though, which super-xbr has (and NNEDI3 has not), which SuperRes doesn't fully remove. See red circle here:
http://madVR.com/doom9/temp/CastleSuperXbr.png
This specific geometrical configuration seems to be difficult. Even waifu2x has problems with this. Not on this specific tower, though. But if you look at the smaller right most tower, waifu2x is not perfect with the same geometrical configuration there. NNEDI3 handles that better, but NNEDI3 has small problems in other areas.
The screenshots were created with 8 SuperRes passes.
TYVM for the comparisons, I'll try my luck this week with running the same procedure but with NNEDI16/32 and 3@0.42 LQ SR in .15 coz comparing NNEDI256 to über-sharp LQ SR in .19 is kinda putting things out of context IMVHO, only one way to find out anyway and your testing procedure makes a heck lot of sense indeed gg
Glad to hear you like my testing procedure. I tried to find a way to make things less subjective, to increase the chances that we may end up on the same page.
You don't seem too keen on telling us what SR does in mVR but it's not a "dumb" sharpener as it would appear? Does it take previous frames in account like the vmotion stuff and as the name implies?
No, it only looks at one frame at a time. It pretty much does what Shiandow explained in that post you quoted earlier. But Shiandow's explanation was for the old SuperRes algo (where we still had number options for anti-aliasing and anti-ringing etc). The new algorithm is based on some newer scientific papers. It works like this:
0) Let e.g. super-xbr upscale the OI (original image). Result: UI (upscaled image).
1) Downscale the UI back to the same size as the OI (using: LQ=Bilinear; HQ=Bicubic).
2) Substract the OI from the downscaled UI, which gives us a sort of "error" image (EI) in the size of the OI.
3) Modify the UI in a clever way, by making use of the EI, to reduce the error.
Steps 1) to 3) is one SuperRes pass. If you want 2 SuperRes passes, you simply perform 1,2,3) twice.
All the magic happens in 3). And this code totally changed from the old to the new SuperRes algorithm. The other parts mostly remained unchanged. The old SuperRes code introduced aliasing and ringing, which is why Shiandow had added extra anti-aliasing and anti-ringing algos. The new SuperRes algorithm doesn't (or shouldn't) produce aliasing, anymore, and not as much ringing as the old code, so that's why there's no anti-ringing and anti-aliasing code in the new algorithm, anymore. I did add my own anti-ringing code in, though.
Yes, please!
I've done all stuff in windowed mode. I've selected a ground truth image which in 100% view exactly fit in the media player in windowed mode, to make things easier for me. The ground truth is already a downscaled image from an even larger original image. So I could choose the exact size I wanted to have for the ground truth.
Please make sure you downscale using madVR with AR (anti-ringing). Don't downscale using an image/photo editor, unless it also has AR (I'm not aware of any that has).
Ok, thanks.
Old 21st July 2015, 10:02   #32007  |  Link
Braum
It works that way, but you can also setup your own keybord shortcuts (but still need to disable FSE :/).
Braum is offline   Reply With Quote
Old 21st July 2015, 10:06   #32008  |  Link
RainyDog
I've decided to make a big screenshot comparison post to compare the different upscaling and sharpening / post-processing options we have now. In order to make all this more "scientific", I've decided that we need a "ground truth" image to compare to, because that's the only way to properly judge if an algorithm produces good results or not. If we don't have a ground truth to compare to, all our evaluations are somewhat subjective. So here comes.
Let me finish by saying that all of the above is of course only *one* test image. Results could in theory vary with other test images. I would like to encourage anyone who is interested in this kind of comparisons to repeat the same tests I've done, with a different test image. But please make sure you have a ground truth to compare to, because only that allows us to objectively judge. Otherwise all we can say is subjective mumbo-jumbo, and every user will have different preferences.
Comments welcome!
Great post madshi!
A couple of things; can you confirm the strength and number of passes you used for SuperRes and super-xbr strength please? I presume defaults but can't see it mentioned in your post.
Also, is SuperRes only really intended for upscaled content or can it be used as a mild sharpener for HQ 1080p material on a 1080p display to help bring out fine details?
RainyDog is offline   Reply With Quote
Old 21st July 2015, 10:25   #32009  |  Link
ryrynz
ryrynz's Avatar
I'd like to see something similar comparing chroma upscaler accuracy.
Old 21st July 2015, 10:34   #32010  |  Link
madshi
super-xbr-100, and highest possible strength (which is 4) for SuperRes. Strength 4 in v0.88.20 equals 8 passes with 1.0 strength in older madVR builds.
Currently SuperRes only works after upscaling. Maybe we'll find a way to make it work without upscaling, too (Shiandow had a suggestion for that, or alternatively we could use supersampling). But I'm not sure when I'll get around to that.
That's much more complicated/difficult, I fear. E.g. Bilateral and SuperRes for chroma both look at the luma information, too. And studios might use anything from Nearest Neighbor Downscaling to Lanczos for chroma downscaling.
Old 21st July 2015, 10:54   #32011  |  Link
Gagorian
I've been using it (after upscaling if needed) at 1080p on a 133" screen. I believe Darbee looks better in motion than when evaluating still images. I think the effect is ok up until about 30% strength and then it gets progressively more ugly. Until that point that it adds a nice amount of crispness/pop to the image and compensates for the slightly soft image of the projector (Sony HW50). I think the artifacts are the worst problem, especially on subtitles. Using lower strength does reduce the artifacts, but not completely.
I've been following this thread closely to see if any of the new algorithms could allow me to replace the Darbee. SuperRes looks like the best so far but I'm not sure if it works to improve the perceived sharpness of the projector like the Darbee does. Perhaps a touch of AS on top?
Gagorian is offline   Reply With Quote
Old 21st July 2015, 10:58   #32012  |  Link
madshi
I can't really say for sure. Just play with the various options and let your eyes be the judge. And please report your findings here, would love to hear how you like SuperRes, AdaptiveSharpen etc compared to what the Darbee does.
Old 21st July 2015, 11:41   #32013  |  Link
ryrynz
ryrynz's Avatar
SuperRes is near to FineSharp in detail level and sharpness, but at the same time manages to hide all artifacts caused by NNEDI3. So SuperRes is not only a good sharpener, but also manages to repair errors of the upscaling algorithm.
It's good at the standard radius setting of 0.66 but provides a rather soft result. Drop the radius to 0.20 and the image is now godly.
BTW at this radius, strength does very little 4 is a touch sharper than 1 and I prefer it at 4.
Comparison sample upscaled using a 2x pixel resize.
ORIGINAL
NNEDI-256+SR-STR4-R0.66
NNEDI-256+SR-STR4-R0.20
Much more accurate to the source using SR at a radius of 0.20, lots of extra detail here all over. I have a new high standard...
Having something is better than nothing.. might not be 100% accurate but *shrug* work with what you got.
Old 21st July 2015, 11:41   #32014  |  Link
ikarad
Bilinear+SuperRes -|- Jinc+SuperRes -|- super-xbr+SuperRes -|- NNEDI3+SuperRes -|- GroundTruth
What we can see here is that SuperRes works well even when using Bilinear upscaling. However, SuperRes does *not* remove aliasing artifacts caused by the upscaling algorithm. E.g. look at the roof edges of the left two towers. Both Bilinear and Jinc have aliasing problems there. super-xbr and NNEDI3 have not. Because of this reason, my recommendation would be to use either super-xbr or NNEDI3, followed by SuperRes, for best image quality. The difference between super-xbr and NNEDI3 is pretty small, if you follow it up with SuperRes with high strength. So using super-xbr should save some precious GPU performance. Using Jinc+SuperRes might be an option, too, but you'll likely get more aliasing problems compared to super-xbr+SuperRes.
Thanks for these comparisons.
I have one question:
super-xbr and nneedi116,32,64,128,256 are only available in image doubling. If I use image doubling, downscaling image is obligatory used for my display (I don't have movie with exactly 50% display resolution).
If I use jinc (jinc is only avalaible in image upscaling) in image upscaling, no need to use donwscaling image.
Even with downscaling, is it better to use superxbr or is it better to use jinc withtout downscaling?
ikarad is offline   Reply With Quote
Old 21st July 2015, 11:51   #32015  |  Link
madshi
It reproduces some more details, but it also adds a lot of aliasing. This might not be so apparent in the castle image, but I've seen it in other images. E.g. try this:
http://madshi.net/clown.png
I fear we may have to increase the radius to a value *higher* than 0.66 to get rid of aliasing problems. Sad but probably necessary...
I think from a quality point of view, using image doubling + downscaling should be better than straight upscaling. Not sure about GPU power, though. Depending on the exact scaling factor, sometimes doubling + downscaling might be faster or slower than straight upscaling.
Old 21st July 2015, 11:52   #32016  |  Link
David
What Didée said about Darbee:
Originally Posted by Didée View Post
Seems that is not quite comparable. FineSharp, as the name somehow suggets, deals mostly with enhancement of fine structures and edges. Darbee seems to implement something like a wide-range Unsharp-Mask with halo protection.
http://forum.doom9.org/showthread.ph...26#post1595526
A year or some other back, I fiddled with a multi-scale sampled, (quasi-) median enhancer. Those results were more or less similar to what Darbee is achieving.
A (pretty naive and pretty slow) version is to simply use a wide-range median filter for sharpening.
# medianblur.dll
# repairSSE2.dll
# mt_masktools-25.dll
imagesource("D:\darbee_6_0_test.png").converttoyv12()
a = last
b = a.medianblur(12,8,8)
c = a.repair(a.repair(a.repair(a.repair(a.repair(a.repair(a.repair(a.repair(b,1),1),1),1),1),1),1),1)
d = mt_lutxy(a,c,"x x y - abs 1.62 2 ^ / 1 1.62 / ^ 1.62 3 ^ * x y - x y - abs 1.62 + / * +",U=3,V=3)
interleave(a,d)
return(last)
(Open in tabs to flip back-n-forth.)
http://forum.doom9.org/showthread.ph...31#post1595531
Not yet. This is only a torchlight, in practice things shouldn't be done that simple. A particular problem is chroma handling, which must be done different. It would be needed to isolate a saturation layer, and work on that. When done directly like in this little script, nasty things will happen. Against a green background, a grey line will turn into purple, and such.
And for big framesizes like full-HD, a multiscale version is pretty much recommended. Doing a big-range median on full-HD is anything but funny, speed-wise.
http://forum.doom9.org/showthread.ph...42#post1595542
David is offline   Reply With Quote
Old 21st July 2015, 11:55   #32017  |  Link
ryrynz
ryrynz's Avatar
Does an image that small really fit the bill as far as being comparable to typical use cases?
Could that be cheated by an additional anti-aliasing step afterwards? Probably overkill...
I do prefer the edges when using a higher radius but I'd rather have that detail there.
I wonder if Shiandow could focus his attention on this particular area at all, a high radius SR utilized for edges only.. I dunno.
Ugh, that's horrible.
Old 21st July 2015, 12:35   #32018  |  Link
x7007
Anyone is able to run CUVID Acceleration from LAV Video Filter with MADVR and not freeze and crash ? None and Write-Back works fine, just the mixed with Madvr + CUVID .
Nvidia 353.49
LavFilters 0.65
PotPlayer 1.6.55124 x32
Windows 10 10240 x64
x7007 is offline   Reply With Quote
Old 21st July 2015, 12:37   #32019  |  Link
ashlar42
madshi, fantastic service to users with your huge images comparison post. I loved it!
I read what you wrote about subs rendering on black bars. I'll wait patiently. Happy to hear you are aware of the need for it.
Old 21st July 2015, 12:52   #32020  |  Link
RainyDog
For scaling 720p>1080p on my 1080p display, I find image-doubling + downscaling to be superior to just upscaling with Jinc3 even with the extra (down)scaling process involved.
Using super-xbr, it's no more resource hungry either.
