Old 29th January 2018, 20:43   #27001  |  Link
Lathe
Lathe's Avatar
Originally Posted by AmigaFuture View Post
Ohh, Mr. Mascot, Mr. Guru?
Any time someone tells me I think too much (or meditate too much)...my alarms begin to chime a warning towards that person. ;-)
Uh huh... Uh... it's called 'Irony' mate
Lathe is offline   Reply With Quote
Old 29th January 2018, 22:40   #27002  |  Link
jdobbs
I, Rony... sounds like a movie title.
Website: www.jdobbs.net
Old 29th January 2018, 23:01   #27003  |  Link
AmigaFuture
AmigaFuture's Avatar
I'm not a believer of irony, mate...that's too shallow for me. ;-)
But now that we know your name, Rony...
Life is not a journey to the grave; but rather to skid out broadside, thoroughly used, torn and warn and loudly proclaim; WOW; What a ride!!! Soon, I'm going to do it AGAiN in different skin!!
AmigaFuture is offline   Reply With Quote
Old 29th January 2018, 23:02   #27004  |  Link
AmigaFuture
Oppps..Dobbs sort of beat me to it. Ha!
Old 30th January 2018, 02:02   #27005  |  Link
Lathe
Lathe's Avatar
There are just TOO damn many clever people here...
Old 30th January 2018, 02:05   #27006  |  Link
gonca
793 posts and nothing meaningful or useful as of yet
gonca is offline   Reply With Quote
Old 30th January 2018, 02:16   #27007  |  Link
Lathe
Lathe's Avatar
Hmmm... do you guys smell something...?
Old 30th January 2018, 02:19   #27008  |  Link
gonca
794 and rising
Old 10th February 2018, 17:34   #27009  |  Link
Blurayhd
Hi Jdobbs I donīt know why on some Bluray encodings I get this message? sorry guys the screen capture is in Spanish (my first language)
And this is the log
[02/10/18] BD Rebuilder v0.50.25
[12:35:10] Source: LES_MISERABLES_25TH_00005
- Input BD size: 43,16 GB
- Approximate total content: [02:49:52.098]
- Target BD size: 22,95 GB
- Windows Version: 6.2 [9200]
- MOVIE-ONLY mode enabled
- Quality: Highest (Very Slow), ABR
- Decoding/Frame serving: DirectShow
[12:35:14] PHASE ONE, Encoding
- [12:35:14] Processing: VID_00007 (1 of 2)
- [12:35:14] Extracting A/V streams [VID_00007]
- [12:44:39] Reencoding video [VID_00007]
- Source Video: VC-1, 1920x1080
- Rate/Length: 23,976fps, 119.784 frames
- Bitrate: 12.137 Kbs
- [12:44:39] Reencoding: VID_00007, Pass 1 of 1
- Encode failed. Aborting.
- BD-Rebuilder v0.50.25
- Working Path Free Space: 88,50GB
- AVISYNTH Version: 2.6.0.6, Ok
- HAALI Splitter: 1.9.42.1, Ok
- FFDSHOW: 4504, Ok
- FFDSHOW VC-1 set to "wmv9", Ok
- FFDSHOW MPEG2 set to "libavcodec": Ok
- FFDSHOW AVC set to "libavcodec": Ok
- AnyDVD settings check: Ok.
- X264: Ok
- AFTEN: Ok
- FAAC: Ok
- MP4BOX: Ok
- WAVI: Ok
- TSMUXER: Ok
- FRIMEncode: Ok
- FRIMDecode: Ok
[13:28:11] - Failed video encode, aborted
So I donīt know what is wrong and how to get a solution?
I hope im doing well posting image and log
Blurayhd is offline   Reply With Quote
Old 10th February 2018, 18:28   #27010  |  Link
gonca
Are you overclocked
How are your temps
That is a x264 crash
Old 10th February 2018, 19:54   #27011  |  Link
Blurayhd
Are you overclocked
How are your temps
No, I donīt I never do any overclock just in case it helps my processor is i7 2700k
Can be the problem if I use an SSD por encoding?
Anyway I hope thereīs can be a solution?
Old 10th February 2018, 20:06   #27012  |  Link
jdobbs
When X264 crashes it is highly likely you are overheating. I'd check your processor's heatsink and see if it is clogged with dust.
Old 10th February 2018, 20:22   #27013  |  Link
Blurayhd
I have an watercooling system, I check frecuently the system and the liquid of course.
And this computer I use for gaming too and noo problems
Could be anything else?
What do you recommend?
Old 10th February 2018, 21:00   #27014  |  Link
jdobbs
Not likely. Other software (even overclock testing software) just doesn't stress your system like X264. It's the ultimate test. The only other possibility I can think of might be memory overheating. You could try cleaning that as well. If you look back through this thread you'll find other similar reports, and I'm pretty sure every one of them was caused to overheating.
Try getting some software (like "Core Temp" or "CPUID HW Monitor") and monitor the temps while you are encoding.
Does your watercooling system have a radiator? I know I have to vacuum mine out regularly or my system overheats.
Old 11th February 2018, 03:07   #27015  |  Link
Blurayhd
Thank you Jdobbs, always you are there tryng (or trying, sorry) to solve problems.
And I have one more question, thereīs a way to clean up Bd rebuilder, avisint and the others tools so I can install everything again without re install the OS?
I have 32gb on my system but maybe re installing all related to Bd rebuilder?
Please dont get my wrong thanks to you BD rebuilder exist, I just need to see the problem
Old 13th February 2018, 01:25   #27016  |  Link
Blurayhd
Dear Jdobbs I tried encoding the same Bluray movie but this time with another computer just in case and I get the same problem
I dont know what to do
Old 13th February 2018, 05:15   #27017  |  Link
jdobbs
Are you sure the source isn't corrupt?
Old 13th February 2018, 15:52   #27018  |  Link
jdobbs
I just wanted to give everyone an update on the UHD capability. I have BD-RB working. It can import 2160p MKVs etc. It can do full backups and movie-only backups of non-protected UHD-BD sources. But... I am having a lot of trouble with audio/video sync after TSMUXER muxes them. I can't blame TSMUXER, however, because MKVMERGE has the same issue after muxing. It may be some inconsistency in the HEVC stream generated by X265, or possibly FFMPEG (used for frame serving) could be losing frames... I really don't know. I don't think it is the audio, as it doesn't necessarily get reencoded, and it is handled no differently than with previous BD-RB versions.
I haven't figured out why this is happening yet, but if and when I do I'll release a test version here on Doom9. The biggest problem is that it takes anywhere between 10 and 18 hours for my system to do a full movie (even at the fastest encode speed and using one-pass ABR)... so you can only do so much in a day.
I think I'll do a couple encodes using AVISYNTH just to eliminate the FFMPEG possibility -- but even if it works correctly that's not a long term solution as it would also be losing the HDR and 10 bit attributes during encode.
Old 13th February 2018, 17:10   #27019  |  Link
Acerjen
I just wanted to give everyone an update on the UHD capability. I have BD-RB working. It can import 2160p MKVs etc. It can do full backups and movie-only backups of non-protected UHD-BD sources. But... I am having a lot of trouble with audio/video sync after TSMUXER muxes them. I can't blame TSMUXER, however, because MKVMERGE has the same issue after muxing. It may be some inconsistency in the HEVC stream generated by X265, I really don't know. I don't think it is the audio, as it doesn't get reencoded, and it is handled no differently than with previous BD-RB versions.
I have a system setup with a Ryzen 1700 (8-Core) running at 3.9 GHz. If you want some help getting some UHD testing done, let me know. Thank you for a great program.
Later,
Acerjen
Acerjen is offline   Reply With Quote
Old 13th February 2018, 17:48   #27020  |  Link
LowDead
Later,
Acerjen
I too got a new rig for UHD encoding. Intel i7 6 core 8700K @3.7GHz with Nvidia 1060 gfx and 32gb ram. Doing Men in Black now down to BD50 under 30 minutes using the gfx card hardware decoding and encoding. Haven't tried software encodes on this CPU yet, but will probably be quite fast too. So count me in if you need testers.
Have nice day!
//LD
LowDead is offline   Reply With Quote
